This allows for arbitrarily long manufacturer ids following the JEDEC
standard of 0x7f continuation bytes. It also makes adding new entries
easier as it's just one element in an array. The downside is that it
increases code size a bit, but we're talking ~50 bytes.
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
When a CFI flash chip could not be detected an error message similar to
the following would be printed on bootup:
FLASH: ## Unknown FLASH on Bank 1 - Size = 0x01000000 = 0 MB
The printf incorrectly converted the flash size into megabytes. This
patch fixes the printing of the flash size in megabytes:
FLASH: ## Unknown FLASH on Bank 1 - Size = 0x01000000 = 16 MB
Signed-off-by: John Schmoller <jschmoller@xes-inc.com>
This patch adds the Numonyx manufacturer code (0x20) to
onenand manufacturers.
Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com>
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Acked-by: Steve Sakoman <steve.sakoman@linaro.org>
Tested-by: Steve Sakoman <steve.sakoman@linaro.org>
Consolidate some code in mtd_get_len_incl_bad(), and fix a condition
where a valid partition could be reported as truncated if it has a
good block at the end of the device (unlikely, since the BBT is usually
there).
Fix mid-block declarations in net_part_size().
Reviewed-by: Ben Gardiner <bengardiner@nanometrics.ca>
The logic to 'spread' mtd partitions needs to calculate the length in
the mtd device, including bad blocks.
This patch introduces a new function, mtd_get_len_incl_bad that can
return both the length including bad blocks and whether that length
was truncated on the device. This new function will be used by the
mtdparts spread command later in this series. The definition of the
function is #ifdef'd out in configurations that do not use the new
'mtdparts spread' command.
Signed-off-by: Ben Gardiner<bengardiner@nanometrics.ca>
CC: Scott Wood <scottwood@freescale.com>
Get rid of the several "#if 0" sections that were keeping around Linux
code that isn't relevant to U-Boot. Besides cluttering the code, these
sections make tracking upstream changes harder, rather than easier.
It's easy to discard obviously irrelevant diff hunks that patch rejects,
but it's not as easy to notice hunks that apply cleanly to the #if 0
section, but *are* relevant to U-Boot and require modification elsewhere.
Also remove suspend/resume, as this is not applicable to U-Boot. Removal
saves 232 bytes on powerpc.
Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
A while back, in http://lists.denx.de/pipermail/u-boot/2009-June/054428.html,
Michele De Candia posted a patch to not count bad blocks toward the
requested size to be erased. This is desireable when you're passing in
something like $filesize, but not when you're trying to erase a partition.
Thus, a .spread subcommand (named for consistency with
http://lists.denx.de/pipermail/u-boot/2010-August/075163.html) is introduced
to make explicit the user's desire to erase for a given amount of data,
rather than to erase a specific region of the chip.
While passing $filesize to "nand erase" is useful, accidentally passing
something like $fliesize currently produces quite unpleasant results, as the
variable evaluates to nothing and U-Boot assumes that you want to erase
the entire rest of the chip/partition. To improve the safety of the
erase command, require the user to make explicit their intentions by
using a .part or .chip subcommand. This is an incompatible user interface
change, but keeping compatibility would eliminate the safety gain, and IMHO
it's worth it.
While touching nand_erase_opts(), make it accept 64-bit offsets and sizes,
fix the percentage display when erase length is rounded up, eliminate
an inconsistent warning about rounding up the erase length which only
happened when the length was less than one block (rounding up for $filesize
is normal operation), and add a diagnostic if there's an attempt to erase
beginning at a non-block boundary.
The underlying code in nand_base.c already supports non-page-aligned reads
and writes, but the block-skipping wrapper code did not.
With block skipping, an unaligned start address is not useful since you
really want to be starting at the beginning of a partition -- or at least
that's where you want to start checking for blocks to skip, but we don't
(yet) support that. So we still require the start address to be aligned.
An unaligned length, though, is useful for passing $filesize to the
read/write command, and handling it does not complicate block skipping.
