path: root/drivers/mmc/s5p_mmc.c
2012-01-08mmc: Implement card detection.Thierry Reding
Check for card detect each time an MMC/SD device is initialized. If card detection is not implemented, this code behaves as before and continues assuming a card is present. If no card is detected, has_init is reset for the MMC/SD device (to force initialization next time) and an error is returned. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Tested-by: Jason Liu <jason.hui@linaro.org>
2011-09-03mmc: S5P: Support DMA restarts at buffer boundariesAnton Staaf
Currently if a DMA buffer straddles a buffer alignment boundary (512KiB) then the DMA engine will pause and generate a DMA interrupt. Since the DMA interrupt is not enabled it will hang the MMC driver. This patch adds support for restarting the DMA transfer. The SYSTEM_ADDRESS register contains the next address that would have been read/written when a boundary is hit. So we can read that and write it back. The write triggers the resumption of the transfer. Signed-off-by: Anton Staaf <robotboy@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Tested-by : Jaehoon Chung <jh80.chung@samsung.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-07-15mmc: Access mode validation for eMMC cards > 2 GiBŁukasz Majewski
This patch provides handling of the two way handshake when SEND_OP_COND (CMD1) is send to mmc card. It is necessary to inform eMMC card if the host can work with high capacity cards (Jedec JESD84-A441, point 7.4.3). The extra flag MMC_MODE_HC (high capacity) is added to indicate if the host is capable of handling the high capacity eMMC cards. Since this change is added to the generic mmc framework, then it requires other boards to indicate if their mmc controllers can handle high capacity cards. As it is now - the old behaviour of the framework is preserved. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2011-05-26S5P: add set_mmc_clk for external clock controlJaehoon Chung
This patch added set_mmc_clk for external clock control. c210 didn't support host clock control. So We need external_clock_control function for c210. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2011-05-26MMC S5P: Fix typoDirk Behme
Fix typo resulting in the compilation error s5p_mmc.c: In function 's5p_mmc_initialize': s5p_mmc.c:469: error: 'struct mmc' has no member named 'm_bmax' introduced by commit "MMC: make b_max unconditional" (8feafcc49c0b7a9c541904f95a43dbef2fecc38b) Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> CC: John Rigby <john.rigby@linaro.org> CC: Andy Fleming <afleming@freescale.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-04-29MMC: make b_max unconditionalJohn Rigby
Make existing field b_max field in struct mmc unconditional and use it instead of CONFIG_SYS_MMC_MAX_BLK_COUNT in mmc_bread and mmc_bwrite. Initialize b_max to CONFIG_SYS_MMC_MAX_BLK_COUNT in mmc_register if it has not been initialized by the hw driver. Initialize b_max to 0 in all callers to mmc_register. Signed-off-by: John Rigby <john.rigby@linaro.org> Signed-off-by: Andy Fleming <afleming@freescale.com>
2011-03-27S5P: mmc: Resolved interrupt error during mmc_initChander Kashyap
Blocksize was hardcoded to 512 bytes. But the blocksize varies depeding on various mmc subsystem commands (between 8 and 512). This hardcoding was resulting in interrupt error during data transfer. It is now calculated based upon the request sent by mmc subsystem. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-10-19s5p_mmc: support 8-bit bus widthJaehoon Chung
This Patch do support 8-bit bus width for s5p So we add parameter for bus_width (in s5p_mmc_init(), s5p_mmc_initialize()) If want to use 8-bit bus width, only change (0, 8) instead of (0, 4). Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-08-17S5P: Use accessor functions instead of SoC specific defines to access the ↵Minkyu Kang
base address This patch is intended to prepare the other S5P SoC. (s5pc210) If use SoC specific defines then can't share with other SoC. So, make the accessor functions for access the base address by common way. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-08-10S5P: mmc: use the standard debug macroMinkyu Kang
Use the standard debug macro instead of the costom macro Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Cc: Wolfgang Denk <wd@denx.de>
2010-08-03S5P: support mmc driverMinkyu Kang
This patch adds support mmc driver for s5p SoC Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
