path: root/drivers/misc/imx8
2020-07-25treewide: convert devfdt_get_addr() to dev_read_addr()Masahiro Yamada
When you enable CONFIG_OF_LIVE, you will end up with a lot of conversions. To generate this commit, I used coccinelle excluding drivers/core/, include/dm/, and test/ The semantic patch that makes this change is as follows: <smpl> @@ expression dev; @@ -devfdt_get_addr(dev) +dev_read_addr(dev) </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2020-07-24Revert "Merge tag 'dm-pull-20jul20' of git://git.denx.de/u-boot-dm"Tom Rini
This reverts commit 5d3a21df6694ebd66d5c34c9d62a26edc7456fc7, reversing changes made to 56d37f1c564107e27d873181d838571b7d7860e7. Unfortunately this is causing CI failures: https://travis-ci.org/github/trini/u-boot/jobs/711313649 Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-20treewide: convert devfdt_get_addr() to dev_read_addr()Masahiro Yamada
2020-07-16misc: scu_api: Add SCFW API to get the index of boot container setYe Li
Add SCFW API sc_misc_get_boot_container to get current boot container set index. The index value returns 1 for primary container set, 2 for secondary container set. Signed-off-by: Ye Li <ye.li@nxp.com> Reviewed-by: Peng Fan <peng.fan@nxp.com>
2020-07-14imx8: fuse: use arm_smccc_smcPeng Fan
Use arm_smccc_smc to replace call_imx_sip Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-18common: Drop linux/bitops.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-10misc: scu: Increase the timeout for MU communicationYe Li
When power on some sources in Video system, current timeout 10ms is too short and returns before SCU response. So increase the timeout to 1s. Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10misc: fuse: Update imx8 fuse driver for 8QMYe Li
Add the second ECC fuse area for 8QM which is different with 8QXP Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-01imx8: Configure SNVSFranck LENORMAND
Add a module to configure the tamper and secure violation of the SNVS using the SCU API. The module also adds some commands: - snvs_cfg: Configure the SNVS HP and LP registers - snvs_dgo_cfg: Configure the SNVS DGO bloc if present (8QXP) - tamper_pin_cfg: Change the configuration of the tamper pins - snvs_clear_status: Allow to write to LPSR and LPTDSR to clear status bits Reviewed-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Franck LENORMAND <franck.lenormand@nxp.com> Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-01imx8: Update SCFW API to version 1.5Ye Li
Sync the latest SCFW API with below commit 6dcd0242ae7a53ac ("SCF-105: Revert accidental change") to add interfaces for PM resource reset and read/write SNVS security violation and tamper DGO registers. Reviewed-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-01imx8: scu api: Add support for SECO manufacturing protection APIsBreno Lima
SECO provides APIs to support CAAM manufacturing protection: - sc_seco_get_mp_key() - sc_seco_get_mp_sign() - sc_seco_update_mpmr() Add SCFW APIs support. Reviewed-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Breno Lima <breno.lima@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-02-05dm: core: Create a new header file for 'compat' featuresSimon Glass
At present dm/device.h includes the linux-compatible features. This requires including linux/compat.h which in turn includes a lot of headers. One of these is malloc.h which we thus end up including in every file in U-Boot. Apart from the inefficiency of this, it is problematic for sandbox which needs to use the system malloc() in some files. Move the compatibility features into a separate header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-17common: Move hang() to the same header as panic()Simon Glass
At present panic() is in the vsprintf.h header file. That does not seem like an obvious choice for hang(), even though it relates to panic(). So let's put hang() in its own header. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Migrate a few more files] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-11-05misc: imx8: scu: simplify code to make it extendablePeng Fan
clk and pinctrl will be get(probed) during each device probe, we don't need to probe them in scu driver. Only need to bind the sub-nodes (clk and iomuxc) of MU node with their drivers. So drop the code to probe the clk/pinctrl, and this patch will make it easy to add more subnodes. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-11-03mach-imx: Adding new argument for SIP call interfaceYe Li
Need to pass total 5 arguments for SIP HAB call on i.MX8MQ, so update the interface to add new argument. Signed-off-by: Ye Li <ye.li@nxp.com> [agust: fixed imx8m-power-domain build] Signed-off-by: Anatolij Gustschin <agust@denx.de> Reviewed-by: Patrick Wildt <patrick@blueri.se> Reviewed-by: Peng Fan <peng.fan@nxp.com>
2019-10-08misc: imx8: add more scfw apiPeng Fan
Add more scfw api for clk/partition/seco usage The api will be used by ccf/partition/secure boot. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-10-08imx: scu_api: add sc_pm_is_partition_startedPeng Fan
Add sc_pm_is_partition_started to check whether a partition has been started. This will be used to detect M4 partition booted up or not, then we could choose which dtb to use. If M4 is up, we need use dtb, such as imx8qm-mek-rpmsg.dtb. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-10-08imx: scu_api: add sc_rm_set_master_sidPeng Fan
Add sc_rm_set_master_sid to set stream sid of masters to make sure they could use smmu. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-07-19misc: imx8: add sc_misc_get_tempPeng Fan
Add sc_misc_get_temp to support get temperature Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-06-11imx8: fuse: fix fuse driverMarcel Ziswiler
This fixes the i.MX 8 fuse driver to actually build for i.MX 8QM as well. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-04-25misc: imx8: scu: add i.MX8QM supportPeng Fan
According to IMX8QXP/8QM config option, choose the clk/iomuxc compatible. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-04-25imx8: fuse: add fuse driverPeng Fan
Add fuse write for i.MX8 Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-01-28imx8: scu: use dedicated MU for SPLPeng Fan
SPL runs in EL3 mode, except MU0_A, others are not powered on, and could not be used. However normal U-Boot use MU1_A, so we could not reuse the one in dts. And we could not replace the one in dts with MU0_A, because MU0_A is reserved in secure world. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-01-09misc: imx8: scu: use platdata instead of priv dataPeng Fan
priv data has not been allocated when doing bind, so it is wrong to use dev_get_priv in bind call back. Let's switch to use platdata in the driver to fix the issue. Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-01-09misc: imx: scu: avoid write null pointerPeng Fan
When boot_dev is true, fill boot device. However the original logic is when boot_dev is false, fill boot device, this will trigger data abort. Also fix sc_misc_get_control when using pointer val. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2018-11-14dm: core: Respect drivers with the DM_FLAG_PRE_RELOC flag in lists_bind_fdt()Bin Meng
Currently the comments of several APIs (eg: dm_init_and_scan()) say: @pre_reloc_only: If true, bind only drivers with the DM_FLAG_PRE_RELOC flag. If false bind all drivers. The 'Pre-Relocation Support' chapter in doc/driver-model/README.txt documents the same that both device tree properties and driver flag are supported. However the implementation only checks these special device tree properties without checking the driver flag at all. This updates lists_bind_fdt() to consider both scenarios. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Squashed in http://patchwork.ozlabs.org/patch/996473/ : Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-22misc: imx8: add scfw api impementationPeng Fan
Add clk/misc/pad/pm/rm scfw api implementaion for different drivers to invoke. The low level code is using misc_call to invoke imx8_scu driver. Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Anatolij Gustschin <agust@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2018-10-22misc: add i.MX8 misc driverPeng Fan
Add i.MX8 MISC driver to handle the communication between A35 Core and SCU. Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Anatolij Gustschin <agust@denx.de> Cc: Stefano Babic <sbabic@denx.de>
