path: root/drivers/misc
2015-09-02Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-09-02mxc: ocotp fix hole in shadow registersPeng Fan
There is a hole in shadow registers address map of size 0x100 between bank 5 and bank 6 on iMX6QP, iMX6DQ, iMX6SDL, iMX6SX and iMX6UL. Bank 5 ends at 0x6F0 and Bank 6 starts at 0x800. When reading the fuses, we should account for this hole in address space. Similar hole exists between bank 14 and bank 15 of size 0x80 on iMX6QP, iMX6DQ, iMX6SDL and iMX6SX. Note: iMX6SL has only 0-7 banks and there is no hole. Note: iMX6UL doesn't have this one. When reading, we use register offset, so need to account for holes to get the correct address. When writing, we use bank/word index, there is no need to account for holes, always use bank/word index from fuse map. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2015-09-02imx: ocotp: mxc add i.MX7D supportAdrian Alonso
* Ocotp of i.MX7D has different operation rule. This patch is to add support for i.MX7D ocotp. Signed-off-by: Adrian Alonso <aalonso@freescale.com> Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Signed-off-by: Ye.Li <B37916@freescale.com>
2015-09-02mxs_ocotp: Shift the HBUS divider correctlyChris Smith
When the original HBUS divider value is retrieved in mxs_ocotp_scale_hclk() for the purpose or restoring it back later, the value is not shifted by the HBUS divider offset in that register. This is not a problem, since the shift is zero on all MXS hardware. Add the shift anyway, for completeness and in case FSL ever decides to re-use this driver on future designs. Signed-off-by: Chris Smith <chris@zxdesign.info> Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2015-09-01arm/ls102xa:add hwconfig setting to support disable unused devicesZhuoyu Zhang
DEVDISRn registers provides a mechanism for gating clocks of IP blocks that are not used. Here we implement hwconfig option to allow users to disable unused peripherals on the board. For ex. If eSDHC/qDMA/eDMA are unused and with disabled status in dts, User can enable CONFIG_FSL_DEVICE_DISABLE and set "devdis:esdhc,qdma,edma" in hwconfig, thus ESDHC controller & eDMA/qDMA will be clock gated to save more power. Signed-off-by: Zhuoyu Zhang <Zhuoyu.Zhang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-09-01driver: misc: debug server: Update Error messagePrabhakar Kushwaha
Append "debug server FW" in error message to make more informative. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: Bhupesh Sharma <bhupesh.sharma@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-08-26x86: superio: Add keyboard controller support to smsc_lpc47m driverBin Meng
Add an api to enable and configure the integrated keyboard controller on SMSC LPC47m superio chipset. It also adds several macros to help future extension. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-12drivers: hierarchize drivers Kconfig menuMasahiro Yamada
The menuconfig for drivers are getting more and more cluttered and unreadable because too many entries are displayed in a single flat menu. Use hierarchic menu for each category. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Update to apply again in a few places, drop USB hunk] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-05cros_ec: Remove the old tunnel codeSimon Glass
This is not needed with driver mode. Remove it. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05cros_ec: Support the LDO access method used by springSimon Glass
Add a driver to support the special LDO access used by spring. This is a custom method in the cros_ec protocol - it does not use an I2C pass-through. There are two implementation choices: 1. Write a special LDO driver which can talk across the EC. Duplicate all the logic from TPS65090 for retrying when the LDO fails to come up. 2. Write a special I2C bus driver which pretends to be a TPS65090 and transfers reads and writes using the LDO message. Either is distasteful. The latter method is chosen since it results in less code duplication and a fairly simple (30-line) implementation of the core logic. The crosec 'ldo' subcommand could be removed (since i2c md/mw will work instead) but is retained as a convenience. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05dm: cros_ec: Convert the I2C tunnel code to use driver modelSimon Glass
The Chrome OS EC supports tunnelling through to an I2C bus on the EC. This currently uses a copy of the I2C command code and a special 'crosec' sub-command. With driver model we can define an I2C bus which tunnels through to the EC, and use the normal 'i2c' command to access it. This simplifies the code and removes some duplication. Add an I2C driver which tunnels through to the EC. Adjust the EC code to support binding child devices so that it can be set up. Adjust the existing I2C xfer function to fit driver model better. For now the old code remains to allow things to still work. It will be removed in a later patch once the new flow is fully enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-27misc: led: pca9551_led: Fix problem with multiple blink frequenciesStefan Roese
Only 2 frequencies are supported. The current driver implementation does not always use the 2 last configured blink frequencies. This patch fixes this problem. So that the last two entered frequencies are active. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Tom Rini <trini@konsulko.com>
2015-07-21dm: test: Add a test for the system controller uclassSimon Glass
Add a test to confirm that we can access system controllers and find their driver data. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21sandbox: Use the reset driver to handle resetSimon Glass
Move sandbox over to use the reset uclass for reset, instead of a direct call to do_reset(). This allows us to add tests. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21sandbox: Add a warm and cold reset driverSimon Glass
