path: root/drivers/misc
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-07-20powerpc/p3041: Add various p3041 related definesKumar Gala
There are various locations that we have chip specific info: * Makefile for which ddr code to build * Added p3041 to cpu_type_list and SVR list * Added number of LAWs for p3041 * Set CONFIG_MAX_CPUS to 4 for p3041 Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-20powerpc/p5020: Add various p5020 related defines (and p5010)Kumar Gala
There are various locations that we have chip specific info: * Makefile for which ddr code to build * Added p5020 & p5010 to cpu_type_list and SVR list * Added number of LAWs for p5020 * Set CONFIG_MAX_CPUS to 2 for p5020 Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16fsl_law.c: Add print_laws() for FSL_CORENET platforms.Becky Bruce
Add printing of LAWBARH/LAWBARL for FSL_CORENET platforms. Signed-off-by: Becky Bruce <Beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16drivers/misc/fsl_law.c: Rearrange code to avoid duplicationBecky Bruce
The current code redefines functions based on FSL_CORENET_ vs not - create macros/inlines instead that hide the differences. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-12gpio_led: add gpio_request to __led_initThomas Chou
This patch adds the gpio usage request. The polarity is changed to positive as suggested by Mike Frysinger. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-05-28misc: add gpio based status led driverThomas Chou
This patch adds a status led driver followed the GPIO access conventions of Linux. The led mask is used to specify the gpio pin. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Tested-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-05-05MX: Added Freescale Power Management DriverStefano Babic
The patch add supports for the Freescale's Power Management Controller (known as Atlas) used together with i.MX31/51 processors. It was tested with a MC13783 (MX31) and MC13892 (MX51). Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-04-0785xx: Added various P1012/P1013/P1021/P1022 definesKumar Gala
There are various locations that we have chip specific info: * Makefile for which ddr code to build * Added P1012/P1013/P1021/P1022 to cpu_type_list and SVR list * Added number of LAWs for P1012/P1013/P1021/P1022 * Set CONFIG_MAX_CPUS to 2 for P1021/P1022 * PCI port config Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-01-04TWL4030: make LEDs selectable for twl4030_led_init()Grazvydas Ignotas
Not all boards have both LEDs hooked, so enabling both on boards with single LED will just waste power. Make it possible to choose LEDs by adding argument to twl4030_led_init(). Using this turn on only LEDB for pandora, leave both LEDs on for all other boards, as it was before this patch. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
2009-09-30ppc/85xx: get_law_entry isn't used in CONFIG_NAND_SPLKumar Gala
Don't include get_law_entry as part of the NAND_SPL build since the code isnt used. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24ppc/p4080: Add various p4080 related defines (and p4040)Kumar Gala
There are various locations that we have chip specific info: * Makefile for which ddr code to build * Added p4080 & p4040 to cpu_type_list and SVR list * Added number of LAWs for p4080 * Set CONFIG_MAX_CPUS to 8 for p4080 Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24ppc/p4080: Add support for CoreNet style platform LAWsKumar Gala
On CoreNet based platforms the LAW address is split between an high & low register and we no longer shift the address. Also, the target IDs on CoreNet platforms have been completely re-assigned. Additionally, added a new find_law() API to which LAW an address hits in. This is need for the CoreNet style boot release code since it will need to determine what the target ID should be set to for boot window translation. Finally, enamed LAWAR_EN to LAW_EN and moved to header so we can use it elsewhere. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-15ppc/85xx: add boot from NAND/eSDHC/eSPI supportMingkai Hu
The MPC8536E is capable of booting form NAND/eSDHC/eSPI, this patch implements these three bootup methods in a unified way - all of these use the general cpu/mpc85xx/start.S, and load the main image to L2SRAM which lets us use the SPD to initialize the SDRAM. For all three bootup methods, the bootup process can be divided into two stages: the first stage will initialize the corresponding controller, configure the L2SRAM, then copy the second stage image to L2SRAM and jump to it. The second stage image is just like the general U-Boot image to configure all the hardware and boot up to U-Boot command line. When boot from NAND, the eLBC controller will first load the first stage image to internal 4K RAM buffer because it's also stored on the NAND flash. The first stage image, also call 4K NAND loader, will initialize the L2SRAM, load the second stage image to L2SRAM and jump to it. The 4K NAND loader's code comes from the corresponding nand_spl directory, along with the code twisted by CONFIG_NAND_SPL. When boot from eSDHC/eSPI, there's no such a first stage image because the CPU ROM code does the same work. It will initialize the L2SRAM according to the config addr/word pairs on the fixed address and initialize the eSDHC/eSPI controller, then load the second stage image to L2SRAM and jump to it. The macro CONFIG_SYS_RAMBOOT is used to control the code to produce the second stage image for all different bootup methods. It's set in the board config file when one of the bootup methods above is selected. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-08fsl: add register read-back to set_law()Timur Tabi
