path: root/drivers/mtd/onenand
2016-07-22mtd: OneNAND: initialize mtd->writebufsize to let UBI workLadislav Michl
io_init checks this value and fails with "bad write buffer size 0 for 2048 min. I/O unit" Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2016-07-22mtd: OneNAND: allow board init function failLadislav Michl
2016-07-22mtd: OneNAND: add timeout to wait ready loopsLadislav Michl
Add timeout to onenand_wait ready loop as it hangs here indefinitely when chip not present. Once there, do the same for onenand_bbt_wait as well (note: recent Linux driver code does the same) Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2016-07-22onenand_spl_simple: Add a simple OneNAND read functionLadislav Michl
2014-08-25mtd, ubi, ubifs: resync with Linux-3.14Heiko Schocher
resync ubi subsystem with linux: commit 455c6fdbd219161bd09b1165f11699d6d73de11c Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Sun Mar 30 20:40:15 2014 -0700 Linux 3.14 A nice side effect of this, is we introduce UBI Fastmap support to U-Boot. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Scott Wood <scottwood@freescale.com> Cc: Joerg Krause <jkrause@posteo.de>
2013-12-31mtd: onenand: Fix unaligned accessMarek Vasut
Fix unaligned access in OneNAND core. The problem is that the ffchars[] array is an array of "unsigned char", but in onenand_write_ops_nolock() can be passed to the memcpy_16() function. The memcpy_16() function will treat the buffer as an array of "unsigned short", thus triggering unaligned access if the compiler decided ffchars[] to be not aligned. I managed to trigger the problem with regular ELDK 5.4 GCC compiler. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Scott Wood <scottwood@freescale.com> Cc: Tom Rini <trini@ti.com>
2013-11-21mtd: move & update nand_ecclayout structure (plus board changes)Prabhakar Kushwaha
nand_ecclayout is present in mtd.h at Linux. Move this structure to mtd.h to comply with Linux. Also, increase the ecc placement locations to 640 to suport device having writesize/oobsize of 8KB/640B. This means that the maximum oobsize has gone up to 640 bytes and consequently the maximum ecc placement locations have also gone up to 640. Changes from Prabhabkar's version (squashed into one patch to preserve bisectability): - Added _LARGE to MTD_MAX_*_ENTRIES This makes the names match current Linux source, and resolves a conflict between http://patchwork.ozlabs.org/patch/280488/ and http://patchwork.ozlabs.org/patch/284513/ The former was posted first and is closer to matching Linux, but unlike Linux it does not add _LARGE to the names. The second adds _LARGE to one of the names, and depends on it in a subsequent patch (http://patchwork.ozlabs.org/patch/284512/). - Made max oobfree/eccpos configurable, and used this on tricorder, alpr, ASH405, T4160QDS, and T4240QDS (these boards failed to build for me without doing so, due to a size increase). On tricorder SPL, this saves 2576 bytes (and makes the SPL build again) versus the new default of 640 eccpos and 32 oobfree, and saves 336 bytes versus the old default of 128 eccpos and 8 oobfree. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> CC: Vipin Kumar <vipin.kumar@st.com> [scottwood@freescale.com: changes as described above] Signed-off-by: Scott Wood <scottwood@freescale.com> Cc: Thomas Weber <weber@corscience.de> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Stefan Roese <sr@denx.de> Cc: York Sun <yorksun@freescale.com> Cc: Tom Rini <trini@ti.com> Reviewed-by: Stefan Roese <sr@denx.de>
2013-10-31drivers: mtd: convert makefiles to Kbuild styleMasahiro Yamada
2013-10-09mtd: driver _read() returns max_bitflips; mtd_read() returns -EUCLEANPaul Burton
