path: root/drivers/mtd/nand
2014-03-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-03-09mtd: nand: atmel: prepare for nand spl boot supportBo Shen
Prepare for nand spl boot support. It supports nand software ECC and hardware PMECC. This patch is take <drivers/mtd/nand/nand_spl_simple.c> as reference. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-03-07ppc4xx: Remove 4xx NAND booting supportStefan Roese
As ppc4xx currently only supports the deprecated nand_spl infrastructure and nobody seems to have time / resources to port this over to the newer SPL infrastructure, lets remove NAND booting completely. This should not affect the "normal", non NAND-booting ppc4xx platforms that are currently supported. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Tirumala Marri <tmarri@apm.com> Cc: Matthias Fuchs <matthias.fuchs@esd.eu> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Tested-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2014-03-04mtd: nand: omap: move omap_elm.h from arch/arm/include/asm to drivers/mtd/nandpekon gupta
omap_elm.h is a generic header used by OMAP ELM driver for all TI platfoms. Hence this file should be present in generic folder instead of architecture specific include folder. Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5 Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-03-04mtd: nand: omap: move omap_gpmc.h from arch/arm/include/asm to drivers/mtd/nandpekon gupta
omap_gpmc.h is a generic header used by OMAP NAND driver for all TI platfoms. Hence this file should be present in generic folder instead of architecture specific include folder. Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5 Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-03-04mtd: nand: omap: merge duplicate GPMC data from different arch-xx headers ↵pekon gupta
into common omap_gpmc.h Each SoC platform (AM33xx, OMAP3, OMAP4, OMAP5) has its own copy of GPMC related defines and declarations scattered in SoC platform specific header files like include/asm/arch-xx/cpu.h However, GPMC hardware remains same across all platforms thus this patch merges GPMC data scattered across different arch-xx specific header files into single header file include/asm/arch/omap_gpmc.h Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5 Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-03-03mtd: nand: omap: optimized chip->ecc.correct() for H/W ECC schemespekon gupta
chip->ecc.correct() is used for detecting and correcting bit-flips during read operations. In omap-nand driver it implemented as: (a) omap_correct_data(): for h/w based ECC_HAM1 scheme (b) omap_correct_data_bch() + CONFIG_NAND_OMAP_ECC_BCH8_CODE_HW_DETECTION_SW for ECC_BCH8 scheme using GPMC and software lib/bch.c (c) omap_correct_data_bch() + CONFIG_NAND_OMAP_ECC_BCH8_CODE_HW for ECC_BCH8 scheme using GPMC and ELM This patch updates (c) - checks for calc_ecc[]==0x00 so that error_correction is not required for known good pages. - adds scalability for other ECC_BCHx scheme by merging following omap_rotate_ecc_bch() + omap_fix_errors_bch() => omap_correct_data_bch() - fixing logic for bit-flip correction based on error_loc[count] Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-03-03mtd: nand: omap: optimize chip->ecc.calculate() for H/W ECC schemespekon gupta
chip->ecc.calculate() is used for calculating and fetching of ECC syndrome by processing the data passed during Read/Write accesses. All H/W based ECC schemes use GPMC controller to calculate ECC syndrome. But each BCHx_ECC scheme has its own implemetation of post-processing and fetching ECC syndrome from GPMC controller. This patch updates OMAP_ECC_BCH8_CODE_HW ECC scheme in following way: - merges multiple chip->calculate API for different ECC schemes omap_calculate_ecc() + omap_calculate_ecc_bch() + omap_calculate_ecc_bch_sw() ==> omap_calculate_ecc() - removes omap_ecc_disable() and instead uses it as inline. Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-03-03mtd: nand: omap: optimize chip->ecc.hwctl() for H/W ECC schemespekon gupta
