CONFIG_SUPPORT_EMMC_BOOT
As requested by Michal Simek <michal.simek@xilinx.com>, these boards
have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated:
xilinx_zynqmp_zc1275_revB
xilinx_zynqmp_zc1751_xm018_dc4
xilinx_zynqmp_zc1751_xm019_dc5
xilinx_zynqmp_zcu100_revC
xilinx_zynqmp_zcu102_rev1_0
xilinx_zynqmp_zcu102_revA
xilinx_zynqmp_zcu102_revB
xilinx_zynqmp_zcu104_revA
xilinx_zynqmp_zcu104_revC
xilinx_zynqmp_zcu106_revA
xilinx_zynqmp_zcu111_revA
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Acked-by: Lukasz Majewski <lukma@denx.de>
Acked-by: Patrick Delaunay <patrick.delaunay@st.com>
Acked-by: Ramon Fried <ramon.fried@gmail.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
The Standard Host Controller Interface (SDHCI) specification version
3.00 adds support for Advanced DMA (ADMA) for both 64 and 32 bit widths
of DMA. ADMA2 uses a table of descriptors for aggregating DMA requests.
This significantly improves read and write throughput.
Add Support for the same.
Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
Add the DM_MMC-compatible DesignWare MMC driver support for Synopsys
ARC devboards. It is created to switch ARC devboards to use DM_MMC.
It required information such as clocks (Bus Interface Unit clock,
Card Interface Unit clock) and SDIO bus width.
Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
The bounce buffer is used by a few drivers (most of the MMC drivers)
to overcome limitations in their respective DMA implementation.
This moves the configuration to Kconfig and makes it user-selectable
(even though it will be a required feature to make those drivers
work): the expected usage is for drivers depending on this to 'select'
it unconditionally from their respective Kconfig (see follow-up
patches).
This commit includes a full migration using moveconfig.py to ensure
that each commit compiles. To ensure bisectability we update
dependencies of various drivers to now select BOUNCE_BUFFER when needed.
[trini: Squash all patches to ensure bisectability]
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion]
Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion]
Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
Add driver for the JZ47xx MSC controller.
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Signed-off-by: Ezequiel Garcia <ezequiel@collabora.com>
This patch adds MT7623 host controller driver for accessing SD/MMC.
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
Signed-off-by: Ryder Lee <ryder.lee@mediatek.com>
Tested-by: Matthias Brugger <matthias.bgg@gmail.com>
Allwinner A64 has new mode but doesn't have a mode switch in CCM,
and CCM_MMC_CTRL_MODE_SEL_NEW is not defined, so compilation fails
if MMC_SUNXI_HAS_NEW_MODE is enabled
Introduce new MMC_SUNXI_HAS_MODE_SWITCH option to be able to ifdef usage
of CCM_MMC_CTRL_MODE_SEL_NEW
Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
[jagan: update commit message]
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Tested-by: Jagan Teki <jagan@amarulasolutions.com> # Amarula A64-Relic
Xilinx is introducing Versal, an adaptive compute acceleration platform
(ACAP), built on 7nm FinFET process technology. Versal ACAPs combine
Scalar Processing Engines, Adaptable Hardware Engines, and Intelligent
Engines with leading-edge memory and interfacing technologies to deliver
powerful heterogeneous acceleration for any application. The Versal AI
Core series has five devices, offering 128 to 400 AI Engines. The series
includes dual-core Arm Cortex™-A72 application processors, dual-core Arm
Cortex-R5 real-time processors, 256KB of on-chip memory with ECC, more
than 1,900 DSP engines optimized for high-precision floating point with
low latency.
The patch is adding necessary infrastructure in place without enabling
platform which is done in separate patch.
AM654 has an arasan sdhci controller and a mmc phy attached to it.
Add basic support for K3 specific arasan sdhci controller.
Add HS400 support.
Selecting HS400 needs first select HS200 according to spec, so use
a dedicated function for HS400.
Add HS400 related macros.
Remove the restriction of only using the low 6 bits of
EXT_CSD_CARD_TYPE, using all the 8 bits.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Cc: Jean-Jacques Hiblot <jjhiblot@ti.com>
Cc: Kishon Vijay Abraham I <kishon@ti.com>
Cc: Faiz Abbas <faiz_abbas@ti.com>
Add support for loading U-Boot on the Broadcom 7445 SoC. This port
assumes Broadcom's BOLT bootloader is acting as the second stage
bootloader, and U-Boot is acting as the third stage bootloader, loaded
as an ELF program by BOLT.