Linux modified the MTD driver interface in commit edbc4540 (with the same name as this commit). The effect is that calls to mtd_read will not return -EUCLEAN if the number of ECC-corrected bit errors is below a certain threshold, which defaults to the strength of the ECC. This allows -EUCLEAN to stop indicating "some bits were corrected" and begin indicating "a large number of bits were corrected, the data held in this region of flash may be lost soon". UBI makes use of this and when -EUCLEAN is returned from mtd_read it will move data to another block of flash. Without adopting this interface change UBI on U-boot attempts to move data between blocks every time a single bit is corrected using the ECC, which is a very common occurance on some devices. For some devices where bit errors are common enough, UBI can get stuck constantly moving data around because each block it attempts to use has a single bit error. This condition is hit when wear_leveling_worker attempts to move data from one PEB to another in response to an -EUCLEAN/UBI_IO_BITFLIPS error. When this happens ubi_eba_copy_leb is called to perform the data copy, and after the data is written it is read back to check its validity. If that read returns UBI_IO_BITFLIPS (in response to an MTD -EUCLEAN) then ubi_eba_copy_leb returns 1 to wear_leveling worker, which then proceeds to schedule the destination PEB for erasure. This leads to erase_worker running on the PEB, and following a successful erase wear_leveling_worker is called which begins this whole cycle all over again. The end result is that (without UBI debug output enabled) the boot appears to simply hang whilst in reality U-boot busily works away at destroying a block of the NAND flash. Debug output from this situation: UBI DBG: ensure_wear_leveling: schedule scrubbing UBI DBG: wear_leveling_worker: scrub PEB 1027 to PEB 4083 UBI DBG: ubi_io_read_vid_hdr: read VID header from PEB 1027 UBI DBG: ubi_io_read: read 4096 bytes from PEB 1027:4096 UBI DBG: ubi_eba_copy_leb: copy LEB 0:0, PEB 1027 to PEB 4083 UBI DBG: ubi_eba_copy_leb: read 1040384 bytes of data UBI DBG: ubi_io_read: read 1040384 bytes from PEB 1027:8192 UBI: fixable bit-flip detected at PEB 1027 UBI DBG: ubi_io_write_vid_hdr: write VID header to PEB 4083 UBI DBG: ubi_io_write: write 4096 bytes to PEB 4083:4096 UBI DBG: ubi_io_read_vid_hdr: read VID header from PEB 4083 UBI DBG: ubi_io_read: read 4096 bytes from PEB 4083:4096 UBI DBG: ubi_io_write: write 4096 bytes to PEB 4083:8192 UBI DBG: ubi_io_read: read 4096 bytes from PEB 4083:8192 UBI: fixable bit-flip detected at PEB 4083 UBI DBG: schedule_erase: schedule erasure of PEB 4083, EC 55, torture 0 UBI DBG: erase_worker: erase PEB 4083 EC 55 UBI DBG: sync_erase: erase PEB 4083, old EC 55 UBI DBG: do_sync_erase: erase PEB 4083 UBI DBG: sync_erase: erased PEB 4083, new EC 56 UBI DBG: ubi_io_write_ec_hdr: write EC header to PEB 4083 UBI DBG: ubi_io_write: write 4096 bytes to PEB 4083:0 UBI DBG: ensure_wear_leveling: schedule scrubbing UBI DBG: wear_leveling_worker: scrub PEB 1027 to PEB 4083 ... This patch adopts the interface change as in Linux commit edbc4540 in order to avoid such situations. Given that none of the drivers under drivers/mtd return -EUCLEAN, this should only affect those using software ECC. I have tested that it works on a board which is currently out of tree, but which I hope to be able to begin upstreaming soon. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Stefan Roese <sr@denx.de>
2013-05-31mtd: resync with Linux-3.7.1Sergey Lapin
This patch is essentially an update of u-boot MTD subsystem to the state of Linux-3.7.1 with exclusion of some bits: - the update is concentrated on NAND, no onenand or CFI/NOR/SPI flashes interfaces are updated EXCEPT for API changes. - new large NAND chips support is there, though some updates have got in Linux-3.8.-rc1, (which will follow on top of this patch). To produce this update I used tag v3.7.1 of linux-stable repository. The update was made using application of relevant patches, with changes relevant to U-Boot-only stuff sticked together to keep bisectability. Then all changes were grouped together to this patch. Signed-off-by: Sergey Lapin <slapin@ossfans.org> [scottwood@freescale.com: some eccstrength and build fixes] Signed-off-by: Scott Wood <scottwood@freescale.com>
