path: root/drivers/mmc
2014-02-17Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-02-07cmd_mmc.c: Drop open/close mmc sub-commandsTom Rini
The open and close mmc sub-commands implement a hard-coded set of values specific to the SMDK5250 platform. Remove these commands as what they did can be done instead with a series of mmc dev / bootpart / bootbus commands instead now. Cc: Amar <amarendra.xt@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-02-07cmd_mmc.c: Add bootbus mmc sub-commandTom Rini
Add a bootbus sub-command to the mmc command to allow for setting the boot_bus_width, reset_boot_bus_width and boot_mode fields of BOOT_BUS_WIDTH (EXT_CSD[177]). Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-02-07cmd_mmc.c: Add 'partconf' command to mmcTom Rini
Add a partconf sub-command to the mmc command to allow for setting the boot_ack, boot_partition and partition_access fields of PARTITION_CONFIG (formerly BOOT_CONFIG, EXT_CSD[179]). Part of this requires changing the check for 'part' from an strncmp to a strcmp, like the rest of the sub-commands. Cc: Andy Fleming <afleming@gmail.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-02-07mmc: Enabled quirk SDHCI_QUIRK_BROKEN_R1BSiva Durga Prasad Paladugu
As per the below commit "mmc: sdhci: add the quirk for broken r1b response" (sha1: 3a6383207be3f71b39004e64464a6e99290b16fa) need to add quirk SDHCI_QUIRK_BROKEN_R1B, when the response type is R1b. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-02-07MMC: DWMMC: Correct the CLKDIV register valueRajeshwari S Shinde
This patch corrects the divider value written to CLKDIV register. Since SDCLKIN is divided inside controller by the DIVRATIO value set in the CLKSEL register, we need to use the same output clock value to calculate the CLKDIV value. as per user manual: cclk_in = SDCLKIN / (DIVRATIO + 1) Input parameter to mmc_clk is changed to dwmci_host, since we need the same to read DWMCI_CLKSEL register. This improves the read timing values for channel 0 on SMDK5250 from 0.288sec to 0.144sec Signed-off-by: Rajeshwari S Shinde <rajeshwari.s@samsung.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-02-07mmc: set rca to 1 for MMC cardsStephen Warren
U-Boot currently sets MMC cards' RCA register to 0. This value is reserved according to the specification. Use a value of 1 instead, just like the Linux kernel. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-02-03mmc: tegra: support Tegra124Stephen Warren
Tegra124's MMC controller is very similar to earlier SoC generations, and can be supported by the same driver. However, there are some non-backwards-compatible HW differences, and hence a new DT compatible value must be used to describe the HW. This patch updates the driver to support that new compatible value. That said, the HW differences are only relevant when enabling certain high-performance transfer modes. Since the driver is currently very simple and doesn't enable those modes, we don't actually need to address any of these HW differences in the code yet, hence the simple nature of this patch. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Tested-by: Thierry Reding <treding@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-01-24drivers: delete unused header filesMasahiro Yamada
2014-01-22esdhc: Detecting 8 bit width before mmc initializationHaijun.Zhang
The upper 4 data signals of esdhc are shared with spi flash. So detect if the upper 4 pins are assigned to esdhc before enable sdhc 8 bit width. Signed-off-by: Haijun Zhang <haijun.zhang@freescale.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-22esdhc: Workaround for card can't be detected on T4240QDSHaijun.Zhang
Card detection pin is ineffective on T4240QDS Rev1.0. There are two cards can be connected to board. 1. eMMC card is built-in board, can not be removed. so For eMMC card it is always there. 2. Card detecting pin is functional for SDHC card in Rev2.0. This workaround force sdhc driver scan and initialize the card regardless of whether the card is inserted or not in case Rev1.0. Signed-off-by: Haijun Zhang <Haijun.Zhang@freescale.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-14mmc: dwmmc: mode change to 0644Minkyu Kang
Don't know why but, file permission was changed Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-01-09socfpga/dwmmc: Adding DesignWare MMC driver support for SOCFPGAChin Liang See
To add the DesignWare MMC driver support for Altera SOCFPGA. It required information such as clocks and bus width from platform specific files (SOCFPGA handoff files) Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Rajeshwari Shinde <rajeshwari.s@samsung.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-01-09mmc: add setdsr supportMarkus Niebel
