This fixes the issue where mxs_dma_init() was called either twice or never,
without introducing any new init hooks.
The idea is to allow each and every device using the APBH DMA block to
configure and request only the channels it uses, instead of making it call init
for all the channels as is now.
The common DMA block init part, which only configures the block, is then called
from CPUs arch_cpu_init() call.
NOTE: This patch depends on:
http://patchwork.ozlabs.org/patch/150957/
Cc: Detlev Zundel <dzu@denx.de>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
This SD DMA function of i.MX28 is still apparently too experimental to be
enabled by default in 2012.04 release. Enable this feature only if the user
plans to tinker with DCache or explicitly enables it.
Fix:
mmc.c: In function 'mmc_bounce_buffer_start':
mmc.c:132:13: warning: no return statement in function returning
non-void [-Wreturn-type]
Cc: Andy Fleming <afleming@gmail.com>
Fix:
tegra2_mmc.c: In function 'mmc_send_cmd':
tegra2_mmc.c:230:3: warning: 'mask' may be used uninitialized in this
function [-Wuninitialized]
Cc: Doug Anderson <dianders@chromium.org>
Cc: Tom Warren <twarren@nvidia.com>
This utilizes the newly introduced bounce buffers in the MMC layer.
Cc: Fabio Estevam <festevam@gmail.com>
This implements generic bounce buffer at the end of MMC command submission
chain. Therefore if unaligned data are passed, they are copied. This stuff
should be pushed down into the MMC subsystem to squash all places generating
these unaligned data.
All boards are using the gen_atmel_mci driver now, so no need
to carry the old driver around.
Signed-off-by: Sven Schnelle <svens@stackframe.org>
gen_atmel_mci works on AVR32 as well, so no need to use the legacy
mmc driver. This also has the nice side effect of being able to use
SDHC cards an those boards.
Align the card status polling with the Linux kernel and retry the
command at least five times. Also some cards apparently mishandle the
status bits, so make sure to check the card state too.
Signed-off-by: Jan Kloetzke <jan.kloetzke@dspg.com>
A MMC/SD card may always go into the programming state (and hence be
busy) after a block write. Therefore always check the card state, even
after single block writes. On the other hand there is no need to check
the card status after a read.
Also make sure that errors during busy polling are propagated upwards.
We are seeing occasional timeouts in the Tegra mmc code when
we are reading from external MMC cards. These don't seem to be
detrimental if they are handled properly. This CL properly
clears the "normal interrupt status register" (norintsts) in
error conditions. If we don't do this, when we come back into
mmc_send_cmd() the register will still contain status from the
last transaction.
Signed-off-by: Doug Anderson <dianders@chromium.org>
Signed-off-by: Tom Warren <twarren@nvidia.com>
Before we can send a command we need both the DATI (command inhibit on
mmc_dat line) bit and CMDI (command inhibit on mmc_cmd line) are clear.
The previous behavior of only checking on DATI was insufficient on some
cards and incorrect behavior in any case. This makes the code check
for both bits being clear and makes the error print more clear as
to what happened. DATI_CMDDIS is removed as it was unused elsewhere
in the code and stood for 'DATI is set, cmds are disabled still'.
Fix originally spotted by Peter Bigot.
Tested-by: Peter A. Bigot <bigotp@acm.org>
Tested-by: Robert Nelson <robertcnelson@gmail.com>
Tested-by: Andreas Müller <schnitzeltony@googlemail.com>
This patch modifies mxcmmc.c to be used
not only by i.MX27 but also by i.MX31 boards.
Both use the same SD controller, but have different
clock set-ups.
The i.MX27 imx_get_XXXclock functions are made static to
generic.c and a public mxc_get_clock() function
is provided. Pins, base address and prototypes for
an i.MX31 specific board_init_mmc() are provided.
Some of the i.MX27 clock getters are unused and marked
as such to avoid warnings (./MAKEALL -s mx27), but
the code was left in for future use.
Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
When the data cache is enabled we must flush on write and invalidate
on read. We also check that buffers are aligned to data cache lines
boundaries. With recent work in U-Boot this should generally be the case
but the warnings will catch problems.
The pointer to the registers used to control the Freescale ESDHC MMC
controller is not initialized correctly when using PIO mode. This is
fixed by initializing the pointer in the same way as all other sites
within the driver.