2013-04-12arm: Remove support for unused s3c64xxBenoît Thébaudeau
Following the removal of the smdk6400 board, the s3c64xx SoC becomes unused, so remove associated code. It will still be possible to restore it later from the Git history if necessary. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-03-08SPL: ONENAND: Fix onenand_spl_load_image implementation.Enric Balletbo i Serra
Tested with an IGEPv2 board seems that current onenand_spl_load_image implementation doesn't work. This patch fixes this function changing the read loop and reading the onenand blocks from page to page. Tested with various IGEP based boards with a OneNAND from Numonyx. Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
2012-04-30linux/compat.h: rename from linux/mtd/compat.hMike Frysinger
This lets us use it in more places than just mtd code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-04-21GCC4.6: Squash warnings in onenand_base.cWolfgang Denk
Fix gcc 4.6 build warnings: onenand_base.c: In function 'onenand_probe': onenand_base.c:2577:6: warning: variable 'maf_id' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com>
2012-04-04onenand: Replace ONENAND_IS_MLC() with ONENAND_HAS_4KB()Lukasz Majewski
This replacement causes 4KB page size devices to work properly with u-boot. The old ONENAND_IS_MLC() behavior has been preserved by explicit setting of ONENAND_HAS_4KB_PAGE for those devices. This change makes the onenand_base.c file more resembling the respective kernel sources. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> --- Test HW: - Samsung S5PC110 GONI - Samsung S5PC210 Universal
2012-04-04onenand:samsung Target dependent OneNAND chip probe functionLukasz Majewski
Separate callback for probing OneNAND memory chip. If no special function is defined, default implementation will be used. This approach gives more flexibility for OneNAND device probing. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2011-11-23Merge branch 'hs@denx.de' of git://git.denx.de/u-boot-stagingWolfgang Denk
* 'hs@denx.de' of git://git.denx.de/u-boot-staging: drivers/net/dnet.c: Fix GCC 4.6 warnings board/xaeniax/flash.c: Fix GCC 4.6 warnings net/bootp.c: Fix GCC 4.6 warning common/cmd_bootm.c: Fix GCC 4.6 warnings board/mx1ads/mx1ads.c: Fix GCC 4.6 warning board/mx1ads/syncflash.c: Fix GCC 4.6 warnings board/lubbock/flash.c: Fix GCC 4.6 warnings drivers/net/cs8900.c: Fix GCC 4.6 warning arch/arm/cpu/arm926ejs/omap/cpuinfo.c: Fix GCC 4.6 warnings drivers/net/lan91c96.c: Fix GCC 4.6 warning board/ronetix/pm9263/pm9263.c: Fix GCC 4.6 warning drivers/mtd/onenand/samsung.c: Fix GCC 4.6 warning drivers/usb/musb/musb_hcd.c: Fix GCC 4.6 warning
2011-11-23drivers/mtd/onenand/samsung.c: Fix GCC 4.6 warningAnatolij Gustschin
Fix: samsung.c: In function 's3c_onenand_check_lock_status': samsung.c:486:6: warning: variable 'tmp' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-11-15GCC4.6: Squash warnings in onenand_base.cMarek Vasut
onenand_base.c: In function ‘onenand_do_lock_cmd’: onenand_base.c:1946:6: warning: variable ‘wp_status_mask’ set but not used [-Wunused-but-set-variable] onenand_base.c: In function ‘onenand_check_maf’: onenand_base.c:2229:8: warning: variable ‘name’ set but not used [-Wunused-but-set-variable] onenand_base.c: In function ‘flexonenand_get_boundary’: onenand_base.c:2258:6: warning: variable ‘ret’ set but not used [-Wunused-but-set-variable] Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Kyungmin Park <kyungmin.park@samsung.com>
2011-11-15OneNAND: Add simple OneNAND SPLMarek Vasut
This introduces small OneNAND loader, fitting into 1kB of space (smallest possible OneNAND RAM size). Some devices equipped with such crappy chips will use this. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Scott Wood <scottwood@freescale.com> V2: Introduce spl_onenand_load_image() to load data from OneNAND in SPL V3: Cleanup, align with nand_spl. Skip whole blocks.
