path: root/drivers/mmc/mvebu_mmc.c
2016-08-05mmc: use the generic error numberJaehoon Chung
Use the generic error number instead of specific error number. If use the generic error number, it can debug more easier. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2015-05-05mmc: remove the MMC_MODE_HC flagRob Herring
High capacity support is not a host capability, but a device capability that is queried via the OCR. The flag in the operating conditions request argument can just be set unconditionally. This matches the Linux implementation. [panto] Hand merged and renumbering MMC_MODE_DDR_52MHz. Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
2015-01-06MVEBUMMC : REMOVE unnecessary delay from initGerald Kerma
Remove unnessecary delay from mvebu_mmc_initialize Signed-off-by: Gérald Kerma <drEagle@doukki.net> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2015-01-06MVEBUMMC : CLEAN codeGerald Kerma
Clean mvebu_mmc_send_cmd Signed-off-by: Gérald Kerma <drEagle@doukki.net> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2015-01-06MVEBUMMC : REMOVE unnecessary delaysGerald Kerma
Remove delays in mvebu_mmc_set_bus and mvebu_mmc_set_clk Signed-off-by: Gérald Kerma <drEagle@doukki.net> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2015-01-06MVEBUMMC : FIX debug stringsGerald Kerma
2015-01-06MVEBUMMC : Speed up access timeGerald Kerma
Get about 40x faster access on SHEEVAPLUG MMC Fix some SD type compatibility Changes in v3: - fix the HW_STATE (from linux mvsdio) - review delays and timeouts Changes in v2: - increase number of loops - remove initial delay Changes in v1: - review all loops, delays and timeouts Signed-off-by: Gérald Kerma <drEagle@doukki.net> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2015-01-06MVEBUMMC : Change copyright dateGerald Kerma
2014-10-23arm: marvell: Move arch/kirkwood.h to arch/soc.hStefan Roese
This move makes is possible to use this header not only from kirkwood platforms but from all Marvell mvebu platforms. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Luka Perkov <luka@openwrt.org> Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
2014-10-03mvebu_mmc: Driver additionMario Schuknecht
In function mvebu_mmc_write notice command timeout. It is possible that a command is done, but a timeout occurred. Enable timeout in set bus function. Set window registers. Without that I could not use the driver on a Kirkwood 88F6282 SoC. Set high capacity and 52MHz driver feature. Signed-off-by: Mario Schuknecht <mario.schuknecht@dresearch-fe.de> Reviewed-by: Stefan Roese <sr@denx.de> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-08-01ARM: kirkwood: add mvsdio driverDrEagle
This patch add Marvell kirkwood MVSDIO/MMC driver and enable it for Sheevaplugs and OpenRD boards. Signed-off-by: Gerald Kerma <drEagle@doukki.net> Reviewed-by: Stefan Roese <sr@denx.de> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