After programming a new LAW, we should read-back the LAWAR register so that we sync the writes. Otherwise, code that attempts to use the new LAW-mapped memory might fail right away. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Added single core members of FSL P1xx/P2xx processors seriesPoonam Aggrwal
P1011 - Single core variant of P1020 P2010 - Single core variant of P2020 Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Added P1020 Processor Support.Poonam Aggrwal
P1020 is another member of QorIQ series of processors which falls in ULE category. It is an e500 based dual core SOC. Being a scaled down version of P2020 it has following differences: - 533MHz - 800MHz core frequency. - 256Kbyte L2 cache - Ethernet controllers with classification capabilities. Also the SOC is pin compatible with P2020 Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-29OMAP3 Move twl4030 power and led functionsTom Rix
Because twl4030 now has its own device files, move exiting omap3 power_init_r to a new location. power_init_r is the only function in board/omap3/common. It initializes the twl4030 power for the board and enables the led. The power part of the the function is moved to twl4030_power_init in drivers/power/twl4030.c The power compilation is conditional on the existing config variable CONFIG_TWL4030_POWER. The led part is moved to twl4030_led_init in the new file drivers/misc/twl4030_led.c The led compilation is conditional on the new config variable CONFIG_TWL4030_LED The directory board/omap3/common was removed because power_init_r was the only function in it. Signed-off-by: Tom Rix <Tom.Rix@windriver.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Heiko Schocher <hs@denx.de>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-04-04fsl_law: Fix bug in calculation of LAW sizingKumar Gala
In set_ddr_laws() when we determined how much of the size requested to be mapped was covered by the the first LAW we needed to recalculate the size based on what was actually mapped. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-03-30MPC85xx: Add MPC8569 CPU supportHaiying Wang
There is a workaround for MPC8569 CPU Errata, which needs to set Bit 13 of LBCR in 4K bootpage. We setup a temp TLB for eLBC controller in bootpage, then invalidate it after LBCR bit 13 is set. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-03-20Move ali512x.hGraeme Russ
Moved ali512x.h from include/asm-i386/ic/ to /include Signed-off-by: Graeme Russ <graeme.russ at gmail.com>
2009-02-16mpc85xx: Add support for the P2020Srikanth Srinivasan
Added various p2020 processor specific details: * SVR for p2020, p2020E * immap updates for LAWs and DDR on p2020 * LAW defines related to p2020 Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com> Signed-off-by: Travis Wheatley <Travis.Wheatley@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2009-01-24Add support for Maxim's DS4510 I2C devicePeter Tyser
Initial support for the DS4510, a CPU supervisor with integrated EEPROM, SRAM, and 4 programmable non-volatile GPIO pins. The CONFIG_DS4510 define enables support for the device while the CONFIG_CMD_DS4510 define enables the ds4510 command. The additional CONFIG_DS4510_INFO, CONFIG_DS4510_MEM, and CONFIG_DS4510_RST defines add additional sub-commands to the ds4510 command when defined. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-10-18fsl_law clear enable before changing.Ed Swarthout
Debug sessions may have left enabled laws. Changing lawbar with an unkown enabled tgtid could cause problems. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
2008-08-27mpc85xx: Add support for the MPC8536Kumar Gala
The MPC8536 Adds SDHC and SATA controllers to the PQ3 family. We also have SERDES init code for the 8536. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com> Signed-off-by: Dejan Minic <minic@freescale.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com> Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-08-27FSL DDR: Provide a generic set_ddr_laws()Kumar Gala
Provide a helper function that will setup the last available LAWs (upto 2) for DDR. Useful for SPD/dyanmic DDR setting code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-13drivers/misc: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-06-11FSL LAW: Add new interface to use the last free LAWKumar Gala
LAWs have the concept of priority so its useful to be able to allocate the lowest (highest number) priority. We will end up using this with the new DDR code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-06-11FSL LAW: Keep track of LAW allocationsKumar Gala
Make it so we keep track of which LAWs have allocated and provide a function (set_next_law) which can allocate a LAW for us if one is free. In the future we will move to doing more "dynamic" LAW allocation since the majority of users dont really care about what LAW number they are at. Also, add CONFIG_MPC8540 or CONFIG_MPC8560 to those boards which needed them Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-01-2486xx: Add print_laws function to fsl_law.cBecky Bruce
This can be used for debug, and will be used by board code to help implement reginfo. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-01-1685xx: Move LAW init code into CKumar Gala
Move the initialization of the LAWs into C code and provide an API to allow modification of LAWs after init. Board code is responsible to provide a law_table and num_law_entries. We should be able to use the same code on 86xx as well. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-11-25drivers/misc : move misc drivers to drivers/miscJean-Christophe PLAGNIOL-VILLARD