Examining the commit history shows that this was broken at introduction
due to a code change in upstream U-Boot to support the mx51 processor
family.
Reported-by: Jim Lentz <JLentz@zhone.com>
Cc: Andy Fleming <afleming@freescale.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
On Tegra2, card-detection is implemented by passing the card-detection
GPIOs to the MMC driver at initialization time. Instead of implementing
the board_mmc_getcd() function, use the card-detect hook and allow
boards to override it by providing their own board_mmc_getcd()
implementation.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
This card-detect hook probably doesn't work. Perhaps somebody with more
knowledge about the hardware can comment on this. I think that perhaps
even the complete code from esdhc_init() could go into the getcd()
function instead or mmc_getcd() needs to be called at some later time
after mmc_init(), which, however, would require many other drivers to
change.
In addition to implementing the hook, this patch also removes the call
to the board_mmc_getcd() function which is now called from the MMC
framework and is no longer required here.
Tested-by: Jason Liu <jason.hui@linaro.org>
Check for card detect each time an MMC/SD device is initialized. If card
detection is not implemented, this code behaves as before and continues
assuming a card is present. If no card is detected, has_init is reset
for the MMC/SD device (to force initialization next time) and an error
is returned.
The new API no longer uses the extra cd parameter that was used to store
the card presence state. Instead, this information is returned via the
function's return value. board_mmc_getcd() returns -1 to indicate that
no card-detection mechanism is implemented; 0 indicates that no card is
present and 1 is returned if it was detected that a card is present.
The rationale for this change can be found in the following email
thread:
http://lists.denx.de/pipermail/u-boot/2011-November/110180.html
In summary, the old API was not consistent with the rest of the MMC API
which always passes a struct mmc as the first parameter. Furthermore the
cd parameter was used to mean "card absence" in some implementations and
"card presence" in others.
Fix:
mv_sdhci.c: In function 'mv_sdh_init':
mv_sdhci.c:47:22: warning: the comparison will always
evaluate as 'true' for the address of 'mv_sdhci_writeb'
will never be NULL [-Waddress]
Cc: Lei Wen <leiwen@marvell.com>
Acked-by: Lei Wen <leiwen@marvell.com>
This patch improve the performance by spliting flag examination code
in ftsdc010_send_cmd() into 3 functions.
This patch also reordered the function which made better capability to
some high performance cards against to the next version of ftsdc010
hardware.
Signed-off-by: Macpaul Lin <macpaul@andestech.com>
Add a host capability checking to avoid the mmc stack
switch the card to HIGHSPEED mode when the card supports
HIGHSPEED while the host doesn't.
This patch avoid furthur transaction problem when the
mmc/sd card runs different mode to the host.
The mmc host controller on the i.mx6q is called usdhc which
is redesigned based on the freescale esdhc controller.
The usdhc controller is almost compatible with esdhc except
it adds one mix register to support debug/SD3.0 and move
the low bit 0-6 of XFERTYP register to the mix control reg
low bit 0-6. Thus on i.mx6q, we have the following compared
with the previous soc: (can refer to RM of chapter 56.3.3)
i.mx6q:
mix control:
bit 31 - bit 7: Added for debug/SD3.0 support
bit 6 - bit 0: move in the XFERTYP register bit 6-0 on previous soc
XFERTYP register:
bit 31 - bit 7: the same as before,
bit 6 - bit 0: no-use
previous soc
mix control: no
XFERTYP register:
bit 31 - bit 0: xfertype information
Signed-off-by: Jason Liu <jason.hui@linaro.org>
tegra2_mmc_init() is implemented by the Tegra2 MMC driver. Since most of
the Tegra2-based boards will need to call it, this commit exports it in
the new public asm/arch/mmc.h header file to prevent each board from
providing its own prototype.
GPIO configuration shall never be done inside a driver, never.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Pass the GPIO numbers for power and card detect to tegra2_mmc_init(), and
modify that function to perform all required GPIO initialization. This
removes the need for board files to perform these operations.
Move board_mmc_getcd() into tegra2_mmc.c now that the driver knows which
GPIOs to use.
Update affected call-sites in seaboard.c and harmony.c. Note that this
change should make all SD ports work on Harmony, since the required GPIO
setup is now being performed.
v4: Fix prototype of tegra2_mmc_init() in board.h to match driver change.
