Integrate 16-bit BCH ECC handling required e.g. for the latest NAND
parts assembled on Colibri T20.
(cherry picked from commit dcca76ea36fc778fa750473aee09fa0297dc5e2b)
The MTD subsystem now uses mtd_to_nand to get to the struct
nand_chip pointer. Use mtd_to_nand in mxs_nand_get_ecc_strength
too.
Should have "&" to access the register address, otherwise uboot will hang.
Signed-off-by: Ye Li <ye.li@nxp.com>
This patch is a porting of
http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/commit/?h=imx_4.1.15_1.0.0_ga&id=e4dacc44d22e9474ec456cb330df525cd805ea38
i.MX6QP and i.MX7D BCH module integrated a new feature to detect the
bitflip number for erased NAND page. So for these two platform, set the
erase threshold to gf/2 and if bitflip detected, GPMI driver will
correct the data to all 0xFF.
Also updated the imx6qp dts file to ditinguish the GPMI module for i.MX6Q
with the one for i.MX6QP.
In this patch, i.MX6UL is added and threshold changed to use ecc_strength.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
This patch is porting from linux:
http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/commit/?h=imx_4.1.15_1.0.0_ga&id=3d42fcece496224fde59f9343763fb2dfc5b0768
We may meet the bitflips in reading an erased page(contains all 0xFF),
this may causes the UBIFS corrupt, please see the log from Elie:
[ 3.831323] UBI warning: ubi_io_read: error -74 (ECC error) while reading 16384 bytes from PEB 443:245760, read only 16384 bytes, retry
[ 3.845026] UBI warning: ubi_io_read: error -74 (ECC error) while reading 16384 bytes from PEB 443:245760, read only 16384 bytes, retry
[ 3.858710] UBI warning: ubi_io_read: error -74 (ECC error) while reading 16384 bytes from PEB 443:245760, read only 16384 bytes, retry
[ 3.872408] UBI error: ubi_io_read: error -74 (ECC error) while reading 16384 bytes from PEB 443:245760, read 16384 bytes
[ 4.011529] UBIFS error (pid 36): ubifs_recover_leb: corrupt empty space LEB 27:237568, corruption starts at 9815
[ 4.021897] UBIFS error (pid 36): ubifs_scanned_corruption: corruption at LEB 27:247383
[ 4.030000] UBIFS error (pid 36): ubifs_scanned_corruption: first 6569 bytes from LEB 27:247383
This patch does a check for the uncorrectable failure in the following steps:
[0] set the threshold.
The threshold is set based on the truth:
"A single 0 bit will lead to gf_len(13 or 14) bits 0 after the BCH
do the ECC."
For the sake of safe, we will set the threshold with half the gf_len, and
do not make it bigger the ECC strength.
[1] count the bitflips of the current ECC chunk, assume it is N.
[2] if the (N <= threshold) is true, we continue to read out the page with
ECC disabled. and we count the bitflips again, assume it is N2.
(We read out the whole page, not just a chunk, this makes the check
more strictly, and make the code more simple.)
[3] if the (N2 <= threshold) is true again, we can regard this is a erased
page. This is because a real erased page is full of 0xFF(maybe also has
several bitflips), while a page contains the 0xFF data will definitely
has many bitflips in the ECC parity areas.
[4] if the [3] fails, we can regard this is a page filled with the '0xFF'
data.
provide one config "CONFIG_NAND_MXS_BCH_LEGACY_GEO" to keep using legacy
bch geometry.
NOTICE: the feature must be enabled/disabled in both u-boot and kernel.
Signed-off-by: Han Xu <han.xu@nxp.com>
(cherry picked from commit 0abc9c182c24f88522bd74fa1b53cd2fa3477184)
The cod change updated the NAND driver BCH ECC layout algorithm to
support large oob size NAND chips(oob > 1024 bytes).
Current implementation requires each chunk size larger than oob size so
the bad block marker (BBM) can be guaranteed located in data chunk. The
ECC layout always using the unbalanced layout(Ecc for both meta and
Data0 chunk), but for the NAND chips with oob larger than 1k, the driver
cannot support because BCH doesn’t support GF 15 for 2K chunk.
The change keeps the data chunk no larger than 1k and adjust the ECC
strength or ECC layout to locate the BBM in data chunk. General idea for
large oob NAND chips is
1.Try all ECC strength from the minimum value required by NAND spec to
the maximum one that works, any ECC makes the BBM locate in data chunk
can be chosen.
