path: root/drivers/mtd
2013-07-12mtd: mxc_nand: Fix crash after MTD resyncMarek Vasut
The driver triggered a BUG() in nand_base.c:3214/nand_scan_tail() because the ecc.strength was not set in NAND_ECC_HW_SYNDROME ECC mode. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Benoit Thebaudeau <benoit.thebaudeau@advansee.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2013-07-01Merge branch 'master' of git://git.denx.de/u-boot-nand-flashTom Rini
2013-06-26mtd/nand: docg4: fix compiler warningsMike Dunn
Newer gcc versions warn about unused variables. This patch corrects a few of those warnings that popped up in a build for the palmtreo680 board. Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
2013-06-26mtd: cfi_flash: Use ARRAY_SIZE at appropriate placesAxel Lin
Signed-off-by: Axel Lin <axel.lin@ingics.com>
2013-06-24dfu, nand: before write a buffer to nand, erase the nand sectorsHeiko Schocher
before writing the received buffer to nand, erase the nand sectors. If not doing this, nand write fails. See for more info here: http://lists.denx.de/pipermail/u-boot/2013-June/156361.html Using the nand erase option "spread", maybe overwrite blocks on, for example another mtd partition, if the erasing range contains bad blocks. So a limit option is added to nand_erase_opts() Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2013-06-24Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
2013-06-23sf: Warn to use BAR for > 16MiB flashesJagannadha Sutradharudu Teki
Warning for > 16MiB flashes to #define CONFIG_SPI_FLASH_BAR Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-06-23sf: Add debug messages on spi_flash_read_commonJagannadha Sutradharudu Teki
- Added debug's on spi_flash_read_common() - Added space Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-06-23sf: Place the sf calls in proper orderJagannadha Sutradharudu Teki
Placed the sf calls in proper order - erase/write/read Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-06-23sf: Unify spi_flash write codeJagannadha Sutradharudu Teki
Move common flash write code into spi_flash_write_common(). Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-06-23sf: Add flag status register polling supportJagannadha Sutradharudu Teki
Flag status register polling is required for micron 512Mb flash devices onwards, for performing erase/program operations. Like polling for WIP(Write-In-Progress) bit in read status register, spi_flash_cmd_wait_ready will poll for PEC(Program-Erase-Control) bit in flag status register. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2013-06-23sf: Remove spi_flash_cmd_poll_bit()Jagannadha Sutradharudu Teki
There is no other call other than spi_flash_cmd_wait_ready(), hence removed spi_flash_cmd_poll_bit and use the poll status code spi_flash_cmd_wait_ready() itself. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2013-06-23sf: spansion: Add support for S25FL512S_64KJagannadha Sutradharudu Teki
Add support for Spansion S25FL512S_64K SPI flash. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-06-23sf: stmicro: Add support for N25Q1024AJagannadha Sutradharudu Teki
Add support for Numonyx N25Q1024A SPI flash. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-06-23sf: stmicro: Add support for N25Q1024Jagannadha Sutradharudu Teki
Add support for Numonyx N25Q1024 SPI flash. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-06-23sf: stmicro: Add support for N25Q512AJagannadha Sutradharudu Teki
Add support for Numonyx N25Q512A SPI flash. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-06-23sf: stmicro: Add support for N25Q512Jagannadha Sutradharudu Teki
Add support for Numonyx N25Q512 SPI flash. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-06-23sf: Use spi_flash_addr() in write callJagannadha Sutradharudu Teki
Use the existing spi_flash_addr() for 3-byte addressing cmd filling in write call. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2013-06-23sf: Add bank addr code in CONFIG_SPI_FLASH_BARJagannadha Sutradharudu Teki
Defined bank addr code on CONFIG_SPI_FLASH_BAR macro, to reduce the size for existing boards which has < 16Mbytes SPI flashes. It's upto user which has provision to use the bank addr code for flashes which has > 16Mbytes. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2013-06-23sf: Update sf read to support all sizes of flashesJagannadha Sutradharudu Teki
This patch updated the spi_flash read func to support all sizes of flashes using bank reg addr facility. The same support has been added in below patch for erase/write spi_flash functions: "sf: Support all sizes of flashes using bank addr reg facility" (sha1: c956f600cbb0943d0afe1004cdb503f4fcd8f415) With these new updates on sf framework, the flashes which has < 16MB are not effected as per as performance is concern and but the u-boot.bin size incrased ~460 bytes. sf update(for first 16MBytes), Changes before: U-Boot> sf update 0x1000000 0x0 0x1000000 - N25Q256 16777216 bytes written, 0 bytes skipped in 199.72s, speed 86480 B/s - W25Q128BV 16777216 bytes written, 0 bytes skipped in 351.739s, speed 48913 B/s - S25FL256S_64K 16777216 bytes written, 0 bytes skipped in 65.659s, speed 262144 B/s sf update(for first 16MBytes), Changes before: U-Boot> sf update 0x1000000 0x0 0x1000000 - N25Q256 16777216 bytes written, 0 bytes skipped in 198.953s, speed 86480 B/s - W25Q128BV 16777216 bytes written, 0 bytes skipped in 350.90s, speed 49200 B/s - S25FL256S_64K 16777216 bytes written, 0 bytes skipped in 66.521s, speed 262144 B/s Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2013-06-23sf: Update sf to support all sizes of flashesJagannadha Sutradharudu Teki
