At HS400 mode the ITAPDLY value is that from High Speed mode
which is incorrect and may cause boot failures.
The ITAPDLY for HS400 speed mode should be the same as ITAPDLY
as HS200 timing after tuning is executed. Add the functionality
to save ITAPDLY from HS200 tuning and save as HS400 ITAPDLY.
Upstream-Status: Backport [f13a830e6e4ad884069e25c7cd2dc333b474da98]
Fixes: c964447ea3d6 ("mmc: am654_sdhci: Add support for input tap delay")
Signed-off-by: Judith Mendez <jm@ti.com>
According to the device datasheet [0], ENDLL=1 for
DDR52 mode, so call am654_sdhci_setup_dll() and write
itapdly after since we do not carry out tuning.
[0] https://www.ti.com/lit/ds/symlink/am62p.pdf
Upstream-Status: Backport [a124e31a97cd2963181d3a8a00678998bf9958a2]
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Set itap_del_ena if ITAPDLY is found in DT or if the tuning
algorithm was executed and found the optimal ITAPDLY. Add the
functionality to save ITAPDLYENA that can be referenced later
by storing the bit in array itap_del_ena[].
Upstream-Status: Backport [056af04a39aef6d9777a8d4fc29917b4494db4a5]
U-Boot is failing to boot class U1 UHS SD cards due to incorrect
OTAP and ITAP delay select values. Update OTAP and ITAP delay select
values from DT.
Upstream-Status: Backport [5048b5c61afddddb0a6ff2e6bffdd9dd028e399b]
Fixes: c7d106b4eb3 ("mmc: am654_sdhci: Update output tap delay writes")
Signed-off-by: Nitin Yadav <n-yadav@ti.com>
Signed-off-by: Andrejs Cainikovs <andrejs.cainikovs@toradex.com>
Currently the sdhci_am654 driver only supports one tuning
algorithm which should be used only when DLL is enabled. The
ITAPDLY is selected from the largest passing window and the
buffer is viewed as a circular buffer.
The new tuning algorithm should be used when the delay chain
is enabled; the ITAPDLY is selected from the largest passing
window and the buffer is not viewed as a circular buffer.
This implementation is based off of the following paper: [1].
Also add support for multiple failing windows.
[1] https://www.ti.com/lit/an/spract9/spract9.pdf
Upstream-Status: Backport [6b8dd9ca6e06bc9ebd3d55cbbe094d4947e197bf]
Fixes: a759abf569d4 ("mmc: am654_sdhci: Add support for software tuning")
U-Boot is fail to boot class U1 UHS SD cards (such as microcenter)
due to incorrect OTAP and ITAP delay select values. Update OTAP and
ITAP delay select values based on recommeded RIOT values to fix boot
issue.
https://source.denx.de/u-boot/custodians/u-boot-raspberrypi
- Fixes for booting newer revs of the SoC in the Raspberry Pi 4
- Propagate some firmware DT properties to the loaded DT
- Update the Zero2W upstream DT name
Newer firmware can manage the SDCDIV clock divisor register, allowing
the divisor to scale with the core as necessary.
Leverage this ability if the firmware supports it.
Adapted from the following raspberrypi Linux kernel commit:
bcm2835-sdhost: Firmware manages the clock divisor
https://github.com/raspberrypi/linux/commit/08532d242d7702ae0add95096aa49c5e96e066e2
Signed-off-by: Vincent Fazio <vfazio@xes-inc.com>
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
For Rockchip platform, DLL bypass bit and start bit need to be set if
DLL is not locked.
With this change applied eMMC in my NanoPi R5S can run at 52 MHz.
Based on linux commit b75a52b0dda3 ("mmc: sdhci-of-dwcmshc: Update DLL
and pre-change delay for rockchip platform")
Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
The get_mmc_clk ops is expected to set a clock rate and return the
configured rate as an unsigned value. However, if clk_set_rate fails,
e.g. using a fixed rate clock, a negative error value is returned.
The mmc core will treat this as a valid unsigned rate and tries to
configure a divider based on this bogus clock rate.
Use 0 as the return value when setting clock rate fails, the mmc core
will configure to use bypass mode instead of using a bogus divider.
