path: root/drivers/mtd/Makefile
2015-06-30mtd, nand: Move common functions from cmd_nand.c to common placeHeiko Schocher
Move common functions from cmd_nand.c (for calculating offset and size from cmdline paramter) to common place, so they could used from other commands which use mtd partitions. For onenand the arg_off_size() is left in common/cmd_onenand.c. It should use now the common arg_off() function, but as I could not test onenand I let it there ... Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: Jagannadh Teki <jteki@openedev.com>
2013-10-31drivers: mtd: convert makefiles to Kbuild styleMasahiro Yamada
2013-05-31mtd: resync with Linux-3.7.1Sergey Lapin
This patch is essentially an update of u-boot MTD subsystem to the state of Linux-3.7.1 with exclusion of some bits: - the update is concentrated on NAND, no onenand or CFI/NOR/SPI flashes interfaces are updated EXCEPT for API changes. - new large NAND chips support is there, though some updates have got in Linux-3.8.-rc1, (which will follow on top of this patch). To produce this update I used tag v3.7.1 of linux-stable repository. The update was made using application of relevant patches, with changes relevant to U-Boot-only stuff sticked together to keep bisectability. Then all changes were grouped together to this patch. Signed-off-by: Sergey Lapin <slapin@ossfans.org> [scottwood@freescale.com: some eccstrength and build fixes] Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-07-07st_smi: Add support for SPEAr SMI driverVipin KUMAR
SMI is the serial memory interface controller provided by ST. Earlier, a driver exists in the u-boot source code for the SMI IP. However, it was specific to spear platforms. This commit converts the same driver to a more generic driver. As a result, the driver files are renamed to st_smi.c and st_smi.h and moved into drivers/mtd folder for reusability by other platforms using smi controller peripheral. Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Signed-off-by: Stefan Roese <sr@denx.de>
2011-04-27ftsmc020: move ftsmc020 static mem controller to driver/mtdMacpaul Lin
Move the header file and definitions of ftsmc020 static memory control unit from a320 SoC folder to "drivers/mtd" folder. This change will let other SoC which also use ftsmc020 could share the same header file. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2010-03-21mod change 755 => 644 for multiple filesThomas Weber
I executed 'find . -name "*.[chS]" -perm 755 -exec chmod 644 {} \;' Signed-off-by: Thomas Weber <swirl@gmx.li> Add some more: neither Makefile nor config.mk need execute permissions. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-01-23SPEAr : smi driver support for SPEAr SoCsVipin KUMAR
SPEAr SoCs contain a serial memory interface controller. This controller is used to interface with spi based memories. This patch adds the driver for this IP. Signed-off-by: Vipin <vipin.kumar@st.com>
2009-06-12mtd: Introduce CONFIG_MTD_DEVICE to select compilation of mtdcore.oStefan Roese
This new define enables mtdcore.c compilation and with this we can select the MTD device infrastructure needed for the reworked mtdparts command. We now have the 2 MTD infrastructure defines, CONFIG_MTD_DEVICE and CONFIG_MTD_PARTITIONS. CONFIG_MTD_DEVICE is needed (as explained above) for the "mtdparts" command and CONFIG_MTD_PARTITIONS is needed for UBI. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Scott Wood <scottwood@freescale.com>
2009-06-12mtd: Add MTD concat support to concatenate multiple MTD NOR devicesStefan Roese
This patch adds concatenation support to the U-Boot MTD infrastructure. By enabling CONFIG_MTD_CONCAT this MTD CFI wrapper will concatenate all found NOR devices into one single MTD device. This can be used by e.g by UBI to access a partition that spans over multiple NOR chips. Signed-off-by: Stefan Roese <sr@denx.de>
2009-04-16CMD_UBI != MTD_PARTITIONSDavid Brownell
Fix dependency goofage: it should certainly be possible to have the partition support without bringing in UBI commands. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Stefan Roese <sr@denx.de>
2008-11-25Merge branch 'master' of git://git.denx.de/u-boot-ubiWolfgang Denk
2008-11-24cfi-mtd: Add cfi-mtd driver.Piotr Ziecik
Add cfi-mtd driver, which exports CFI flash to MTD layer. This allows CFI flash devices to be used from MTD layer. Building of the new driver is controlled by CONFIG_FLASH_CFI_MTD option. Initialization is done by calling cfi_mtd_init() from flash_init(). Signed-off-by: Piotr Ziecik <kosmo@semihalf.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-11-19MTD: Add MTD paritioning infrastructureKyungmin Park
This MTD part infrastructure will be used by the upcoming UBI support. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-04-01dataflash: Move CONFIG_HAS_DATAFLASH to MakefileJean-Christophe PLAGNIOL-VILLARD
2007-12-08CFI: support JEDEC flash roms in CFI-flash frameworkMichael Schwingen
The following patch adds support for non-CFI flash ROMS, by hooking into the CFI flash code and using most of its code, as recently discussed here in the thread "Mixing CFI and non-CFI flashs". Signed-off-by: Michael Schwingen <michael@schwingen.org> Signed-off-by: Stefan Roese <sr@denx.de>
2007-11-25drivers/mtd : move mtd drivers to drivers/mtdJean-Christophe PLAGNIOL-VILLARD
