https://source.denx.de/u-boot/custodians/u-boot-imx
u-boot-imx-20211020
First PR from u-boot-imx for 2022.01
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/9535
- new board: kontron-sl-mx8mm
- imx8m:
- fix secure boot
- imx ESDHC: fixes
- i.MX53: Support thum2, bmode and fixes for Menlo board
usbarmory switch to Ethernet driver model
- imx6 :
- DDR calibration for Toradex boards
- imx7:
- Fixes
- Updated gateworks boards (ventana / venice)
# gpg verification failed.
https://source.denx.de/u-boot/custodians/u-boot-stm
- Disable ATAGS for STM32 MCU and MPU boards
- Disable bi_boot_params for STM32 MCU and MPU boards
- Update stm32-usbphyc node management
- Convert CONFIG_STM32_FLASH to Kconfig for STM32 MCU boards
- Convert some USB config flags to Kconfig for various boards
- Convert CONFIG_BOOTCOMMAND flag to Kconfig for STM32 F429 board
- Remove specific CONFIG_STV0991 flags
- Remove unused CONFIG_USER_LOWLEVEL_INIT flag
- Add ofdata_to_platdata() callback for stm32_spi driver
- Update for stm32f7_i2c driver
- Remove gpio_hog_probe_all() from STM32 MP1 board
- Fix bind command
Fix a regression brings by commit 84f8e36f03fa ("cmd: bind: allow to
bind driver with driver data")
As example, the following bind command doesn't work:
bind /soc/usb-otg@49000000 usb_ether
As usb_ether driver has no compatible string, it can't be find by
lists_bind_fdt(). In bind_by_node_path(), which called lists_bind_fdt(),
the driver entry is known, pass it to lists_bind_fdt() to force the driver
entry selection.
For this, add a new parameter struct *driver to lists_bind_fdt().
Fix also all lists_bind_fdt() callers.
Fixes: 84f8e36f03fa ("cmd: bind: allow to bind driver with driver data")
Signed-off-by: Patrice Chotard <patrice.chotard@foss.st.com>
Reported-by: Herbert Poetzl <herbert@13thfloor.at>
Cc: Herbert Poetzl <herbert@13thfloor.at>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
This allows removal of the OCOTP driver when SPL is enabled.
Disabling OCOTP reduces SPL size efficiently.
Signed-off-by: Michael Scott <mike@foundries.io>
Co-developed-by: Oleksandr Suvorov <oleksandr.suvorov@foundries.io>
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@foundries.io>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
This function is available but not exported. More generally it does not
really work as intended.
Reimplement it and add a sandbox test too.
Convert some of these occurences to C code, where it is easy to do. This
should help encourage this approach to be used in new code.
Now that we have a 'positive' Kconfig option, use this instead of the
negative one, which is harder to understand.
Use this new Kconfig to simplify the compilation conditions where
appropriate.
- Rename usages of CONFIG_SYS_DEF_EEPROM_ADDR to CONFIG_SYS_I2C_EEPROM_ADDR
based on current usage.
- Convert CONFIG_SYS_I2C_EEPROM_ADDR, CONFIG_SYS_I2C_EEPROM_ADDR_LEN,
CONFIG_SYS_I2C_EEPROM_BUS, CONFIG_CONFIG_SYS_EEPROM_SIZE
CONFIG_SYS_EEPROM_PAGE_WRITE_BITS and CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS
to Kconfig. We move these symbols around a bit and add appropriate
dependencies to them. In some cases, we now add a correct default value
as well.
Move struct mu_type to common header to make it reusable by upower and
S400
Signed-off-by: Peng Fan <peng.fan@nxp.com>
This driver uses FSB to read some fuses, but not support program fuse.
It only works in SPL (secure mode), u-boot needs traps to ATF to
read them.
Some fuses can read from S400 API and others are from FSB.
Also support program some fuses via S400 API
Signed-off-by: Ye Li <ye.li@nxp.com>
Since S400 will set the memory of SPL image to R/X. We can't write
to any data in SPL image.
1. Set the parameters save/restore only for u-boot, not for SPL. to
avoid write data.
2. Not use MU DM driver but directly call MU API to send release XRDC
to S400 at early phase.
3. Configure the SPL image memory of SRAM2 to writable (R/W/X)
Add API to support fuse read and write
The RDC API is updated to add a field for XRDC or TRDC
Add S400 API for image authentication
According to latest S400 API doc, the the success indicate value is
changed to 0xd6. So update the driver codes.
Add MU driver and S400 API. Need enable MISC driver to work
It is a pain to have to specify the value 16 in each call. Add a new
hextoul() function and update the code to use it.
Add a proper comment to simple_strtoul() while we are here.
At present this driver assumes that ulong is 64-bits long. On 32-bit
machines it is not. Use the 64-bit code only on 64-bit machines.
This makes things work correctly on 32-bit machines.
Rather than calling directly into the sandbox SDL code, we can use the
normal U-Boot console handling for this feature. Update the code, to make
it more generic.
The v2 format is 64-bytes in size. Support this and drop v1 since it is
not used anymore.
This function is not needed anymore. Drop it.
Add a function to read this information from the EC. It is useful for
determining whether the battery has enough charge to boot.
At present the return value of ofnode_get_property() is not checked, which
causes a coverity warning. While we are here, use logging for the errors.
