path: root/drivers/mtd/stm32_flash.c
2020-05-18common: Drop flash.h from common headerSimon Glass
Move this uncommon header out of the common header. Fix up some style problems in flash.h while we are here. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-03-13arch-stm32: Factorize stm32.h for STM32F4 and F7Patrice Chotard
For STM32F4 and F7 SoCx family, a specific stm32.h file exists. Some common defines are duplicated or even unused in each of these stm32.h. Factorize all common definition in arch/arm/include/asm/stm32f.h and keep specific definitions in each arch/arm/include/asm/arch-stm32fx/stm32.h. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-07-10mtd: stm32: use parameter instead of default valuePatrice Chotard
To set wait state, a hard coded value is used instead of using latency parameter. stm32_flash_latency_cfg() is currently used in arch/arm/mach-stm32/stm32f4/clock.c and in drivers/clk/clk_stm32f7.c with, in both case, "5" as parameter. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2016-04-11stm32: stm32_flash: add memory barrier during flash writeVikas Manocha
After writing data to flash space, next instruction is checking if flash controller is busy writing to the flash memory. Memory barrier is required here to avoid transaction re-ordering for data write and busy status check. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
2016-03-26stm32: stm32f4: move flash driver to mtd driver locationVikas Manocha
Same flash driver can be used by other stm32 families like stm32f7. Better place for this driver would be mtd driver location. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
