path: root/drivers/mmc/pic32_sdhci.c
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-23mmc: sdhci: Distinguish between base clock and maximum peripheral frequencyStefan Herbrechtsmeier
The sdhci controller assumes that the base clock frequency is fully supported by the peripheral and doesn't support hardware limitations. The Linux kernel distinguishes between base clock (max_clk) of the host controller and maximum frequency (f_max) of the card interface. Use the same differentiation and allow the platform to constrain the peripheral interface. Signed-off-by: Stefan Herbrechtsmeier <stefan.herbrechtsmeier@weidmueller.com>
2017-01-13mmc: pic32_sdhci: rename {pci->pic}32_sdhci_get_cdMasahiro Yamada
I suspect this is a typo. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-01-11mmc: sdhci: remove the SDHCI_QUIRK_NO_CDJaehoon Chung
This quirk doesn't need anymore. It's replaced to get_cd callback function. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
2017-01-11mmc: pic32_sdhci: move the code to pic32_sdhci.cJaehoon Chung
This code is used for only pic32_sdhci controller. To remove the "#ifdef", moves to pic32_sdhci.c. And use the get_cd callback function. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-05-17dm: mmc: Set up the device pointer when using the MMC uclassSimon Glass
Update the existing drivers to set up this new pointer. This will be required by the MMC uclass. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-04-25mmc: sdhci: add const qualifier to the name of struct sdhci_hostMasahiro Yamada
This allows to drop annoying (char *) casts when setting the host name of struct sdhci_host. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-01drivers: mmc: add driver for Microchip PIC32 SDHCI controller.Andrei Pistirica
This driver implements platform specific glue and fixups for PIC32 internal SDHCI controller. Signed-off-by: Andrei Pistirica <andrei.pistirica@microchip.com> Signed-off-by: Sandeep Sheriker Mallikarjun <sandeepsheriker.mallikarjun@microchip.com> Signed-off-by: Purna Chandra Mandal <purna.mandal@microchip.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