Updated the spi_flash framework to handle all sizes of flashes using bank/extd addr reg facility The current implementation in spi_flash supports 3-byte address mode due to this up to 16Mbytes amount of flash is able to access for those flashes which has an actual size of > 16MB. As most of the flashes introduces a bank/extd address registers for accessing the flashes in 16Mbytes of banks if the flash size is > 16Mbytes, this new scheme will add the bank selection feature for performing write/erase operations on all flashes. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2013-06-23sf: Read flash bank addr register at probe timeJagannadha Sutradharudu Teki
Read the flash bank addr register to get the state of bank in a perticular flash. and also bank write happens only when there is a change in bank selection from user. bank read only valid for flashes which has > 16Mbytes those are opearted in 3-byte addr mode, each bank occupies 16Mytes. Suppose if the flash has 64Mbytes size consists of 4 banks like bank0, bank1, bank2 and bank3. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2013-06-23sf: Discover the bank addr commandsJagannadha Sutradharudu Teki
Bank/Extended addr commands are specific to particular flash vendor so discover them based on the idocode0. Assign the discovered bank commands to spi_flash members so-that the bank read/write will use their specific operations. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-06-23sf: Add bank address register writing supportJagannadha Sutradharudu Teki
This patch provides support to program a flash bank address register. extended/bank address register contains an information to access the 4th byte addressing in 3-byte address mode. reff' the spec for more details about bank addr register in Page-63, Table 8.16 http://www.spansion.com/Support/Datasheets/S25FL128S_256S_00.pdf Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2013-06-22sf: winbond: Add support for W25QXXXFVJagannadha Sutradharudu Teki
Add support for Winbond W25QXXXFV SPI flash. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-06-22sf: winbond: Add support for W25Q16DWJagannadha Sutradharudu Teki
Add support for Winbond W25Q16DW SPI flash. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-06-22sf: winbond: Add support for W25Q128FWJagannadha Sutradharudu Teki
Add support for Winbond W25Q128FW SPI flash. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-06-22sf: winbond: Update the names for W25Q 0x40XX ID's flash partsJagannadha Sutradharudu Teki
Use the exact names for W25Q 0x40XX ID's flash parts, as the same sizes of flashes comes with different ID's. so-that the distinguishes becomes easy with this change. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-06-22sf: spansion: Correct name of S25FL128S 64K Sector partJagannadha Sutradharudu Teki
Corrected the name of S25FL128S 64K sector part SPI flash, S25FL128S supported has been added in below commit "sf: spansion: Add support for S25FL128S" (sha1: 1bfb9f156aa66cca6bb9c773867a1f02a84b14be) Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-06-22Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-06-20powerpc/mpc85xx: new SPL support for IFC NANDPrabhakar Kushwaha
Linker script is not able find start.o binary. So add its absolute path in u-boot-spl.lds. This change is similar to u-boot-nand.lds common/Makefile: Avoid compiling unnecssary files fsl_ifc_spl.c : It is is responsible for reading u-boot binary from NAND flash and copying into DDR. It also transfer control from NAND SPL to u-boot image present in DDR. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-19Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: spl/Makefile
2013-06-18mtd: nand: fix initialization of BBT optionsDaniel Schwierzeck
commit dfe64e2c89731a3f9950d7acd8681b68df2bae03 Author: Sergey Lapin <slapin@ossfans.org> Date: Mon Jan 14 03:46:50 2013 +0000 mtd: resync with Linux-3.7.1 changed the initialization of BBT options. Fix drivers jz4740 and s3c2410 which have not been updated yet and cause compile errors. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2013-06-17mtd: nand/docg4: fix driver after Linux resyncMike Dunn
Commit dfe64e2c89731a3f9950d7acd8681b68df2bae03: mtd: resync with Linux-3.7.1 broke the docg4 driver. Specifically: - some of the prototypes of the ecc methods changed - the NAND_NO_AUTOINCR flag was removed - the ecc.strength element was added. This patch fixes these. Tested on the docg4 on my palmtre680 board. Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
2013-06-13Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
2013-06-13sf: winbond: Correct the nr_blocks used for W25Q32DWJagannadha Sutradharudu Teki