Remove prototype of gpio_config_mmc() from board.h
Acked-by: Andy Fleming <afleming@freescale.com>
This reverts commit 02f3029f1810b99869254d0cf0a71946a008a728.
This patch add 3 times retry to CMD8 because the Marvell mmc controller
doesn't obey the power ramp up process in the SD specification 6.4.1.
(Please refer to figure 6.1 and 6.2 in the specification.)
The CMD0 should be send after power ramp up has been finished.
However, the Marvell mmc contorller must do power ramp up after the
first CMD0 command has been send.
This patch also affect existing platforms like Nokia N900 and other
platforms.
sdhci_readw does not work for host version read in Armada100 series
SoCs. This patch fix this issue by making a sdhci_readl call to get host
version.
Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
Fix:
davinci_mmc.c: In function 'dmmc_wait_fifo_status':
davinci_mmc.c:72:7: warning: variable 'mmcstatus1' set but not used [-Wunused-but-set-variable]
davinci_mmc.c: In function 'dmmc_busy_wait':
davinci_mmc.c:89:7: warning: variable 'mmcstatus1' set but not used [-Wunused-but-set-variable]
Delete the unused variable.
Cc: Sandeep Paulraj <s-paulraj@ti.com>
* 'master' of git://git.denx.de/u-boot-arm:
arm, davinci: add DAVINCI_MMC_CLKID
arm, davinci_emac: fix driver bug if more then 3 PHYs are detected
arm, davinci: da850/dm365 lowlevel cleanup
omap5: Add omap5_evm board build support.
omap4/5: Add support for booting with CH.
omap5: emif: Add emif/ddr configurations required for omap5 evm
omap5: clocks: Add clocks support for omap5 platform.
omap5: Add minimal support for omap5430.
omap: Checkpatch fixes
omap4: make omap4 code common for future reuse
GCC4.6: Squash warnings in onenand_base.c
GCC4.6: Fix common/usb.c on xscale
OneNAND: Add simple OneNAND SPL
PXA: vpac270: Enable the new generic MMC driver
PXA: Cleanup serial_pxa
PXA: Drop csb226 and innokom boards (unmaintained)
m28evk: Fix comment about the number of RAM banks
mx31: Fix checkpatch warnings in generic.c
mx31: Use proper IO accessor for GPR register
mx31: Remove duplicate definition for GPR register
qong: Use generic function for configuring GPR register
M28EVK: Enable USB HOST support
iMX28: Add USB HOST driver
iMX28: Add USB and USB PHY register definitions
M28: Add memory detection into SPL
iMX28: Fix ARM vector handling
M28: Add doc/README.m28 documentation
M28: Add MMC SPL
iMX28: Add support for DENX M28EVK board
iMX28: Add u-boot.sb target to Makefile
iMX28: Add image header generator tool
iMX28: Add driver for internal RTC
iMX28: Add GPMI NAND driver
iMX28: Add APBH DMA driver
iMX28: Add SPI driver
iMX28: Add GPIO control
iMX28: Add I2C bus driver
iMX28: Add PINMUX control
FEC: Add support for iMX28 quirks
iMX28: Add SSP MMC driver
iMX28: Initial support for iMX28 CPU
MX25: zmx25: GCC4.6 fix build warnings
da850: add new config file for AM18xx
BeagleBoard: config: Switch to ttyO2
OMAP3: Change omap3_evm maintainer
devkit8000: Fix NAND SPL on boards with 256MB NAND
integrator: enable Vpp and disable flash protection
integrator: add system controller header
integrator: make flash writeable on boot
integrator: use io-accessors for board init
integrator: move text offset to config
integrator: pass configs for core modules
ARM: remove superfluous setting of arch_number in board specific code.
SPL: Allow ARM926EJS to avoid compiling in the CPU support code
integrator: do not test first part of the memory
arm: a320: fix broken timer
ARM: define CONFIG_MACH_TYPE for all ronetix boards
dm646x: pass board revision info to kernel
dm646x: add new configuration for dm6467T
arm, davinci: Fix setting of the SDRAM configuration register
arm, davinci: Remove the duplication of LPSC functions
arm, davinci: Rename AM1808 lowlevel functions to DA850
da8xxevm: fix build error
ARM: re-add MACH_TYPE_XXXXXX for VCMA9 board and add CONFIG_MACH_TYPE
Fixing them here so that when the files are reused in
subsequent patches for omap5, avoids new checkpatch
warnings.