chip->ecc.hwctl() is used for preparing the H/W controller before read/write NAND accesses (like assigning data-buf, enabling ECC scheme configs, etc.) Though all ECC schemes in OMAP NAND driver use GPMC controller for generating ECC syndrome (for both Read/Write accesses). But but in current code HAM1_ECC and BCHx_ECC schemes implement individual function to achieve this. This patch (1) removes omap_hwecc_init() and omap_hwecc_init_bch() as chip->ecc.hwctl will re-initializeGPMC before every read/write call. omap_hwecc_init_bch() -> omap_enable_ecc_bch() (2) merges the GPMC configuration code for all ECC schemes into single omap_enable_hwecc(), thus adding scalability for future ECC schemes. omap_enable_hwecc() + omap_enable_ecc_bch() -> omap_enable_hwecc() Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-02-03driver/ifc:Change accessor function to take care of endiannessPrabhakar Kushwaha
IFC registers can be of type Little Endian or big Endian depending upon Freescale SoC. Here SoC defines the register type of IFC IP. So update acessor functions with common IFC acessor functions to take care both type of endianness. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2014-01-21powerpc:mpc85xx: Add ifc nand boot support for TPL/SPLPo Liu
Using the TPL method for nand boot by sram was already supported. Here add some code for mpc85xx ifc nand boot. - For ifc, elbc, esdhc, espi, all need the SPL without section .resetvec. - Use a clear function name for nand spl boot. - Add CONFIG_SPL_DRIVERS_MISC_SUPPORT to compile the fsl_ifc.c in spl/Makefile; Signed-off-by: Po Liu <Po.Liu@freescale.com> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-17nand, gpmc: fix reading after switching eccJeroen Hofstee
The omap_gpmc allows switching ecc at runtime. Since the NAND_SUBPAGE_READ flag is only set, it is kept when switching to hw ecc, which is not correct. This leads to calling chip->ecc.read_subpage which is not a valid pointer. Therefore clear the flag when switching ecc so reading in hw mode works again. Cc: Scott Wood <scottwood@freescale.com> Cc: Pekon Gupta <pekon@ti.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2013-12-17mtd: nand: omap: fix ecc ops assignment when changing eccNikita Kiryanov
If we change to software ecc and then back to hardware ecc, the nand ecc ops pointers are populated with incorrect function pointers. This is related to the way nand_scan_tail() handles assigning functions to ecc ops: If we are switching to software ecc/no ecc, it assigns default functions to the ecc ops pointers unconditionally, but if we are switching to hardware ecc, the default hardware ecc functions are assigned to ops pointers only if these pointers are NULL (so that drivers could set their own functions). In the case of omap_gpmc.c driver, when we switch to sw ecc, sw ecc functions are assigned to ecc ops by nand_scan_tail(), and when we later switch to hw ecc, the ecc ops pointers are not NULL, so nand_scan_tail() does not overwrite them with hw ecc functions. The result: sw ecc functions used to write hw ecc data. Clear the ecc ops pointers in omap_gpmc.c when switching ecc types, so that ops which were not assigned by the driver will get the correct default values from nand_scan_tail(). Cc: Scott Wood <scottwood@freescale.com> Cc: Pekon Gupta <pekon@ti.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2013-12-17mtd: nand: omap: fix sw->hw->sw ecc switchNikita Kiryanov