This patch corrected the nr_blocks used for W25Q32DW SPI flash. nr_blcoks are incorrectly assigned on below patch "sf: winbond: add W25Q32DW" (sha1: 772ba15474f73adc942e817cc072b6e9750836cc) Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-06-13sf: winbond: Add support for W25Q80BWJagannadha Sutradharudu Teki
Add support for Winbond W25Q80BW SPI flash. This patch corrected the flash name, nr_blocks and also commit message header from below patch. "sf: winbond: add W25Q32" (sha1: c969abc47033d6f810d3c9dbdb994ea9d691d038) Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-06-13sf: spansion: Update the name for S25FL256S flashJagannadha Sutradharudu Teki
As the per the ID tabl the flash is under Uniform 64-kB sector architecture, hence updated with proper name. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-06-04bug, nand, am33xx: nand->ecc.strength not set in board_nand_init()Sergey Lapin
commit dfe64e2c89731a3f9950d7acd8681b68df2bae03 Author: Sergey Lapin <slapin@ossfans.org> Date: Mon Jan 14 03:46:50 2013 +0000 mtd: resync with Linux-3.7.1 Introduced runtime bug: U-Boot 2013.04-00499-g46567df-dirty (Jun 04 2013 - 08:17:08) I2C: ready DRAM: 512 MiB WARNING: Caches not enabled NAND: BUG: failure at nand_base.c:3214/nand_scan_tail()! BUG! resetting ... on boards using drivers/mtd/nand/omap_gpmc.c as in board_nand_init() nand->ecc.strength is not set. Fix this! Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Scott Wood <scottwood@freescale.com> Cc: Tom Rini <trini@ti.com>
2013-06-03cmd_sf: Add print mesgs on sf read/write commandsJagannadha Sutradharudu Teki
This patch adds a print messages while using 'sf read' and 'sf write' commands to make sure that how many bytes read/written from/into flash device. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Acked-by: Tom Rini <trini@ti.com>
2013-06-03cmd_sf: Add print mesg for 'sf erase' commandJagannadha Sutradharudu Teki
This patch adds a print messages while using 'sf erase' command to make sure that how many bytes erased in flash device. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Acked-by: Tom Rini <trini@ti.com>
2013-06-03sf: Fix sf read for memory-mapped SPI flashesJagannadha Sutradharudu Teki
Missing return after memcpy is done for memory-mapped SPI flashes, hence added retun 0 after memcpy done. The return is missing in below patch "sf: Enable FDT-based configuration and memory mapping" (sha1: bb8215f437a7c948eec82a6abe754c226978bd6d) Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-05-31Merge branch 'master' of git://git.denx.de/u-boot-nand-flashTom Rini
2013-05-31mtd: resync with Linux-3.7.1Sergey Lapin
This patch is essentially an update of u-boot MTD subsystem to the state of Linux-3.7.1 with exclusion of some bits: - the update is concentrated on NAND, no onenand or CFI/NOR/SPI flashes interfaces are updated EXCEPT for API changes. - new large NAND chips support is there, though some updates have got in Linux-3.8.-rc1, (which will follow on top of this patch). To produce this update I used tag v3.7.1 of linux-stable repository. The update was made using application of relevant patches, with changes relevant to U-Boot-only stuff sticked together to keep bisectability. Then all changes were grouped together to this patch. Signed-off-by: Sergey Lapin <slapin@ossfans.org> [scottwood@freescale.com: some eccstrength and build fixes] Signed-off-by: Scott Wood <scottwood@freescale.com>
2013-05-30Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: common/cmd_fpga.c drivers/usb/host/ohci-at91.c
2013-05-28sf: winbond: Add support for W25PXX SPI flashKuo-Jung Su
Add support for Winbond's W25PXX SPI flash. These devices is used on Faraday A369 evaluation board. Signed-off-by: Kuo-Jung Su <dantesu@faraday-tech.com> CC: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> CC: Tom Rini <trini@ti.com> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2013-05-28sf: winbond: Add support for W25Q256Jagannadha Sutradharudu Teki
Add support for Winbond W25Q256 SPI flash. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2013-05-28sf: spansion: Add Spansion S25FL064P IDsMarek Vasut
This is a S25FL064A successor. It supports up to 104MHz bus speed. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Scott Wood <scottwood@freescale.com> Cc: Wolfgang Denk <wd@denx.de> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2013-05-24sf: spansion: Add support for S25FL128SXie Xiaobo
SPANSION recommend S25FL128S supersedes S25FL129P, and the two flash memory have the same device ID and Memory architecture. So they can use the same config parameters. Signed-off-by: Xie Xiaobo <X.Xie@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-23cfi_flash: return NULL for invalid base address inputMasahiro Yamada
When base address given was out of valid flash address ranges, flash_get_info() function returned the pointer to the last element of flash_info[i] array. This patch changes this function to return NULL pointer in such a case, which is more correct behaviour. The function flash_protect_default() calls flash_protect() immediately after flash_get_info() invocation. With this correction, flash_protect() function would be able to return soon, for NULL flash_info. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Stefan Roese <sr@denx.de>