This patch introduces an extra mask-field in spansion_spi_flash_params
to support flash chips with 1-byte extended ID (like the S25FL032P).
Signed-off-by: David Jander <david@protonic.nl>
The spansion_erase currently only works when the sector size is 64KB.
cmd[1] should contain the higher 8 bit of the 24 bit address of the
sector to be erased. Currently it is holding the sector index to be
erased which happens to be the same thing when the sector size is
64KB.
Signed-off-by: Marc-Andre Hebert <marc-andre.hebert@humanware.com>
Adds support for Winbond's W25Q64 SPI flash. These devices are used on
(among others) Xilinx' SP601 and SP605 Spartan-6 evaluation boards.
Tested with "sf" commands.
Signed-off-by: Graeme Smecher <graeme.smecher@mail.mcgill.ca>
include/ppc4xx.h
Commit 2ee951ba (UBI: Enable re-initializing of the "ubi part" command)
reset mtd_devs in ubi_exit() but missed ubi_init()'s failure path.
Signed-off-by: Karl Beldan <karl.beldan@gmail.com>
Cc: Stefan Roese <sr@denx.de>
This patch moves some ppc4xx related headers from the common include
directory (include/) to the powerpc specific one
(arch/powerpc/include/asm/). This way to common include directory is not
so cluttered with files.
Now that the defines are moved to header files we don't need this
conditional compilation any more. Remove it.
This patch simplifies the use of CONFIG_SYS_MAX_FLASH_BANKS_DETECT. By
moving these optional variables and defines into the common code, board
specific code is minimized. Currently only the following board use
this feature:
APC405, IDS8247, TQM834x
And IDS8247 doesn't seem to really need this feature, since its not
updating the bank number variable at all. So this patch removes the
definition of CONFIG_SYS_MAX_FLASH_BANKS_DETECT from this board port.
This new framework will be used by the upcoming lwmon5 update as well.
Acked-by: Heiko Schocher <hs@denx.de>
Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
cfi_flash_bank_addr(int bank_nr) returns the base addresses of the
requested bank. Introducing this weak default enables boards to override
this functions with a board specific version when required.
This feature will be used in the lwmon5 board update, supporting runtime
detection of 2 board revisions with different flash layouts.
This patch removes an unecessary check in the return statement. This is
not needed, since "info" is initializes to NULL. And "info" will not be
written to again, if the flash address is not found.
Additionally "info" is not initialized to "0" but to "NULL".
Due to a register glitch (result code <4 might show up right after the
start-calculation-bit was set), make sure the ECC has really started.
See 1c3275b656045aff9a75bb2c9f3251af1043ebb3 in the kernel.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Cc: Sandeep Paulraj <s-paulraj@ti.com>
This printk was added recently and results in ugly output on systems
with no NAND:
NAND: nand_get_flash_type: unknown NAND device: Manufacturer ID: 0x00, Chip ID: 0x00 0 MiB
instead of:
NAND: 0 MiB
Signed-off-by: Steve Sakoman <steve@sakoman.com>
Acked-by: Scott Wood <scottwood@freescale.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Use the same configuration around S5P SoCs.
(s5pc100, s5pc110, s5pc210 and so on)
I have "ported" U-boot to a in house made board with Numonyx Axcell P33/P30
256-Mbit 65nm flash chips.
After some time :( searching for bugs in our board or soft, we have
discovered that those chips have a small but annoying bug, documented in
"Numonyx Axcell P33/P30 256-Mbit Specification Update"
It states :
When customer uses [...] block unlock, the block lock status might be
altered inadvertently. Lock status might be set to either 01h or 03h
unexpectedly (00h as expected data), which leads to program/erase failure
on certain blocks.
A working workaround is given, which I have applied and tested with success :
Workaround: If the interval between 60h and its subsequent command
can be guaranteed within 20us, Option I is recommended,
otherwise Option II (involves hardware) should be selected.