When switching ecc mode, omap_select_ecc_scheme() assigns the appropriate values into the current nand chip's ecc.layout struct. This is done under the assumption that the struct exists only to store values, so it is OK to overwrite it, but there is at least one situation where this assumption is incorrect: When switching to 1 bit hamming code sw ecc, the job of assigning layout data is outsourced to nand_scan_tail(), which simply assigns into ecc.layout a pointer to an existing struct prefilled with the appropriate values. This struct doubles as both data and layout definition, and therefore shouldn't be overwritten, but on the next switch to hardware ecc, this is exactly what's going to happen. The next time the user switches to software ecc, they're going to get a messed up ecc layout. Prevent this and possible similar bugs by explicitly using the private-to-omap_gpmc.c omap_ecclayout struct when switching ecc mode. Cc: Scott Wood <scottwood@freescale.com> Cc: Pekon Gupta <pekon@ti.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2013-12-17nand_util.c: Use '%zd' for length in nand_unlock debug printTom Rini
length is size_t so needs to be '%zd' not '%d' to avoid warnings. Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Tom Rini <trini@ti.com>
2013-12-17mtd: nand: omap: fix HAM1_SW ecc using default value for ecc.sizeNikita Kiryanov
Commit "mtd: nand: omap: enable BCH ECC scheme using ELM for generic platform" (d016dc42cedbf6102e100fa9ecb58462edfb14f8) changed the way software ECC is configured, both during boot, and during ecc switch, in a way that is not backwards compatible with older systems: Older version of omap_gpmc.c always assigned ecc.size = 0 when configuring for software ecc, relying on nand_scan_tail() to select a default for ecc.size (256), while the new version of omap_gpmc.c assigns ecc.size = pagesize, which is likely to not be 256. Since 1 bit hamming sw ecc is only meant to be used by legacy devices, revert to the original behavior. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Tom Rini <trini@ti.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Pekon Gupta <pekon@ti.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Pekon Gupta <pekon@ti.com>
2013-12-17mtd: nand: omap_gpmc: cosmetic: Fix indentationStefan Roese
Signed-off-by: Stefan Roese <sr@denx.de> Cc: Pekon Gupta <pekon@ti.com> Cc: Scott Wood <scottwood@freescale.com> [scottwood@freescale.com: wrap some long lines] Signed-off-by: Scott Wood <scottwood@freescale.com>
2013-12-17mtd: nand: omap: fix ecc-layout for HAM1 ecc-schemepekon gupta
As per OMAP3530 TRM referenced below [1] For large-page NAND, ROM code expects following ecc-layout for HAM1 ecc-scheme - OOB[1] (offset of 1 *byte* from start of OOB) for x8 NAND device - OOB[2] (offset of 1 *word* from start of OOB) for x16 NAND device Thus ecc-layout expected by ROM code for HAM1 ecc-scheme is: *for x8 NAND Device* +--------+---------+---------+---------+---------+---------+---------+ | xxxx | ECC[A0] | ECC[A1] | ECC[A2] | ECC[B0] | ECC[B1] | ECC[B2] | ... +--------+---------+---------+---------+---------+---------+---------+ *for x16 NAND Device* +--------+--------+---------+---------+---------+---------+---------+---------+ | xxxxx | xxxxx | ECC[A0] | ECC[A1] | ECC[A2] | ECC[B0] | ECC[B1] | ECC[B2] | +--------+--------+---------+---------+---------+---------+---------+---------+ This patch fixes ecc-layout *only* for HAM1, as required by ROM-code For other ecc-schemes like (BCH8) ecc-layout is same for x8 or x16 devices. [1] OMAP3530: http://www.ti.com/product/omap3530 TRM: http://www.ti.com/litv/pdf/spruf98x Chapter-25: Initialization Sub-topic: Memory Booting Section: 25.4.7.4 NAND Figure 25-19. ECC Locations in NAND Spare Areas Reported-by: Stefan Roese <sr@denx.de> Signed-off-by: Pekon Gupta <pekon@ti.com> Tested-by: Stefan Roese <sr@denx.de>
2013-12-13drivers/mtd: descend into sub directories only when it is necessaryMasahiro Yamada
2013-12-10Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/armv7/rmobile/Makefile doc/README.scrapyard Needed manual fix: arch/arm/cpu/armv7/omap-common/Makefile board/compulab/cm_t335/u-boot.lds
2013-12-09at91: nand: switch atmel_nand to generic GPIO APIAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de> Tested-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de> Acked-by: Scott Wood <scottwood@freescale.com>
