path: root/drivers/mtd
2014-10-11Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-10-09mtd: denali: support NAND_CMD_RNDOUT commandMasahiro Yamada
The function nand_flash_detect_ext_param_page() requires NAND_CMD_RNDOUT command supported. It is necessary to detect some types of ONFi-compliant devices. Without it, the error message "unsupported command received 0x5" is shown. Let's support this command on the Denali NAND controller driver. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Chin Liang See <clsee@altera.com>
2014-10-09mtd: denali: fix NAND_CMD_PARAM commandMasahiro Yamada
NAND_CMD_PARAM (0xEC) command is not working on the Denali NAND controller driver. Unlike NAND_CMD_READID (0x90), when the NAND_CMD_PARAM command is followed by an address cycle, the target device goes busy. (R/B# is deasserted) Wait until the parameter data are ready. In addition, unnecessary clear_interrupts() should be removed. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Chin Liang See <clsee@altera.com>
2014-10-08Merge remote-tracking branch 'u-boot-imx/master'Albert ARIBAUD
The single file conflict below is actually trivial. Conflicts: board/boundary/nitrogen6x/nitrogen6x.c
2014-10-07Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-10-06cfi_flash: don't hide write/erase errorsBaruch Siach
Partially revert commit 0d01f66d235118 (CFI: cfi_flash write fix for AMD legacy). flash_full_status_check() used to skip status register parsing when flash_status_check() returns OK. This is wrong since flash_status_check() must return OK for other status bits to be valid. Cc: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Stefan Roese <sr@denx.de>
2014-10-05mtd: denali: add Denali NAND driver for SPLMasahiro Yamada
The SPL-mode driver for Denali(Cadence) NAND Flash Memory Controller IP. This driver requires two CONFIG macros: - CONFIG_SPL_NAND_DENALI Define to enable this driver. - CONFIG_SYS_NAND_BAD_BLOCK_POS Specify bad block mark position in the oob space. Typically 0. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Chin Liang See <clsee@altera.com> Cc: Scott Wood <scottwood@freescale.com>
2014-10-05mtd: denali: add Denali controller configs to KconfigMasahiro Yamada
Commit 3eb3e72a3f66 (nand/denali: Adding Denali NAND driver support) introduced some new options, and some of them were documented by commit f9860cf081ef (nand/denali: Document CONFIG symbols). This commit allows users to enable/disable them via Kconfig with more detailed help docs. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Chin Liang See <clsee@altera.com> Cc: Scott Wood <scottwood@freescale.com>
2014-09-26Merge branch 'for-tom' of git://git.denx.de/u-boot-dmTom Rini
2014-09-26sandbox: Convert SPI flash emulation to use sf_paramsSimon Glass
At present sandbox has its own table of supported SPI flash chips. Now that the SPI flash system is fully consolidated and has its own list, sandbox should use that. This enables us to expand the number of chips that sandbox supports. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-09-26Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2014-09-25nand/denali: Adding Denali NAND driver supportChin Liang See
To add the Denali NAND driver support into U-Boot. This driver is leveraged from Linux with commit ID fdbad98dff8007f2b8bee6698b5d25ebba0471c9. For Denali controller 64 variance, you need to declare macro CONFIG_SYS_NAND_DENALI_64BIT. Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-25mtd: nand: Fix length bug in ioread16_rep() and iowrite16_rep()Stefan Roese
The ioread16_rep() and iowrite16_rep() implementations are U-Boot specific and have been introduced with the Linux MTD v3.14 sync. While introducing these functions, the length for the loop has been miscalculated. The ">> 1" is already present in the caller. So lets remove it in the function. Tested on omap3_ha. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Scott Wood <scottwood@freescale.com> Acked-by: Heiko Schocher <hs@denx.de>
2014-09-25mtd: nand: am335x: Fix 'bit-flip' errors in SPLRostislav Lisovy
OMAP GPMC driver used with some NAND Flash devices (e.g. Spansion S34ML08G1) causes that U-boot shows hundreds of 'nand: bit-flip corrected' error messages. Possible cause was discussed in the mailinglist thread: http://lists.denx.de/pipermail/u-boot/2014-April/177508.html The issue was partially fixed with the cc81a5291910d7a.git however this has to be done to fix the SPL. The original author of the code is Belisko Marek <marek.belisko@gmail.com> Signed-off-by: Rostislav Lisovy <lisovy@merica.cz>
2014-09-25driver/mtd: Use generic timer API for FSL IFC, eLBCPrabhakar Kushwaha
Freescale's flash control driver is using architecture specific timer API i.e. usec2ticks Replace usec2ticks with get_timer() (generic timer API) Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-09-24kconfig: add blank Kconfig filesMasahiro Yamada
This would be useful to start moving various config options. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-09-24sf: Add M25PX64 SPI NOR flash IDStefan Roese
Add ID for this Numonix / STMicro chip. Tested on Marvell DB-78460-BP board. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Luka Perkov <luka@openwrt.org> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-09-24spl: replace CONFIG_SPL_SPI_* with CONFIG_SF_DEFAULT_*Nikita Kiryanov
