path: root/drivers/mailbox
2020-05-18common: Drop linux/bitops.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-15rename symbol: CONFIG_TEGRA -> CONFIG_ARCH_TEGRATrevor Woerner
Have this symbol follow the pattern of all other such symbols. Signed-off-by: Trevor Woerner <twoerner@gmail.com>
2020-02-05dm: core: Create a new header file for 'compat' featuresSimon Glass
At present dm/device.h includes the linux-compatible features. This requires including linux/compat.h which in turn includes a lot of headers. One of these is malloc.h which we thus end up including in every file in U-Boot. Apart from the inefficiency of this, it is problematic for sandbox which needs to use the system malloc() in some files. Move the compatibility features into a separate header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-05mailbox: Rename free() to rfree()Simon Glass
This function name conflicts with our desire to #define free() to something else on sandbox. Since it deals with resources, rename it to rfree(). Signed-off-by: Simon Glass <sjg@chromium.org>
2019-12-02common: Move get_ticks() function out of common.hSimon Glass
This function belongs in time.h so move it over and add a comment. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-10-08mailbox: zynqmp: ipi mailbox driverIbai Erkiaga
ZynqMP mailbox driver implementing IPI communication with PMU. This would allow U-Boot SPL to communicate with PMUFW to request privileged operations. Signed-off-by: Ibai Erkiaga <ibai.erkiaga-elorza@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-10-08mailbox: allow subnode for mbox regsIbai Erkiaga
The following patch allows the mailbox node in DT to host subnodes with mailbox definitions. If the client phandle to the mailbox is not the mailbox driver node, just checks parents as well. Signed-off-by: Ibai Erkiaga <ibai.erkiaga-elorza@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-10-08mailbox: check ops prior callingIbai Erkiaga
Check if request and free operations are present prior calling to the functions. Signed-off-by: Ibai Erkiaga <ibai.erkiaga-elorza@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-07-12mailbox: introduce stm32-ipcc driverFabien Dessenne
On STM32 family, the IPCC peripheral allows the communication between 2 processors offering doorbells mechanism. Signed-off-by: Fabien Dessenne <fabien.dessenne@st.com> Signed-off-by: Loic Pallardy <loic.pallardy@st.com> Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
2018-10-28drivers: cosmetic: Convert SPDX license tags to Linux Kernel stylePatrick Delaunay
Complete in the drivers directory the work started with commit 83d290c56fab ("SPDX: Convert all of our single license tags to Linux Kernel style"). Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-09-11spl: Allow mailbox drivers to be used within SPLLokesh Vutla
Add an option for building mailbox drivers within SPL. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-09-11mailbox: Introduce K3 Secure Proxy DriverLokesh Vutla
Secure Proxy module manages hardware threads that are meant for communication between the processor entities. Adding support for this driver. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-01dm: mailbox: Update uclass to support livetreeSimon Glass
Update the mailbox uclass to support livetree. Fix the xlate() method in all callers. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: Rename dev_addr..() functionsSimon Glass
These support the flat device tree. We want to use the dev_read_..() prefix for functions that support both flat tree and live tree. So rename the existing functions to avoid confusion. In the end we will have: 1. dev_read_addr...() - works on devices, supports flat/live tree 2. devfdt_get_addr...() - current functions, flat tree only 3. of_get_address() etc. - new functions, live tree only All drivers will be written to use 1. That function will in turn call either 2 or 3 depending on whether the flat or live tree is in use. Note this involves changing some dead code - the imx_lpi2c.c file. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-13libfdt: Bring in upstream stringlist functionsSimon Glass
These have now landed upstream. The naming is different and in one case the function signature has changed. Update the code to match. This applies the following upstream commits by Thierry Reding <treding@nvidia.com> : 604e61e fdt: Add functions to retrieve strings 8702bd1 fdt: Add a function to get the index of a string 2218387 fdt: Add a function to count strings Signed-off-by: Simon Glass <sjg@chromium.org>
2016-08-04ARM: tegra: adapt to latest HSP DT bindingStephen Warren
The DT binding for the Tegra186 HSP module apparently wasn't quite final when I posted initial U-Boot support for it. Add the final DT binding doc and adapt all code and DT files to match it. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-06-19mailbox: add Tegra186 HSP driverStephen Warren
Tegra186's HSP module implements doorbells, mailboxes, semaphores, and shared interrupts. This patch provides a driver for HSP, and hooks it into the mailbox API. Currently, only doorbells are supported. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2016-06-19mailbox: rename headersStephen Warren
Rename mailbox*.h to match the naming convention requested during review of the new reset subsystem. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-05-26mailbox: implement a sandbox testStephen Warren
This adds a sandbox mailbox implementation (provider), a test client device, instantiates them both from Sandbox's DT, and adds a DM test that excercises everything. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> # v1
2016-05-26Add a mailbox driver framework/uclassStephen Warren
A mailbox is a hardware mechanism for transferring small message and/or notifications between the CPU on which U-Boot runs and some other device such as an auxilliary CPU running firmware or a hardware module. This patch defines a standard API that connects mailbox clients to mailbox providers (drivers). Initially, DT is the only supported method for connecting the two. The DT binding specification (mailbox.txt) was taken from Linux kernel v4.5's Documentation/devicetree/bindings/mailbox/mailbox.txt. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
