path: root/drivers/mmc/sunxi_mmc.c
2020-05-18common: Drop linux/delay.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-01-29mmc: sunxi: Honour non-removable property in DTAndre Przywara
If a board DT describes a cd-gpios property, but also marks the storage as non-removable, we must ignore the GPIO (as Linux does). Teach the DM_MMC part of the Allwinner MMC driver about the non-removable DT property, to fix DM_MMC access on the SoPine and Pine64-LTS board. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Jagan Teki <jagan@openedev.com>
2019-01-29mmc: sunxi: Add DM clk and reset supportAndre Przywara
Now that we have the gate clocks and the reset gates in our new Allwinner clock driver, let's make use of them in the MMC driver, when DM_MMC is defined. We treat the reset device as optional now, as the older SoCs don't implement it. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2019-01-29mmc: sunxi: Add DM_MMC support for A80Jagan Teki
A80 gates clock already be part of CLK framework, so just add mod_clk offset with A80 compatible string. Cc: Rask Ingemann Lambertsen <rask@formelder.dk> Cc: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Andre Przywara <andre.przywara@arm.com>
2019-01-29mmc: sunxi: Add DM_MMC support for H6Jagan Teki
Unlike other Allwinner SoC's, H6 uses a different MMC mod clock offset. Connect that with the respective compatible string. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2019-01-29mmc: sunxi: Add remaining compatible stringsJagan Teki
Add MMC compatible strings for A83T, A64, H5. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2019-01-10mmc: sunxi: Fix mmc clocks for DM_MMCJagan Teki
Existing clock configure code has been followed based on the legacy MMC dt node definitions and it cannot work with recent dts(i) sync from Linux. So, add clock configure code for Allwinner platforms which support DM_MMC and eventually this will drop once CLK support is in Mainline. Fixes: 3c92cca3cda0 ("ARM: dts: sun4i: Update A10 dts(i) files from Linux-v4.18-rc3") Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Priit Laes <plaes@plaes.org> # Gemei G9 A10 Tablet Tested-by: Marek Kraus <gamelasterv2@gmail.com> # A10-OLinuXino-Lime
2018-11-22sunxi-mmc: use new mode on both controllers on A64Vasily Khoruzhick
Using new mode improves stability of eMMC and SD cards. Without it SPL fails to load u-boot from SD on Pinebook. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Reviewed-by: Chen-Yu Tsai <wens@csie.org> Tested-by: Jagan Teki <jagan@amarulasolutions.com> # Amarula A64-Relic Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-11-22sunxi-mmc: don't double clock for new mode unconditionallyVasily Khoruzhick
Comment in Linux driver says that clock needs to be doubled only if we use DDR modes, moreover divider has to be set accordingly. U-boot driver doesn't declare support for any DDR modes and doesn't set internal clock divider in CLKCR, so it doubles clock unconditionally when new mode is used. Some cards can't handle that and as result SPL fails to load u-boot. Fixes: de9b1771c3b ("mmc: sunxi: Support new mode") Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> # Amarula A64-Relic
2018-11-22sunxi-mmc: introduce new MMC_SUNXI_HAS_MODE_SWITCH optionVasily Khoruzhick
Allwinner A64 has new mode but doesn't have a mode switch in CCM, and CCM_MMC_CTRL_MODE_SEL_NEW is not defined, so compilation fails if MMC_SUNXI_HAS_NEW_MODE is enabled Introduce new MMC_SUNXI_HAS_MODE_SWITCH option to be able to ifdef usage of CCM_MMC_CTRL_MODE_SEL_NEW Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com> [jagan: update commit message] Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> # Amarula A64-Relic
2018-11-13mmc: sunxi: add support for automatic delay calibrationVasily Khoruzhick
A64 and H6 support automatic delay calibration and Linux driver uses it instead of hardcoded delays. Add support for it to u-boot driver. Fixes eMMC instability on Pinebook Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Tested-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Andre Przywara <andre.przywara@arm.com> Cc: Vagrant Cascadian <vagrant@debian.org> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-07-31sunxi: add MMC support for H6Icenowy Zheng
The Allwinner H6 SoC has 3 MMC controllers like the ones in A64, with the MMC2 come with the capability to do crypto by EMCE. Add MMC support for H6. EMCE support is not added yet. Signed-off-by: Icenowy Zheng <icenowy@aosc.io> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2018-07-16dm: mmc: sunxi: Add A10/A20 compatible stringsAdam Sampson
Commit dd27918c2252 ("dm: mmc: sunxi: Add support for driver model") only added the allwinner,sun5i-a13-mmc compatible string for this driver. The DM initialisation code here also works with (at least) A10 and A20, so add the appropriate compatible strings as per Linux 4.17's driver. Tested on A10 Cubieboard and A20 pcDuino3 Nano with CONFIG_DM_MMC. (A20 worked already, because sun7i-a20.dtsi specifies both the A13 and A20 strings.) Signed-off-by: Adam Sampson <ats@offog.org> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2018-04-25sunxi: improve throughput in the sunxi_mmc driverPhilipp Tomsich