Currently, CONFIG_SPL_SPI_* #defines are used for controlling SPI boot in SPL. These #defines do not allow the user to select SPI mode for the SPI flash (there's no CONFIG_SPL_SPI_MODE, so the SPI mode is hardcoded in spi_spl_load.c), and duplicate information already provided by CONFIG_SF_DEFAULT_* #defines. Kill CONFIG_SPL_SPI_*, and use CONFIG_SF_DEFAULT_* instead. Cc: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Bo Shen <voice.shen@atmel.com> Cc: Hannes Petermaier <hannes.petermaier@br-automation.com> Cc: Michal Simek <monstr@monstr.eu> Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-09-24mtd: spi: add support for M25PE16 and M25PX16Nikita Kiryanov
Add support for M25PE16 and M25PX16 Cc: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-09-23sf: Add an empty entry to the parameter listSimon Glass
The list is supposed to be terminated with a NULL name, but is not. If a board probes a chip which does not appear in the table, U-Boot will crash (at least on sandbox). Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-22Merge branch 'master' of git://git.denx.de/u-boot-armStefano Babic
2014-09-19mtd: atmel_nand: Disable subpage NAND write when using Atmel PMECCBoris BREZILLON
Disable subpage write when using PMECC to prevent buggy partial page write. This fix has been taken from linux sources (see commit 90445ff6241e2a13445310803e2efa606c61f276) Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Acked-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-09-19mtd: atmel-nand: use pmecc_readl(b)/pmecc_writel to access the pmecc registerWu, Josh
We defined the macro pmecc_readl(b)/pmecc_writel for pmecc register access. But in the driver we also use the readl(b)/writel. To keep consistent, this patch make all use pmecc_readl(b)/pmecc_writel. Signed-off-by: Josh Wu <josh.wu@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-09-16mtdcore: Fix a build error with CONFIG_CMD_MTDPARTS_SPREADmaxin.john@enea.com
This patch fixes the build error for CONFIG_CMD_MTDPARTS_SPREAD Signed-off-by: Maxin B. John <maxin.john@enea.com>
2014-09-16mtd: nand: davinci_nand: update write_page function for keystone RBLKhoronzhuk, Ivan
After mtd was synced with Linux 3.14 (ff94bc40af3481d47546595ba73c136de6af6929) the number of parameters for write_page function of nand_chip was changed. The additional two var were needed for subpage write. As keystone has no supbage write they are not needed. So correct only function definition by upgrading it's parameter list. That helps to get ritd of compilation warning. Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-09-16kbuild: force to define __UBOOT__ in all the C sourcesMasahiro Yamada
U-Boot has imported various source files from other projects, mostly Linux. Something like #ifdef __UBOOT__ [ modification for U-Boot ] #else [ original code ] #endif is an often used strategy for clarification of adjusted parts, that is, easier re-sync in future. Instead of defining __UBOOT__ in each source file, passing it from the top Makefile would be easier. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2014-09-16mtd: nand: add Freescale vf610_nfc driverStefan Agner
This adds initial support for Freescale NFC (NAND Flash Controller) found in ARM Vybrid SoC's, Power Architecture MPC5125 and others. The driver is called vf610_nfc since this is the first supported and tested hardware platform supported by the driver. Signed-off-by: Stefan Agner <stefan@agner.ch> Acked-by: Bill Pringlemeir <bpringlemeir@nbsps.com>
2014-09-04mtd: nand: omap_gpmc: Fix 'bit-flip' errorsRostislav Lisovy
OMAP GPMC driver used with some NAND Flash devices (e.g. Spansion S34ML08G1) causes that U-boot shows hundreds of 'nand: bit-flip corrected' error messages. Possible cause was discussed in the mailinglist thread: http://lists.denx.de/pipermail/u-boot/2014-April/177508.html Quote (Author: Pekon Gupta <pekon@ti.com>): "The issue is mainly due to a NAND protocol violation in the omap driver since the Random Data Output command (05h-E0h) expects to see only the column address that should be addressed within the already loaded read page into the read buffer. Only 2 address cycles with ALE active should be provided between the 05h and E0h commands. The Page read command expects the full address footprint (2bytes for column address + 3bytes for row address), but once the page is loaded into the read buffer, Random Data Output should be used with only 2bytes for column address." This patch combines the solution proposed in the mailinglist and the patch provided by the Spansion company (GPLv2 code, source: http://www.spansion.com/Support/Software/u-boot-psp-04.04.00.01-NAND.zip) Signed-off-by: Rostislav Lisovy <lisovy@merica.cz>
2014-09-04mtd: nand: omap_gpmc: Enable multiple NAND flash devicesRostislav Lisovy
Since the CS of a device connected to the GPMC was stored in the global variable, it was not possible to use multiple devices. In this patch the CS is stored per device in its 'struct omap_nand_info'. This makes it possible to use up to 'GPMC_MAX_CS' NAND Flash devices connected to U-boot. Signed-off-by: Rostislav Lisovy <lisovy@merica.cz>
2014-09-04mtd: nand: davinci_nand: correct keystone RBL layout definitionKhoronzhuk, Ivan
