NAND flavors, like serial and parallel, have a lot in common and would
benefit to share code. Let's move raw (parallel) NAND specific code in a
raw/ subdirectory, to ease the addition of a core file in nand/ and the
introduction of a spi/ subdirectory specific to SPI NANDs.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Some MTD sublayers/drivers are implementing ->_read/write_oob() and
provide dummy wrappers for their ->_read/write() implementations.
Let the core handle this case instead of duplicating the logic.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Acked-by: Brian Norris <computersforpeace@gmail.com>
Reviewed-by: Miquel Raynal <miquel.raynal@free-electrons.com>
Tested-by: Ladislav Michl <ladis@linux-mips.org>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Convert the EINVAL error into ENOTSUPP when the GET/SET_FEATURES
is not supported.
Signed-off-by: Mylène Josserand <mylene.josserand@bootlin.com>
Acked-by: Jagan Teki <jagan@openedev.com>
`nand_get_flash_type()` allows identification of supported NAND flashs.
The function is useful in SPL (like mxs_nand_spl.c) to lookup for a NAND
flash (which does not support ONFi) instead of using nand_simple.c and
hard-coding all required NAND parameters.
Signed-off-by: Jörg Krause <joerg.krause@embedded.rocks>
This header was renamed to rawnand.h in Linux.
The following is the corresponding commit in Linux.
commit d4092d76a4a4e57b65910899948a83cc8646c5a5
Author: Boris Brezillon <boris.brezillon@free-electrons.com>
Date: Fri Aug 4 17:29:10 2017 +0200
mtd: nand: Rename nand.h into rawnand.h
We are planning to share more code between different NAND based
devices (SPI NAND, OneNAND and raw NANDs), but before doing that
we need to move the existing include/linux/mtd/nand.h file into
include/linux/mtd/rawnand.h so we can later create a nand.h header
containing all common structure and function prototypes.
Several drivers check ->chipsize to see if the third row address cycle
is needed. Instead of embedding magic sizes such as 32MB, 128MB in
drivers, introduce a new flag NAND_ROW_ADDR_3 for clean-up. Since
nand_scan_ident() knows well about the device, it can handle this
properly. The flag is set if the row address bit width is greater
than 16.
Delete comments such as "One more address cycle for ..." because
intention is now clear enough from the code.
Acked-by: Wenyou Yang <wenyou.yang@microchip.com>
[Linux commit: 14157f861437ebe2d624b0a845b91bbdf8ca9a2d]
Driver are responsible for setting up ECC parameters correctly.
Those include:
- Check if ECC parameters specified (usually by DT) are valid
- Meet the chip's ECC requirement
- Maximize ECC strength if NAND_ECC_MAXIMIZE flag is set
The logic can be generalized by factoring out common code.
This commit adds 3 helpers to the NAND framework:
nand_check_ecc_caps - Check if preset step_size and strength are valid
nand_match_ecc_req - Match the chip's requirement
nand_maximize_ecc - Maximize the ECC strength
To use the helpers above, a driver needs to provide:
- Data array of supported ECC step size and strength
- A hook that calculates ECC bytes from the combination of
step_size and strength.
By using those helpers, code duplication among drivers will be
reduced.
[Linux commit: 2c8f8afa7f92acb07641bf95b940d384ed1d0294]
Some NAND controllers can assign different NAND timings to different
CS lines. Pass the CS line information to ->setup_data_interface() so
that the NAND controller driver knows which CS line is concerned by
the setup_data_interface() request.
[Linux commit: 104e442a67cfba4d0cc982384761befb917fb6a1]
In some cases, nand_do_{read,write}_ops is passed with unaligned
ops->datbuf. Drivers using DMA will be unhappy about unaligned
buffer.
The new struct member, buf_align, represents the minimum alignment
the driver require for the buffer. If the buffer passed from the
upper MTD layer does not have enough alignment, nand_do_*_ops will
use bufpoi.