Signed-off-by: sricharan <r.sricharan@ti.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
This is a well encapsulated section of mmc_send_cmd, by moving
it to it's own function it increases the readability of mmc_send_cmd.
Signed-off-by: Anton Staaf <robotboy@chromium.org>
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Currently when no expected completion condition occures in the
mmc_send_cmd while loop that is waiting for a data transfer to
complete the MMC driver just hangs.
This patch adds an arbitrary 2 second timeout. If nothing we
recognize occures within 2 seconds some diagnostic information
is printed and we fail out.
Currently if a DMA buffer straddles a buffer alignment boundary
(512KiB) then the DMA engine will pause and generate a DMA
interrupt. Since the DMA interrupt is not enabled it will hang
the MMC driver.
This patch adds support for restarting the DMA transfer. The
SYSTEM_ADDRESS register contains the next address that would have
been read/written when a boundary is hit. So we can read that
and write it back. The write triggers the resumption of the
transfer.
This moves the magic numbers sprinkled about the MMC driver
to a single location in the header file and gives them
meaningful names.
Acked-by: Andy Fleming <afleming@gmail.com>
The new IO FPGA implementation for Versatile Express contains an MMCI
(PL180) cell with the FIFO extended to 128 words. This causes the
read_bytes() function to go into an infinite loop; as it will wait for
for the half-full signal (SDI_STA_RXFIFOBR) if there are more than 8
words remaining (SDI_FIFO_BURST_SIZE), but it won't receive this signal
once there are fewer than 64 words left to transfer.
One possible fix is to add some build time configuration to change
SDI_FIFO_BURST_SIZE for the new implementation. However, the problematic
code only seems to exist as a small performance optimisation, so the
solution implemented by this patch is to simply remove it. The error
checking following the loop is also removed as this will be handled by
code further down the function.
Signed-off-by: Jon Medhurst <jon.medhurst@linaro.org>
This centralizes knowledge of MMC clocking into the MMC driver. This also
removes clock setup from the board files, which will simplify later changes
that modify the Harmony board to support the correct set of MMC controllers.
SDHCI spec need to reset the sdma base address while the software
try to accorss the 512k bytes address boundary. When meet such
accross behavior, sdhci controller would generate a interrupt
automatically, and software need handle this.
Signed-off-by: Lei Wen <leiwen@marvell.com>
So that sdhci host would tell in the driver that the mmc current
attributes.
Only flush the memory range needed.
As per JEDEC document JESD84-A441 (page 105) response for CMD7
(MMC_CMD_SELECT_CARD) response should be R1 instead of R1b. In uboot we
never take MMC to disconnected state and on powerup its always ideal
state which later goes to stand-by state.
from document footnote:
R1 while selecting from Stand-By State to Transfer State; R1b while
selecting from Disconnected State to Programming State.
For we don't know mmc bus width from reading registers, the only way
to check is to test.
Current compare offset is:
EXT_CSD_PARTITIONING_SUPPORT
EXT_CSD_ERASE_GROUP_DEF
EXT_CSD_REV
EXT_CSD_HC_ERASE_GRP_SIZE
EXT_CSD_SEC_CNT
Previous magic number is hard to parse its meaning, change it to
respective macro definition
Acked-by: WOlfgang Denk <wd@denx.de>
Marvell 88SV331xV5 platform's sdhci host control is not very standard
with the spec in the 8bit handling. It need to set its private register
to switch to the 8bit mode which is not included in the standard sdhci
registers.
This patch mainly hacks the writeb method, and set its private register
if it find the driver is going to switch to the 8bit mode.
For some controller it has dynamic clock gating, and only toggle out clk
when the first cmd0 send out, while some card strictly obey the 74
clocks rule, the interval may not be sufficient between the cmd0 and
this cmd8, retry to fulfil the clock requirement.
