path: root/drivers/misc
2020-02-26misc: k3_avs: Fix possible NULL pointer deferenceVignesh Raghavendra
Its possible that k3_avs_priv is NULL because the driver may not have been probed yet. Therefore check if pointer is valid before dereferencing it. Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
2020-02-11Merge tag 'dm-pull-6feb20' of https://gitlab.denx.de/u-boot/custodians/u-boot-dmTom Rini
sandbox conversion to SDL2 TPM TEE driver Various minor sandbox video enhancements New driver model core utility functions
2020-02-10Merge https://gitlab.denx.de/u-boot/custodians/u-boot-x86Tom Rini
- Move P2SB from Apollo Lake to a more generic location - Add a function to find a device by drvdata in DM core - Enhancement of DM IRQ uclass driver - Add a clock driver for Intel devices - Add support for ACPI general-purpose events - Add a TPM driver for H1/Cr50 - Enable TPM on Google Chromebook Coral
2020-02-09misc: i2c_eeprom: set offset len and chip addr offset maskRobert Beckett
Set the correct offset length and chip address offset mask for each device to allow correct access to total capacity of the devices. Signed-off-by: Robert Beckett <bob.beckett@collabora.com>
2020-02-07dm: irq: Add support for requesting interruptsSimon Glass
At present driver model supports the IRQ uclass but there is no way to request a particular interrupt for a driver. Add a mechanism, similar to clock and reset, to read the interrupts required by a device from the device tree and to request those interrupts. U-Boot itself does not have interrupt-driven handlers, so just provide a means to read and clear an interrupt. This can be useful to handle peripherals which must use an interrupt to determine when data is available, for example. Bring over the basic binding file as well, from Linux v5.4. Note that the older binding is not supported in U-Boot; the newer 'special form' must be used. Add a simple test of the new functionality. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2020-02-07dm: irq: Add support for interrupt controller typesSimon Glass
There can be different types of interrupt controllers in a system and some drivers may need to distinguish between these. In general this can be handled using the device tree by adding the interrupt information to device nodes. However on x86 devices we have interrupt controllers which are not tied to any particular device and not really used in U-Boot. These still need to be inited, so a convenient method is to give each controller a type and allow a particular controller type to be probed. Add support for this in sandbox along with a test. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> [bmeng: remove the new bland line at EOF of test/dm/irq.c] Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2020-02-05sandbox: Complete migration away from os_malloc()Simon Glass
Now that we can use direct access to the system malloc() in sandbox, drop the remaining uses of os_malloc(). The only one remaining now is for the RAM buffer, which we do want to be at a known address, so this is intended. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-05dm: core: Create a new header file for 'compat' featuresSimon Glass
At present dm/device.h includes the linux-compatible features. This requires including linux/compat.h which in turn includes a lot of headers. One of these is malloc.h which we thus end up including in every file in U-Boot. Apart from the inefficiency of this, it is problematic for sandbox which needs to use the system malloc() in some files. Move the compatibility features into a separate header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-05dm: core: Require users of devres to include the headerSimon Glass
At present devres.h is included in all files that include dm.h but few make use of it. Also this pulls in linux/compat which adds several more headers. Drop the automatic inclusion and require files to include devres themselves. This provides a good indication of which files use devres. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Anatolij Gustschin <agust@denx.de>
2020-02-05dm: pci: Update the PCI read_config() method to const dev *Simon Glass
At present this method uses a non-const udevice pointer, but the call should not modify the device. Use a const pointer. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-17common: Move hang() to the same header as panic()Simon Glass
At present panic() is in the vsprintf.h header file. That does not seem like an obvious choice for hang(), even though it relates to panic(). So let's put hang() in its own header. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Migrate a few more files] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-01-17common: Drop floppy disk supportSimon Glass
This seems pretty old now. It has not been converted to driver model and is not used by any boards. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-08Merge tag 'u-boot-imx-20200108' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-imx --------------------------------------------------------------------- Add i.MX8MP SoC and EVK board Update README for i.MX8MN EVK and fix mmc env Add pca9450 driver -------------------------------------------------------------------- Travis: https://travis-ci.org/sbabic/u-boot-imx/builds/634211885