[Linux commit: 477544c62a84d3bacd9f90ba75ffc16c04d78071]
NAND_ECC_CUSTOM_PAGE_ACCESS
Drivers setting NAND_ECC_CUSTOM_PAGE_ACCESS are supposed to handle the
full read/write page sequence, and waiting for a page to actually be
programmed is part of this write-page sequence.
This is also what is done in ->write_oob_xxx() hooks, so let's do that in
->write_page_xxx() as well to make it consistent.
[Linux commit: 41145649f4acb30249b636b945053db50c9331c5]
[masahiro:
There is no driver setting NAND_ECC_CUSTOM_PAGE_ACCESS in U-Boot.
No driver is affected by this change.]
The ->errstat() hook is no longer implemented NAND controller drivers.
Get rid of it before someone starts abusing it.
[Linux commit: 7d135bcced20be2b50128432c5426a7278ec4f6d]
[masahiro: modify davinci_nand.c for U-Boot]
Cached programming is always skipped, so drop the associated code until
we decide to really support it.
[Linux commit: 0b4773fd1649e0d418275557723a7ef54f769dc9]
If your controller already sends the required NAND commands when
reading or writing a page, then the framework is not supposed to
send READ0 and SEQIN/PAGEPROG respectively.
Signed-off-by: Marc Gonzalez <marc_gonzalez@sigmadesigns.com>
[Linux commit: 3371d663bb4579f1b2003a92162edd6d90edd089]
When changing from one data interface setting to another, one has to
ensure a specific sequence which is described in the ONFI spec.
One of these constraints is that the CE line has go high after a reset
before a command can be sent with the new data interface setting, which
is not guaranteed by the current implementation.
Rework the nand_reset() function and all the call sites to make sure the
CE line is asserted and released when required.
Also make sure to actually apply the new data interface setting on the
first die.
Fixes: d8e725dd8311 ("mtd: nand: automate NAND timings selection")
Reviewed-by: Sascha Hauer <s.hauer@pengutronix.de>
Tested-by: Marc Gonzalez <marc_gonzalez@sigmadesigns.com>
[Linux commit: 73f907fd5fa56b0066d199bdd7126bbd04f6cd7b]
The NAND framework provides several helpers to query timing modes supported
by a NAND chip, but this implies that all NAND controller drivers have
to implement the same timings selection dance. Also currently NAND
devices can be resetted at arbitrary places which also resets the timing
for ONFI chips to timing mode 0.
Provide a common logic to select the best timings based on ONFI or
->onfi_timing_mode_default information. Hook this into nand_reset()
to make sure the new timing is applied each time during a reset.
NAND controller willing to support timings adjustment should just
implement the ->setup_data_interface() method.
[Linux commit: d8e725dd831186a3595036b2b1df9f68cbc6efa3]
When NAND devices are resetted some initialization may have to be done,
like for example they have to be configured for the timing mode that
shall be used. To get a common place where this initialization can be
implemented create a nand_reset() function. This currently only issues
a NAND_CMD_RESET to the NAND device. The places issuing this command
manually are replaced with a call to nand_reset().
[Linux commit: 2f94abfe35b210e7711af9202a3dcfc9e779219a]
The generic NAND DT bindings allows one to tweak the ECC strength and
step size to their need. It can be used to lower the ECC strength to
match a bootloader/firmware config, but might also be used to get a better
reliability.
In the latter case, the user might want to use the maximum ECC strength
without having to explicitly calculate the exact value (this value not
only depends on the OOB size, but also on the NAND controller, and can
be tricky to extract).
Add a generic 'nand-ecc-maximize' DT property and the associated
NAND_ECC_MAXIMIZE flag, to let ECC controller drivers select the best
ECC strength and step-size on their own.
Acked-by: Rob Herring <robh@kernel.org>
[Linux commit: ba78ee00e1ff84de9b3ad33edbd3ec599099ee82]
[masahiro: of_property_read_bool -> fdt_getprop for U-Boot]
Same macros are defined in various places. Collect them into
include/linux/bitops.h like Linux.