In case when 4K page keystone RBL layout is used the compilation error is appeared. That's because the #ifdef has to be placed under struct name. This patch correct it. Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-08-30arm/kirkwood/nand: allow forced disabling for subpage writesHolger Brunck
Make it configurable to disable subpage writes like the DaVinci NAND driver already does. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Scott Wood <scottwood@freescale.com>
2014-08-29Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2014-08-25mtd,ubi,ubifs: sync with linux v3.15Heiko Schocher
snyc with linux v3.15: commit 1860e379875dfe7271c649058aeddffe5afd9d0d Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Sun Jun 8 11:19:54 2014 -0700 Linux 3.15 Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Tom Rini <trini@ti.com>
2014-08-25mtd, ubi, ubifs: update for the sync with linux v3.14Heiko Schocher
while playing with the new mtd/ubi/ubifs sync, found some small updates for it: - add del_mtd_partition() to include/linux/mtd/mtd - mtd: add a debug_printf - remove some not used functions Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Tom Rini <trini@ti.com>
2014-08-25mtd, ubi, ubifs: resync with Linux-3.14Heiko Schocher
resync ubi subsystem with linux: commit 455c6fdbd219161bd09b1165f11699d6d73de11c Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Sun Mar 30 20:40:15 2014 -0700 Linux 3.14 A nice side effect of this, is we introduce UBI Fastmap support to U-Boot. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Scott Wood <scottwood@freescale.com> Cc: Joerg Krause <jkrause@posteo.de>
2014-08-11Merge branch 'master' of git://git.denx.de/u-boot-armStefano Babic
Conflicts: boards.cfg Signed-off-by: Stefano Babic <sbabic@denx.de>
2014-08-08Merge branch 'master' of git://git.denx.de/u-boot-armStefano Babic
2014-08-06sf: sf_ops: Stop leaking memoryMarek Vasut
It's usually a common pattern to free() the memory that we allocated. Implement this here to stop leaking memory. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-07-29Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-07-28Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-07-25mtd: nand: davinci: add opportunity to write keystone U-boot imageKhoronzhuk, Ivan
The Keystone SoCs use the same NAND driver as Davinci. This patch adds opportunity to write Keystone U-boot image to NAND device using appropriate RBL ECC layout. This is needed only if RBL boots U-boot from NAND device and that's supposed that raw u-boot partition is used only for writing image. The main problem is that default Davinci ECC layout is different from Keystone RBL layout. To read U-boot image the RBL needs that image was written using RBL ECC layout. The BBT table is written using default Davinci layout and has to be updated using one. The BBT can be updated only while erasing chip or by forced bad block assigning, so erase function has to use native ecc layout in order to be able to write BBT correctly. So if we're writing to NAND U-boot address we use RBL layout for others we use default ECC layout. Also remove definition for CONFIG_CMD_NAND_ECCLAYOUT as there is no reasons to use ECC layout commands. It was added by mistake. Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-07-23spi: add config option to enable the WP pin function on st micron flashesHeiko Schocher
enable the W#/Vpp signal to disable writing to the status register on ST MICRON flashes like the N25Q128 thorugh the new config option CONFIG_SYS_SPI_ST_ENABLE_WP_PIN Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2014-07-22driver/nand: Add support of 16K SRAM for IFC 2.0Prabhakar Kushwaha
Internal SRAM has been incresed from 8KB to 16KB for IFC cotroller ver 2.0. Update the page offset calculation logic to support the same. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-07-22driver/nand: Update SRAM initialize logic for IFC.Prabhakar Kushwaha
IFC controller v1.1.0 requires internal SRAM initialize by reading NAND flash. Higher controller versions have provided "SRAM init" bit in NCFGR register space. update SRAM initialize logic to reflect the same. Also print error message in case of Page read error. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-07-22driver/nand:Define MAX_BANKS same as SoC defined for IFCPrabhakar Kushwaha
The number of chip select used by IFC controller vary from one SoC to other. For eg. P1010 has 4, T4240 has 8. Update MAX_BANKS same as SoC defined Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-07-18mtd: cfi_flash: fix clang warningJeroen Hofstee
clang warns this check is silly; it is since s is a local variable. u-boot/drivers/mtd/cfi_flash.c:2363:13: warning: comparison of array 's' not equal to a null pointer is always true else if ((s != NULL) && (strcmp(s, "yes") == 0)) { cc: Stefan Roese <sr@denx.de> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-07-01Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-06-30Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-06-19mtd: nand: davinci: add header file for driver definitionsKhoronzhuk, Ivan
The definitions inside emif_defs.h concern davinci nand driver and should be in it's header. So create header file for davinci nand driver and move definitions from emif_defs.h and nand_defs.h to it. Acked-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com> [trini: Fixup more davinci breakage] Signed-off-by: Tom Rini <trini@ti.com>
2014-06-11Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
