spi_nor_read_sfdp() calls nor->read() to read the SFDP data.
The MTD and SPI subsystem expects the tx and rx buf used for
transfers should point to a dma-safe memory.
However, two out of the three calls of spi_nor_read_sfdp() were given
pointers to stack allocated memory as buf argument, hence not in a
dma-safe area.
The third and last call of spi_nor_read_sfdp() was already given a
kmalloc'ed buffer argument, hence dma-safe.
So this patch fixes this issue by introducing a
spi_nor_read_sfdp_dma_unsafe() function which simply wraps the existing
spi_nor_read_sfdp() function and uses some kmalloc'ed memory as a bounce
buffer.
This patch is ported from upstream Linux mtd spi-nor fix commit
bfa4133795e5a0badd402dd3f58b13b3cec64a4b ("mtd: spi-nor: fix DMA unsafe
buffer issue in spi_nor_read_sfdp()")
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Signed-off-by: Cyrille Pitchen <cyrille.pitchen@wedev4u.fr>
Fixes: 0c6f187cdb18b52bcf6d3964771cf3a36b758568 ("mtd: spi: spi-nor-core: Add SFDP support")
Signed-off-by: Apurva Nandan <a-nandan@ti.com>
Reviewed-by: Vaishnav Achath <vaishnav.a@ti.com>
Reviewed-by: Dhruva Gole <d-gole@ti.com>
MT35XU512ABA has only BFPT and 4-Byte Address Instruction Table
in SFDP. Commit bebdc237507c (" mtd: spi-nor: Parse SFDP SCCR Map")
added checks in spi_nor_octal_dtr_enable() to bail out if the 22nd DWORD
in SCCR does not indicate DTR Octal Mode Enable, since MT35XU512ABA device
supports octal DTR mode, add this property in SFDP fixup.
Signed-off-by: Vaishnav Achath <vaishnav.a@ti.com>
On DTR capable flashes like Micron Xcella the writes cannot start or end
at an odd address in DTR mode. Extra 0xff bytes need to be prepended or
appended respectively to make sure both the start and end addresses are
even.
Signed-off-by: Pratyush Yadav <p.yadav@ti.com>
Reviewed-by: Vignesh Raghavendra <vigneshr@ti.com>
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
Once the flash is initialized tell the controller it can run calibration
procedures if needed. This can be useful when calibration is needed to
run at higher clock speeds.
A template of the read op will be needed in a upcoming commit. So,
refactor the code to create a read op in spi_nor_read_data() to a
separate function that returns the template of the op. The caller can
then fill in the details like address, data length, and the data buffer.
Update spi_nor_read_data() to use this template.
Infineon S25FS256T is 256Mbit Quad SPI NOR flash. The key features and
differences comparing to other Spansion/Cypress flash familes are:
- 4-byte address mode by factory default
- Quad mode is enabled by factory default
- Supports mixture of 128KB and 64KB sectors by OTP configuration
(this patch supports uniform 128KB only)
Signed-off-by: Takahiro Kuwano <Takahiro.Kuwano@infineon.com>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Rename s25hx_t prefix to s25 so that the single set of fixup hooks can
support all other S25 families.
Acked-by: Dhruva Gole <d-gole@ti.com>
Cypress defines two flavors of configuration registers, volatile and
non volatile, and both use the same bit fields. Rename the bitfields in
the configuration registers so that they can be used for both flavors.
Suggested-by: Tudor Ambarus <tudor.ambarus@linaro.org>
Reviewed-by: Tudor Ambarus <tudor.ambarus@linaro.org>
flash_is_locked is changed to flash_is_unlocked with commit 513c6071ce73
("mtd: spi: Convert is_locked callback to is_unlocked"). sst26_is_locked()
is also changed to sst26_is_unlocked() but the logic remained same.
Invert the logic for the flash lock/unlock to work properly.
Signed-off-by: Algapally Santosh Sagar <santoshsagar.algapally@amd.com>
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@amd.com>
Reviewed-by: Jan Kiszka <jan.kiszka@siemens.com>
Link: https://lore.kernel.org/r/20221122051833.13306-1-ashok.reddy.soma@amd.com
Signed-off-by: Michal Simek <michal.simek@amd.com>
Array index for SCCR 22th DWORD should be 21.
Fixes: bebdc237507c ("mtd: spi-nor: Parse SFDP SCCR Map")
address mode
The flash's internal address mode is tracked by nor->add_mode_nbytes and
it is set to 3 in BFPT parse. SEMPER multi-die package parts (>1Gb) are
3- or 4-byte address mode by default, depending on model number. We need
to make sure that 4-byte address mode is used for multi-die package parts.
For single-die package parts (<=1Gb), registers can be accessed by 3-byte
address. Read, program, and erase use the 4B opcodes that always take
4-byte address regardless of flash's internal address mode.