Set Features (0xEF) command toggles the R/B# pin after 4 sub feature
parameters are written.
Currently, nand_command(_lp) calls chip->dev_ready immediately after
the address cycle because NAND_CMD_SET_FEATURES falls into default:
label. No wait is needed at this point.
If you see nand_onfi_set_features(), R/B# is already cared by the
chip->waitfunc call.
[ Linux commit: c5d664aa5a4c4b257a54eb35045031630d105f49 ]
Read ID (0x90) command does not toggle the R/B# pin. Without this
patch, NAND_CMD_READID falls into the default: label, then R/B# is
checked by chip->dev_ready().
[ Linux commit: 3158fa0e739615769cc047d2428f30f4c3b6640e ]
The architecture is currently unmaintained, remove.
Cc: Benjamin Matthews <mben12@gmail.com>
Cc: Chong Huang <chuang@ucrobotics.com>
Cc: Dimitar Penev <dpn@switchfin.org>
Cc: Haitao Zhang <hzhang@ucrobotics.com>
Cc: I-SYST Micromodule <support@i-syst.com>
Cc: M.Hasewinkel (MHA) <info@ssv-embedded.de>
Cc: Martin Strubel <strubel@section5.ch>
Cc: Peter Meerwald <devel@bct-electronic.com>
Cc: Sonic Zhang <sonic.adi@gmail.com>
Cc: Valentin Yakovenkov <yakovenkov@niistt.ru>
Cc: Wojtek Skulski <info@skutek.com>
Cc: Wojtek Skulski <skulski@pas.rochester.edu>
Now, arch/${ARCH}/include/asm/errno.h and include/linux/errno.h have
the same content. (both just wrap <asm-generic/errno.h>)
Replace all include directives for <asm/errno.h> with <linux/errno.h>.
[trini: Fixup include/clk.]
nand_do_write_ops() determines if it is writing a partial page with the
formula:
part_pagewr = (column || writelen < (mtd->writesize - 1))
When 'writelen' is exactly 1 byte less than the NAND page size the formula
equates to zero, so the code doesn't process it as a partial write, although
it should.
As a consequence the function remains in the while(1) loop with 'writelen'
becoming 0xffffffff and iterating until the watchdog timeout triggers.
To reproduce the issue on a NAND with 2K page (0x800):
=> nand erase.part <partition>
=> nand write $loadaddr <partition> 7ff
Signed-off-by: Hector Palacios <hector.palacios@digi.com>
These are already-documented common bindings for NAND chips. Let's
handle them in nand_base.
If NAND controller drivers need to act on this data before bringing up
the NAND chip (e.g., fill out ECC callback functions, change HW modes,
etc.), then they can do so between calling nand_scan_ident() and
nand_scan_tail().
The original commit has been slightly reworked to use the fdtdec_xxx()
helpers (instead of the of_xxxx() ones).
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Acked-by: Hans de Goede <hdegoede@redhat.com>
This empty line should not be there. Remove it.
Signed-off-by: Andre Renaud <andre@designa-electronics.com>
Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
Updates the NAND code to match Linux v4.6. The previous sync was from
Linux v4.1 in commit d3963721d93fafa.
Note that none of the individual NAND drivers tracked Linux closely
enough to be synced themselves, other than manually applying a few
cross-tree changes.
Signed-off-by: Scott Wood <oss@buserror.net>
Tested-by: Heiko Schocher <hs@denx.de>
This change is part of the Linux 4.6 sync. It is being done before the
main sync patch in order to make it easier to address the issue across
all NAND drivers (many/most of which do not closely track their Linux
counterparts) separately from other merge issues.
These functions are part of the Linux 4.6 sync. They are being added
before the main sync patch in order to make it easier to address the
issue across all NAND drivers (many/most of which do not closely track
their Linux counterparts) separately from other merge issues.