Signed-off-by: Jonas Karlman <jonas@kwiboo.se>
In case one of the calls in probe fail, trigger a fail path and
undo all the steps done in probe until the point of failure.
The current implementation failed to stop controller clock and
free claimed clock, so fix that. Furthermore, print return code
in error prints for easier debugging.
Signed-off-by: Marek Vasut <marek.vasut+renesas@mailbox.org>
The prior stage bootloader might have left the SDnCKCR register in completely
arbitrary state before passing control to U-Boot, which includes the register
being populated with incorrect values. Currently the SDHI driver will attempt
to use clock framework to configure SDn clock, which may fail in case SDnCKCR
contains invalid values for the SDnH clock, because the clock framework would
not be able to determine SDnH clock rate and would get -EINVAL instead, which
in turn would not allow the clock framework to determine the correct SDn clock
divider ratio.
This failure occurs specifically in case SDnCKCR reads back 0x209 .
Correct the problem by first setting default SDnH clock rate to 800 MHz, thus
assuring the SDnCKCR SDnH bits are correct, and only afterward set up the SDn
clock rate to default 200 MHz.
Note that the SDHI driver may reconfigure SDnH clock later based on IOS
settings obtained from the attached card, the 800 MHz set up here is only
the default value.
The RK3288 TRM states that, for 8-bit DDR modes:
The CLKDIV register should always be programmed with a value
higher than zero (0); that is, a clock divider should always be
used for 8-bit DDR mode.
In Linux, the driver applies this logic for all SoCs using the driver
and does not distinguish RK3288, so presumably this requirement is the
same for all other Rockchip SoCs using this IP.
Add the necessary code to double the clock frequency when 8-bit DDR is
selected. The dw_mmc core already handles setting CLKDIV correctly
given the input clock and desired bus clock.
Signed-off-by: John Keeping <john@metanate.com>
This converts 1 usage of this option to the non-SPL form, since there is
no SPL_SUPPORT_EMMC_RPMB defined in Kconfig
no SPL_RENESAS_SDHI defined in Kconfig
no SPL_MMC_QUIRKS defined in Kconfig
The old SD handling code was huge and could not handle all the details
which showed up on R-Car Gen3 SoCs meanwhile. It is time to switch to
another design. Have SDnH a separate clock, use the existing divider
clocks and move the errata handling from the clock driver to the SDHI
driver where it belongs.
Based on Linux series by Wolfram Sang, commit bb6d3fa98a41 ("clk:
renesas: rcar-gen3: Switch to new SD clock handling") and commit
e5f7e81ee430a ("mmc: renesas_sdhi: Parse DT for SDnH")
Signed-off-by: Hai Pham <hai.pham.ud@renesas.com>
Marek: - Add rcar_clk_* prefix to all functions
- Fix missing ~ in GENMASK(a, b), use clrsetbits_le32 instead
- Use DIV_ROUND_CLOSEST, else if parent clock = 199999992 and
rate = 200000000, the divider would be 0 and table lookup
would fail.
- Turn rcar_clk_get_table_val into signed integer, so it can
return 0 as a valid value and negative values as errors.
- Make the code operate on correct clock and add comment
which explains the reasoning behind it.
- Rebase on changes to
clk: renesas: Introduce and use rcar_clk_get_rate64_div_table function
V3M handles SDnH differently than other Gen3 SoCs, so let's add a
separate entry for that. This will allow better SDnH handling in the
future.
Based on Linux commit 627151b4966f ("mmc: renesas_sdhi: Flag
non-standard SDnH handling for V3M") by Wolfram Sang
It is unnecessary, so clean it up.
Reviewed-by: Marek Vasut <marek.vasut+renesas@mailbox.org>
Signed-off-by: Marek Vasut <marek.vasut+renesas@mailbox.org> # update commit message, mention ES3.0
Support R8A77961 M3-W+ SoC.
Still uses 0x3 for now, adjust the offset value to TMPPORT3 accordingly
Adjust HS400 calibration tables based on Linux settings
Further filter out HS400 support on certain SoCs.
