path: root/drivers/keyboard.c
2005-03-31* Patch by Detlev Zundel, 31 Mar 2005:wdenk
Cleanup duplicate definition of overwrite_console() * Update TQM5200 configuration; prepare for Rev. 200 starter kit boards
2004-12-12Patch by Martin Krause, 27 Oct 2004:wdenk
- add support for "STK52xx" board (including PS/2 multiplexer) - add hardware detection for TQM5200
2004-01-21* Fix PS/2 keyboard problem caused by statically initialized variablewdenk
pointing to a location in flash * Fix INCA-IP clock calculation: 400/3 = 133.3 MHz, not 130.
2004-01-16[Strange. I _did_ check these in before. Seems SF restored an oldwdenk
version of the repository???] * Patch by Reinhard Meyer, 09 Jan 2004: - add RTC support for MPC5200 based boards (requires RTC_XTAL) * Add support for IDE LED on BMS2003 board (exclusive with status LED!) * Add support for PS/2 keyboard (used with PS/2 multiplexor on BMS2003 board) * Patches by Reinhard Meyer, 4 Jan 2004 + 7 Jan 2004: Add common files for "emk" boards