2010-10-11mtd: OneNAND: add support for OneNAND manufactured by NumonyxEnric Balletbo i Serra
This patch adds the Numonyx manufacturer code (0x20) to onenand manufacturers. Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Steve Sakoman <steve.sakoman@linaro.org> Tested-by: Steve Sakoman <steve.sakoman@linaro.org>
2010-08-26ARMV7: S5P: rename from CONFIG_S5PC1XX to CONFIG_S5PMinkyu Kang
Use the same configuration around S5P SoCs. (s5pc100, s5pc110, s5pc210 and so on) Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-11-13Flex-OneNAND driver supportAmul Kumar Saha
This patch adds support for Flex-OneNAND devices. Signed-off-by: Rohit Hagargundgi <h.rohit@samsung.com> Signed-off-by: Amul Kumar Saha <amul.saha@samsung.com>
2009-10-13s5pc1xx: support onenand driverMinkyu Kang
This patch includes the onenand driver for s5pc100 Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2009-08-26OneNAND: Remove unused read_spareramKyungmin Park
Remove unused read_spareram and add unlock_all as kernel does Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2009-06-12mtd: Introduce CONFIG_MTD_DEVICE to select compilation of mtdcore.oStefan Roese
This new define enables mtdcore.c compilation and with this we can select the MTD device infrastructure needed for the reworked mtdparts command. We now have the 2 MTD infrastructure defines, CONFIG_MTD_DEVICE and CONFIG_MTD_PARTITIONS. CONFIG_MTD_DEVICE is needed (as explained above) for the "mtdparts" command and CONFIG_MTD_PARTITIONS is needed for UBI. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Scott Wood <scottwood@freescale.com>
2009-04-28mtd: nand/onenand: Register mtd device upon device scanningStefan Roese
With this patch the NAND and OneNAND devices are registered in the MTD subsystem and can then be referenced by the mtdcore code (e.g. get_mtd_device_nm()). This is needed for the new "ubi part" command syntax without the flash type parameter (nor|nand|onenand). Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-23OneNAND: Additional sync with 2.6.27Stefan Roese
- Add subpage write support - Add onenand_oob_64/32 ecclayout This has been missing and without it UBI has some incompatibilies issues with the current (>= 2.6.27) Linux kernel version. vid_hdr_offset is placed differently (2048 instead of 512) without this fix. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-01-23Add markbad functionKyungmin Park
Add missing markbad function If not, it's hang when it entered the mtd->mark_bad(). Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2009-01-23OneNAND: Save version_id in onenand_chip structStefan Roese
The version (ver_id) was not stored in the onenand_chip structure and because of this the continuous locking scheme could be enabled on some chips. Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-23OneNAND: Fix compiler warningsStefan Roese
2009-01-23Sync with 2.6.27Kyungmin Park
Sync with OneNAND kernel codes Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-10-29NAND: sync with 2.6.27Scott Wood
This brings the core NAND code up to date with the Linux kernel. Since there were several drivers in Linux as of the last update that are not in u-boot, I'm not bringing over new drivers that have been added since in the absence of an interested party. I did not update OneNAND since it was recently synced by Kyungmin Park, and I'm not sure exactly what the common ancestor is. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-25Minor coding style cleanup, updte CHANGELOGWolfgang Denk
2008-08-21Fix OneNAND read_oob/write_oob functions compatabilityKyungmin Park
Also sync with kernel OneNAND codes Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-14Coding Style cleanup, update CHANGELOGWolfgang Denk
2008-08-14Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
2008-08-13Fix OneNAND build breakKyungmin Park
Since page size field is changed from oobblock to writesize. But OneNAND is not updated. - fix bufferram management at erase operation This patch includes the NAND/OneNAND state filed too. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-13drivers/mtd/onenand: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-08-12OneNAND: Fill in MTD function pointers for OneNAND.Fathi BOUDRA
onenand_print_device_info(): - Now returns a string to be placed in mtd->name, rather than calling printf. - Remove verbose parameter as it becomes useless. Signed-off-by: Fathi Boudra <fabo@debian.org> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-11OneNAND: Remove unused parameters to onenand_verify_pageSteve Sakoman
The block and page parameters of onenand_verify_page() are not used. This causes a compiler error when CONFIG_MTD_ONENAND_VERIFY_WRITE is enabled. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Dirk Behme <dirk.behme@gmail.com>
2008-07-09NAND: Rename DEBUG to MTDDEBUG to avoid namespace pollution.Scott Wood
This is particularly problematic now that non-NAND-specific code is including <nand.h>, and thus all debugging code is being compiled regardless of whether it was requested, as reported by Scott McNutt <smcnutt@psyent.com>. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-05-01onenand: rename 16 bit memory copy into memcpy_16() to avoid conflictsWolfgang Denk
Onenand needs a version of memcpy() which performs 16 bit accesses only; make sure the name does not conflict with the standard function. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-13Fix OneNAND readKyungmin Park
It should access with 16-bit instead of 8-bit Now it uses the generic memcpy with 8-bit access. It means it reads wrong data from OneNAND. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-03-26Add Flex-OneNAND booting supportKyungmin Park
Flex-OneNAND is a monolithic integrated circuit with a NAND Flash array using a NOR Flash interface. This on-chip integration enables system designers to reduce external system logic and use high-density NAND Flash in applications that would otherwise have to use more NOR components. Flex-OneNAND enables users to configure to partition it into SLC and MLC areas in more flexible way. While MLC area of Flex-OneNAND can be used to store data that require low reliability and high density, SLC area of Flex-OneNAND to store data that need high reliability and high performance. Flex-OneNAND can let users take advantage of storing these two different types of data into one chip, which is making Flex-OneNAND more cost- and space-effective. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-01-16OneNAND: Separate U-Boot dependent code from OneNANDKyungmin Park
OneNAND: Separate U-Boot dependent code from OneNAND Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
