path: root/drivers/mtd
2016-10-26mtd: nand: Kconfig: Add NAND_MXS entryJagan Teki
Added kconfig for NAND_MXS driver. Cc: Scott Wood <oss@buserror.net> Cc: Simon Glass <sjg@chromium.org> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Peng Fan <peng.fan@nxp.com> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-06spl: Update ext functions to take an spl_image parameterSimon Glass
Update the ext loader to avoid using the spl_image global variable. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spi: Move freescale-specific code into a private headerSimon Glass
At present there are two SPI functions only used by freescale which are defined in the spi_flash.h header. One function name matches an existing generic SPL function. Move these into a private header to avoid confusion. Arcturus looks like it does not actually support SPI, so drop the SPI code from that board. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Convert spl_spi_load_image() to use linker listSimon Glass
Add a linker list declaration for this method and remove the explicit switch() code. Also set up the sunxi function. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: spi: Move the generic SPI loader into common/splSimon Glass
All the other SPL loaders are in this directory, so move the SPI one in there too. There are two board-specific SPI loaders (fsl and sunxi). These remain in the drivers/mtd/spi directory, since they do not contain generic code. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Convert boot_device into a structSimon Glass
At present some spl_xxx_load_image() functions take a parameter and some don't. Of those that do, most take an integer but one takes a string. Convert this parameter into a struct so that we can pass all functions the same thing. This will allow us to use a common function signature. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Add a parameter to spl_parse_image_header()Simon Glass
Instead of using the global spl_image variable, pass the required struct in as an argument. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2016-09-22sf: Move flags macro's to spi_flash_params{} membersJagan Teki
This patch moves flags macro's to respective member position on spi_flash_params{}, for better readabilty and finding the respective member macro's easily. Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Cc: Vignesh R <vigneshr@ti.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-09-22sf: Add CONFIG_SPI_FLASH_USE_4K_SECTORS in spi_flashJagan Teki
Add CONFIG_SPI_FLASH_USE_4K_SECTORS in spi_flash code from header file. Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Cc: Vignesh R <vigneshr@ti.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-09-22sf: Remove SECT_32KJagan Teki
SECT_32K never used anywhere in the code. Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Cc: Vignesh R <vigneshr@ti.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-09-22spi: Use mode for rx mode flagsJagan Teki
Make rx mode flags as generic to spi, earlier mode_rx is maintained separately because of some flash specific code. Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Cc: Vignesh R <vigneshr@ti.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-09-22sf: Remove e_rd_cmd from param tableJagan Teki
e_rd_cmd is maintained separately for fastest read command code, since the read commands are computed normally this e_rd_cmd is not required in spi_flash_params table. Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Cc: Vignesh R <vigneshr@ti.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-09-22sf: Simplify fastest read cmd codeJagan Teki
Fastest read command code look for fastest read command taking inputs from spi->mode_rx and flags from param table and controller mode_rx is always been a priority. Since mode_rx is always set from controller side this optimized code doesn't require much and this code required exctra overhead like 1) Maintain e_rx_cmd in param table 2) Maintain mode_rx in spi_slave {} Hence removed this code, and look for read command from normal spi->mode from spi_slave{} and params->flags Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Cc: Vignesh R <vigneshr@ti.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-09-09Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2016-09-06mtd: nand: mxs: fix cache alignment for cache lines >32Stefan Agner
Currently the command buffer gets allocated with a size of 32 bytes. This causes warning messages on systems with cache lines bigger than 32 bytes: CACHE: Misaligned operation at range [9df17a00, 9df17a20] Define command buffer to be at least 32 bytes, but more if cache line is bigger. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2016-09-01nand: Fix some more NULL name testsScott Wood
Now that nand_info[] is an array of pointers we need to test the pointer itself rather than using name as a proxy for NULLness. Fixes: b616d9b0a708eb9 ("nand: Embed mtd_info in struct nand_chip") Signed-off-by: Scott Wood <oss@buserror.net> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Tony Lindgren <tony@atomide.com> Acked-by: Tony Lindgren <tony@atomide.com>
2016-09-01mtd: nand: pxa3xx: use nand_set_controller_dataChris Packham