Signed-off-by: Thomas Fitzsimmons <fitzsim@fitzsim.org>
Cc: Stefan Roese <sr@denx.de>
Cc: Florian Fainelli <f.fainelli@gmail.com>
Convert CONFIG_SUPPORT_EMMC_RPMB to Kconfig. Split the command handling
from the underlying support and expose this through CMD_MMC_RPMB.
Add the MMC_TRACE config in Kconfig.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Add Kconfig entry for SH MMCIF driver.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Add Kconfig entry for the Renesas SDHI variant of the controller
and split the Makefile entries accordingly.
Migrate the CONFIG_FSL_ESDHC option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
nsd32_mmc was created to support ftsdc010 dm.
It is not necessary to separate both, so merge it
to ftsdc010.
Signed-off-by: Rick Chen <rick@andestech.com>
Signed-off-by: Rick Chen <rickchen36@gmail.com>
Cc: Greentime Hu <green.hu@gmail.com>
Convert CONFIG_FTSDC010_SDIO to Kconfig.
So CONFIG_FTSDC010_SDIO can also be
removed from config_whitelist.txt.
This patch added Kconfig support for CONFIG_ZYNQ_SDHCI_MIN_FREQ
and enabled it in respective defconfig.
Signed-off-by: Vipul Kumar <vipulk@xilinx.com>
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
This patch added Kconfig support for CONFIG_ZYNQ_SDHCI_MAX_FREQ
Some platforms don't have ADMA controllers. For those platforms, compiling
it out reduces the size of the binary by about 600 bytes.
Leaving the support in doesn't break things as the driver checks at runtime
if the ADMA2 controller is present.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
Tested-by: Adam Ford <aford173@gmail.com>
config_fallbacks.h has some logic that sets HAVE_BLOCK_DEVICE
based on a list of enabled options. Moving HAVE_BLOCK_DEVICE to
Kconfig allows us to drastically shrink the logic in
config_fallbacks.h
[trini: Rename HAVE_BLOCK_DEVICE to CONFIG_BLOCK_DEVICE]
CONFIG_APBH_DMA
CONFIG_APBH_DMA_BURST
CONFIG_APBH_DMA_BURST8
Reviewed-by: Stefan Agner <stefan.agner@toradex.com>
[trini: Add in MMC as well]
The BCM2835 family of SoCs has 2 different SD controllers: One based on
the SDHCI spec and a custom, home-grown one.
This patch implements a driver for the latter based on the Linux driver.
This is needed so that we can make use of device trees that assume driver
presence of both SD controllers.
Poll for broken card detection case instead of return
no card detected.
Signed-off-by: Jun Nie <jun.nie@linaro.org>
This allows using CONFIG_IS_ENABLED(MMC_WRITE) to compile out code
needed only if write support is required.
The option is added for u-boot and for SPL
Not all boards have an eMMC and not all users have a need for this.
Allow to compile it out. By default it is still included.
Supporting USH and HS200 increases the code size as it brings in IO voltage
control, tuning and fatter data structures.
Use Kconfig configuration to select which of those features should be
built in.
This allows to compile out the log message by tweaking the LOGLEVEL.
With certain SD cards like Kingston 8GB/16GB UHS card, it is seen that
MMC_CMD_ALL_SEND_CID cmd fails on first attempt, but succeeds
subsequently. Therefore, retry MMC_CMD_ALL_SEND_CID cmd a few time
as done in Linux kernel.
Similarly, it is seen that MMC_CMD_SET_BLOCKLEN may fail on first
attempt, therefore retry this cmd a few times as done in kernel.
To make it clear that those are optionnal workarounds, a new Kconfig
option 'MMC_QUIRKS' is added (enabled by default).
Signed-off-by: Vignesh R <vigneshr@ti.com>
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
no functionnal changes.
In order to add the support for the high speed SD and MMC modes, it is
useful to track this information.
Add nds32_mmc to support ftsdc010 dm flow.
Convert this driver to driver model.
This driver is also used by VEXPRESS platforms which doesn't
use driver model.
Tested on STM32F746 and STM32F769 platforms.
Signed-off-by: Christophe Priouzeau <christophe.priouzeau@st.com>
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
Since e7881d85 "dm: mmc: Drop CONFIG_DM_MMC_OPS" DM_MMC_OPS
is no more used, remove it from STM32_SDMMC2 dependencies
This patch adds SD/MMC support for STM32H7 SoCs.
Here is an extraction of SDMMC main features, embedded in
STM32H7 SoCs.