Read/Write Any Register commands take 3- or 4- byte address depending on
flash's internal address mode. The nor->addr_width tracks number of
address bytes used in read/program/erase ops that can be 4
(with 4B opcodes) regardless of flash's internal address mode. The
nor->addr_mode_nbytes tracks flash's internal address mode so replace
nor->addr_width by that.
The nor->addr_width tracks number of address bytes used in
read/program/erase ops and eventually set to 4 for >16MB chips, regardless
of flash's internal address mode. For Infineon SEMPER flash's, we use
Read/Write Any Register commands for configuration and status check.
These commands take 3- or 4-byte address depending on flash's internal
address mode.
JESD216D-01 mentions that "defaults to 3-Byte mode; enters 4-Byte mode on
command."
Add flash info table entries for s28hl512gt, s28hl01gt, and s28hs01gt.
These devices have the same functionality as s28hs512t.
In spi-nor-core, use device ID byte to detect S28 family instead of
device name.
Change configuration macro name to support all other devices in SEMPER S28
family.
Change prefix to support all other devices in SEMPER S28 family.
Globally replace all occurances of WATCHDOG_RESET() with schedule(),
which handles the HW_WATCHDOG functionality and the cyclic
infrastructure.
Tested-by: Tom Rini <trini@konsulko.com> [am335x_evm, mx6cuboxi, rpi_3,dra7xx_evm, pine64_plus, am65x_evm, j721e_evm]
This adds support for the dirmap API to the spi-nor subsystem, as
introduced in Linux commit df5c21002cf4 ("mtd: spi-nor: use
spi-mem dirmap API").
This patch is synchronize from the following patch
https://patchwork.ozlabs.org/project/uboot/patch/20210205043924.149504-4-seanga2@gmail.com/
The corresponding Linux kernel SHA1 is df5c21002cf4.
Signed-off-by: Chin-Ting Kuo <chin-ting_kuo@aspeedtech.com>
Signed-off-by: Sean Anderson <seanga2@gmail.com>
Acked-by: Pratyush Yadav <p.yadav@ti.com>
Move this out of the common header and include it only where needed.
A large number of files include <flash.h> as it used to be how various
SPI flash related functions were found, or for other reasons entirely.
In order to migrate some further CONFIG symbols to Kconfig we need to
not include flash.h in cases where we don't have a NOR flash of some
sort enabled. Furthermore, in cases where we are in common code and it
doesn't make sense to try and further refactor the code itself in to new
files we need to guard this inclusion.
There was no user of this callback after 5b66fdb29dc3 anymore, and its
semantic as now inconsistent between stm and sst26. What we need for the
upcoming new usecase is a "completely unlocked" semantic. So consolidate
over this.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
Parse SCCR 22nd dword and check DTR Octal Mode Enable
Volatile bit for Octal DTR enable
Signed-off-by: JaimeLiao <jaimeliao.tw@gmail.com>
Power-on-Reset is a method to restore flash back to 1S-1S-1S mode from 8D-8D-8D
in the begging of probe.
Command extension type is not standardized across flash vendors in DTR mode.
For suiting different vendor flash devices, adding a flag to seperate types for
soft reset on boot.
Follow patch <f6adec1af4b2f5d3012480c6cdce7743b74a6156> (Allow using Micron mt35xu512aba
in Octal DTR mode).
Enable Octal DTR mode with 20 dummy cycles to allow running at the
maximum supported frequency for adding Macronix flash in Octal DTR mode.
-https://www.mxic.com.tw/Lists/Datasheet/Attachments/7841/MX25LM51245G,%203V,%20512Mb,%20v1.1.pdf
When SPI flash is used in SPL there is no console, so ctrlc() cannot be
called. Add a condition to fix this.
Use moveconfig.py script to convert define CONFIG_SYS_MAX_FLASH_BANKS
and CONFIG_SYS_MAX_FLASH_BANKS_DETECT to Kconfig and move these entries
to defconfigs.
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
[trini: Re-switch to IS_ENABLED check in spi-nor-core.c, re-run migration]
Replace CONFIG_SYS_MAX_FLASH_BANKS by CFI_FLASH_BANKS to prepare
Kconfig migration and avoid to redefine CONFIG_SYS_MAX_FLASH_BANKS
in cfi_flash.h.
After this patch CONFIG_SYS_MAX_FLASH_BANKS should be never used in
the cfi code: use CFI_MAX_FLASH_BANKS for struct size or CFI_FLASH_BANKS
for number of CFI banks which can be dynamic.
This patch modify all the files which include mtd/cfi_flash.h.
The original purpose of mtd_erase_callback() in Linux at the time it was
imported to U-Boot, was to inform the caller that erasing is done (since
it was an asynchronous operation).