In commit 17cb4b8f327e ("mtd: nand: Add+use mtd_to/from_nand and nand_get/set_controller_data") the assignment of mtd->priv was removed but was not replaced. This adds the required nand_set_controller_data() call. Signed-off-by: Chris Packham <judge.packham@gmail.com>
2016-07-30sf: sf_params: Add AT25DF321 flash supportWenyou Yang
Add AT25DF321 flash support. Fix AT25DF321A device name. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-07-30spi: Add support for N25Q016AMoritz Fischer
This commit adds support in the spi-nor driver for the N25Q016A, a 16Mbit SPI NOR flash from Micron. Signed-off-by: Moritz Fischer <moritz.fischer@ettus.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-07-24mtd: nand: fix bug writing 1 byte less than page sizeHector Palacios
nand_do_write_ops() determines if it is writing a partial page with the formula: part_pagewr = (column || writelen < (mtd->writesize - 1)) When 'writelen' is exactly 1 byte less than the NAND page size the formula equates to zero, so the code doesn't process it as a partial write, although it should. As a consequence the function remains in the while(1) loop with 'writelen' becoming 0xffffffff and iterating until the watchdog timeout triggers. To reproduce the issue on a NAND with 2K page (0x800): => nand erase.part <partition> => nand write $loadaddr <partition> 7ff Signed-off-by: Hector Palacios <hector.palacios@digi.com>
2016-07-24mtd: nand: Add a full-id entry for the H27QCG8T2E5R‐BCF NANDBoris Brezillon
Add a full-id entry for the H27QCG8T2E5R‐BCF NAND. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Hans de Goede <hdegoede@redhat.com>
2016-07-24mtd: nand: Add the sunxi NAND controller driverBoris Brezillon
We already have an SPL driver for the sunxi NAND controller, now add the normal/standard one. The source has been copied from Linux 4.6 with a few changes to make it work in u-boot. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Hans de Goede <hdegoede@redhat.com>
2016-07-24mtd: nand: add common DT init codeBrian Norris
These are already-documented common bindings for NAND chips. Let's handle them in nand_base. If NAND controller drivers need to act on this data before bringing up the NAND chip (e.g., fill out ECC callback functions, change HW modes, etc.), then they can do so between calling nand_scan_ident() and nand_scan_tail(). The original commit has been slightly reworked to use the fdtdec_xxx() helpers (instead of the of_xxxx() ones). Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Hans de Goede <hdegoede@redhat.com>
2016-07-22mtd: OneNAND: initialize mtd->writebufsize to let UBI workLadislav Michl
io_init checks this value and fails with "bad write buffer size 0 for 2048 min. I/O unit" Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2016-07-22mtd: OneNAND: allow board init function failLadislav Michl
2016-07-22mtd: OneNAND: add timeout to wait ready loopsLadislav Michl
Add timeout to onenand_wait ready loop as it hangs here indefinitely when chip not present. Once there, do the same for onenand_bbt_wait as well (note: recent Linux driver code does the same) Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2016-07-22armv7: make gpmc_cfg constLadislav Michl
Signed-off-by: Ladislav Michl <ladis@linux-mips.org> [trini: Adapt am33xx, duovero, omap_zoom1] Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-07-22spl: Lightweight UBI and UBI fastmap supportThomas Gleixner
Booting a payload out of NAND FLASH from the SPL is a crux today, as it requires hard partioned FLASH. Not a brilliant idea with the reliability of todays NAND FLASH chips. The upstream UBI + UBI fastmap implementation which is about to brought to u-boot is too heavy weight for SPLs as it provides way more functionality than needed for a SPL and does not even fit into the restricted SPL areas which are loaded from the SoC boot ROM. So this provides a fast and lightweight implementation of UBI scanning and UBI fastmap attach. The scan and logical to physical block mapping code is developed from scratch, while the fastmap implementation is lifted from the linux kernel source and stripped down to fit the SPL needs. The text foot print on the board which I used for development is: 6854 0 0 6854 1abd drivers/mtd/ubispl/built-in.o Attaching a NAND chip with 4096 physical eraseblocks (4 blocks are reserved for the SPL) takes: In full scan mode: 1172ms In fastmap mode: 95ms The code requires quite some storage. The largest and unknown part of it is the number of fastmap blocks to read. Therefor the data structure is not put into the BSS. The code requires a pointer to free memory handed in which is initialized by the UBI attach code itself. See doc/README.ubispl for further information on how to use it. This shares the ubi-media.h and crc32 implementation of drivers/mtd/ubi There is no way to share the fastmap code, as UBISPL only utilizes the slightly modified functions ubi_attach_fastmap() and ubi_scan_fastmap() from the original kernel ubi fastmap implementation. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-07-22onenand_spl_simple: Add a simple OneNAND read functionLadislav Michl
2016-07-22nand_spl_simple: Add a simple NAND read functionThomas Gleixner
