path: root/drivers/nand/nand_ids.c
2007-11-25drivers/mtd : move mtd drivers to drivers/mtdJean-Christophe PLAGNIOL-VILLARD
2007-08-15Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-07-09drivers/[n-z]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04drivers/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-05-24[PATCH][NAND] Define the Vendor Id for Micron NAND FlashUlf Samuelsson
Signed-off-by: Ulf Samuelsson <ulf@atmel.com> Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Stefan Roese <sr@denx.de>
2006-04-08Fix JFFS2 support for legacy NAND driver.Marian Balakowicz
Some more NAND cleanup and small fixes.
2006-03-05Re-factoring the legacy NAND code (legacy NAND now only in board-specificBartlomiej Sieka
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is implemented for these boards.
2006-02-24Merge with /home/wd/git/u-boot/testing-NAND/ to add new NAND handling.Bartlomiej Sieka
2005-09-14Update of new NAND codeWolfgang Denk
Patch by Ladislav Michl, 13 Sep 2005
2005-08-17Rewrite of NAND code based on what is in 2.6.12 Linux kernelWolfgang Denk
Patch by Ladislav Michl, 29 Jun 2005