Option I: The table below lists the detail command sequences:
Command
Data bus Address bus Remarks
Sequence
1 90h Block Address
Read Lock Status
2 Read Block Address + 02h
(2)(3) (1)
3 60h Block Address
(2)(3) (1) Lock/Unlock/RCR Configuration
4 D0h/01h/03h Block Address
Notes:
(1) Block Address refers to RCR configuration data only when the 60h
command sequence is used to set RCR register combined with 03h
subsequent command.
(2) For the third and fourth command sequences, the Block Address must
be the same.
(3) The interval between 60h command and its subsequent D0h/01h/2Fh/03h
commands should be less than 20us.
And here is a log comparison of a simple (destructive) flash test without
and with the workaround.
diff without-numonyx-workaround.log with-numonyx-workaround.log
-U-Boot 2010.06-00696-g22b002c-dirty (Aug 16 2010 - 15:07:47)
+U-Boot 2010.06-00696-g22b002c-dirty (Aug 16 2010 - 15:25:19)
CPU: Freescale MCF5484
CPU CLK 200 MHz BUS CLK 100 MHz
Board: Macq Electronique ME2060
I2C: ready
DRAM: 64 MiB
FLASH: 32 MiB
In: serial
Out: serial
Err: serial
Net: FEC0, FEC1
-> flinfo
Bank # 1: CFI conformant FLASH (16 x 16) Size: 32 MB in 259 Sectors
Intel Extended command set, Manufacturer ID: 0x89, Device ID: 0x8922
Erase timeout: 4096 ms, write timeout: 1 ms
Buffer write timeout: 5 ms, buffer size: 1024 bytes
Sector Start Addresses:
FE000000 RO FE008000 RO FE010000 RO FE018000 RO FE020000 RO
FE040000 RO FE060000 RO FE080000 RO FE0A0000 RO FE0C0000 RO
FFF80000 RO FFFA0000 RO FFFC0000 RO FFFE0000 RO
-> protect off all
Un-Protect Flash Bank # 1
................... done
-> erase all
Erase Flash Bank # 1
-> cp.b 1000000 fe000000 2000000
-Copy to Flash... Flash not Erased
+Copy to Flash... done
Signed-off-by: Philippe De Muyter <phdm@macqel.be>
This patch does the following:
- Extract code to detect if sector is erased into function
sector_erased().
- Because of this, we don't have variable declarations inside the
sector loop in flash_print_info()
- Change "return" to "break" in the "if (ctrlc()) statement:
This fixes a problem with the resulting output. Before this
patch the output was:
FC000000 FC020000 FC040000 =>
With this patch it is now:
Cc: Kim Phillips <kim.phillips@freescale.com>
Fix reading and printing of CFI flashes 16-bit devices identifiers
Nowadays CFI flashes have a 16-bit device identifier. U-boot still
print them and read them as if they were only 8-bit wide. Fix that.
Before:
Intel Extended command set, Manufacturer ID: 0x89, Device ID: 0x1B
After:
Intel Extended command set, Manufacturer ID: 0x89, Device ID: 0x881B
flashes getting larger, users more impatient.
While running from flash, i. e. before relocation, we have only a
limited C runtime environment without writable data segment. In this
phase, some configurations (for example with environment in EEPROM)
must not use the normal getenv(), but a special function. This
function had been called getenv_r(), with the idea that the "_r"
suffix would mean the same as in the _r_eentrant versions of some of
the C library functions (for example getdate vs. getdate_r, getgrent
vs. getgrent_r, etc.).
Unfortunately this was a misleading name, as in U-Boot the "_r"
generally means "running from RAM", i. e. _after_ relocation.
To avoid confusion, rename into getenv_f() [as "running from flash"]
Acked-by: Detlev Zundel <dzu@denx.de>
Currently, 83xx, 86xx, and 85xx have a lot of duplicated code
dedicated to defining and manipulating the LBC registers. Merge
this into a single spot.
