path: root/drivers/mmc/mmc_private.h
2016-05-27dm: mmc: Fix up mmc_bread/bwrite() prototypes for SPLSimon Glass
When these functions are not compiled in, we still need to declare the correct function signature to avoid a build warnings in SPL. Fix this. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: mmc: Add support for driver-model block devicesSimon Glass
Add support for enabling CONFIG_BLK with MMC. This involves changing a few functions to use struct udevice and adding a MMC block device driver. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: mmc: Move the device list into a separate fileSimon Glass
At present the MMC subsystem maintains its own list of MMC devices. This cannot work with driver model, which needs to maintain this itself. Move the list code into a separate 'legacy' file. The core MMC code remains, and will be shared with the driver-model implementation. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-14dm: Drop the block_dev_desc_t typedefSimon Glass
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long and causes 80-column violations, rename it to struct blk_desc. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-01-13block: pass block dev not num to read/write/erase()Stephen Warren
This will allow the implementation to make use of data in the block_dev structure beyond the base device number. This will be useful so that eMMC block devices can encompass the HW partition ID rather than treating this out-of-band. Equally, the existence of the priv field is crying out for this patch to exist. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-05-04mmc: fsl_esdhc: Add adapter card type identification supportYangbo Lu
Add adapter card type identification support by reading FPGA STAT_PRES1 register SDHC Card ID[0:2] bits. To use this function, define CONFIG_FSL_ESDHC_ADAPTER_IDENT. Signed-off-by: Yangbo Lu <yangbo.lu@freescale.com> Cc: York Sun <yorksun@freescale.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> [York Sun: resolve conflicts in README.fsl-esdhc] Reviewed-by: York Sun <yorksun@freescale.com>
2013-09-20mmc: don't support write & erase for SPL buildsPaul Burton
For SPL builds this is just dead code since we'll only need to read. Eliminating it results in a significant size reduction for the SPL binary, which may be critical for certain platforms where the binary size is highly constrained. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