All supplied callback methods in U-Boot do nothing, but the
mtd_erase_callback() function was (until previous patch) grossly abused
in U-Boot's mtdpart implementation for completely different purpose.
Since we got rid of the abusement, remove the mtd_erase_callback()
function and the .callback member from struct erase_info entirely, in
order to avoid such problems in the future.
Signed-off-by: Marek Behún <marek.behun@nic.cz>
May it possible to interrupt the spi_nor_erase() function.
Tested-by: Masami Hiramatsu <masami.hiramatsu@linaro.org>
The spi_nor_erase() function does not call mtd_erase_callback() as it
should.
The mtdpart code currently implements the subtraction of partition
offset in mtd_erase_callback().
This results in partition offset being added prior calling
spi_nor_erase(), but not subtracted back on return. The result is that
the `mtd erase` command does not erase the whole partition, only some of
it's blocks:
=> mtd erase "Rescue system"
Erasing 0x00000000 ... 0x006fffff (1792 eraseblock(s))
jedec_spi_nor spi-nor@0: at 0x100000, len 4096
jedec_spi_nor spi-nor@0: at 0x201000, len 4096
jedec_spi_nor spi-nor@0: at 0x302000, len 4096
jedec_spi_nor spi-nor@0: at 0x403000, len 4096
jedec_spi_nor spi-nor@0: at 0x504000, len 4096
jedec_spi_nor spi-nor@0: at 0x605000, len 4096
jedec_spi_nor spi-nor@0: at 0x706000, len 4096
This is obviously wrong.
Add proper calling of mtd_erase_callback() into the spi_nor_erase()
function.
Reported-by: Masami Hiramatsu <masami.hiramatsu@linaro.org>
spi_nor_erase()
This check is already done in all callers: mtdcore's mtd_write() /
mtd_erase(), legacy spi_nor_write() / spi_flash_erase(). No reason to do
this here as well.
The cleanup code of spi_nor_erase() function calls write_disable(), but
does not return it's return value even in case of failure. Fix this.
The cleanup code of the spi_nor_erase() function overwrites the ret
variable with return value of clean_bar(), even if the ret variable is
already set. Fix this.
The spi_nor_erase() function does not check return value of the
write_enable() call. Fix this.
Reviewed-by: Pratyush Yadav <p.yadav@ti.com>
Use the cleanup codepath of spi_nor_erase() also in the event of failure
of writing the BAR register.
The S25FL256L is a part of the S25FL-L family and has the same feature set
as S25FL128L except the density.
The datasheet can be found in the following link.
https://www.cypress.com/file/316171/download
The S25FL256L is 32MB NOR Flash that does not support Bank Address
Register. This fixup is activated if CONFIG_SPI_FLASH_BAR is enabled and
returns ENOTSUPP in setup() hook to avoid further ops.
Tested on Xilinx Zynq-7000 FPGA board.
Force the mtd name of spi-nor to "nor" + the driver sequence number:
"nor0", "nor1"... beginning after the existing nor devices.
This patch is coherent with existing "nand" and "spi-nand"
mtd device names.
When CFI MTD NOR device are supported, the spi-nor index is chosen after
the last CFI device defined by CONFIG_SYS_MAX_FLASH_BANKS.
When CONFIG_SYS_MAX_FLASH_BANKS_DETECT is activated, this config
is replaced by to cfi_flash_num_flash_banks in the include file
mtd/cfi_flash.h.
This generic name "nor%d" can be use to identify the mtd spi-nor device
without knowing the real device name or the DT path of the device,
used with API get_mtd_device_nm() and is used in mtdparts command.
This patch also avoids issue when the same NOR device is present 2 times,
for example on STM32MP15F-EV1:
STM32MP> mtd list
SF: Detected mx66l51235l with page size 256 Bytes, erase size 64 KiB, \
total 64 MiB
List of MTD devices:
* nand0
- type: NAND flash
- block size: 0x40000 bytes
- min I/O: 0x1000 bytes
- OOB size: 224 bytes
- OOB available: 118 bytes
- ECC strength: 8 bits
- ECC step size: 512 bytes
- bitflip threshold: 6 bits
- 0x000000000000-0x000040000000 : "nand0"
* mx66l51235l
- device: mx66l51235l@0
- parent: spi@58003000
- driver: jedec_spi_nor
- path: /soc/spi@58003000/mx66l51235l@0
- type: NOR flash
- block size: 0x10000 bytes
- min I/O: 0x1 bytes
- 0x000000000000-0x000004000000 : "mx66l51235l"
* mx66l51235l
- device: mx66l51235l@1
- path: /soc/spi@58003000/mx66l51235l@1
- type: NOR flash
The same mtd name "mx66l51235l" identify the 2 instances
mx66l51235l@0 and mx66l51235l@1.
