path: root/drivers/misc/tegra186_bpmp.c
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-01dm: core: Update device_bind_driver_to_node() to use ofnodeSimon Glass
Adjust this function to us an ofnode instead of an offset, so it can be used with livetree. This involves updating all callers. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-08-15misc: add Tegra BPMP driverStephen Warren
The Tegra BPMP (Boot and Power Management Processor) is a separate auxiliary CPU embedded into Tegra to perform power management work, and controls related features such as clocks, resets, power domains, PMIC I2C bus, etc. This driver provides the core low-level communication path by which feature-specific drivers (such as clock) can make requests to the BPMP. This driver is similar to an MFD driver in the Linux kernel. It is unconditionally selected by CONFIG_TEGRA186 since virtually any Tegra186 build of U-Boot will need the feature. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