2.If none of them works, using separate ECC for meta, which will add one
extra ecc with the same ECC strength as other data chunks. This extra
ECC can guarantee BBM located in data chunk, of course, we need to check
if oob can afford it.
Signed-off-by: Han Xu <b45815@freescale.com>
Commit 35c204d8a9d0 ("nand: reinstate lazy bad block scanning")
introduced lazy BBT scanning. However, some controller do parts
of the initialization (mxs_nand.c) during scan_bbt, hence for
those controllers the BBT must be scanned at initialization time.
In most situation the U-Boot environment gets read first, and
the U-Boot environment code checks for bad blocks first. Checking
for bad blocks will ask for scan_bbt before reading the first page,
hence in most situation the issue does not appear in practice.
However, when there is no environment configured, other code might
access NAND first which does not explicitly checks for bad blocks,
in those cases ECC reads will fail always.
Cc: Rostislav Lisovy <lisovy@gmail.com>
Added kconfig for NAND_MXS driver.
Cc: Scott Wood <oss@buserror.net>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Matteo Lisi <matteo.lisi@engicam.com>
Cc: Michael Trimarchi <michael@amarulasolutions.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Update the ext loader to avoid using the spl_image global variable.
At present there are two SPI functions only used by freescale which are
defined in the spi_flash.h header. One function name matches an existing
generic SPL function.
Move these into a private header to avoid confusion.
Arcturus looks like it does not actually support SPI, so drop the SPI code
from that board.
Add a linker list declaration for this method and remove the explicit
switch() code. Also set up the sunxi function.
All the other SPL loaders are in this directory, so move the SPI one in
there too.
There are two board-specific SPI loaders (fsl and sunxi). These remain in
the drivers/mtd/spi directory, since they do not contain generic code.
At present some spl_xxx_load_image() functions take a parameter and some
don't. Of those that do, most take an integer but one takes a string.
Convert this parameter into a struct so that we can pass all functions the
same thing. This will allow us to use a common function signature.
Instead of using the global spl_image variable, pass the required struct in
as an argument.
move the UBI config options into Kconfig.
Reviewed-by: Andrew F. Davis <afd@ti.com>
Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
Now, arch/${ARCH}/include/asm/errno.h and include/linux/errno.h have
the same content. (both just wrap <asm-generic/errno.h>)
Replace all include directives for <asm/errno.h> with <linux/errno.h>.
[trini: Fixup include/clk.]
This patch moves flags macro's to respective member position on
spi_flash_params{}, for better readabilty and finding the
respective member macro's easily.
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Cc: Vignesh R <vigneshr@ti.com>
Cc: Mugunthan V N <mugunthanvnm@ti.com>
Signed-off-by: Jagan Teki <jteki@openedev.com>
Add CONFIG_SPI_FLASH_USE_4K_SECTORS in spi_flash code from header file.
SECT_32K never used anywhere in the code.
Make rx mode flags as generic to spi, earlier mode_rx is
maintained separately because of some flash specific code.
e_rd_cmd is maintained separately for fastest read command code,
since the read commands are computed normally this e_rd_cmd
is not required in spi_flash_params table.
Fastest read command code look for fastest read command
taking inputs from spi->mode_rx and flags from param table
and controller mode_rx is always been a priority.
Since mode_rx is always set from controller side this optimized
code doesn't require much and this code required exctra overhead like
1) Maintain e_rx_cmd in param table
2) Maintain mode_rx in spi_slave {}
Hence removed this code, and look for read command from normal
spi->mode from spi_slave{} and params->flags
Currently the command buffer gets allocated with a size of 32 bytes.
This causes warning messages on systems with cache lines bigger than
32 bytes:
CACHE: Misaligned operation at range [9df17a00, 9df17a20]
Define command buffer to be at least 32 bytes, but more if cache
line is bigger.
Reviewed-by: Stefano Babic <sbabic@denx.de>
Now that nand_info[] is an array of pointers we need to test the
pointer itself rather than using name as a proxy for NULLness.