2013-12-02Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2013-11-25Driver/IFC: Move Freescale IFC driver to a common driverYork Sun
Freescale IFC controller has been used for mpc8xxx. It will be used for ARM-based SoC as well. This patch moves the driver to driver/misc and fix the header file includes. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-21mtd: nand: omap: add CONFIG_NAND_OMAP_ECCSCHEME for selection of ecc-schemepekon gupta
This patch adds new CONFIG_NAND_OMAP_ECCSCHEME, replacing other distributed CONFIG_xx used for selecting NAND ecc-schemes. This patch aims at solving following issues. 1) Currently ecc-scheme is tied to SoC platform, which prevents user to select other ecc-schemes also supported in hardware. like; - most of OMAP3 SoC platforms use only 1-bit Hamming ecc-scheme, inspite the fact that they can use higher ecc-schemes like 8-bit ecc-schemes with software based error detection (OMAP_ECC_BCH4_CODE_HW_DETECTION_SW). - most of AM33xx SoC plaforms use 8-bit BCH ecc-scheme for now, but hardware supports BCH16 ecc-scheme also. 2) Different platforms use different CONFIG_xx to select ecc-schemes, which adds confusion for user while migrating platforms. - *CONFIG_NAND_OMAP_ELM* which enables ELM hardware engine, selects only 8-bit BCH ecc-scheme with h/w based error-correction (OMAP_ECC_BCH8_CODE_HW) whereas ELM hardware engine supports other ecc-schemes also like; BCH4, and BCH16 (in future). - *CONFIG_NAND_OMAP_BCH8* selects 8-bit BCH ecc-scheme with s/w based error correction (OMAP_ECC_BCH8_CODE_HW_DETECTION_SW). - *CONFIG_SPL_NAND_SOFTECC* selects 1-bit Hamming ecc-scheme using s/w library Thus adding new *CONFIG_NAND_OMAP_ECCSCHEME* de-couples ecc-scheme dependency on SoC platform and NAND driver. And user can select ecc-scheme independently foreach board. However, selection some hardware based ecc-schemes (OMAP_ECC_BCHx_CODE_HW) still depends on presence of ELM hardware engine on SoC. (Refer doc/README.nand) Signed-off-by: Pekon Gupta <pekon@ti.com>
2013-11-21mtd: nand: omap: enable BCH ECC scheme using ELM for generic platformpekon gupta
BCH8_ECC scheme implemented in omap_gpmc.c driver has following favours +-----------------------------------+-----------------+-----------------+ |ECC Scheme | ECC Calculation | Error Detection | +-----------------------------------+-----------------+-----------------+ |OMAP_ECC_BCH8_CODE_HW |GPMC |ELM H/W engine | |OMAP_ECC_BCH8_CODE_HW_DETECTION_SW |GPMC |S/W BCH library | +-----------------------------------+-----------------+-----------------+ Current implementation limits the BCH8_CODE_HW only for AM33xx device family. (using CONFIG_AM33XX). However, other SoC families (like TI81xx) also have ELM hardware module, and can support ECC error detection using ELM. This patch - removes CONFIG_AM33xx Thus this driver can be reused by all devices having ELM h/w engine. - adds omap_select_ecc_scheme() A common function to handle ecc-scheme related configurations. This can be used both during device-probe and via user-space u-boot commads to change ecc-scheme. During device probe ecc-scheme is selected based on CONFIG_NAND_OMAP_ELM or CONFIG_NAND_OMAP_BCH8 - enables CONFIG_BCH S/W library (lib/bch.c) required by OMAP_ECC_BCHx_CODE_HW_DETECTION_SW is enabled by CONFIG_BCH. - enables CONFIG_SYS_NAND_ONFI_DETECTION for auto-detection of ONFI compliant NAND devices - updates following README doc doc/README.nand board/ti/am335x/README doc/README.omap3 Signed-off-by: Pekon Gupta <pekon@ti.com> [scottwood@freescale.com: fixed unused variable warning] Signed-off-by: Scott Wood <scottwood@freescale.com>
2013-11-21mtd: nand: omap: make am33xx/elm.c as common driver for all OMAPx and AMxxxx ↵pekon gupta
