path: root/drivers/mtd/nand/bfin_nand.c
2013-05-31mtd: resync with Linux-3.7.1Sergey Lapin
This patch is essentially an update of u-boot MTD subsystem to the state of Linux-3.7.1 with exclusion of some bits: - the update is concentrated on NAND, no onenand or CFI/NOR/SPI flashes interfaces are updated EXCEPT for API changes. - new large NAND chips support is there, though some updates have got in Linux-3.8.-rc1, (which will follow on top of this patch). To produce this update I used tag v3.7.1 of linux-stable repository. The update was made using application of relevant patches, with changes relevant to U-Boot-only stuff sticked together to keep bisectability. Then all changes were grouped together to this patch. Signed-off-by: Sergey Lapin <slapin@ossfans.org> [scottwood@freescale.com: some eccstrength and build fixes] Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-02-12Blackfin: bfin_nand: mark local func staticMike Frysinger
This devready func is only used in this driver, so mark it static. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: bfin_nand: convert to portmux frameworkMike Frysinger
Rather than bang MMRs directly, use the new portmux framework to handle the details. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Scott Wood <scottwood@freescale.com>
2010-05-26Blackfin: nand: drain the write buffer before returningAndrew Caldwell
The current Blackfin nand write function fills up the write buffer but returns before it has had a chance to drain. On faster systems, this isn't a problem as the operation finishes before the ECC registers are read, but on slower systems the ECC may be incomplete when the core tries to read it. So wait for the buffer to drain once we're done writing to it. Signed-off-by: Andrew Caldwell <Andrew.Caldwell@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-04-06Blackfin: nand: flush peripheral before polling itGraf Yang
We need to make sure the data written to the nand flash controller makes it there before we start polling its status register. Otherwise, we may get stale data and return before the controller is actually ready. Signed-off-by: Graf Yang <graf.yang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Scott Wood <scottwood@freescale.com>
2009-02-02Blackfin: add driver for on-chip NAND controllerMike Frysinger
This is a port of the Linux Blackfin on-chip NFC driver to U-Boot. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