Throughput tests have shown the sunxi_mmc driver to take over 10s to read 10MB from a fast eMMC device due to excessive delays in polling loops. This commit restructures the main polling loops to use get_timer(...) to determine whether a (millisecond) timeout has expired. We choose not to use the wait_bit function, as we don't need interruptability with ctrl-c and have at least one case where two bits (one for an error condition and another one for completion) need to be read and using wait_bit would have not added to the clarity. The observed speedup in testing on a A31 is greater than 10x (e.g. a 10MB write decreases from 9.302s to 0.884s). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com> Tested-by: Mylène Josserand <mylene.josserand@bootlin.com> Acked-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-04-23sunxi: mmc: Fix phase delaysStefan Mavrodiev
U-boot driver for sunxi-mmc uses PLL6, unlike linux kernel where PLL5 is used, with clock rates respectively 600MHz and 768MHz. Thus there are different phase degree steps - 24 for the kernel and 30 for u-boot. In the kernel driver the phase is set 90 deg for output and 120 for sample. Dividing by 30 will result values 3 and 4. Those are the values set in the u-boot driver. However, the condition defining delays is wrong. MMC core driver requests clock of 52MHz, sunxi-driver sets clock of 50MHz, but phase is set 30 deg for output and 120 deg for sample. Apparently this works for most cards. On A20-SOM204-EVB-eMMC there is eMMC card (KLMAG2GEND) which complains about it. Maybe there is other boards with similar problem? So the fix is to match delays for both u-boot and kernel. Signed-off-by: Stefan Mavrodiev <stefan@olimex.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-03-13mmc: sunxi: support cd-invertedHeinrich Schuchardt
With CONFIG_DM_MMC the BananaPi does not detect SD cards. The sunxi device trees use the cd-inverted property to indicate that the card detect is inverted. This property is documented in Linux kernel devicetree/bindings/mmc/mmc.txt The property is not marked as deprecated. A similar patch was posted by Tuomas but is in status "Changes Requested". https://patchwork.ozlabs.org/patch/850377/ This patch is a stripped down version of his patch. Suggested-by: Tuomas Tynkkynen <tuomas@tuxera.com> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-09-01mmc: sunxi: Only update timing mode bit when enabling new timing modeChen-Yu Tsai
When enabling the new mmc timing mode, we inadvertently clear all the remaining bits in the new timing mode register. The bits cleared include a default phase delay on the output clock. The BSP kernel states that the default values are supposed to be used. Clearing them results in decreased performance or transfer errors on some boards. Fixes: de9b1771c3b6 ("mmc: sunxi: Support new mode") Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-08-28mmc: sunxi: fix legacy MMC initialisationMaxime Ripard
The driver-model rework changed, among other things, the way the private data were moved around. It now uses the private field in the struct mmc. However, the mmc_create argument was changed in the process to always pass the array we used to have to store our private structures. The basically means that all the MMC driver instances will now have the private data of the first instance, which obviously doesn't work very well. Pass the proper pointer to mmc_create. Fixes: 034e226bc77e ("dm: mmc: sunxi: Pass private data around explicitly") Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Tested-by: Chen-Yu Tsai <wens@csie.org> Tested-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-08-28mmc: sunxi: Support new modeMaxime Ripard
Almost all of the newer Allwinner SoCs have a new operating mode for the eMMC clocks that needs to be enabled in both the clock and the MMC controller. Details about that mode are sparse, and the name itself (new mode vs old mode) doesn't give much details, but it seems that the it changes the sampling of the MMC clock. One side effect is also that it divides the parent clock rate by 2. Add support for it through a Kconfig option. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-08-01dm: mmc: sunxi: Add support for driver modelSimon Glass
Add a driver-model version of this driver which mostly uses the existing code. The old code can be removed once all boards are switched over. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-01dm: mmc: sunxi: Drop mmc_clk_io_on()Simon Glass
This function has #ifdefs in it which we want to avoid for driver model. Instead we should use different compatible strings and the .data field. It also uses the MMC device number which is not available in driver model except through aliases. Move the function's into its caller so that the driver-model version can do things its own way. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-08-01dm: mmc: sunxi: Pass private data around explicitlySimon Glass