The eMMC and the SD-Card specifications describe the optional SET_DSR command. During measurements at our lab we found that some cards implementing this feature having really strong driver strengts per default. This can lead to voltage peaks above the specification of the host on signal edges for data sent from a card to the host. Since availability of a given card type may be shorter than the time a certain hardware will be produced it is useful to have support for this command (Alternative would be changing termination resistors and adapting the driver strength of the host to the used card.) Following proposal for an implementation: - new field that reflects CSD field DSR_IMP in struct mmc - new field for design specific DSR value in struct mmc - board code can set DSR value in mmc struct just after registering an controller - mmc_startup sends the the stored DSR value before selecting a card, if DSR_IMP is set Additionally the mmc command is extended to make is possible to play around with different DSR values. The concept was tested on a i.MX53 based platform using a Micron eMMC card where the default DSR is 0x0400 (12mA) but in our design 0x0100 (0x0100) were enough. To use this feature for instance on a mx53loco one have to add a call to mmc_set_dsr() in board_mmc_init() after calling fsl_esdhc_initialize() for the eMMC. Signed-off-by: Markus Niebel <Markus.Niebel@tqs.de> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-01-09mmc: Minor cleanup of sdhci.cDarwin Rambo
Fixup prints to show where the print is done from, and a few minor formatting/grammar issues. Signed-off-by: Darwin Rambo <drambo@broadcom.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-01-09mmc/dwmmc: use bounce buffer for data exchange between CPU and MMC controllerAlexey Brodkin
Bounce buffer implementation takes care of proper data buffer alignemt and correct flush/invalidation of data cache at once so we no longer depend on input data variety and make sure CPU and MMC controller deal with expected data in case of enabled data cache. Bounce buffer requires to add its definition (CONFIG_BOUNCE_BUFFER) in board configuration, otherwise corresponding library won't be compiled and linker will fail to build resulting executable. Difference since v1 - fixed compile-time warning with type casting to "void *": Slight edit to remove UTF8 characters in the commit message. Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Tested-by: Jaehoon Chung <jh80.chung@samsung.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> ==== passing argument 2 of 'bounce_buffer_start' discards 'const' qualifier from pointer target type ==== Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Mischa Jonker <mjonker@synopsys.com> Cc: Alim Akhtar <alim.akhtar@samsung.com> Cc: Rajeshwari Shinde <rajeshwari.s@samsung.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Amar <amarendra.xt@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Simon Glass <sjg@chromium.org> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Andy Fleming <afleming@gmail.com>
2014-01-08mmc/dwmmc: Using calloc instead mallocChin Liang See
To enhance the SDMMC DesignWare driver to use calloc instead of malloc. This will avoid the incident that uninitialized members of mmc structure are later used for NULL comparison. Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Rajeshwari Shinde <rajeshwari.s@samsung.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Mischa Jonker <mjonker@synopsys.com> Cc: Alexey Brodkin <abrodkin@synopsys.com> Cc: Andy Fleming <afleming@freescale.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-12-08mmc: add Faraday FTSDC021 SDHCI controller supportKuo-Jung Su
Faraday FTSDC021 is a controller which is compliant with SDHCI v3.0, SDIO v2.0 and MMC v4.3. However this driver is only verified with SD memory cards. Signed-off-by: Kuo-Jung Su <dantesu@faraday-tech.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> CC: Andy Fleming <afleming@gmail.com>
2013-12-08powerpc: mmc: Add corenet devices support in esdhc splPriyanka Jain
Existing eSDHC SPL framework assumes booting from sd-image with boot_format header which contains final u-boot Image offset and size. No such header is present in case of corenet devices like T1040 as corenet deivces use PBI-RCW based intialization. So, for corenet deives, SPL bootloader use values provided at compilation time. These values can be defined in board specific config file. Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-12-08mmc/dwmmc: modify FIFO threshold only if value explicitly setAlexey Brodkin
If platform provides "host->fifoth_val" it will be used for initialization of DWMCI_FIFOTH register. Otherwise default value will be used. This implementation allows: * escape unclear and recursive calculations that are currently in use * use whatever custom value for DWMCI_FIFOTH initialization if any particular SoC requires it Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Mischa Jonker <mjonker@synopsys.com> Cc: Alim Akhtar <alim.akhtar@samsung.com> Cc: Rajeshwari Shinde <rajeshwari.s@samsung.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Amar <amarendra.xt@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Simon Glass <sjg@chromium.org> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Andy Fleming <afleming@freescale.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-12-08mmc: dw_mmc: remove the exynos specific code in dw-mmc.cJaehoon Chung
