path: root/drivers/nand
2006-04-08Fix JFFS2 support for legacy NAND driver.Marian Balakowicz
Some more NAND cleanup and small fixes.
2006-03-11Some code cleanup for GCC 4.xWolfgang Denk
2006-03-06Merge with /home/wd/git/u-boot/masterWolfgang Denk
Code cleanup.
2006-03-06Cleanup of NAND support of delta board using the Monahans Data FlashMarkus Klotzbücher
Controller.
2006-03-06NAND finally working. Two bugs fixed:Markus Klotzbücher
* For READ_STATUS and READID commands always 8 bytes need to be read from NDDB. Otherwise they stay there and get send to flash as the first data word when writing. * In nand_base.c the oob variable is not reset so this->oob_buf is overwritten what eventually screws up the bad block descriptor table.
2006-03-05Re-factoring the legacy NAND code (legacy NAND now only in board-specificBartlomiej Sieka
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is implemented for these boards.
2006-02-24Merge with /home/wd/git/u-boot/testing-NAND/ to add new NAND handling.Bartlomiej Sieka
2005-11-02* Add hook to NAND erase and implement nand_wait function.Wolfgang Denk
Patch by Mike Rapoport, 01 Nov 2005 Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2005-09-14Update of new NAND codeWolfgang Denk
Patch by Ladislav Michl, 13 Sep 2005
2005-08-17Rewrite of NAND code based on what is in 2.6.12 Linux kernelWolfgang Denk
Patch by Ladislav Michl, 29 Jun 2005
