path: root/drivers/mmc/atmel_sdhci.c
2015-11-03mmc: atmel: Add atmel sdhci supportWenyou Yang
The SDHCI is introduced by sama5d2, named as Secure Digital Multimedia Card Controller(SDMMC). It supports the embedded MultiMedia Card (e.MMC) Specification V4.41, the SD Memory Card Specification V3.0, and the SDIO V3.0 specification. It is compliant with the SD Host Controller Standard V3.0 specification. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
