path: root/drivers/misc/fsl_iim.c
2014-01-03arm: mx5: Add fuse supply enable in fsl_iimSergey Alyoshin
Enable fuse supply before fuse programming and disable after. Signed-off-by: Sergey Alyoshin <alyoshin.s@gmail.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-28Add fsl_iim driverBenoît Thébaudeau
Add a fsl_iim driver common to i.MX and MPC. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
