path: root/drivers/input
2009-04-03Rename common ns16550 constants with UART_ prefix to prevent conflictsDetlev Zundel
Fix problems introduced in commit 7b5611cdd12ca0cc33f994f0d4a4454788fc3124 [inka4x0: Add hardware diagnosis functions for inka4x0] which redefined MSR_RI which is already used on PowerPC systems. Also eliminate redundant definitions in ps2mult.h. More cleanup will be needed for other redundant occurrences though. Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-08-13drivers/input: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-07-14Code cleanup: fix old style assignment ambiguities like "=-" etc.Wolfgang Denk
2008-06-11TQM8548: Basic support for the TQM8548 modulesWolfgang Grandegger
This patch adds basic support for the TQM8548 module from TQ-Components (http://www.tqc.de/) including DDR2 SDRAM initialisation and support for eTSEC 3 and 4 Furthermore Flash buffer write has been enabled to speed up output to the Flash by approx. a factor of 10. Signed-off-by: Thomas Waehner <thomas.waehner@tqs.de> Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2007-11-25drivers/input : move input drivers to drivers/inputJean-Christophe PLAGNIOL-VILLARD
