path: root/drivers/led/led_gpio.c
2015-07-21dm: test: Add a test for the LED uclassSimon Glass
Add a test to confirm that we can adjust LEDs using the led_gpio driver. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21dm: led: Add a driver for GPIO-controlled LEDsSimon Glass
Add a simple driver which allows use of LEDs attached to GPIOs. The linux device tree binding is used. Signed-off-by: Simon Glass <sjg@chromium.org>