Add drivers for sandbox. One can only perform a warm reset (which does nothing). The other can perform a cold reset or a power reset (the latter will quit U-Boot). These can be used for testing the reset uclass. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21dm: reset: Allow reset_walk() to returnSimon Glass
Add a new reset_walk_halt() function to cause a reset and then halt on failure. The reset_walk() function returns an error code. This is needed for testing since otherwise U-Boot will halt in the middle of a test. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21dm: Add a system reset uclassSimon Glass
It is common for system reset to be available at multiple levels in modern hardware. For example, an SoC may provide a reset option, and a board may provide its own reset for reasons of security or thoroughness. It is useful to be able to model this hardware without hard-coding the behaviour in the SoC or board. Also there is a distinction sometimes between resetting just the CPU (leaving GPIO state alone) and resetting all the PMICs, just cutting power. To achieve this, add a simple system reset uclass. It allows multiple devices to provide reset functionality and provides a way to walk through them, requesting a particular reset type until is it provided. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-20driver/fsl_debug_server: Fix the DDR hide logic for LS2085aBhupesh Sharma
This patch fixes the DDR hide logic for LS2085a, correcting the way the Debug Server FW and MC FW images are placed on the top of system DDR and how the rest of the system DDR space is made visibile to Linux. Signed-off-by: Bhupesh Sharma <bhupesh.sharma at freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar at freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-05-14sandbox: cros_ec: Support EC_CMD_ENTERING_MODE emulationSimon Glass
Emualate this function which is used with Chrome OS verified boot. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-05-14sandbox: Add missing errno.h includes in a few filesSimon Glass
These files use error numbering, so add the include. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-05-08misc: led: Add PCA9551 LED driverStefan Roese
This patch adds a driver for the PCA9551 LED controller. Originated-by: Timo Herbrecher <t.herbrecher@gateware.de> Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Cc: Fabio Estevam <festevam@gmail.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-05-05cros_ec: Handle the single duplex requirement in cros_ecSimon Glass
With several chips using the SPI protocol it seems better to put the single duplex functionality in the EC rather than the SPI driver. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-05-05cros_ec: Show the protocol version in the debug messageSimon Glass
When starting up, show the protocol version that has been negotiated with the EC. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-29x86: Set serial port IRQ for SMSC LPC47MBin Meng
For starting a Linux console on the superio serial port under interrupt mode, the IRQ number must be configured. Signed-off-by: Jian Luo <jian.luo4@boschrexroth.de> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-24Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2015-04-23armv8/ls2085aqds: NAND boot supportScott Wood
This adds NAND boot support for LS2085AQDS, using SPL framework. Details of forming NAND image can be found in README. Signed-off-by: Scott Wood <scottwood@freescale.com> [York Sun: Remove +S from defconfig after commit 252ed872] Signed-off-by: York Sun <yorksun@freescale.com>
2015-04-23driver/fsl_ifc: Add support to finalize CS1, CS3 address bindingPrabhakar Kushwaha
For fsl-lsch3, IFC is binded with address within 32-bit at fist. After u-boot relocates to DDR, CS1, CS3 can be binded to higher address to support large space. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com>
2015-04-23cmd_led: Extend led command to support blinking and more ledsStefan Roese
This patch extends the U-Boot "led" command to support automatic blinking by setting a blink frequency in milliseconds. Additionally the number of supported LEDs is increased to 6 (0...5). This will be used by the PCA9551 LED driver. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-04-21armv8/fsl-lsch3: Add Freescale Debug Server driverBhupesh Sharma
The Debug Server driver is responsible for loading the Debug server FW on the Service Processor (Cortex-A5 core) on LS2085A like SoCs and then polling for the successful initialization of the same. TOP MEM HIDE is adjusted to ensure the space required by Debug Server FW is accounted for. MC uses the DDR area which is calculated as: MC DDR region start = Top of DDR - area reserved by Debug Server FW Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-18sandbox: cros_ec: Add Kconfig for sandbox EC configSimon Glass
Move CONFIG_CROS_EC_SANDBOX to Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18cros_ec: exynos: Match up device tree with kernel versionSimon Glass
The U-Boot device trees are slightly different in a few places. Adjust them to remove most of the differences. Note that U-Boot does not support the concept of interrupts as distinct from GPIOs, so this difference remains. For sandbox, use the same keyboard file as for ARM boards and drop the host emulation bus which seems redundant. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18cros_ec: Drop unused CONFIG_DM_CROS_ECSimon Glass
Since all supported boards enable this option now, we can remove it along with the old code. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18cros_ec: Reinit the cros_ec device when 'crosec init' is usedSimon Glass
This command is supposed to reinit the device. At present with driver model is does nothing. Implement this feature. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: cros_ec: Convert cros_ec LPC driver to driver modelSimon Glass
This is the last driver to be converted. It requires an LPC bus and a special check_version() method. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: sandbox: pci: Enable PCI for sandboxSimon Glass
