path: root/drivers/misc/fsl_law.c
2008-01-2486xx: Add print_laws function to fsl_law.cBecky Bruce
This can be used for debug, and will be used by board code to help implement reginfo. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-01-1685xx: Move LAW init code into CKumar Gala
Move the initialization of the LAWs into C code and provide an API to allow modification of LAWs after init. Board code is responsible to provide a law_table and num_law_entries. We should be able to use the same code on 86xx as well. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