Update the NAND code to match Linux v4.1. The previous sync was
from Linux v3.15 in commit 4e67c57125290b25.
CONFIG_SYS_NAND_RESET_CNT is removed, as the upstream Linux code now
has its own timeout. Plus, CONFIG_SYS_NAND_RESET_CNT was undocumented
and not selected by any board.
In addition to mtd_block_isbad(), which checks if a block is bad or
reserved, it's needed to check if a block is reserved only (but not
bad). This commit adds an MTD interface for it, in a similar fashion to
mtd_block_isbad().
While here, fix mtd_block_isbad() so the out-of-bounds checking is done
before the callback check.
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Tested-by: Pekon Gupta <pekon@ti.com>
[scottwood: Cherry-picked from Linux 8471bb73ba10ed67]
I didn't approve the patch that added them. Get them out of the way
before doing a sync.
The CONFIG_MTD_NAND_VERIFY_WRITE has been removed from Linux for some
time and a more generic method of NAND verification now exists in U-Boot.
Acked-by: Heiko Schocher <hs@denx.de>
These boards are still non-generic boards.
It is a good thing that we can drop board-specific hack code
from drivers/mtd/nand/nand_base.c
Cc: Andrea "llandre" Marson <andrea.marson@dave-tech.it>
Currently, "nand scrub" runs chip->scan_bbt at the end of
nand_erase_opts() even if NAND_SKIP_BBTSCAN flag is set.
It violates the intention of NAND_SKIP_BBTSCAN.
Move NAND_SKIP_BBTSCAN flag check to nand_block_checkbad() so that
chip->scan_bbt() is never run if NAND_SKIP_BBTSCAN is set.
Also, unset NAND_BBT_SCANNED flag instead of running chip->scan_bbt()
right after scrub. We can be lazier here because the BBT is scanned
at the next call of nand_block_checkbad().
Cc: Scott Wood <scottwood@freescale.com>
Commit 35c204d8a9d0 (nand: reinstate lazy bad block scanning)
broke NAND_BBT_USE_FLASH feature.
Its git-log claimed that it reinstated the change as by commit
fb49454b1b6c ("nand: reinstate lazy bad block scanning"), but it moved
"chip->options |= NAND_BBT_SCANNED" below "chip->scan_bbt(mtd);".
It causes recursion if scan_bbt does not find a flash based BBT
and tries to write one, and the attempt to erase the BBT area
causes a bad block check.
Reinstate commit ff49ea8977b5 (NAND: Mark the BBT as scanned prior to
calling scan_bbt.).
Cc: Rostislav Lisovy <lisovy@merica.cz>
Since commit ff94bc40af34 (mtd, ubi, ubifs: resync with Linux-3.14),
the "nand scrub" command has not been working.
Commit ff94bc40af3481d47546595ba73c136de6af6929
("mtd, ubi, ubifs: resync with Linux-3.14")
accidentally reverted part of the commit
13f0fd94e3cae6f8a0d9fba5d367e311edc8ebde
("NAND: Scan bad blocks lazily.").
Reinstate the change as by commit
fb49454b1b6c7c6e238ac3c0b1e302e73eb1a1ea
Signed-off-by: Rostislav Lisovy <lisovy@merica.cz>
The ioread16_rep() and iowrite16_rep() implementations are U-Boot specific
and have been introduced with the Linux MTD v3.14 sync. While introducing
these functions, the length for the loop has been miscalculated. The ">> 1"
is already present in the caller. So lets remove it in the function.
Tested on omap3_ha.
Cc: Tom Rini <trini@ti.com>
U-Boot has imported various source files from other projects,
mostly Linux.
Something like
#ifdef __UBOOT__
[ modification for U-Boot ]
#else
[ original code ]
#endif
is an often used strategy for clarification of adjusted parts,
that is, easier re-sync in future.
