path: root/drivers/mtd/nand/nand_bbt.c
2010-10-11nand: remove dead code and suspend/resumeScott Wood
Get rid of the several "#if 0" sections that were keeping around Linux code that isn't relevant to U-Boot. Besides cluttering the code, these sections make tracking upstream changes harder, rather than easier. It's easy to discard obviously irrelevant diff hunks that patch rejects, but it's not as easy to notice hunks that apply cleanly to the #if 0 section, but *are* relevant to U-Boot and require modification elsewhere. Also remove suspend/resume, as this is not applicable to U-Boot. Removal saves 232 bytes on powerpc. Signed-off-by: Scott Wood <scottwood@freescale.com> Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
2009-11-13NAND: Update to support 64 bit device sizeSandeep Paulraj
This patch adds support for NANDs greater than 2 GB. Patch is based on the MTD NAND driver in the kernel. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-10-29NAND: sync with 2.6.27Scott Wood
This brings the core NAND code up to date with the Linux kernel. Since there were several drivers in Linux as of the last update that are not in u-boot, I'm not bringing over new drivers that have been added since in the absence of an interested party. I did not update OneNAND since it was recently synced by Kyungmin Park, and I'm not sure exactly what the common ancestor is. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-13drivers/mtd/nand: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
rename CFG_NAND_LEGACY to CONFIG_NAND_LEGACY Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-08-12NAND: Make NAND driver less verbose per defaultStefan Roese
This patch turns off printing of bad blocks per default upon bootup. This can always be shown via the "nand bad" command later. Signed-off-by: Stefan Roese <sr@denx.de>
2008-08-12Update MTD to that of Linux 2.6.22.1William Juul
A lot changed in the Linux MTD code, since it was last ported from Linux to U-Boot. This patch takes U-Boot NAND support to the level of Linux 2.6.22.1 and will enable support for very large NAND devices (4KB pages) and ease the compatibility between U-Boot and Linux filesystems. This patch is tested on two custom boards with PPC and ARM processors running YAFFS in U-Boot and Linux using gcc-4.1.2 cross compilers. MAKEALL ppc/arm has some issues: * DOC/OneNand/nand_spl is not building (I have not tried porting these parts, and since I do not have any HW and I am not familiar with this code/HW I think its best left to someone else.) Except for the issues mentioned above, I have ported all drivers necessary to run MAKEALL ppc/arm without errors and warnings. Many drivers were trivial to port, but some were not so trivial. The following drivers must be examined carefully and maybe rewritten to some degree: cpu/ppc4xx/ndfc.c cpu/arm926ejs/davinci/nand.c board/delta/nand.c board/zylonite/nand.c Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Stig Olsen <stig.olsen@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-07-09NAND: Rename DEBUG to MTDDEBUG to avoid namespace pollution.Scott Wood
This is particularly problematic now that non-NAND-specific code is including <nand.h>, and thus all debugging code is being compiled regardless of whether it was requested, as reported by Scott McNutt <smcnutt@psyent.com>. Signed-off-by: Scott Wood <scottwood@freescale.com>
2007-11-25drivers/mtd : move mtd drivers to drivers/mtdJean-Christophe PLAGNIOL-VILLARD