Tested-by: Marek Vasut <marek.vasut@gmail.com>
ARM: Add Calxeda Highbank platform
dkb: make mmc command as default enabled
Marvell: dkb: add mmc support
ARM: pantheon: add mmc definition
davinci: remove config.mk file from the sources
ARM:AM33XX: Add support for TI AM335X EVM
ARM:AM33XX: Added timer support
ARM:AM33XX: Add emif/ddr support
ARM:AM33XX: Add clock definitions
ARM:AM33XX: Added support for AM33xx
omap3/emif4: fix registers definition
davinci: remove obsolete macro CONFIG_EMAC_MDIO_PHY_NUM
davinci: emac: add support for more than 1 PHYs
davinci: emac: add new features to autonegotiate for EMAC
da850evm: Move LPSC configuration to board_early_init_f()
omap4_panda: Build in cmd_gpio support on panda
omap: Don't use gpio_free to change direction to input
mmc: omap: Allow OMAP_HSMMC[23]_BASE to be unset
OMAP3: overo : Add environment variable optargs to bootargs
OMAP3: overo: Move ethernet CS4 configuration to execute based on board id
OMAP3: overo : Use ttyO2 instead of ttyS2.
da830: add support for NAND boot mode
dm36x: revert cache disable patch
dm644X: revert cache disable patch
devkit8000: Add malloc space
omap: spl: fix build break due to changes in FAT
OMAP3 SPL: Provide weak omap_rev_string
omap: beagle: Use ubifs instead of jffs2 for nand boot
omap: overo: Disable pull-ups on camera PCLK, HS and VS signals
omap: overo: Configure mux for gpio10
SPL: Add DMA library
omap3: Add interface for omap3 DMA
omap3: Add DMA register accessors
omap3: Add Base register for DMA
arm, davinci: add missing LSPC define for MMC/SD1
U-Boot/SPL: omap4: Make ddr pre-calculated timings as default.
DaVinci: correct MDSTAT.STATE mask
omap4: splitting padconfs into common, 4430 and 4460
omap4: adding revision detection for 4460 ES1.1
omap4: replacing OMAP4_CONTROL with OMAP4430_CONTROL
gplug: fixed build error as a result of code cleanup patch
kirkwood_spi: add dummy spi_init()
gpio: mvmfp: reduce include platform file
ARM: orion5x: reduce dependence of including platform file
serial: reduce include platform file for marvell chip
ARM: kirkwood: reduce dependence of including platform file
ARM: armada100: reduce dependence of including platform file
ARM: pantheon: reduce dependence of including platform file
Armada100: Add env storage support for Marvell gplugD
Armada100: Add SPI flash support for Marvell gplugD
Armada100: Add SPI support for Marvell gplugD
SPI: Add SPI driver support for Marvell Armada100
dreamplug: initial board support.
imx: fix coding style
misc: pmic: drop old Freescale's pmic driver
MX31: mx31pdk: use new pmic driver
MX31: mx31ads: use new pmic driver
MX31: mx31_litekit: use new pmic driver
MX5: mx53evk: use new pmic driver
MX5: mx51evk: use new pmic driver
MX35: mx35pdk: use new pmic driver
misc: pmic: addI2C support to pmic_fsl driver
misc: pmic: use I2C_SET_BUS in pmic I2C
MX5: efikamx/efikasb: use new pmic driver
MX3: qong: use new pmic driver
RTC: Switch mc13783 to generic pmic code
MX5: vision2: use new pmic driver
misc: pmic: Freescale PMIC switches to generic PMIC driver
misc:pmic:samsung Enable PMIC driver at GONI target
misc:pmic:max8998 MAX8998 support at a new PMIC driver.
misc:pmic:core New generic PMIC driver
mx31pdk: Remove unneeded config
mx31: provide readable WEIM CS accessor
MX51: vision2: Set global macros
I2C: Add i2c_get/set_speed() to mxc_i2c.c
ARM: Update mach-types
devkit8000: Add config to enable SPL MMC boot
devkit8000: protect board_mmc_init
arm, post: add missing post_time_ms for arm
cosmetic, post: Codingstyle cleanup
arm, logbuffer: make it compileclean
tegra2: Enable MMC for Seaboard
tegra2: Add more pinmux functions
tegra2: Rename PIN_ to PINGRP_
tegra2: Add more clock functions
tegra2: Clean up board code a little
tegra2: Rename CLOCK_PLL_ID to CLOCK_ID