platforms ELM hardware engine which is used for ECC error detection, is present on all latest OMAP SoC (like OMAP4xxx, OMAP5xxx, DRA7xxx, AM33xx, AM43xx). Thus ELM driver should be moved to common drivers/mtd/nand/ folder so that all SoC having on-chip ELM hardware engine can re-use it. This patch has following changes: - mv arch/arm/include/asm/arch-am33xx/elm.h arch/arm/include/asm/omap_elm.h - mv arch/arm/cpu/armv7/am33xx/elm.c drivers/mtd/nand/omap_elm.c - update Makefiles - update #include <asm/elm.h> - add CONFIG_NAND_OMAP_ELM to compile driver/mtd/nand/omap_elm.c and include in all board configs using AM33xx SoC platform. Signed-off-by: Pekon Gupta <pekon@ti.com>
2013-11-21mtd: atmel_nand: use dev_xxx instead of printkWu, Josh
Signed-off-by: Josh Wu <josh.wu@atmel.com>
2013-11-21mtd: atmel_nand: don't print bit correction message in driverWu, Josh
Since for some MLC nand, bit errors happened too often. Just disable it to avoid noise Signed-off-by: Josh Wu <josh.wu@atmel.com>
2013-11-21mtd: atmel_nand: enable PMECC support for 8k bytes page NAND flashWu, Josh
increase the delay to 75us to support the 8k bytes page nand flash Signed-off-by: Josh Wu <josh.wu@atmel.com>
2013-11-21mtd/ifc: Add support of 8K page size NAND flashPrabhakar Kushwaha
Current IFC driver supports till 4K page size NAND flash. Add support of 8K NAND flash - Program Spare region size in csor_ext - Add nand_ecclayout for 4 bit & 8 bit ecc - Defines constants - Add support of 8K NAND boot. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> CC: Liu Po <po.liu@freescale.com>
2013-11-13driver/mtd/ifc: Read Status while programming NAND flashPrabhakar Kushwaha
as per controller description, "While programming a NAND flash, status read should never skipped. Because it may happen that a new command is issued to the NAND Flash, even when the device has not yet finished processing the previous request. This may result in unpredictable behaviour." IFC controller never polls for R/B signal after command send. It just return control to software. This behaviour may not occur with NAND flash access. because new commands are sent after polling R/B signal. But it may happen in scenario where GPCM-ASIC and NAND flash device are working simultaneously. Update the controller driver to take care of this requirement Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2013-11-13MTD: atmel_nand: support for software BCH ECCBo Shen
Add possible to use software BCH ECC for atmel nand driver Signed-off-by: Bo Shen <voice.shen@gmail.com>
2013-11-09Merge branch 'iu-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile board/compulab/cm_t35/Makefile board/corscience/tricorder/Makefile board/ppcag/bg0900/Makefile drivers/bootcount/Makefile include/configs/omap4_common.h include/configs/pdnb3.h Makefile conflicts are due to additions/removals of object files on the ARM branch vs KBuild introduction on the main branch. Resolution consists in adjusting the list of object files in the main branch version. This also applies to two files which are not listed as conflicting but had to be modified: board/compulab/common/Makefile board/udoo/Makefile include/configs/omap4_common.h conflicts are due to the OMAP4 conversion to ti_armv7_common.h on the ARM side, and CONFIG_SYS_HZ removal on the main side. Resolution is to convert as this icludes removal of CONFIG_SYS_HZ. include/configs/pdnb3.h is due to a removal on ARM side. Trivial resolution is to remove the file. Note: 'git show' will also list two files just because they are new: include/configs/am335x_igep0033.h include/configs/omap3_igep00x0.h
2013-11-01nand, davinci: add special UBL ecc positionHeiko Schocher
enable the RBL/UBL ECC layout through CONFIG_NAND_6BYTES_OOB_FREE_10BYTES_ECC define see for more info: http://processors.wiki.ti.com/index.php/DM365_Nand_ECC_layout Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Scott Wood <scottwood@freescale.com>
2013-10-31drivers: mtd: convert makefiles to Kbuild styleMasahiro Yamada
2013-10-31nand_util.c: Correct licensingTom Rini