At present the driver-private data is obtained in various functions by various means. With driver model this is provided automatically. Without driver model it comes from a C array declared at the top of the file. Adjust internal functions so that they are passed the private data as a parameter, allowing the caller to obtain it using either means. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-08-01dm: mmc: sunxi: Rename mmchost to privSimon Glass
Use the driver-model naming convention for this structure. It is data private to the driver so the local variable should be called 'priv'. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-08-01dm: mmc: sunxi: Rename struct sunxi_mmc_host to sunxi_mmc_privSimon Glass
Use the driver-model naming convention for this structure. It is data private to the driver. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-01-11mmc: change the set_ios return type from void to intJaehoon Chung
To maintain consistency, set_ios type of legacy mmc_ops changed to int. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-11-16mmc: sunxi: Enable 8bits bus width for sun8iMaxime Ripard
The sun8i SoCs also have a 8 bits capable MMC2 controller. Enable the support for those too. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Hans de Goede <hdegoede@redhat.com>
2016-08-05mmc: use the generic error numberJaehoon Chung
Use the generic error number instead of specific error number. If use the generic error number, it can debug more easier. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2016-07-15sunxi: Use BROM stored boot_media value to determine our boot-sourceHans de Goede
Now that we know that the BROM stores a value indicating the boot-source at the beginning of SRAM, use that instead of trying to recreate the BROM's boot probing. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-07-15sunxi: mmc: increase status register polling rate for data transfersTobias Doerffel
With a recent bunch of SD3.0 cards in our A20-based board we experienced data transfer rates of about 250 KiB/s instead of 10 MiB/s with previous cards from the same vendor (both 4 GB/class 10). By increasing status register polling rate from 1 kHz to 1 MHz we were able to reach the original transfer rates again. With the old cards we now even reach about 16 MiB/s. Signed-off-by: Tobias Doerffel <tobias.doerffel@ed-chemnitz.de> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-04-01sunxi: Add support for Allwinner A64 SoCsSiarhei Siamashka
The Allwinner A64 SoC is used in the Pine64. This patch adds all bits necessary to compile U-Boot for it running in AArch64 mode. Unfortunately SPL is not ready yet due to legal problems, so we need to boot using the binary boot0 for now. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> [agraf: remove SPL code, move to AArch64] Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-04-01sunxi: Explicitly cast u32 pointer conversionsAlexander Graf
Some parts of the sunxi code cast explicitly between u32 values and pointers. This is not a problem in practice, because all 64bit SoCs today only use the lower 32 bits for their phyical address space. But we need to make sure that the compiler is sure this is not an accident as well. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-01-13block: pass block dev not num to read/write/erase()Stephen Warren
This will allow the implementation to make use of data in the block_dev structure beyond the base device number. This will be useful so that eMMC block devices can encompass the HW partition ID rather than treating this out-of-band. Equally, the existence of the priv field is crying out for this patch to exist. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-09-29sunxi: mmc: Fix clk-delay settingsHans de Goede
In recent allwinner kernel sources the mmc/sdio clk-delay settings have been slightly tweaked, and for sun9i they are completely different then what we are using. This commit brings us in sync with what allwinner does, fixing problems accessing sdcards on some A33 devices (and likely others). For pre sun9i hardware this makes the following changes: -At 400Khz change the sample delay from 7 to 0 (first introduced in A31 sdk) -At 50 Mhz change the sample delay from 5 to 4 (first introduced in A23 sdk) -Above 50 MHz change the out delay from 2 to 1 (first introduced in A20 sdk) Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-08-31sunxi: mmc: set transfer timeout according to byte_cnt.Yousong Zhou
Originally a timeout value of 2 seconds was used regardless of the size of data to be transfered. This prevented slow devices from working correctly while there was no much gain for faster devices, e.g. it takes 3708ms for a transfer of uImage of size 1899008 bytes. Signed-off-by: Yousong Zhou <yszhou4tech@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-07-24sunxi: Create helper function veryfing valid boot signature on MMCDaniel Kochmański
This patch extracts checking for valid SD card "eGON.BT0" signature from `board_mmc_init` into function `sunxi_mmc_has_egon_boot_signature`. Buffer for mmc sector is allocated and freed at runtime. `panic` is triggered on malloc failure. Signed-off-by: Daniel Kochmański <dkochmanski@turtle-solutions.eu> CC: Roy Spliet <r.spliet@ultimaker.com> Cc: Ian Campbell <ijc@hellion.org.uk> [hdegoede@redhat.com: Small bugfix to make it work for devs other then mmc0] Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-06-04sunxi: mmc: Enable pull-up on card-detect gpio pinHans de Goede