Reported-by: Coverity (CID: 331157)
Linux kernel binding is using atmel,24c01 compatible string. On the
other hand there is atmel,24c01a which is not listed in the kernel.
Add compatible string without "a" suffix to be compatible with Linux
kernel binding.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Michal Simek <michal.simek@xilinx.com>
This patch adds a limited pulse-width modulator to sandbox's Chromium OS
Embedded Controller emulation. The emulated PWM device supports multiple
channels but can only set a duty cycle for each, as the actual EC
doesn't expose any functionality or information other than that. Though
the EC supports specifying the PWM channel by its type (e.g. display
backlight, keyboard backlight), this is not implemented in the emulation
as nothing in U-Boot uses this type specification.
This emulated PWM device is then used to test the Chromium OS PWM driver
in sandbox. Adding the required device node to the sandbox test
device-tree unfortunately makes it the first PWM device, so this also
touches some other tests to make sure they still use the sandbox PWM.
Signed-off-by: Alper Nebi Yasak <alpernebiyasak@gmail.com>
Define LOG_CATEGORY for all uclass to allow filtering with
log command.
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
UCLASS_IRQ driver is not Intel specific. Make CONFIG_IRQ
selectable for all platforms.
Signed-off-by: Wasim Khan <wasim.khan@nxp.com>
Tested-by: Vladimir Oltean <vladimir.oltean@nxp.com>
Add MMIO driver for QFW.
Note that there is no consumer as of this patch.
Signed-off-by: Asherah Connor <ashe@kivikakk.ee>
A sandbox driver and test are added for the qfw uclass, and a test in
QEMU added for qfw functionality to confirm it doesn't break in real
world use.
We move qfw into its own uclass and split the PIO functions into a
specific driver for that uclass. The PIO driver is selected in the
qemu-x86 board config (this covers x86 and x86_64).
include/qfw.h is cleaned up and documentation added.
Tested-by: Bin Meng <bmeng.cn@gmail.com>
This PWM is used in rk3399-gru-bob and rk3399-gru-kevin to control
the display brightness. We can only change the duty cycle, so on
set_config() we just try to match the duty cycle that dividing duty_ns
by period_ns gives us. To disable, we set the duty cycle to zero while
keeping the old value for when we want to re-enable it.
The cros_ec_set_pwm_duty() function is taken from Depthcharge's
cros_ec_set_bl_pwm_duty() but modified to use the generic pwm type.
The driver itself is very loosely based on rk_pwm.c for the general pwm
driver structure.
The devicetree binding file is from Linux, before it was converted to
YAML at 5df5a577a6b4 ("dt-bindings: pwm: Convert google,cros-ec-pwm.txt
to YAML format") in their repo.
i.MX8MQ B2 also has fixed value in OCOTP_READ_FUSE_DATA register,
so it does not support "fuse sense" command like B1.
This can crash if the EC has not yet been probed. Add a check to prevent
this.
It is possible to boot U-Boot for chromebook_coral either 'bare metal' or
from coreboot. In the latter case we want to provide access to the coreboot
sysinfo tables. Move the definitions into a file available to any x86
board.
We should not enable debugging by default. Drop this.
This function finds a device by its driver_info index. With
of-platdata-inst we do not use driver_info, but instead instantiate
udevice records at build-time.
However the semantics of using the function are the same in each case:
the caller provides an index and gets back a device.
So rename the function to device_get_by_ofplat_idx(), so that it can be
used for both situations. The caller does not really need to worry about
the details.
Add support for generating a file containing udevice instances. This
avoids the need to create these at run time.
Update a test uclass to include a 'per_device_plat_auto' member, to
increase test coverage.
Add another tab to the driver_info output so it lines up nicely like the
device-instance output.
Add support for generating a file containing uclass instances. This avoids
Update a test uclass to include a 'priv_auto' member, to increase test
coverage.
Now that we have the alias information we can assign a sequence number
to each device in the uclass. Store this in the node associated with each
device.
This requires renaming the sandbox test drivers to have the right name.
Note that test coverage is broken with this patch, but fixed in the next
one.
At present if U-Boot proper uses driver model for I2C, then SPL has to
also. While this is desirable, it places a significant barrier to moving
to driver model in some cases. For example, with a space-constrained SPL
it may be necessary to enable CONFIG_SPL_OF_PLATDATA which involves
adjusting some drivers.
This patch introduces a separate Kconfig symbols for enabling DM_I2C and
DM_I2C_GPIO support in SPL.
This will also help to get away from dirty workarounds to
achieve non-DM I2C support for SPL, which is currently used in some
board header files like:
ifdef CONFIG_SPL_BUILD
undef CONFIG_DM_I2C
endif
Signed-off-by: Igor Opaniuk <igor.opaniuk@foundries.io>
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
The EC can store small amounts of data for the benefit of the
verified boot process. Since the EC is seldom reset, this can allow the
AP to store data that survives a reboot or a suspend/resume cycle.
Add support for this.
Avoid reading the device tree when of-platdata is in use.
Add a command to show the current events as a list of names. This is
easier to decipher than a bit mask.
On x86 platforms the EC provides a way to read 'switches', which are
on/off values determined by the EC.
Add a new driver method for this and implement it for LPC.
The EC can support a variety of features and provides a way to find out
what is available. Add support for this.
Also update the feature list to the lastest available while we are here.
This is at:
https://chromium.googlesource.com/chromiumos/platform/ec/+/refs/heads/master/include/ec_commands.h
