path: root/drivers/misc
2015-05-14sandbox: cros_ec: Support EC_CMD_ENTERING_MODE emulationSimon Glass
Emualate this function which is used with Chrome OS verified boot. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-05-14sandbox: Add missing errno.h includes in a few filesSimon Glass
These files use error numbering, so add the include. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-05-08misc: led: Add PCA9551 LED driverStefan Roese
This patch adds a driver for the PCA9551 LED controller. Originated-by: Timo Herbrecher <t.herbrecher@gateware.de> Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Cc: Fabio Estevam <festevam@gmail.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-05-05cros_ec: Handle the single duplex requirement in cros_ecSimon Glass
With several chips using the SPI protocol it seems better to put the single duplex functionality in the EC rather than the SPI driver. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-05-05cros_ec: Show the protocol version in the debug messageSimon Glass
When starting up, show the protocol version that has been negotiated with the EC. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-29x86: Set serial port IRQ for SMSC LPC47MBin Meng
For starting a Linux console on the superio serial port under interrupt mode, the IRQ number must be configured. Signed-off-by: Jian Luo <jian.luo4@boschrexroth.de> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-24Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2015-04-23armv8/ls2085aqds: NAND boot supportScott Wood
This adds NAND boot support for LS2085AQDS, using SPL framework. Details of forming NAND image can be found in README. Signed-off-by: Scott Wood <scottwood@freescale.com> [York Sun: Remove +S from defconfig after commit 252ed872] Signed-off-by: York Sun <yorksun@freescale.com>
2015-04-23driver/fsl_ifc: Add support to finalize CS1, CS3 address bindingPrabhakar Kushwaha
For fsl-lsch3, IFC is binded with address within 32-bit at fist. After u-boot relocates to DDR, CS1, CS3 can be binded to higher address to support large space. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com>
2015-04-23cmd_led: Extend led command to support blinking and more ledsStefan Roese
This patch extends the U-Boot "led" command to support automatic blinking by setting a blink frequency in milliseconds. Additionally the number of supported LEDs is increased to 6 (0...5). This will be used by the PCA9551 LED driver. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-04-21armv8/fsl-lsch3: Add Freescale Debug Server driverBhupesh Sharma
The Debug Server driver is responsible for loading the Debug server FW on the Service Processor (Cortex-A5 core) on LS2085A like SoCs and then polling for the successful initialization of the same. TOP MEM HIDE is adjusted to ensure the space required by Debug Server FW is accounted for. MC uses the DDR area which is calculated as: MC DDR region start = Top of DDR - area reserved by Debug Server FW Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-18sandbox: cros_ec: Add Kconfig for sandbox EC configSimon Glass
Move CONFIG_CROS_EC_SANDBOX to Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18cros_ec: exynos: Match up device tree with kernel versionSimon Glass
The U-Boot device trees are slightly different in a few places. Adjust them to remove most of the differences. Note that U-Boot does not support the concept of interrupts as distinct from GPIOs, so this difference remains. For sandbox, use the same keyboard file as for ARM boards and drop the host emulation bus which seems redundant. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18cros_ec: Drop unused CONFIG_DM_CROS_ECSimon Glass
Since all supported boards enable this option now, we can remove it along with the old code. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18cros_ec: Reinit the cros_ec device when 'crosec init' is usedSimon Glass
This command is supposed to reinit the device. At present with driver model is does nothing. Implement this feature. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: cros_ec: Convert cros_ec LPC driver to driver modelSimon Glass
This is the last driver to be converted. It requires an LPC bus and a special check_version() method. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: sandbox: pci: Enable PCI for sandboxSimon Glass
Enable PCI options so that sandbox can be used for testing this bus with driver model. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: sandbox: Add a emulated PCI device as an exampleSimon Glass
This device sits on the sandbox PCI bus and provides a case-swapping service for sandbox. It illustrates the use of both PCI I/O and PCI memory accesses. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-16dm: core: Add dev_get_uclass_priv() to access uclass private dataSimon Glass
Add a convenience function to access the private data that a uclass stores for each of its devices. Convert over most existing uses for consistency and to provide an example for others. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-03-05fsl_sec_mon: Add driver for Security Monitor block of Freescalegaurav rana
The Security Monitor is the SOC’s central reporting point for security-relevant events such as the success or failure of boot software validation and the detection of potential security compromises. The API's for transition of Security states have been added which will be used in case of SECURE BOOT. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-02-19dm: cros_ec: Convert to KconfigSimon Glass