Prior to SPDX licensing this file was GPL-2.0 with Freescale granting rights for "or later" for their contributed code. We incorrectly moved this file to GPL-2.0+, so correct it to GPL-2.0. In addition we cannot easily denote in the file where or what code is "or later", so just set that aside for now and the file as a whole is GPL-2.0 regardless. Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Tom Rini <trini@ti.com>
2013-10-24mtd/fsl_elbc: take NAND_ECC_SOFT_BCH config option into accountValentin Longchamp
NAND_ECC_SOFT was the only option available while the SOFT_BCH option may also be used. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-by: Scott Wood <scottwood@freescale.com>
2013-10-14Coding Style cleanup: remove trailing empty linesWolfgang Denk
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-10-09mtd: driver _read() returns max_bitflips; mtd_read() returns -EUCLEANPaul Burton
Linux modified the MTD driver interface in commit edbc4540 (with the same name as this commit). The effect is that calls to mtd_read will not return -EUCLEAN if the number of ECC-corrected bit errors is below a certain threshold, which defaults to the strength of the ECC. This allows -EUCLEAN to stop indicating "some bits were corrected" and begin indicating "a large number of bits were corrected, the data held in this region of flash may be lost soon". UBI makes use of this and when -EUCLEAN is returned from mtd_read it will move data to another block of flash. Without adopting this interface change UBI on U-boot attempts to move data between blocks every time a single bit is corrected using the ECC, which is a very common occurance on some devices. For some devices where bit errors are common enough, UBI can get stuck constantly moving data around because each block it attempts to use has a single bit error. This condition is hit when wear_leveling_worker attempts to move data from one PEB to another in response to an -EUCLEAN/UBI_IO_BITFLIPS error. When this happens ubi_eba_copy_leb is called to perform the data copy, and after the data is written it is read back to check its validity. If that read returns UBI_IO_BITFLIPS (in response to an MTD -EUCLEAN) then ubi_eba_copy_leb returns 1 to wear_leveling worker, which then proceeds to schedule the destination PEB for erasure. This leads to erase_worker running on the PEB, and following a successful erase wear_leveling_worker is called which begins this whole cycle all over again. The end result is that (without UBI debug output enabled) the boot appears to simply hang whilst in reality U-boot busily works away at destroying a block of the NAND flash. Debug output from this situation: UBI DBG: ensure_wear_leveling: schedule scrubbing UBI DBG: wear_leveling_worker: scrub PEB 1027 to PEB 4083 UBI DBG: ubi_io_read_vid_hdr: read VID header from PEB 1027 UBI DBG: ubi_io_read: read 4096 bytes from PEB 1027:4096 UBI DBG: ubi_eba_copy_leb: copy LEB 0:0, PEB 1027 to PEB 4083 UBI DBG: ubi_eba_copy_leb: read 1040384 bytes of data UBI DBG: ubi_io_read: read 1040384 bytes from PEB 1027:8192 UBI: fixable bit-flip detected at PEB 1027 UBI DBG: ubi_io_write_vid_hdr: write VID header to PEB 4083 UBI DBG: ubi_io_write: write 4096 bytes to PEB 4083:4096 UBI DBG: ubi_io_read_vid_hdr: read VID header from PEB 4083 UBI DBG: ubi_io_read: read 4096 bytes from PEB 4083:4096 UBI DBG: ubi_io_write: write 4096 bytes to PEB 4083:8192 UBI DBG: ubi_io_read: read 4096 bytes from PEB 4083:8192 UBI: fixable bit-flip detected at PEB 4083 UBI DBG: schedule_erase: schedule erasure of PEB 4083, EC 55, torture 0 UBI DBG: erase_worker: erase PEB 4083 EC 55 UBI DBG: sync_erase: erase PEB 4083, old EC 55 UBI DBG: do_sync_erase: erase PEB 4083 UBI DBG: sync_erase: erased PEB 4083, new EC 56 UBI DBG: ubi_io_write_ec_hdr: write EC header to PEB 4083 UBI DBG: ubi_io_write: write 4096 bytes to PEB 4083:0 UBI DBG: ensure_wear_leveling: schedule scrubbing UBI DBG: wear_leveling_worker: scrub PEB 1027 to PEB 4083 ... This patch adopts the interface change as in Linux commit edbc4540 in order to avoid such situations. Given that none of the drivers under drivers/mtd return -EUCLEAN, this should only affect those using software ECC. I have tested that it works on a board which is currently out of tree, but which I hope to be able to begin upstreaming soon. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Stefan Roese <sr@denx.de>