To do this, we have to decide on a common name for the data structure
that holds the lbc registers - it will now be known as fsl_lbc_t, and we
adopt a common name for the immap layouts that include the lbc - this was
previously known as either im_lbc or lbus; use the former.
In addition, create accessors for the BR/OR regs that use in/out_be32
and use those instead of the mismash of access methods currently in play.
I have done a successful ppc build all and tested a board or two from
each processor family.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Rather than bang MMRs directly, use the new portmux framework to handle
the details.
Make it easy to use GPIOs for the DEV_READY pin by using the common GPIO
framework. Also make the NAND_PLAT_INIT() define optional.
Tested-by: Thomas Chou <thomas@wytron.com.tw>
The Toshiba TC58NVG0* parts are 128Mbytes x 8 bits 3.3V parts with the 0xD1
identifier. Add these to the list of known devices IDs.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
When the NAND part is not supported, it is useful to show the manufacturer
and device ID to help debugging and reporting.
At the moment, the default SPI flash subsystem is quite terse. Errors and
successes both result in a generic message. So move the useful errors and
useful successes to printf output by default.
While we're here, also convert the messages to use print_size().
Some old STMicro parts do not support JEDEC ID (0x9f). This patch
uses RES (0xab) to get Electronic ID and translates it to JEDEC ID.
UBI: initialise update marker
The in kernel copy of a volume's update marker is not initialised from the
volume table. This means that volumes where an update was unfinnished will
not be treated as "forbidden to use". This is basically that the update
functionality was broken.
Signed-off-by: Peter Horton <zero@colonel-panic.org>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
The current Blackfin nand write function fills up the write buffer but
returns before it has had a chance to drain. On faster systems, this
isn't a problem as the operation finishes before the ECC registers are
read, but on slower systems the ECC may be incomplete when the core tries
to read it.
So wait for the buffer to drain once we're done writing to it.
Signed-off-by: Andrew Caldwell <Andrew.Caldwell@analog.com>
The current U-Boot UBI implementation is copied from Linux. In this
porting the UBI background thread was not handled correctly. Upon write
operations ubi_wl_flush() makes sure, that all queued operations, like
page-erase, are completed. But this is missing for read operations.
This patch now makes sure that such operations (like scrubbing upon
bit-flip errors) are not queued, but executed directly.
Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
This patch adds reset_timer() before the flash status check
waiting loop.
Since the timer is basically running asynchronous to the cfi
code, it is possible to call get_timer(0), then only a few
_SYSCLK_ cycles later an interrupt is generated. This causes
timeout even though much less time has elapsed. So the timer
period registers should be reset before get_timer(0) is
called.
There is similar usage in nand_base.c.
This patch adds status polling method to offer an alternative to
data toggle method for amd flash chips.
This patch is needed for nios2 cfi flash interface, where the bus
controller performs 4 bytes read cycles for a single byte read
instruction. The data toggle method can not detect chip busy
status correctly. So we have to poll DQ7, which will be inverted
when the chip is busy.
This feature is enabled with the config def,
CONFIG_SYS_CFI_FLASH_STATUS_POLL
With old configuration it could happen tout=0 if CONFIG_SYS_HZ<1000.
Signed-off-by: Renato Andreola <renato.andreola@imagos.it>
Signed-off-by: Alessandro Rubini <rubini@gnudd.com>
This is a patch to use the hardware ECC controller of
the AT91SAM9260 for the AT91 nand. Taken from the kernel 2.6.33.
Signed-off-by: Nikolay Petukhov <Nikolay.Petukhov@gmail.com>
Modified to use IO accessor routines consistently. Eliminated volatile usage
to keep checkpatch.pl happy.
Signed-off-by: Cyril Chemparathy <cyril@ti.com>
I executed 'find . -name "*.[chS]" -perm 755 -exec chmod 644 {} \;'
Signed-off-by: Thomas Weber <swirl@gmx.li>
Add some more: neither Makefile nor config.mk need execute permissions.
Coding style cleanup, update CHANGELOG.