Since M3-W r1.2 does not support HS400, drop the calibration table and
rename the one for M3-W r1.3 to r8a7796_rev13_calib_table
Early ES revisions of M3-W SoCs requires 4-tap HS400. Reflect the status
from datasheet.
Add support for HS400 in mode2timing array.
Add a quirk for Versal NET platform to indicate that HS400 is supported
through bit63 of capability register.
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@amd.com>
HS400 is indicated in bit63 of capability register in few IP's.
Add a quirk to check this and add HS400 to host capabilities.
Check if the low level driver supports config_dll callback function and
call it if it does. Call with dll disable before calling set_clock and
with dll enable after it.
Add support for eMMC 5.1 for Versal NET platform
- Add new compatible string(xlnx,versal-net-5.1-emmc).
- Add CONFIG_ARCH_VERSAL_NET condition wherever required.
- Add DLL and Delay Chain mode support
- Add input and output tap delays for eMMC.
- Add Strobe select tap for HS400 mode.
Add more capable "bkops" command which allows enabling and disabling both
manual and automatic bkops. The existing 'mmc bkops-enable' subcommand is
poorly named to cover all the possibilities, hence the new-ish subcommand.
Note that both commands are wrappers around the same common code.
https://source.denx.de/u-boot/custodians/u-boot-microblaze
Xilinx chnages for v2023.04-rc1
makefile:
- Add multi_dtb_fit dependency
clk:
- Handle error cases
microblaze:
- Disable falcon mode and cleanup code around
xilinx:
- Enable regular expression matching in board_fit_config_name_match()
- Fix FRU handling for 0xC1 format
- Fix Xilinx legacy format eeprom parsing
zynqmp:
- Some DT updates/cleanups
- Fix IDcode for xck24
- Remove empty mini config files
- Add support for k24
versal:
versal_net:
- Setup timer when runs in EL3
- Build u-boot.elf for mini configurations
zynq-gem:
- Add support for new compatible strings
- Remove support for Avnet Ultrazedev SOM
- Handle SGMII with PCS phy
spi:
- Add support for gigadevice parts
misc:
- Remove CONFIG_TARGET_VENUS ifdef
- Add missing headers to remove sparse warnings
tuning_loop_counter is of char type, which is not capable of handling
the entire data range of this variable. This is pointed by below sparse
warning. Change datatype to int to fix this.
warning: comparison is always false due to limited range of data type.
Signed-off-by: Algapally Santosh Sagar <santoshsagar.algapally@amd.com>
Link: https://lore.kernel.org/r/20230120053617.32463-5-ashok.reddy.soma@amd.com
Signed-off-by: Michal Simek <michal.simek@amd.com>
This contains some fixes, and the first bunch of some clean up patches
to get rid of legacy GPIO and PMIC code.
Highlight is the DM AXP PMIC driver, which is required to convert some
drivers over to use DM regulators, and also is required to get rid
of some less optimal PMIC setup code in Trusted Firmware. This isn't
enabled by any defconfig yet, but can be enabled manually and works. For
the full glory some patches are still missing, and this requires more
testing, which would be simpler if the core code is upstream.
We need extensions to be set up before we start trying to boot any of the
bootdevs. Add a new priority before all the others for tht sort of thing.
Also add a 'none' option, so that the first one is not 0.
While we are here, comment enum bootdev_prio_t fully and expand the test
for the 'bootdev hunt' command.
Add a hunter for MMC. This doesn't do anything at present, since MMC is
currently set up when U-Boot starts. If MMC moves to lazy init then we can
add a hunter function.
The code in these functions turns out to often be the same. Add a default
get_bootflow() function and allow the drivers to select it by setting
the method to NULL.
This saves a little code space.
At present MMC uses the bootdev_setup_for_dev() function to set up the
bootdev. This is because MMC only has one block-device child, so does not
need to worry about naming of the bootdev.
However this inconsistency with other bootdevs that use block devices is a
bit annoying. The only real reason for it is to have a name like
'mmc0.bootdev' instead of 'mmc0.blk.bootdev'.
Update bootdev_setup_sibling_blk() to drop '.blk' from the name where it
appears, thus removing the only reason to use the bootdev_setup_for_dev().