dw-mmc.c is the general driver file. So, remove the exynos specific code at dw-mmc.c. Instead, exynos specific cod can be move into exynos-dw_mmc.c. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Acked-by: Alexey Brodkin <abrodkin@synopsys.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2013-10-31drivers: convert makefiles to Kbuild styleMasahiro Yamada
2013-10-31powerpc/esdhc: Add 3.3v voltage support in esdhc capacity registerHaijun.Zhang
T4240QDS eSDHC host capabilities reigster should have VS33 bit define. Add quirk CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 to deal with capacity missing Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Haijun Zhang <Haijun.Zhang@freescale.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-10-31esdhc: memset mmc struct before putting into useHaijun.Zhang
struct mmc should be clear to all '0' after malloc to avoid unexpect variable value. Like mmc->has_init = xxx. In this case mmcinfo will believe the card had been initialized before and skip the initialization. Test on P5040 and T4240, Error Log: => mmcinfo Device: FSL_SDHC Manufacturer ID: 0 OEM: 0 Name: Tran Speed: 0 Rd Block Len: 0 MMC version 0.0 High Capacity: No Capacity: 0 Bytes Bus Width: 0-bit => Signed-off-by: Haijun Zhang <Haijun.Zhang@freescale.com> Signed-off-by: Xie Shaohui-B21989 <B21989@freescale.com> Tested-by: Ryan Barnett <rjbarnet@rockwellcollins.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-10-31Powerpc/esdhc: Add simple description of esdhc registerHaijun.Zhang
Add some descriptions for esdhc register for easily using. Signed-off-by: Haijun Zhang <haijun.zhang@freescale.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-10-31powerpc/esdhc: Map register for eSDHC Host Controller V3.0Haijun.Zhang
eSDHC host controller has new register to support SD Spec 3.0. And the according host controller version was Freescale eSDHC Version 3.0. Signed-off-by: Haijun Zhang <haijun.zhang@freescale.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-10-31DWMMC: SMDK5420: Disable SMU for eMMCRajeshwari Shinde
SMDK5420 has a new Security Management Unit added for dwmmc driver, hence, configuring the control registers to support booting via eMMC. Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-10-31mmc: sdhci: Avoid commands errors by simple timeout adaptation.Przemyslaw Marczak
Old command timeout value was too small and it caused I/O errors which led to uncompleted read/write/erase operations and filesystem errors. Timeout adaptation fixes this issue. Changes in sdhci_send_command() function: - change timeout variable to static - increase default command timeout to 100 ms - add definition of max command timeout value, which can be redefined in each board config file - wait for card ready state for max defined time if it doesn't exceed defined maximum or return COMM_ERR Once successfully increased timeout value will be used in next function call. This fix was tested on Goni, Trats, Trats2 boards by testing UMS on MMC storage. Changes v2: - move global variable cmd_timeout into function sdhci_send_command() - change condition "==" to ">=" when comparing time with timeout - print information about timeout increasing and card busy timeout Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-10-31mmc: dw_mmc: change the callback function name.Jaehoon Chung
To prevent the confusion, use the get_mmc_clk() instead of mmc_clk(). get_mmc_clk() is more exactly name. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-10-31mmc: Fix erase_grp_size for partitioned cardOliver Metz
EXT_CSD_ERASE_GROUP_DEF is lost every time after a reset or power off. Set it if device has enhanced partitions. Signed-off-by: Oliver Metz <oliver@freetz.org> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-10-02Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-09-20Fix wrong sdhci host control register read and writeJuhyun \(Justin\) Oh
The patch fixes the improper read and write of sdhci host control register for sdma transfer. The problem comes when reading and writing 1 byte long host control register with the sdhci_readl() and sdhci_writel(). The misuse of these functions overwrite the value of the next registers which are in 4 bytes boundary. This patch replaces four byte register read/write functions with one byte read/write ones. Beside, it eliminates unnecessary bit operation. i.e. or-ing zero against a variable. Signed-off-by: Juhyun (Justin) Oh <Juhyun_Oh@sigmadesigns.com>
2013-09-20mmc/dw_mmc: Allocate the correct amount of descriptorsMischa Jonker
This fixes two issues: * a descriptor was allocated for every block, while a descriptor can take 8 blocks * there was an off-by-one error in the descriptor preparation: there were two last descriptors, one with length==0 Signed-off-by: Mischa Jonker <mjonker@synopsys.com> Cc: Alexey Brodkin <abrodkin@synopsys.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Andy Fleming <afleming@gmail.com>