The SD/MMC block include the following:
_ Full compliance with MultiMediaCard System Specification
Version 4.51. Card support for three different databus modes:
1-bit (default), 4-bit and 8-bit.
_ Full compatibility with previous versions of MultiMediaCards
(backward compatibility).
_ Full compliance with SD memory card specifications version 4.1.
(SDR104 SDMMC_CK speed limited to maximum allowed IO speed,
SPI mode and UHS-II mode not supported).
_ Full compliance with SDIO card specification version 4.0.
Card support for two different databus modes: 1-bit (default)
and 4-bit. (SDR104 SDMMC_CK speed limited to maximum allowed IO
speed, SPI mode and UHS-II mode not supported).
_ Data transfer up to 208 Mbyte/s for the 8 bit mode.
(depending maximum allowed IO speed).
_ Data and command output enable signals to control external
bidirectional drivers.
The current version of the SDMMC supports only one SD/SDIO/MMC card
at any one time and a stack of MMC Version 4.51 or previous.
Signed-off-by: Christophe Kerello <christophe.kerello@st.com>
In the TI SOCs a PBIAS cell exists to provide a bias voltage to the MMC1
IO cells. Without this bias voltage these I/O cells can not function
properly. The PBIAS cell is controlled by software.
Add OF match entries and quirks for Renesas RCar Gen3 controllers
into the driver. The IP this driver handles is in fact Matsushita
one and in used both in Socionext and Renesas chips.
Almost all of the newer Allwinner SoCs have a new operating mode for the
eMMC clocks that needs to be enabled in both the clock and the MMC
controller.
Details about that mode are sparse, and the name itself (new mode vs old
mode) doesn't give much details, but it seems that the it changes the
sampling of the MMC clock. One side effect is also that it divides the
parent clock rate by 2.
Add support for it through a Kconfig option.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
All boards which use DM_MMC have now been converted to use DM_MMC_OPS.
Drop the option and good riddance.
This should depend on SPL_DM_MMC, not SPL_DM. For it and update the only
affected board's defconfig.
At present if U-Boot proper uses driver model for MMC, then SPL has to
also. While this is desirable, it places a significant barrier to moving
to driver model in some cases. For example, with a space-constrained SPL
it may be necessary to enable CONFIG_SPL_OF_PLATDATA which involves
adjusting some drivers.
Add new SPL versions of the options for DM_MMC, DM_MMC_OPS and BLK. By
default these follow their non-SPL versions, but this can be changed by
boards which need it.
The Kconfig entry depends on RMOBILE, but this was renamed
to ARCH_RMOBILE in commit 1cc95f6e1b38 (ARM: Rmobile: Rename
CONFIG_RMOBILE to CONFIG_ARCH_RMOBILE) . Fix this omission.
Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com>
Reviewed-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Now CONFIG_GENERIC_MMC and CONFIG_MMC match for all defconfig.
We do not need two options for the same feature. Deprecate the
former.
This commit was generated with the sed script 's/GENERIC_MMC/MMC/'
and manual fixup of drivers/mmc/Kconfig.
Add the driver model support for Atmel mci while retaining the
existing legacy code. This allows the driver to support boards
that have converted to driver model as well as those that have not.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
This driver implements MMC support on Meson GX (S905) based systems.
It's based on Carlo Caione's work, changes:
- BLK support added
- general refactoring
Signed-off-by: Carlo Caione <carlo@caione.org>
Signed-off-by: Andreas Färber <afaerber@suse.de>
Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com>
Tested-by: Vagrant Cascadian <vagrant@debian.org>
Introduce CONFIG_TEGRA124_MMC_DISABLE_EXT_LOOPBACK to disable the external clock
loopback and use the internal one on SDMMC3 as per the SDMMC_VENDOR_MISC_CNTRL_0
register's SDMMC_SPARE1 bits being set to 0xfffd according to the TRM.
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
Signed-off-by: Tom Warren <twarren@nvidia.com>
This patch adds Intel Tangier eMMC/SDHCI driver.
Intel Tangier SoC contains a hybrid of PCI and non-PCI devices. SDHCI
controller is one of the devices which are *not* on a PCI and, hence,
cannot be enumerated by standard PCI means. This driver, allows for
SDHCI controller on Tangier SoC to work in U-Boot.
Signed-off-by: Vincent Tinelli <vincent.tinelli@intel.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
We don't want pci_mmc to compile every time x86 compiles, only when
there's a platform that needs it. For that reason, we're adding a new
CONFIG_MMC_PCI which platforms can choose to enable.
Suggested-by: Jaehoon Chung <jh80.chung@samsung.com>