To support UBI in SPL we need a simple NAND read function. Add one to nand_spl_simple and keep it as simple as it goes. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Acked-by: Scott Wood <oss@buserror.net> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2016-07-21powerpc/mpc85xx: SECURE BOOT- Enable chain of trust in SPLSumit Garg
As part of Chain of Trust for Secure boot, the SPL U-Boot will validate the next level U-boot image. Add a new function spl_validate_uboot to perform the validation. Enable hardware crypto operations in SPL using SEC block. In case of Secure Boot, PAMU is not bypassed. For allowing SEC block access to CPC configured as SRAM, configure PAMU. Reviewed-by: Ruchika Gupta <ruchika.gupta@nxp.com> Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <york.sun@nxp.com>
2016-07-20mtd: cfi_flash: fix polling for bit XSR.7 on Intel chipsDaniel Schwierzeck
flash_full_status_check() checks bit XSR.7 on Intel chips. This should be done by only checking bit 7 and not by comparing the whole status byte or word with 0x80. This fixes the non-working block erase in the pflash emulation of Qemu when used with the MIPS Malta board. MIPS Malta uses x32 mode to access the pflash device. In x32 mode Qemu mirrors the lower 16 bits of the status word into the upper 16 bits. Thus the CFI driver gets a status word of 0x8080 in x32 mode. If flash_full_status_check() uses flash_isequal(), then it polls for XSR.7 by comparing 0x8080 with 0x80 which never becomes true. Reported-by: Alon Bar-Lev <alon.barlev@gmail.com> Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2016-07-16Various, unrelated tree-wide typo fixes.Robert P. J. Day
Fix a number of typos, including: * "compatble" -> "compatible" * "eanbeld" -> "enabled" * "envrionment" -> "environment" * "FTD" -> "FDT" (for "flattened device tree") * "ommitted" -> "omitted" * "overriden" -> "overridden" * "partiton" -> "partition" * "propogate" -> "propagate" * "resourse" -> "resource" * "rest in piece" -> "rest in peace" * "suport" -> "support" * "varible" -> "variable" Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-07-15sunxi: Support booting from SPI flashSiarhei Siamashka
Allwinner devices support SPI flash as one of the possible bootable media type. The SPI flash chip needs to be connected to SPI0 pins (port C) to make this work. More information is available at: https://linux-sunxi.org/Bootable_SPI_flash This patch adds the initial support for booting from SPI flash. The existing SPI frameworks are not used in order to reduce the SPL code size. Right now the SPL size grows by ~370 bytes when CONFIG_SPL_SPI_SUNXI option is enabled. While there are no popular Allwinner devices with SPI flash at the moment, testing can be done using a SPI flash module (it can be bought for ~2$ on ebay) and jumper wires with the boards, which expose relevant pins on the expansion header. The SPI flash chips themselves are very cheap (some prices are even listed as low as 4 cents) and should not cost much if somebody decides to design a development board with an SPI flash chip soldered on the PCB. Another nice feature of the SPI flash is that it can be safely accessed in a device-independent way (since we know that the boot ROM is already probing these pins during the boot time). And if, for example, Olimex boards opted to use SPI flash instead of EEPROM, then they would have been able to have U-Boot installed in the SPI flash now and boot the rest of the system from the SATA hard drive. Hopefully we may see new interesting Allwinner based development boards in the future, now that the software support for the SPI flash is in a better shape :-) Testing can be done by enabling the CONFIG_SPL_SPI_SUNXI option in a board defconfig, then building U-Boot and finally flashing the resulting u-boot-sunxi-with-spl.bin binary over USB OTG with a help of the sunxi-fel tool: sunxi-fel spiflash-write 0 u-boot-sunxi-with-spl.bin The device needs to be switched into FEL (USB recovery) mode first. The most suitable boards for testing are Orange Pi PC and Pine64. Because these boards are cheap, have no built-in NAND/eMMC and expose SPI0 pins on the Raspberry Pi compatible expansion header. The A13-OLinuXino-Micro board also can be used. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-06-24mtd: nand: Drop a blank line in nand_wait()Andre Renaud
This empty line should not be there. Remove it. Signed-off-by: Andre Renaud <andre@designa-electronics.com> Reviewed-by: Andreas Bießmann <andreas@biessmann.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2016-06-20Merge git://git.denx.de/u-boot-nand-flashTom Rini
2016-06-19mtd: nand: Patch remaining places where nand_to_mtd() should be usedBoris Brezillon
Some drivers are still directly accessing the chip->mtd field. Patch them to use nand_to_mtd() instead. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
2016-06-19nand: nand torture: follow sync with linux v4.6Max Krummenacher
follow parameter name change (nand to mtd) to fix compiler error. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-19spl: nand: sunxi: add support for NAND config auto-detectionBoris Brezillon