Fixes: b616d9b0a708eb9 ("nand: Embed mtd_info in struct nand_chip")
Signed-off-by: Scott Wood <oss@buserror.net>
Cc: Lukasz Majewski <l.majewski@samsung.com>
Cc: Tony Lindgren <tony@atomide.com>
In commit 17cb4b8f327e ("mtd: nand: Add+use mtd_to/from_nand and
nand_get/set_controller_data") the assignment of mtd->priv was removed
but was not replaced. This adds the required nand_set_controller_data()
call.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
Add AT25DF321 flash support.
Fix AT25DF321A device name.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
Reviewed-by: Jagan Teki <jteki@openedev.com>
This commit adds support in the spi-nor driver for the
N25Q016A, a 16Mbit SPI NOR flash from Micron.
Signed-off-by: Moritz Fischer <moritz.fischer@ettus.com>
nand_do_write_ops() determines if it is writing a partial page with the
formula:
part_pagewr = (column || writelen < (mtd->writesize - 1))
When 'writelen' is exactly 1 byte less than the NAND page size the formula
equates to zero, so the code doesn't process it as a partial write, although
it should.
As a consequence the function remains in the while(1) loop with 'writelen'
becoming 0xffffffff and iterating until the watchdog timeout triggers.
To reproduce the issue on a NAND with 2K page (0x800):
=> nand erase.part <partition>
=> nand write $loadaddr <partition> 7ff
Signed-off-by: Hector Palacios <hector.palacios@digi.com>
Add a full-id entry for the H27QCG8T2E5R‐BCF NAND.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Acked-by: Hans de Goede <hdegoede@redhat.com>
We already have an SPL driver for the sunxi NAND controller, now add
the normal/standard one.
The source has been copied from Linux 4.6 with a few changes to make
it work in u-boot.
These are already-documented common bindings for NAND chips. Let's
handle them in nand_base.
If NAND controller drivers need to act on this data before bringing up
the NAND chip (e.g., fill out ECC callback functions, change HW modes,
etc.), then they can do so between calling nand_scan_ident() and
nand_scan_tail().
The original commit has been slightly reworked to use the fdtdec_xxx()
helpers (instead of the of_xxxx() ones).
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
io_init checks this value and fails with "bad write buffer size 0 for
2048 min. I/O unit"
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Add timeout to onenand_wait ready loop as it hangs here indefinitely
when chip not present. Once there, do the same for onenand_bbt_wait
as well (note: recent Linux driver code does the same)
[trini: Adapt am33xx, duovero, omap_zoom1]
Booting a payload out of NAND FLASH from the SPL is a crux today, as
it requires hard partioned FLASH. Not a brilliant idea with the
reliability of todays NAND FLASH chips.
The upstream UBI + UBI fastmap implementation which is about to
brought to u-boot is too heavy weight for SPLs as it provides way more
functionality than needed for a SPL and does not even fit into the
restricted SPL areas which are loaded from the SoC boot ROM.
So this provides a fast and lightweight implementation of UBI scanning
and UBI fastmap attach. The scan and logical to physical block mapping
code is developed from scratch, while the fastmap implementation is
lifted from the linux kernel source and stripped down to fit the SPL
needs.
The text foot print on the board which I used for development is:
6854 0 0 6854 1abd
drivers/mtd/ubispl/built-in.o
Attaching a NAND chip with 4096 physical eraseblocks (4 blocks are
reserved for the SPL) takes:
In full scan mode: 1172ms
In fastmap mode: 95ms
The code requires quite some storage. The largest and unknown part of
it is the number of fastmap blocks to read. Therefor the data
structure is not put into the BSS. The code requires a pointer to free
memory handed in which is initialized by the UBI attach code itself.
See doc/README.ubispl for further information on how to use it.
This shares the ubi-media.h and crc32 implementation of drivers/mtd/ubi
There is no way to share the fastmap code, as UBISPL only utilizes the
slightly modified functions ubi_attach_fastmap() and ubi_scan_fastmap()
from the original kernel ubi fastmap implementation.
Acked-by: Heiko Schocher <hs@denx.de>
To support UBI in SPL we need a simple NAND read function. Add one to
nand_spl_simple and keep it as simple as it goes.
Acked-by: Scott Wood <oss@buserror.net>
As part of Chain of Trust for Secure boot, the SPL U-Boot will validate
the next level U-boot image. Add a new function spl_validate_uboot to
perform the validation.
Enable hardware crypto operations in SPL using SEC block.
In case of Secure Boot, PAMU is not bypassed. For allowing SEC block
access to CPC configured as SRAM, configure PAMU.