2013-09-20mmc/dw_mmc: Fix DMA descriptor corruptionMischa Jonker
In dwmci_prepare_data, the descriptors are allocated for DMA transfer. These are allocated using the ALLOC_CACHE_ALIGN_BUFFER. This macro uses the stack to allocate these descriptors. This becomes a problem if the DMA transfer continues after the processor leaves the function in which the descriptors were allocated. Therefore, I have moved the allocated of the buffers up one level, to dwmci_send_cmd(). The DMA transfer should be complete when leaving this function. Signed-off-by: Mischa Jonker <mjonker@synopsys.com> Cc: Alexey Brodkin <abrodkin@synopsys.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Andy Fleming <afleming@gmail.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-09-20mmc: don't support write & erase for SPL buildsPaul Burton
For SPL builds this is just dead code since we'll only need to read. Eliminating it results in a significant size reduction for the SPL binary, which may be critical for certain platforms where the binary size is highly constrained. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-09-20mmc: fsl_esdhc: Check the result from malloc()Fabio Estevam
malloc can fail, so we should better check its return value before using it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-09-17mmc: don't call *printf or puts when SPL & !CONFIG_SPL_LIBCOMMON_SUPPORTPaul Burton
If we don't have CONFIG_SPL_LIBCOMMON_SUPPORT defined then stdio & *printf functions are unavailable & calling them will cause a link failure. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-09-17ARM: OMAP: Enable 8-bit eMMC access for OMAP4/5/DRA7xxLubomir Popov
Enable 8-bit host capability for HSMMC2 and/or HSMMC3. CONFIG_HSMMC2_8BIT (for OMAP4/5/DRA7xx) and/or CONFIG_HSMMC3_8BIT (for DRA7xx only) must be defined in the board header if an 8-bit eMMC device is connected to the corresponding port. Fix the "No status update" error that appeared for eMMC devices by inserting a 20 us delay between writing arguments and command. This solution has been proposed by Michael Cashwell <mboards@prograde.net>. A minor cosmetic fix in a comment as well. Signed-off-by: Lubomir Popov <lpopov@mm-sol.com>
2013-09-17omap_hsmmc: omap4+/am335x: modify MMC controller internal fsm reset funcOleksandr Tyshchenko
"mmc_send_cmd: timeout: No status update" error sometimes happens in omap_hsmmc driver func mmc_send_cmd() when the MMC controller card identification and selection sequence is executed for eMMC on OMAP4 boards. It happens due to incorrect execution of CMD line reset procedure for OMAP4. Because CMD(DAT) lines reset procedures are slightly different for OMAP3 and OMAP4(AM335x,OMAP5,DRA7xx). According to OMAP3 TRM: Set SRC(SRD) bit in MMCHS_SYSCTL register to 0x1 and wait until it returns to 0x0. According to OMAP4(AM335x,OMAP5,DRA7xx) TRMs, CMD(DATA) lines reset procedure steps must be as follows: 1. Initiate CMD(DAT) line reset by writing 0x1 to SRC(SRD) bit in MMCHS_SYSCTL register (SD_SYSCTL for AM335x). 2. Poll the SRC(SRD) bit until it is set to 0x1. 3. Wait until the SRC(SRD) bit returns to 0x0 (reset procedure is completed). Unfortunately, at present omap_hsmmc driver has support only for OMAP3. And as result step #2 is missing for OMAP4(AM335x,OMAP5,DRA7xx). This sometimes leads to the fact that the waiting loop which is required in step #3 does not executed, because SRC bit does not set yet (at the moment of checking a condition of a loop execution). And as a result this can cause to timeout error when sending a next command. In the particular case (working with eMMC witch do not respond to some SD specific command) due to incorrect reset sequence after command SD_CMD_SEND_IF_COND which finished with CTO flag within 64 clock cycles, the next command MMC_CMD_APP_CMD leads to a timeout error within 1s. So, extend CMD(DATA) lines reset procedure in func mmc_reset_controller_fsm() by adding the missing step #2 for OMAP4+/AM335x boards. Signed-off-by: Oleksandr Tyshchenko <oleksandr.tyshchenko@ti.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-09-17mmc: Remove unused variable backup from mmc_send_cmd()Oleksandr Tyshchenko
Do not call a memset for unused variable backup every time. Remove unused variable from function. Signed-off-by: Oleksandr Tyshchenko <oleksandr.tyshchenko@ti.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-09-17mmc: sdhci: use the SDHCI_QUIRK_USE_WIDE8 for samsung SoCJaehoon Chung
Samsung SoC is supported the WIDE8, even if Controller version is v2.0. So add the SDHCI_QUIRK_USE_WIDE8 for Samsung-SoC. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-09-05Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/serial/serial.c The conflict above was a trivial case of adding one init function in each branch, and manually resolved in merge.