Instead of defining __UBOOT__ in each source file,
passing it from the top Makefile would be easier.
snyc with linux v3.15:
commit 1860e379875dfe7271c649058aeddffe5afd9d0d
Author: Linus Torvalds <torvalds@linux-foundation.org>
Date: Sun Jun 8 11:19:54 2014 -0700
Linux 3.15
resync ubi subsystem with linux:
commit 455c6fdbd219161bd09b1165f11699d6d73de11c
Date: Sun Mar 30 20:40:15 2014 -0700
Linux 3.14
A nice side effect of this, is we introduce UBI Fastmap support
to U-Boot.
Cc: Sergey Lapin <slapin@ossfans.org>
Cc: Joerg Krause <jkrause@posteo.de>
As per following Sections in ONFI Spec, NAND_CMD_READID should use only
lower 8-bit for transfering command, address and data even on x16 NAND device.
*Section: Target Initialization"
"The Read ID and Read Parameter Page commands only use the lower 8-bits of the
data bus. The host shall not issue commands that use a word data width on x16
devices until the host determines the device supports a 16-bit data bus width
in the parameter page."
*Section: Bus Width Requirements*
"When the host supports a 16-bit bus width, only data is transferred at the
16-bit width. All address and command line transfers shall use only the lower
8-bits of the data bus. During command transfers, the host may place any value
on the upper 8-bits of the data bus. During address transfers, the host shall
set the upper 8-bits of the data bus to 00h."
Thus porting following commit from linux-kernel to ensure that column address
is not altered to align to x16 bus when issuing NAND_CMD_READID command.
commit 3dad2344e92c6e1aeae42df1c4824f307c51bcc7
mtd: nand: force NAND_CMD_READID onto 8-bit bus
Author: Brian Norris <computersforpeace@gmail.com> (preserving authorship)
The NAND command helpers tend to automatically shift the column address
for x16 bus devices, since most commands expect a word address, not a
byte address. The Read ID command, however, expects an 8-bit address
(i.e., 0x00, 0x20, or 0x40 should not be translated to 0x00, 0x10, or
0x20).
This fixes the column address for a few drivers which imitate the
nand_base defaults.
Signed-off-by: Pekon Gupta <pekon@ti.com>
Porting below commit from linux-tree, preserving original authorship & commit log
commit bd9c6e99b58255b9de1982711ac9487c9a2f18be
mtd: nand: don't use read_buf for 8-bit ONFI transfers
Use a repeated read_byte() instead of read_buf(), since for x16 buswidth
devices, we need to avoid the upper I/O[16:9] bits. See the following
commit for reference:
commit 05f7835975dad6b3b517f9e23415985e648fb875 (from linux-tree)
Author: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Date: Thu Dec 5 22:22:04 2013 +0100
mtd: nand: don't use {read,write}_buf for 8-bit transfers
Now, I think that all barriers to probing ONFI on x16 devices are
removed, so remove the check from nand_flash_detect_onfi().
[trini: Drop changes for PEP 4 following python tools]
Linux modified the MTD driver interface in commit edbc4540 (with the
same name as this commit). The effect is that calls to mtd_read will
not return -EUCLEAN if the number of ECC-corrected bit errors is below
a certain threshold, which defaults to the strength of the ECC. This
allows -EUCLEAN to stop indicating "some bits were corrected" and begin
indicating "a large number of bits were corrected, the data held in
this region of flash may be lost soon". UBI makes use of this and when
-EUCLEAN is returned from mtd_read it will move data to another block
of flash. Without adopting this interface change UBI on U-boot attempts
to move data between blocks every time a single bit is corrected using
the ECC, which is a very common occurance on some devices.
