Fix a cast that causes warnings on 64-bit machines.
This allows to drop annoying (char *) casts when setting the host
name of struct sdhci_host.
At present pci_mmc_init() does not correctly use the PCI function since the
list it passes is not terminated. The array size passed to pci_mmc_init() is
actually not used correctly. Fix this and adjust the pci_mmc_init() to scan
all available MMC devices.
Adjust this code to use the new driver model PCI API.
This should move over to the new MMC uclass at some point.
Since these board functions seem to be the same for all boards which use
FSP, move them into a common file. We can adjust this later if future FSPs
need more flexibility.
This creates a generic PCI MMC device.
Tested-by: Bin Meng <bmeng.cn@gmail.com>