2020-01-08mxc_ocotp: support i.MX8MPPeng Fan
i.MX8MP use similar ocotp as i.MX8MN, but has changed fuse banks and ctrl register bit definitions, so update to reflect that. Reviewed-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-12-18Merge branch 'next' of https://gitlab.denx.de/u-boot/custodians/u-boot-x86 ↵Tom Rini
into next - Various x86 common codes updated for TPL/SPL - I2C designware driver updated for PCI - ICH SPI driver updated to support Apollo Lake - Add Intel FSP2 base support - Intel Apollo Lake platform specific drivers support - Add a new board Google Chromebook Coral
2019-12-17misc: i2c_eeprom: add size queryRobert Beckett
Add ability to query size of eeprom device and partitions Signed-off-by: Robert Beckett <bob.beckett@collabora.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2019-12-17misc: i2c_eeprom: add fixed partitions supportRobert Beckett
Add ability to partition eeprom via devicetree bindings Signed-off-by: Robert Beckett <bob.beckett@collabora.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2019-12-17dm: i2c: EEPROM simulator add tests for addr offset maskRobert Beckett
Add support for setting the chip address offset mask to EEPROM sumulator and add tests to test it. Signed-off-by: Robert Beckett <bob.beckett@collabora.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2019-12-17dm: i2c: EEPROM simulator allow tests visibility of addr and offsetRobert Beckett
Improve i2c EEPROM simulator testing by providing access functions to check the previous chip addr and offset. Given that we can now directly test the offsets, also simplified the offset mapping and allow for wrapping acceses. Signed-off-by: Robert Beckett <bob.beckett@collabora.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2019-12-15sandbox: Add a test for IRQSimon Glass
Add a simple sandbox test for this uclass. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-12-15x86: Move UCLASS_IRQ into a separate fileSimon Glass
Update this uclass to support the needs of the Apollo Lake ITSS. It supports four operations. Move the uclass into a separate directory so that sandbox can use it too. Add a new Kconfig to control it and enable this on x86. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-12-15sandbox: Add PCI driver and test for p2sbSimon Glass
Add a sandbox driver and PCI-device emulator for p2sb. Also add a test which uses a simple 'adder' driver to test the p2sb functionality. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-12-15pci: Add support for p2sb uclassSimon Glass
The Primary-to-Sideband bus (P2SB) is used to access various peripherals through memory-mapped I/O in a large chunk of PCI space. The space is segmented into different channels and peripherals are accessed by device-specific means within those channels. Devices should be added in the device tree as subnodes of the p2sb. This adds a uclass and enables it for sandbox. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-12-10cros_ec: use uint instead of uint8_t for cmd paramMichael Auchter
Chromium EC commands can be up to 16-bits, so using a uint8_t here can cause truncation. Update to use a uint instead. It looks like this should likely have been done as a part of 9fea76f5d30264dc08ac591a7a89427b8441555b, but this function was skipped for some reason. Signed-off-by: Michael Auchter <michael.auchter@ni.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-12-02common: Move old EEPROM functions into a new headerSimon Glass
These functions do not use driver model but are still used. Move them to a new eeprom.h header file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02common: Move get_ticks() function out of common.hSimon Glass
This function belongs in time.h so move it over and add a comment. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02crc32: Use the crc.h header for crc functionsSimon Glass
Drop inclusion of crc.h in common.h and use the correct header directly instead. With this we can drop the conflicting definition in fw_env.h and rely on the crc.h header, which is already included. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02status_led: Tidy up the code styleSimon Glass
There are a few whitespace problems with this code. Tidy them up. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02common: Drop global inclusion of status_led.hSimon Glass
This is only used by a few files so it should not be in the common header. Move it out. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-11-17misc: add driver for the Rockchip otp controllerFinley Xiao
Newer Rockchip socs like the px30 use a different ip block to handle one-time-programmable memory, so add a misc driver for it as well. Signed-off-by: Finley Xiao <finley.xiao@rock-chips.com> Signed-off-by: Heiko Stuebner <heiko.stuebner@theobroma-systems.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-11-12Merge tag 'u-boot-imx-20191105' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-imx u-boot-imx-20191105 ------------------- i.MX8MN SoC support ROM API image download support i.MX8MM enet enabling
2019-11-07misc: k3_avs: Add j721e supportKeerthy
j721e SoCs have different OPP tables. Add support for the same. Note: DM Still has lot of voltages TBD hence the correct values need to be programmed once they are published. Signed-off-by: Keerthy <j-keerthy@ti.com>