Reviewed-by: Ruchika Gupta <ruchika.gupta@nxp.com>
Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com>
Signed-off-by: Sumit Garg <sumit.garg@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
flash_full_status_check() checks bit XSR.7 on Intel chips. This
should be done by only checking bit 7 and not by comparing the
whole status byte or word with 0x80.
This fixes the non-working block erase in the pflash emulation
of Qemu when used with the MIPS Malta board. MIPS Malta uses x32
mode to access the pflash device. In x32 mode Qemu mirrors the
lower 16 bits of the status word into the upper 16 bits. Thus
the CFI driver gets a status word of 0x8080 in x32 mode. If
flash_full_status_check() uses flash_isequal(), then it polls for
XSR.7 by comparing 0x8080 with 0x80 which never becomes true.
Reported-by: Alon Bar-Lev <alon.barlev@gmail.com>
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Fix a number of typos, including:
* "compatble" -> "compatible"
* "eanbeld" -> "enabled"
* "envrionment" -> "environment"
* "FTD" -> "FDT" (for "flattened device tree")
* "ommitted" -> "omitted"
* "overriden" -> "overridden"
* "partiton" -> "partition"
* "propogate" -> "propagate"
* "resourse" -> "resource"
* "rest in piece" -> "rest in peace"
* "suport" -> "support"
* "varible" -> "variable"
Allwinner devices support SPI flash as one of the possible
bootable media type. The SPI flash chip needs to be connected
to SPI0 pins (port C) to make this work. More information is
available at:
https://linux-sunxi.org/Bootable_SPI_flash
This patch adds the initial support for booting from SPI flash.
The existing SPI frameworks are not used in order to reduce the
SPL code size. Right now the SPL size grows by ~370 bytes when
CONFIG_SPL_SPI_SUNXI option is enabled.
While there are no popular Allwinner devices with SPI flash at
the moment, testing can be done using a SPI flash module (it
can be bought for ~2$ on ebay) and jumper wires with the boards,
which expose relevant pins on the expansion header. The SPI flash
chips themselves are very cheap (some prices are even listed as
low as 4 cents) and should not cost much if somebody decides to
design a development board with an SPI flash chip soldered on
the PCB.
Another nice feature of the SPI flash is that it can be safely
accessed in a device-independent way (since we know that the
boot ROM is already probing these pins during the boot time).
And if, for example, Olimex boards opted to use SPI flash instead
of EEPROM, then they would have been able to have U-Boot installed
in the SPI flash now and boot the rest of the system from the SATA
hard drive. Hopefully we may see new interesting Allwinner based
development boards in the future, now that the software support
for the SPI flash is in a better shape :-)
Testing can be done by enabling the CONFIG_SPL_SPI_SUNXI option
in a board defconfig, then building U-Boot and finally flashing
the resulting u-boot-sunxi-with-spl.bin binary over USB OTG with
a help of the sunxi-fel tool:
sunxi-fel spiflash-write 0 u-boot-sunxi-with-spl.bin
The device needs to be switched into FEL (USB recovery) mode first.
The most suitable boards for testing are Orange Pi PC and Pine64.
Because these boards are cheap, have no built-in NAND/eMMC and
expose SPI0 pins on the Raspberry Pi compatible expansion header.
The A13-OLinuXino-Micro board also can be used.
Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
This empty line should not be there. Remove it.
Signed-off-by: Andre Renaud <andre@designa-electronics.com>
Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
Some drivers are still directly accessing the chip->mtd field. Patch
them to use nand_to_mtd() instead.
follow parameter name change (nand to mtd) to fix compiler error.
NAND chips are supposed to expose their capabilities through advanced
mechanisms like READID, ONFI or JEDEC parameter tables. While those
methods are appropriate for the bootloader itself, it's way to
complicated and takes too much space to fit in the SPL.
Replace those mechanisms by a dumb 'trial and error' mechanism.
With this new approach we can get rid of the fixed config list that was
used in the sunxi NAND SPL driver.
Split the 'load page' and 'read page' logic in 2 different functions so
we can later load the page and test different ECC configs without the
penalty of reloading the same page in the NAND cache.
We also move common setup to a dedicated function (nand_apply_config()) to
avoid rewriting the same values in NFC registers each time we read a page.
These new functions are passed a pointer to an nfc_config struct to limit
the number of parameters.