Enable PCI options so that sandbox can be used for testing this bus with driver model. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: sandbox: Add a emulated PCI device as an exampleSimon Glass
This device sits on the sandbox PCI bus and provides a case-swapping service for sandbox. It illustrates the use of both PCI I/O and PCI memory accesses. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-16dm: core: Add dev_get_uclass_priv() to access uclass private dataSimon Glass
Add a convenience function to access the private data that a uclass stores for each of its devices. Convert over most existing uses for consistency and to provide an example for others. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-03-05fsl_sec_mon: Add driver for Security Monitor block of Freescalegaurav rana
The Security Monitor is the SOC’s central reporting point for security-relevant events such as the success or failure of boot software validation and the detection of potential security compromises. The API's for transition of Security states have been added which will be used in case of SECURE BOOT. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-02-19dm: cros_ec: Convert to KconfigSimon Glass
Since both I2C and SPI are converted to Kconfig, we can convert cros_ec to Kconfig for these buses. LPC will need to wait until driver mode PCI is available. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: Expand and complete Kconfig in drivers/Simon Glass
Expand the help messages for each driver. Add missing Kconfig for I2C, SPI flash and thermal. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-01-29dm: cros_ec: Convert cros_ec_i2c over to driver modelSimon Glass
Move this driver to use driver model and update the snow configuration to match. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: cros_ec_spi: Remove old pre-driver-model codeSimon Glass
This is no-longer needed since all platforms use SPI for cros_ec. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: cros_ec: Don't require protocol 3 supportSimon Glass
I2C is now deprecated on ARM platforms and there are no devices that use it with the v3 protocol. We can't require v3 support if we want to support I2C. Adjust the error handling to suit. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: spi: Move slave details to child platdataSimon Glass
At present we go through various contortions to store the SPI slave's chip select in its private data. This only exists when the slave is active so must be set up when it is probed. Until the device is probed we don't actually know what chip select it will appear on. However, now that we can support per-child platform data, we can use that instead. This allows us to set up the chip select when the child is bound, and avoid the messy contortions. Unfortunately this is a fairly large change and it seems to be difficult to break it down further. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: cros_ec: Remove use of fdtdec GPIO supportSimon Glass
These functions are going away, so use the new uclass support instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-05i2c_eeprom: include <linux/err.h> to fix build errorMasahiro Yamada
drivers/misc/i2c_eeprom.c fails to build unless CONFIG_FIT_SIGNATURE is defined. CC drivers/misc/i2c_eeprom.o drivers/misc/i2c_eeprom.c: In function 'i2c_eeprom_read': drivers/misc/i2c_eeprom.c:15:10: error: 'ENODEV' undeclared (first use in this function) drivers/misc/i2c_eeprom.c:15:10: note: each undeclared identifier is reported only once for each function it appears in drivers/misc/i2c_eeprom.c: In function 'i2c_eeprom_write': drivers/misc/i2c_eeprom.c:21:10: error: 'ENODEV' undeclared (first use in this function) drivers/misc/i2c_eeprom.c:22:1: warning: control reaches end of non-void function [-Wreturn-type] drivers/misc/i2c_eeprom.c: In function 'i2c_eeprom_read': drivers/misc/i2c_eeprom.c:16:1: warning: control reaches end of non-void function [-Wreturn-type] make[2]: *** [drivers/misc/i2c_eeprom.o] Error 1 make[1]: *** [drivers/misc] Error 2 make: *** [drivers] Error 2 By the way, Sandbox (enabling CONFIG_FIT_SIGNATURE) is luckily working depending on it. Sandbox includes include/asm-generic/errno.h from include/errno.h from include/u-boot/rsa-checksum.h from include/image.h from include/common.h from drivers/misc/i2c_eeprom.c Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-13x86: Add a simple superio driver for SMSC LPC47MBin Meng
On most x86 boards, the legacy serial ports (io address 0x3f8/0x2f8) are provided by a superio chip connected to the LPC bus. We must program the superio chip so that serial ports are available for us. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-11dm: Add a simple EEPROM driverSimon Glass
There seem to be a few EEPROM drivers around - perhaps we should have a single standard one? This simple driver is used for sandbox testing, but could be pressed into more active service. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-11dm: i2c: Add an I2C EEPROM simulatorSimon Glass
To enable testing of I2C, add a simple I2C EEPROM simulator for sandbox. It supports reading and writing from a small data store. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-01mxc_ocotp: Do not disable the OCOTP clock after every accessFabio Estevam
Leave the OCOTP turned on, so that we subsequent access do not fail. After enabling the thermal driver on a mx6sxsabresd board: U-Boot 2015.01-rc1-18267-g99d4189-dirty (Nov 24 2014 - 12:59:01) CPU: Freescale i.MX6SX rev1.0 at 792 MHz CPU: Temperature 48 C Reset cause: POR Board: MX6SX SABRE SDB I2C: ready DRAM: 1 GiB PMIC: PFUZE100 ID=0x10 MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2 00:01.0 - 16c3:abcd - Bridge device 01:00.0 - 8086:08b1 - Network controller In: serial Out: serial Err: serial Net: (hang) As the thermal driver accesses the ocotp registers, its clock will be disabled afterwards. Then when the MAC address is read (also from ocotp registers) it will cause a hang. Do not disable the ocotp clock to prevent this problem. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau.dev@gmail.com>