2013-09-11mxs_nand: Fix ECC strength for NAND flash with OOB size of 224Elie De Brauwer
On a board with an i.mx28 and a Micron MT29F4G08ABAEAH4, Linux says: NAND device: Manufacturer ID: 0x2c, Chip ID: 0xdc (Micron MT29F4G08ABAEAH4), 512MiB, page size: 4096, OOB size: 224) the ECC strength is 16. root@(none):/sys/devices/virtual/mtd/mtd0# for i in ecc_strength oobsize subpagesize; do echo $i = `cat $i`; done ecc_strength = 16 oobsize = 224 subpagesize = 4096 The ECC strength was not properly discovered by U-Boot causing the data written by Linux to return an -74 (EBADMSG) when read from U-Boot. This patch fixes mxs_nand_get_ecc_strength() to function in case of a NAND flash with page_data_size = 4096 and page_oob_size= 224. Signed-off-by: Elie De Brauwer <eliedebrauwer@gmail.com> Acked-by: Scott Wood <scottwood@freescale.com>
2013-09-04mtd: atmel_nand: pmecc: fix bug fail to correct bit error in 1024-bytes sectorWu, Josh
The PMECC use BCH algorithm to correct error. In BCH algorithm, the primitive polynomial value is GF(2^13) for 512-bytes sector size. And it is GF(2^14) for 1024-bytes sector size. This patch will choose correct degree of the remainders (13 or 14) for different sector size. Tested in AT91SAM9X5-EK with MLC nand flash. More detail can be refered to section 5.4.1 of: AT91SAM ARM-based Embedded MPU Application Note <http://www.atmel.com/Images/doc11127.pdf> Signed-off-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-09-04Merge branch 'u-boot-atmel/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-08-22nand_util: delete a useless variableMasahiro Yamada
2013-08-22ARM: at91: atmel_nand: add code to check the ONFI parameter ECC requirementWu, Josh
1. if CONFIG_SYS_NAND_ONFI_DETECTION is defined, driver will check NAND flash's ecc minimum requirement in ONFI parameter. a) if CONFIG_PMECC_CAP, CONFIG_PMECC_SECTOR_SIZE are defined. then use it. Driver will display a WARNING if the values are different from ONFI parameters. b) if CONFIG_PMECC_CAP, CONFIG_PMECC_SECTOR_SIZE are not defined, then use the value from ONFI parameters. * If ONFI ECC parameters are in ONFI extended parameter page, since we are not support it, so assume the minimum ecc requirement is 2 bits in 512 bytes. * For non-ONFI support nand flash, also assume the minimum ecc requirement is 2 bits in 512 bytes. 2. if CONFIG_SYS_NAND_ONFI_DETECTION is not defined, just use CONFIG_PMECC_CAP and CONFIG_PMECC_SECTOR_SIZE. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-08-22mtd: atmel_nand: alloc memory instead of use static array for pmecc dataWu, Josh
In this way, the pmecc corraction capbility can change in run time. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-08-22ARM: at91: atmel_nand: pmecc driver will select the galois table by sector sizeWu, Josh
Define the galois index table offset in chip head file. So user do not need to set by himself. Driver will set it correctly according to sector_size. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Scott Wood <scottwood@freescale.com> [rebased on master] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-08-20powerpc: p1022ds: add TPL for p1022ds nand bootYing Zhang
TPL is introduced in the patch "NAND: TPL : introduce the TPL based on the SPL", here enable TPL for p1022ds nand boot. Signed-off-by: Ying Zhang <b40530@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-07-12mtd: mxc_nand: Fix crash after MTD resyncMarek Vasut
The driver triggered a BUG() in nand_base.c:3214/nand_scan_tail() because the ecc.strength was not set in NAND_ECC_HW_SYNDROME ECC mode. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Benoit Thebaudeau <benoit.thebaudeau@advansee.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