This patch fixes a ST32CubeProgrammer / stm32prog command issue
with nor0 target on STM32MP157C-EV1 board introduced by
commit b7f060565e31 ("mtd: spi-nor: allow registering multiple MTDs when
DM is enabled").
Fixes: b7f060565e31 ("mtd: spi-nor: allow registering multiple MTDs when DM is enabled")
[trini: Add <dm/device.h> to <mtd.h> for DM_MAX_SEQ_STR]
The DT bindings of "jedec,spi-nor" [1] defines "m25p,fast-read" property
to indicate that "fast read" opcode can be used to read data from the
chip instead of the usual "read" opcode.
If this property is not present in DT, mask out fast read in
spi_nor_init_params(). This change mirrors the same logic in
spi_nor_info_init_params() in drivers/mtd/spi-nor/core.c in
the Linux kernel v5.14-rc3.
[1] Documentation/devicetree/bindings/mtd/jedec,spi-nor.yaml in the kernel tree
The smart spi_nor_adjust_hwcaps() does not respect the SPI flash's
hwcaps, and only looks to the controller on what can be supported.
The flash's hwcaps needs to be AND'ed before checking.
Fixes: 71025f013ccb ("mtd: spi-nor-core: Rework hwcaps selection")
The nor->ready() and spansion_sr_ready() introduced earlier in this
series are used for multi-die package parts.
The nor->quad_enable() sets the volatile QE bit on each die.
The nor->erase() is hooked if the device is not configured to uniform
sectors, assuming it has 32 x 4KB sectors overlaid on bottom address.
Other configurations, top and split, are not supported at this point.
Will submit additional patches to support it as needed.
The post_bfpt/sfdp() fixes the params wrongly advertised in SFDP.
Cypress chips support SPINOR_OP_EN4B(B7h) to enable 4-byte addressing mode.
Cypress chips support B8h to disable 4-byte addressing mode instead of
SPINOR_OP_EX4B(E9h).
This patch defines new opcode and updates set_4byte() to support
enable/disable 4-byte addressing mode for Cypress chips.
The spansion_sr_ready() reads status register 1 by Read Any Register
commnad. This function is called from Flash specific hook with die address
and dummy cycles to support multi-die package parts from Spansion/Cypress.
For dual/quad die package devices from Spansion/Cypress, the device's
status needs to be checked by reading status registers in all dies, by
using Read Any Register command. To support this, a Flash specific hook
that can overwrite the legacy status check is needed.
Some of Spansion/Cypress chips support volatile version of configuration
registers and it is recommended to update volatile registers in the field
application due to a risk of the non-volatile registers corruption by
power interrupt. This patch adds a function to set Quad Enable bit in CFR1
volatile.
Some of Spansion/Cypress chips support Read/Write Any Register commands.
These commands are mainly used to write volatile registers and access to
the registers in second and subsequent die for multi-die package parts.
The Read Any Register instruction (65h) is followed by register address
and dummy cycles, then the selected register byte is returned.
The Write Any Register instruction (71h) is followed by register address
and register byte to write.
Since this flash doesn't have a Profile 1.0 table, the Octal DTR
capabilities are enabled in the post SFDP fixup, along with the 8D-8D-8D
fast read settings.
maximum supported frequency of 200Mhz.
The Cypress Semper flash is an xSPI compliant octal DTR flash. Add
support for using it in octal DTR mode.
The flash by default boots in a hybrid sector mode. Switch to uniform
sector mode on boot. Use the default 20 dummy cycles for a read fast
command.
The SFDP programming on some older versions of the flash was incorrect.
Fixes for that are included in the fixup hooks.
Some of Spansion/Cypress chips have overlaid 4KB sectors at top and/or
bottom, depending on the device configuration, while U-Boot supports
uniform sector layout only.
The spansion_erase_non_uniform() erases overlaid 4KB sectors,
non-overlaid portion of normal sector, and remaining normal sectors, by
selecting correct erase command and size based on the address to erase
and size of overlaid portion in parameters. Since different Spansion
flashes can use different opcode for erasing the 4K sectors, the opcode
must be passed in as a parameter based on the flash being used.
[p.yadav@ti.com: Refactor the function to be compatible with nor->erase,
make 4K opcode customizable, call spi_nor_setup_op() before executing
the op.]
On devices with non-uniform sector sizes like Spansion S25 or S28 family
of flashes the sector under erase does not necessarily have to be
mtd->erasesize bytes long. For example, on S28 flashes the first 128 KiB
region is composed of 32 4 KiB sectors, then a 128 KiB sector, and then
256 KiB sectors till the end.
Let the flash-specific erase functions erase less than the requested
length in case of the 4 or 128 KiB sectors and report the number of
bytes erased back to the calling function.