Since both I2C and SPI are converted to Kconfig, we can convert cros_ec to Kconfig for these buses. LPC will need to wait until driver mode PCI is available. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: Expand and complete Kconfig in drivers/Simon Glass
Expand the help messages for each driver. Add missing Kconfig for I2C, SPI flash and thermal. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-01-29dm: cros_ec: Convert cros_ec_i2c over to driver modelSimon Glass
Move this driver to use driver model and update the snow configuration to match. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: cros_ec_spi: Remove old pre-driver-model codeSimon Glass
This is no-longer needed since all platforms use SPI for cros_ec. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: cros_ec: Don't require protocol 3 supportSimon Glass
I2C is now deprecated on ARM platforms and there are no devices that use it with the v3 protocol. We can't require v3 support if we want to support I2C. Adjust the error handling to suit. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: spi: Move slave details to child platdataSimon Glass
At present we go through various contortions to store the SPI slave's chip select in its private data. This only exists when the slave is active so must be set up when it is probed. Until the device is probed we don't actually know what chip select it will appear on. However, now that we can support per-child platform data, we can use that instead. This allows us to set up the chip select when the child is bound, and avoid the messy contortions. Unfortunately this is a fairly large change and it seems to be difficult to break it down further. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: cros_ec: Remove use of fdtdec GPIO supportSimon Glass
These functions are going away, so use the new uclass support instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-05i2c_eeprom: include <linux/err.h> to fix build errorMasahiro Yamada
drivers/misc/i2c_eeprom.c fails to build unless CONFIG_FIT_SIGNATURE is defined. CC drivers/misc/i2c_eeprom.o drivers/misc/i2c_eeprom.c: In function 'i2c_eeprom_read': drivers/misc/i2c_eeprom.c:15:10: error: 'ENODEV' undeclared (first use in this function) drivers/misc/i2c_eeprom.c:15:10: note: each undeclared identifier is reported only once for each function it appears in drivers/misc/i2c_eeprom.c: In function 'i2c_eeprom_write': drivers/misc/i2c_eeprom.c:21:10: error: 'ENODEV' undeclared (first use in this function) drivers/misc/i2c_eeprom.c:22:1: warning: control reaches end of non-void function [-Wreturn-type] drivers/misc/i2c_eeprom.c: In function 'i2c_eeprom_read': drivers/misc/i2c_eeprom.c:16:1: warning: control reaches end of non-void function [-Wreturn-type] make[2]: *** [drivers/misc/i2c_eeprom.o] Error 1 make[1]: *** [drivers/misc] Error 2 make: *** [drivers] Error 2 By the way, Sandbox (enabling CONFIG_FIT_SIGNATURE) is luckily working depending on it. Sandbox includes include/asm-generic/errno.h from include/errno.h from include/u-boot/rsa-checksum.h from include/image.h from include/common.h from drivers/misc/i2c_eeprom.c Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-13x86: Add a simple superio driver for SMSC LPC47MBin Meng
On most x86 boards, the legacy serial ports (io address 0x3f8/0x2f8) are provided by a superio chip connected to the LPC bus. We must program the superio chip so that serial ports are available for us. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-11dm: Add a simple EEPROM driverSimon Glass
There seem to be a few EEPROM drivers around - perhaps we should have a single standard one? This simple driver is used for sandbox testing, but could be pressed into more active service. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-11dm: i2c: Add an I2C EEPROM simulatorSimon Glass
To enable testing of I2C, add a simple I2C EEPROM simulator for sandbox. It supports reading and writing from a small data store. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-01mxc_ocotp: Do not disable the OCOTP clock after every accessFabio Estevam
Leave the OCOTP turned on, so that we subsequent access do not fail. After enabling the thermal driver on a mx6sxsabresd board: U-Boot 2015.01-rc1-18267-g99d4189-dirty (Nov 24 2014 - 12:59:01) CPU: Freescale i.MX6SX rev1.0 at 792 MHz CPU: Temperature 48 C Reset cause: POR Board: MX6SX SABRE SDB I2C: ready DRAM: 1 GiB PMIC: PFUZE100 ID=0x10 MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2 00:01.0 - 16c3:abcd - Bridge device 01:00.0 - 8086:08b1 - Network controller In: serial Out: serial Err: serial Net: (hang) As the thermal driver accesses the ocotp registers, its clock will be disabled afterwards. Then when the MAC address is read (also from ocotp registers) it will cause a hang. Do not disable the ocotp clock to prevent this problem. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau.dev@gmail.com>
2014-12-01mxs_ocotp: clear the error flag before initiating write operationHector Palacios
A previous operation may have set the error flag, which must be cleared before a new write operation can be issued. Signed-off-by: Hector Palacios <hector.palacios@digi.com>
2014-12-01mxs_ocotp: check for errors from the OTP controller after writingHector Palacios
The write operation may fail when trying to write to a locked area. In this case the ERROR bit is set in the CTRL register. Check for that condition and return an error. Signed-off-by: Hector Palacios <hector.palacios@digi.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-12-01mxs_ocotp: prevent error path from returning successHector Palacios