2013-08-23mmc: mxsmmc: Enable MMC HC supportAmaury Pouly
Enable support for high-capacity eMMC and MMC cards. The MXS MMC driver has no problem with those. Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Amaury Pouly <amaury.pouly@gmail.com> Cc: Andy Fleming <afleming@freescale.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br> Reviewed-by: Otavio Salvador <otavio@ossystems.com.br>
2013-08-20SPDX-License-Identifier: clean up license headerYork Sun
This patch cleans up license header in these files: board/freescale/p1022ds/spl.c drivers/mmc/fsl_esdhc_spl.c drivers/mtd/spi/fsl_espi_spl.c Signed-off-by: York Sun <yorksun@freescale.com>
2013-08-20powerpc: mpc85xx: Support booting from SD Card with SPLYing Zhang
The code from the internal on-chip ROM. It loads the final uboot image into DDR, then jump to it to begin execution. The SPL's size is sizeable, the maximum size must not exceed the size of L2 SRAM. It initializes the DDR through SPD code, and copys final uboot image to DDR. So there are two stage uboot images: * spl_boot, 96KB size. The env variables are copied to L2 SRAM, so that ddr spd code can get the interleaving mode setting in env. It loads final uboot image from offset 96KB. * final uboot image, size is variable depends on the functions enabled. Signed-off-by: Ying Zhang <b40530@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-07-25Merge branch 'master' of git://git.denx.de/u-boot-nds32Tom Rini
2013-07-24mmc: ftsdc010_mci: fix build error if CONFIG_FTSDC010_SDIO is not definedGabor Juhos
The FTSDC010_DCR_FIFO_RST symbol is conditionally defined in <faraday/ftsdc010.h> and it is available available when CONFIG_FTSDC010_SDIO is enabled. However the actual driver code unconditionally uses the FTSDC010_DCR_FIFO_RST constant and this causes build error if CONFIG_FTSDC010_SDIO is not enabled. The following error happens when compiling for the adp-ag101 board: ftsdc010_mci.c: In function 'ftsdc010_request': ftsdc010_mci.c:178: error: 'FTSDC010_DCR_FIFO_RST' undeclared (first use in this function) ftsdc010_mci.c:178: error: (Each undeclared identifier is reported only once ftsdc010_mci.c:178: error: for each function it appears in.) The patch ensures that the FTSDC010_DCR_FIFO_RST symbol gets used only if CONFIG_FTSDC010_SDIO is defined. Compile tested only. Cc: Kuo-Jung Su <dantesu@faraday-tech.com> Cc: Macpaul Lin <macpaul@andestech.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Reviewed-by: Kuo-Jung Su <dantesu@faraday-tech.com>
2013-07-16fsl_esdhc: Touch only relevant sys ctrl bitsDirk Behme
Dealing with the sys ctrl register should touch only the relevant bits and not accidently the whole register. On i.MX6, the sys control register contains bits which shouldn't be reset to 0, e.g. SYS_CTRL[3-0] and IPP_RST_N (SYS_CTRL[23]). Do this by read/modify/write instead of just a 32bit write. Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> Acked-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-07-16drivers/mmc/dw_mmc - remove extra arch specific "asm/arch/clk.h" inclusionAlexey Brodkin
1. No contents of "asm/arch/clk.h" is used within "dw_mmc.c". 2. If arch doesn't have "asm/arch/clk.h" driver won't build. Without mentioned inclusion dw_mmc driver could be built for arches other than ARM. For ARM driver still builds without it. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Mischa Jonker <mjonker@synopsys.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Rajeshwari Shinde <rajeshwari.s@samsung.com> Cc: Amar <amarendra.xt@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
