Enable nand lock, unlock and status of lock feature.
Not every device and platform requires this, hence,
it is under define for CONFIG_CMD_NAND_LOCK_UNLOCK
Nand unlock and status operate on block boundary instead
of page boundary. Details in:
http://www.micron.com/products/partdetail?part=MT29C2G24MAKLAJG-6%20IT
Intial solution provided by Vikram Pandita <vikram.pandita@ti.com>
Includes preliminary suggestions from Scott Wood
Signed-off-by: Nishanth Menon <nm@ti.com>
This caused the operation to be needlessly repeated if there were
no bad blocks and no errors.
Signed-off-by: Valeriy Glushkov <gvv@lstec.com>
As reported by Ilko Iliev <iliev@ronetix.at>, the "nand erase clean"
command is currently broken, and among other things causes all blocks
to be marked bad.
This implements it properly using MTD_OOB_AUTO, along with some
indentation fixes.
rename CFG_NAND_LEGACY to CONFIG_NAND_LEGACY
Implement block-skipping read/write, based on a patch from
Morten Ebbell Hestens <morten.hestnes@tandberg.com>.
Signed-off-by: Morten Ebbell Hestnes <morten.hestnes@tandberg.com>
Signed-off-by: William Juul <william.juul@tandberg.com>
A lot changed in the Linux MTD code, since it was last ported from
Linux to U-Boot. This patch takes U-Boot NAND support to the level
of Linux 2.6.22.1 and will enable support for very large NAND devices
(4KB pages) and ease the compatibility between U-Boot and Linux
filesystems.
This patch is tested on two custom boards with PPC and ARM
processors running YAFFS in U-Boot and Linux using gcc-4.1.2
cross compilers.
MAKEALL ppc/arm has some issues:
* DOC/OneNand/nand_spl is not building (I have not tried porting
these parts, and since I do not have any HW and I am not familiar
with this code/HW I think its best left to someone else.)
Except for the issues mentioned above, I have ported all drivers
necessary to run MAKEALL ppc/arm without errors and warnings. Many
drivers were trivial to port, but some were not so trivial. The
following drivers must be examined carefully and maybe rewritten to
some degree:
cpu/ppc4xx/ndfc.c
cpu/arm926ejs/davinci/nand.c
board/delta/nand.c
board/zylonite/nand.c
Signed-off-by: Stig Olsen <stig.olsen@tandberg.com>
This patch fixes NAND related printf format warning. Those warnings are
now visible since patch dc4b0b38d4aadf08826f6c31270f1eecd27964fd
[Fix printf errors.] by Andrew Klossner has been applied. Thanks, this is
really helpful.
For NAND erase sizes smaller than one NAND erase block, erase
percentage output becomes grater than 100% e.g.
-- cut --
> nand info
Device 0: NAND 64MiB 1,8V 8-bit, sector size 16 KiB
> nand erase 0x100000 0x2000
NAND erase: device 0 offset 0x100000, size 0x2000
Erasing at 0x100000 -- 200% complete.
OK
-- cut --
Correct this and give user a warning that more is erased than specified:
-- cut --
Warning: Erase size 0x00002000 smaller than one erase block 0x00004000
Erasing 0x00004000 instead
Erasing at 0x100000 -- 100% complete.
OK
-- cut --
Signed-off-by: Dirk Behme <dirk.behme@gmail.com>
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