NAND chips are supposed to expose their capabilities through advanced mechanisms like READID, ONFI or JEDEC parameter tables. While those methods are appropriate for the bootloader itself, it's way to complicated and takes too much space to fit in the SPL. Replace those mechanisms by a dumb 'trial and error' mechanism. With this new approach we can get rid of the fixed config list that was used in the sunxi NAND SPL driver. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Hans de Goede <hdegoede@redhat.com>
2016-06-19spl: nand: sunxi: split 'load page' and 'read page' logicBoris Brezillon
Split the 'load page' and 'read page' logic in 2 different functions so we can later load the page and test different ECC configs without the penalty of reloading the same page in the NAND cache. We also move common setup to a dedicated function (nand_apply_config()) to avoid rewriting the same values in NFC registers each time we read a page. These new functions are passed a pointer to an nfc_config struct to limit the number of parameters. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Hans de Goede <hdegoede@redhat.com>
2016-06-19spl: nand: sunxi: rework status polling loopBoris Brezillon
check_value_xxx() helpers are using a 1ms delay between each test, which can be quite long for some operations (like a page read on an SLC NAND). Since we don't have anything to do but to poll this register, reduce the delay between each test to 1us. While we're at it, rename the max_number_of_retries parameters and the MAX_RETRIES macro into timeout_us and DEFAULT_TIMEOUT_US to reflect that we're actually waiting a given amount of time and not only a number of retries. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Hans de Goede <hdegoede@redhat.com>
2016-06-19spl: nand: sunxi: stop guessing the redundant u-boot offsetBoris Brezillon
Use CONFIG_SYS_NAND_U_BOOT_OFFS_REDUND value instead of trying to guess where the redundant u-boot image is based on simple (and most of the time erroneous) heuristics. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Hans de Goede <hdegoede@redhat.com> # Conflicts: # drivers/mtd/nand/sunxi_nand_spl.c
2016-06-19spl: nand: support redundant u-boot imageBoris Brezillon
On modern NAND it's more than recommended to have a backup copy of the u-boot binary to recover from corruption: bitflips are quite common on MLC NANDs, and the read-disturbance will corrupt your u-boot partitition more quickly than what you would see on an SLC NAND. Add an extra Kconfig option to specify the offset of the redundant u-boot image. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Hans de Goede <hdegoede@redhat.com> [scottwood: added ifdef to fix build break] Signed-off-by: Scott Wood <oss@buserror.net>
2016-06-19spl: nand: rework SYS_NAND_U_BOOT_OFFS Kconfig option dependencyBoris Brezillon
The SYS_NAND_U_BOOT_OFFS is quite generic, but the Kconfig entry is forced to explicitly depend on platforms that are not already defining it in their include/configs/<board>.h header. Add the SYS_NAND_U_BOOT_LOCATIONS option, make the SYS_NAND_U_BOOT_OFFS depends on it, remove the dependency on NAND_SUNXI and make it dependent on SPL selection. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Hans de Goede <hdegoede@redhat.com>
2016-06-19spl: nand: sunxi: remove support for so-called 'syndrome' modeBoris Brezillon
The sunxi SPL NAND controller driver supports use 'BootROM'-like configs, that is, configs where the ECC bytes and real data are interleaved in the page instead of putting ECC bytes in the OOB area. Doing that has several drawbacks: - since you're interleaving data and ECC bytes you can't use the whole page otherwise you might override the bad block marker with non-FF bytes. - to solve the bad block marker problem, the ROM code supports partially using the page, but this introduces a huge penalty both in term of read speed and NAND memory usage. While this is fine for rather small binaries(like the SPL one which is at maximum 24KB large), it becomes non-negligible for the bootloader image (several hundred of KB). - auto-detection of the page size is not reliable (this is in my opinion the biggest problem). If you get the page size wrong, you'll end up reading data at a different offset than what was specified by the caller and the reading may succeed (if valid data were written at this address). For all those reasons I think it's wiser to completely remove support for 'syndrome' configs. If we ever need to support it again, then I'd recommend specifying all the config parameters through Kconfig options. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Hans de Goede <hdegoede@redhat.com>
2016-06-13Merge branch 'master' of git://git.denx.de/u-boot-atmelTom Rini
2016-06-12at91: nand: Set up the ECC strength correctlyAndre Renaud
This needs to be set to avoid a fatal error when ECC is used. Signed-off-by: Andre Renaud <andre@designa-electronics.com> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
2016-06-12at91: Correct NAND ECC register accessAndre Renaud
This uses the wrote base register value. Fix it. Signed-off-by: Andre Renaud <andre@designa-electronics.com> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