The code may goto 'fail' upon error with 'ret' variable set to an error code, but this variable was being overwritten by a final preparation function to restore the HCLK, so success was (in general) returned even after an error was hit previously. With this change, the function may now return success even if the final preparation function fails, but it's probably enough to print a message because (if successful) the real programming of the fuses has already completed. Signed-off-by: Hector Palacios <hector.palacios@digi.com>
2014-11-24Merge git://git.denx.de/u-boot-dmTom Rini
Conflicts: drivers/serial/serial-uclass.c Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23linux/kernel.h: sync min, max, min3, max3 macros with LinuxMasahiro Yamada
U-Boot has never cared about the type when we get max/min of two values, but Linux Kernel does. This commit gets min, max, min3, max3 macros synced with the kernel introducing type checks. Many of references of those macros must be fixed to suppress warnings. We have two options: - Use min, max, min3, max3 only when the arguments have the same type (or add casts to the arguments) - Use min_t/max_t instead with the appropriate type for the first argument Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Pavel Machek <pavel@denx.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [trini: Fixup arch/blackfin/lib/string.c] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-22cros_ec: Fix uninitialised variable in cros_ec.cSimon Glass
This fixes this cppcheck report: [drivers/misc/cros_ec.c:704]: (error) Uninitialized variable: req Signed-off-by: Simon Glass <sjg@chromium.org> Reported-by: Wolfgang Denk <wd@denx.de>
2014-11-20replace DIV_ROUND with DIV_ROUND_CLOSESTMasahiro Yamada
The Linux-compatible macro DIV_ROUND_CLOSEST is a bit more flexible and safer than DIV_ROUND. For example, foo = DIV_ROUND_CLOSEST(x, y++) works expectedly, but foo = DIV_ROUND(x, y++) does not. (y is incremented twice.) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-23Merge git://git.denx.de/u-boot-x86Tom Rini
2014-10-22x86: cros_ec: Update LPC driver for new cros_ec headerSimon Glass
There was a minor rename of one of the defines, so update the driver. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-22dm: exynos: cros_ec: Move cros_ec_spi to driver modelSimon Glass
Adjust this driver to use driver model and move smdk5420 boards over to use it. Acked-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-22dm: sandbox: cros_ec: Move sandbox cros_ec to driver moduleSimon Glass
Adjust the sandbox cros_ec emulation driver to work with driver model, and switch over to driver model for sandbox cros_ec. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2014-10-22dm: cros_ec: Add support for driver modelSimon Glass
Add support for driver model if enabled. This involves minimal changes to the code, mostly just plumbing around the edges. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2014-09-24kconfig: add blank Kconfig filesMasahiro Yamada
This would be useful to start moving various config options. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-08-06cros_ec: Fix two bugs in the SPI implementationSimon Glass
An incorrect message version is passed to the EC in some cases and the parameters of one function are switched. Fix these problems. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Ajay Kumar <ajaykumar.rs@samsung.com> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-07-23stdio: Pass device pointer to stdio methodsSimon Glass
At present stdio device functions do not get any clue as to which stdio device is being acted on. Some implementations go to great lengths to work around this, such as defining a whole separate set of functions for each possible device. For driver model we need to associate a stdio_dev with a device. It doesn't seem possible to continue with this work-around approach. Instead, add a stdio_dev pointer to each of the stdio member functions. Note: The serial drivers have the same problem, but it is not strictly necessary to fix that to get driver model running. Also, if we convert serial over to driver model the problem will go away. Code size increases by 244 bytes for Thumb2 and 428 for PowerPC. 22: stdio: Pass device pointer to stdio methods arm: (for 2/2 boards) all +244.0 bss -4.0 text +248.0 powerpc: (for 1/1 boards) all +428.0 text +428.0 Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Marek Vasut <marex@denx.de>
2014-06-19includes: move openssl headers to include/u-bootJeroen Hofstee
commit 18b06652cd "tools: include u-boot version of sha256.h" unconditionally forced the sha256.h from u-boot to be used for tools instead of the host version. This is fragile though as it will also include the host version. Therefore move it to include/u-boot to join u-boot/md5.h etc which were renamed for the same reason. cc: Simon Glass <sjg@chromium.org> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-04-22driver/fsl_ifc: Add a function to finalize CS0 address bindingYork Sun
For fsl-lsch3 NOR flash boot, IFC CS0 needs to be binded with address within 32-bit at fist. After u-boot relocates to DDR, CS0 can be binded to higher address to support large space. Signed-off-by: York Sun <yorksun@freescale.com> CC: Prabhakar Kushwaha <prabhakar@freescale.com>
2014-04-04Merge branch 'master' of git://git.denx.de/u-boot-arm into masterStefano Babic
Conflicts: arch/arm/cpu/arm926ejs/mxs/mxsimage.mx23.cfg arch/arm/cpu/arm926ejs/mxs/mxsimage.mx28.cfg Signed-off-by: Stefano Babic <sbabic@denx.de>
