path: root/drivers/mmc/socfpga_dw_mmc.c
2015-12-20arm: socfpga: fix up a questionable macro for SDMMCDinh Nguyen
Move the macro into the socfpga_dwmci_clksel(). Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com> Signed-off-by: Marek Vasut <marex@denx.de> [fix parenthesis in the sdmmc_mask]
2015-12-07mmc: dwmmc: socfpga: Convert to DMMarek Vasut
Convert the SoCFPGA shim for registering the DWMMC driver to DM. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com>
2015-11-30mmc: socfpga_dw_mmc: Move drvsel and smplsel to dtsChin Liang See
socfpga_dw_mmc driver will obtain the drvsel and smplsel value from device tree instead of definition in config header file. Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Dinh Nguyen <dinh.linux@gmail.com> Cc: Pavel Machek <pavel@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Cc: Jaehoon Chung <jh80.chung@samsung.com> Acked-by: Marek Vasut <marex@denx.de>
2015-09-04mmc: dw_mmc: Probe the MMC from OFMarek Vasut
Rework the driver to probe the MMC controller from Device Tree and make it mandatory. There is no longer support for probing from the ancient qts-generated header files. This patch now also removes previous temporary workaround. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Tom Rini <trini@konsulko.com>
2014-10-06arm: socfpga: mmc: Pick the clock from clock managerPavel Machek
Make the SoCFPGA MMC stub pick clock via the clock manager frequency accessors instead of hard-coding the frequency. Also fix calloc() misuse. Signed-off-by: Pavel Machek <pavel@denx.de> Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Acked-by: Dinh Nguyen <dinguyen@opensource.altera.com>
2014-08-30socfpga: cleanup socfpga_dw_mmcPavel Machek
Cleanups as suggested by wd on mailing list. Signed-off-by: Pavel Machek <pavel@denx.de> Acked-by: Chin Liang See <clsee@altera.com>
2014-08-29socfpga: fix clock manager register definitionPavel Machek
Structure defining clock manager hardware was wrong, leading to wrong registers being accessed and hang in MMC init. This fixes structure to match hardware. Signed-off-by: Pavel Machek <pavel@denx.de>
2014-01-09socfpga/dwmmc: Adding DesignWare MMC driver support for SOCFPGAChin Liang See
To add the DesignWare MMC driver support for Altera SOCFPGA. It required information such as clocks and bus width from platform specific files (SOCFPGA handoff files) Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Rajeshwari Shinde <rajeshwari.s@samsung.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