Switch MMC over to the subling function.
When running multiple tests the mmc emulator calls malloc() to obtain the
memory for its disk image. Since the memory is not cleared, it is possible
that it happens to contain a partition table.
The dm_test_part() test (for one) relies on mmc0 being empty on startup.
Zero the memory to ensure that it is.
As the SPL code for sunxi boards does not use the driver model, we have
two mmc_ops structures, one for DM, one for non-DM. The actual hardware
access code is shared, with the respective callback functions using that
common code.
To make this more obvious and easier to read, reorder the functions to
group them: we first have the common code, then the non-DM bits, and
the proper DM implementation at the end.
Also document this structure in the comment at the beginning of the file.
No functional change intended.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Samuel Holland <samuel@sholland.org>
Tested-by: Samuel Holland <samuel@sholland.org>
The sunxi MMC code does not use the DM in the SPL, as we don't have a
device tree available that early, also no space for it.
This also means we cannot access the card-detect GPIO information from
there, so we have Kconfig symbols called CONFIG_MMCx_CD_PIN, which each
board has to define. This is a burden, also requires extra GPIO code in
the SPL.
As the SPL is the natural successor of the BootROM (from which we are
loaded), we can actually ignore the CD pin completely, as this is what
the BootROM does as well: CD GPIOs are board specific, but the BootROM
is not, so accesses the MMC devices anyway.
Also, as we must have been loaded from an MMC device when reaching this
code, there must have been a card in the slot.
Remove the card detect code from the non-DM implementation of the sunxi
MMC driver, to get rid of this unneeded code.
CONFIG_FSL_ESDHC_PIN_MUX
CONFIG_FLASH_SPANSION_S29WS_N
CONFIG_FLASH_VERIFY
CONFIG_FSL_FM_10GEC_REGULAR_NOTATION
CONFIG_FSL_ISBC_KEY_EXT
CONFIG_FSL_TRUST_ARCH_v1
CONFIG_FSL_SDHC_V2_3
CONFIG_MAX_DSP_CPUS
CONFIG_MIU_2BIT_INTERLEAVED
CONFIG_SERIAL_BOOT
CONFIG_SPI_BOOTING
CONFIG_X86EMU_RAW_IO
CONFIG_HSMMC2_8BIT
The rest of the unmigrated CONFIG symbols in the CONFIG_SYS namespace do
not easily transition to Kconfig. In many cases they likely should come
from the device tree instead. Move these out of CONFIG namespace and in
to CFG namespace.
Migrate all of COFIG_SYS_FSL* to the CFG_SYS namespace.
CONFIG_SYS_MMC_MAX_BLK_COUNT
When MMC_WRITE is disabled this driver produced a build error. Fix this.
Also update a comment while we are here.
Use the correct SPL_TPL_ variable so that these features can be enabled in
TPL and VPL as needed.
Disable it by default in TPL to avoid any code-size increase. No boards
are actually using it since the Makefile rules don't allow including
drivers/block/ with TPL_DM enabled. It can be manually enabled as needed.
Correct pointer dereferencing check to be more consistent.
Eliminate the below smatch warning:
drivers/mmc/mmc.c:3118 mmc_init_device()
warn: variable dereferenced before check 'm' (see line 3116)
Signed-off-by: Venkatesh Yadav Abbarapu <venkatesh.abbarapu@amd.com>
Reviewed-by: Michal Simek <michal.simek@amd.com>
Unconditionally clearing DTO when RXDR is set leads to spurious timeouts
in FIFO mode transfers if events occur in the following order:
mask = dwmci_readl(host, DWMCI_RINTSTS);
// Hardware asserts DWMCI_INTMSK_DTO here
dwmci_writel(host, DWMCI_RINTSTS, DWMCI_INTMSK_DTO);
if (mask & DWMCI_INTMSK_DTO) {
// Unreachable as DTO is cleared without being handled!
return 0;
Only clear interrupts that we have seen and are handling so that DTO is
not missed.
Tested-by: Jerome Forissier <jerome.forissier@linaro.org> (Rock PI 4B)
Tested-by: Quentin Schulz <quentin.schulz@theobroma-systems.com>