2019-11-07misc: k3_avs: add driver for K3 Adaptive Voltage Scaling Class 0Tero Kristo
Adaptive Voltage Scaling is a technology used in TI SoCs to optimize the operating voltage based on characterization data written to efuse during production. Add a driver to support this feature for K3 line of SoCs, initially for AM65x. Signed-off-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Keerthy <j-keerthy@ti.com>
2019-11-05misc: imx8: scu: simplify code to make it extendablePeng Fan
clk and pinctrl will be get(probed) during each device probe, we don't need to probe them in scu driver. Only need to bind the sub-nodes (clk and iomuxc) of MU node with their drivers. So drop the code to probe the clk/pinctrl, and this patch will make it easy to add more subnodes. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-11-03mach-imx: Adding new argument for SIP call interfaceYe Li
Need to pass total 5 arguments for SIP HAB call on i.MX8MQ, so update the interface to add new argument. Signed-off-by: Ye Li <ye.li@nxp.com> [agust: fixed imx8m-power-domain build] Signed-off-by: Anatolij Gustschin <agust@denx.de> Reviewed-by: Patrick Wildt <patrick@blueri.se> Reviewed-by: Peng Fan <peng.fan@nxp.com>
2019-10-24misc: microchip_flexcom: introduce microchip_flexcom driverEugen Hristev
The Microchip Flexcom is just a wrapper which embeds a SPI controller, an I2C controller and an USART. Only one function can be used at a time and is chosen at boot time according to the device tree. The bindings are kept as in Linux. The driver registers to MISC_UCLASS. Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2019-10-09Merge tag 'u-boot-imx-20191009' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-imx u-boot-imx-20191009 ------------------- Travis : https://travis-ci.org/sbabic/u-boot-imx/builds/595148532 - MX6UL / ULZ - Toradex board - Allow to set OCRAM for MX6Q/D - MX7ULP - MX8: (container image, imx8mq_mek), SCU API - fix several board booting from SD/EMMC (cubox-i for example) - pico boards [trini: display5 merged manually] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-10-08misc: imx8: add more scfw apiPeng Fan
Add more scfw api for clk/partition/seco usage The api will be used by ccf/partition/secure boot. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-10-08imx: scu_api: add sc_pm_is_partition_startedPeng Fan
Add sc_pm_is_partition_started to check whether a partition has been started. This will be used to detect M4 partition booted up or not, then we could choose which dtb to use. If M4 is up, we need use dtb, such as imx8qm-mek-rpmsg.dtb. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-10-08imx: scu_api: add sc_rm_set_master_sidPeng Fan
Add sc_rm_set_master_sid to set stream sid of masters to make sure they could use smmu. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-10-08misc: Kconfig: make i.MX7ULP could use MXC_OCOTPPeng Fan
2019-10-08sandbox: pci: Create a new sandbox_pci_read_bar() functionSimon Glass
The code in swapcase can be used by other sandbox drivers. Move it into a common place to allow this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> [bmeng: remove inclusion of <asm/test.h> in pci_sandbox.c] Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2019-10-08sandbox: pci: Move pci_offset_to_barnum() to pci.hSimon Glass
This function is useful in PCI emulators. More it into the header file to avoid duplicating it in other drivers. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-10-08sandbox: pci: Drop the get_devfn() methodSimon Glass
This method is not used anymore since the bus/device/function of PCI devices can be obtained from their (parent's per-child) platform data. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-10-08sandbox: swap_case: Use statics where possibleSimon Glass
Some functions and a struct should be marked static since they are not used outside this file. Update them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-10-08sandbox: Rename PCI ID for swap_case to be more specificSimon Glass
Rename this ID to SANDBOX_PCI_SWAP_CASE_EMUL_ID since it is more descriptive and allows us to add new PCI emulators without any conflict or confusion. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-08-27Merge branch 'u-boot-stm32_20190827' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-stm - Fixes and update related to STM32MP1 platforms
2019-08-27misc: change RCC form MISC to NOP uclassPatrick Delaunay
The RCC driver have no operation so the new NOP uclass is more appropriate. It only used as parent for clock and reset driver. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-08-27pmu: stpmic1: change specific NVM api to MISCPatrick Delaunay
Use MISC u-class to export the NVM register (starting at 0xF8 offset) and avoid specific API. - SHADOW have offset < 0. - NVM have register > 0 Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-08-27bsec: update after MISC u-class updatePatrick Delaunay
Since the commit 8729b1ae2cbd ("misc: Update read() and write() methods to return bytes xfered"); The misc bsec driver need to be adapted to reflect the number of transferred bytes. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