For some devices where bit errors are common enough, UBI can get stuck
constantly moving data around because each block it attempts to use has
a single bit error. This condition is hit when wear_leveling_worker
attempts to move data from one PEB to another in response to an
-EUCLEAN/UBI_IO_BITFLIPS error. When this happens ubi_eba_copy_leb is
called to perform the data copy, and after the data is written it is
read back to check its validity. If that read returns UBI_IO_BITFLIPS
(in response to an MTD -EUCLEAN) then ubi_eba_copy_leb returns 1 to
wear_leveling worker, which then proceeds to schedule the destination
PEB for erasure. This leads to erase_worker running on the PEB, and
following a successful erase wear_leveling_worker is called which
begins this whole cycle all over again. The end result is that (without
UBI debug output enabled) the boot appears to simply hang whilst in
reality U-boot busily works away at destroying a block of the NAND
flash. Debug output from this situation:
UBI DBG: ensure_wear_leveling: schedule scrubbing
UBI DBG: wear_leveling_worker: scrub PEB 1027 to PEB 4083
UBI DBG: ubi_io_read_vid_hdr: read VID header from PEB 1027
UBI DBG: ubi_io_read: read 4096 bytes from PEB 1027:4096
UBI DBG: ubi_eba_copy_leb: copy LEB 0:0, PEB 1027 to PEB 4083
UBI DBG: ubi_eba_copy_leb: read 1040384 bytes of data
UBI DBG: ubi_io_read: read 1040384 bytes from PEB 1027:8192
UBI: fixable bit-flip detected at PEB 1027
UBI DBG: ubi_io_write_vid_hdr: write VID header to PEB 4083
UBI DBG: ubi_io_write: write 4096 bytes to PEB 4083:4096
UBI DBG: ubi_io_read_vid_hdr: read VID header from PEB 4083
UBI DBG: ubi_io_read: read 4096 bytes from PEB 4083:4096
UBI DBG: ubi_io_write: write 4096 bytes to PEB 4083:8192
UBI DBG: ubi_io_read: read 4096 bytes from PEB 4083:8192
UBI: fixable bit-flip detected at PEB 4083
UBI DBG: schedule_erase: schedule erasure of PEB 4083, EC 55, torture 0
UBI DBG: erase_worker: erase PEB 4083 EC 55
UBI DBG: sync_erase: erase PEB 4083, old EC 55
UBI DBG: do_sync_erase: erase PEB 4083
UBI DBG: sync_erase: erased PEB 4083, new EC 56
UBI DBG: ubi_io_write_ec_hdr: write EC header to PEB 4083
UBI DBG: ubi_io_write: write 4096 bytes to PEB 4083:0
This patch adopts the interface change as in Linux commit edbc4540 in
order to avoid such situations. Given that none of the drivers under
drivers/mtd return -EUCLEAN, this should only affect those using
software ECC. I have tested that it works on a board which is
currently out of tree, but which I hope to be able to begin
upstreaming soon.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
This patch is essentially an update of u-boot MTD subsystem to
the state of Linux-3.7.1 with exclusion of some bits:
- the update is concentrated on NAND, no onenand or CFI/NOR/SPI
flashes interfaces are updated EXCEPT for API changes.
- new large NAND chips support is there, though some updates
have got in Linux-3.8.-rc1, (which will follow on top of this patch).
To produce this update I used tag v3.7.1 of linux-stable repository.
The update was made using application of relevant patches,
with changes relevant to U-Boot-only stuff sticked together
to keep bisectability. Then all changes were grouped together
to this patch.
Signed-off-by: Sergey Lapin <slapin@ossfans.org>
[scottwood@freescale.com: some eccstrength and build fixes]
When writelen is mtd->writesize - 1, it is still a partial page write
Signed-off-by: Tao Hou <hotforest@gmail.com>
Use a flag instead of a hard-coded macro so that sub-page reads can be
enabled in other cases (such as on-die ecc).
This is the same as a5ff4f102937a3492bca4a9ff0c341d78813414c in Linux
nand_ecc.c:82:5: warning: symbol 'nand_calculate_ecc' was not declared. Should it be static?
nand_ecc.c:155:5: warning: symbol 'nand_correct_data' was not declared. Should it be static?
nand_base.c:2854:1: error: directive in argument list
nand_base.c:2856:1: error: directive in argument list
Acked-by: Scott Wood <scottwood@freescale.com>
