This patch adds the support of the WP# signal. WP will be disabled
before the first access to the NAND flash.
Signed-off-by: Christophe Kerello <christophe.kerello@foss.st.com>
Reviewed-by: Patrice Chotard <patrice.chotard@foss.st.com>
We only include <linux/mtd/rawnand.h> in <nand.h> for the forward
declaration of struct nand_chip, so do that directly. Then, include
<linux/mtd/rawnand.h> where required directly.
nand_dt_init() is still using fdtdec_xx() interface.
If OF_LIVE flag is enabled, dt property can't be get anymore.
Updating all fdtdec_xx() interface to ofnode_xx() to solve this issue.
For doing this, node parameter type must be ofnode.
First idea was to convert "node" parameter to ofnode type inside
nand_dt_init() using offset_to_ofnode(node). But offset_to_ofnode()
is not bijective, in case OF_LIVE flag is enabled, it performs an assert().
So, this leads to update nand_chip struct flash_node field from int to
ofnode and to update all nand_dt_init() callers.
Signed-off-by: Patrice Chotard <patrice.chotard@foss.st.com>
Change pr_* to dev_ or log_ macro and define LOG_CATEGORY.
Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
In the spirit of using the same base name for all of these related macros,
rename this to have the operation at the end. This is not widely used so
the impact is fairly small.
This construct is quite long-winded. In earlier days it made some sense
since auto-allocation was a strange concept. But with driver model now
used pretty universally, we can shorten this to 'auto'. This reduces
verbosity and makes it easier to read.
Coincidentally it also ensures that every declaration is on one line,
thus making dtoc's job easier.
FMC2 EBI support has been added. Common resources (registers base
address and clock) can now be shared between the 2 drivers using
"st,stm32mp1-fmc2-nfc" compatible string. It means that the
common resources should now be found in the parent device when EBI
node is available.
Signed-off-by: Christophe Kerello <christophe.kerello@st.com>
This patch uses clrsetbits_le32 function instead of multiple instructions.
This patch removes custom macros and uses FIELD_PREP and FIELD_GET macros.
relevant
This patch renames functions and local variables.
This cleanup is done to get all functions starting by stm32_fmc2_nfc
in the FMC2 raw NAND driver when all functions will start by
stm32_fmc2_ebi in the FMC2 EBI driver.
FMC2_TIMEOUT_5S will be used each time that we need to wait.
It was seen, during stress tests in an overloaded system,
that we could be close to 1 second, even if we never met this
value. To be safe, FMC2_TIMEOUT_MS is set to 5 seconds.
Remove inline comments that are useless since function label are
self explanatory.
The chip select defined in the device tree could only be 0 or 1.
Move this uncommon header out of the common header.
Move this header out of the common header.
At present devres.h is included in all files that include dm.h but few
make use of it. Also this pulls in linux/compat which adds several more
headers. Drop the automatic inclusion and require files to include devres
themselves. This provides a good indication of which files use devres.
Reviewed-by: Anatolij Gustschin <agust@denx.de>
This patch solves warnings detected by setting W=1 when building.
Warnings type detected:
- [-Wsign-compare]
- [-Wtype-limits]
The driver adds the support for the STMicroelectronics FMC2 NAND
Controller found on STM32MP SOCs.
This patch adds the polling mode, a basic mode that do not need
any DMA channels.
Only NAND_ECC_HW mode is actually supported.
The driver supports a maximum 8k page size.
The following ECC strength and step size are currently supported:
- nand-ecc-strength = <8>, nand-ecc-step-size = <512> (BCH8)
- nand-ecc-strength = <4>, nand-ecc-step-size = <512> (BCH4)
- nand-ecc-strength = <1>, nand-ecc-step-size = <512> (Extended ECC
based on Hamming)
This patch has been tested on Micron MT29F8G08ABACAH4.