On some boards we need to enable the internal pull-up te reliable detect that no card is inserted. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-05-05Merge branch 'master' of git://git.denx.de/u-boot-mmcTom Rini
2015-05-05mmc: remove the MMC_MODE_HC flagRob Herring
High capacity support is not a host capability, but a device capability that is queried via the OCR. The flag in the operating conditions request argument can just be set unconditionally. This matches the Linux implementation. [panto] Hand merged and renumbering MMC_MODE_DDR_52MHz. Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
2015-05-04sunxi: mmc: Fix card-detect gpio handling to work with the driver-modelHans de Goede
The driver-model gpio functions may return another value then -1 as error, make the sunxi mmc code properly handle this. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-04sunxi: Introduce a hidden SUNXI_GEN_SUNxI Kconfig boolHans de Goede
sun6i and newer (derived) SoCs such as the sun8i-a23, sun8i-a33 and sun9i have a various things in common, like having separate ahb reset control registers, the SID living inside the pmic, custom pmic busses, new style watchdog, etc. This commit introduces a new hidden SUNXI_GEN_SUN6I Kconfig bool which can be used to check for these features avoiding the need for an ever growing list of "#if defined CONFIG_MACH_SUN?I" conditionals as we add support for more "new style" sunxi SoCs. Note that this commit changes the behavior of the gmac and hdmi code for sun8i and the upcoming sun9i devices. This does not matter as sun8i does not have gmac nor hdmi, and sun9i has new hardware-blocks for these so the old code will not work there. Also this is intentional as if a sun8i / sun9i variant which does use the old hwblocks shows up then the GEN_SUN6I code paths will be the right ones to use. For completeness this also adds a SUNXI_GEN_SUN4I bool for A10/A13/A20. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-21sunxi: mmc: Always declare High Capacity capabilityHans de Goede
High Capacity (e)MMC cards work fine on sun4i / sun5i, and not having this capability set causes u-boot to not recognize the eMMC on an Utoo P66 A13 tablet, so always set it thereby fixing this. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-02sunxi: mmc: Add 'sunxi_' prefix to the static functionsSiarhei Siamashka
This results in a much more readable callgraph, because now they can't be confused with the function having exactly the same name in the generic mmc code. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-22sunxi: mmc: Add support for sun9i (A80)Hans de Goede
The clocks on the A80 are hooked up slightly different, add support for this. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-22sunxi: mmc: Use a realistic timeout when sending a mmc commandHans de Goede
Wait 1 second for the sdcard to respond, rather then waiting for 0xfffff milliseconds. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14mmc: sunxi: Fix misuse of gpio_direction_input()Axel Lin
It does not make sense to make gpio_direction_input() return the gpio input status. The return value of gpio_direction_input() is inconsistent if CONFIG_DM_GPIO is defined. And we don't need to call gpio_direction_input() int sunxi_mmc_getcd(). Just init the gpio once in mmc_resource_init() is enough. Signed-off-by: Axel Lin <axel.lin@ingics.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: mmc: Properly setup mod-clk and clock sampling phasesHans de Goede
The sunxi mmc controller has both an internal clock divider, as well as the divider in the mod0-clk for the mmc controller. The internal divider cannot be used, as it conflicts with the setting of clock sampling phases which is done in the mod0-clk, so it must be set to 0 (divide by 1). For some reason while the kernel has had this correct from day one, the u-boot sunxi mmc code has been using a fixed mod0-clk and setting its internal divider depending on the desired speed. This is something which we've inherited from the original Allwinner u-boot sources, but while this has been fixed in Allwinner's own u-boot code at least for the A23 and later upstream u-boot was still doing this wrong. This commit fixes this, thereby also fixing mmc support not working reliable on the A23 (which seems more sensitive to this) and possible also fixes some other sunxi mmc issues. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-05dm: sunxi: Request card detect gpioHans de Goede
This is necessary for the device-model enabled builds to work properly. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-05sunxi: Use CONFIG_MACH_SUN?I from Kconfig instead of CONFIG_SUN?IIan Campbell
Mostly automatic with: sed -i -e 's/CONFIG_\(SUN[45678]I\)/CONFIG_MACH_\1/g' $(git grep -l CONFIG_SUN[45678]I) followed by removing the relevant #defines from include/configs/sun?i.h by hand. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
