path: root/drivers/i2c
2015-07-10exynos: i2c: Correct bug in pinmux selectionSimon Glass
When driver model is not used the current code does not correctly select the pinmux for the I2C bus. This bug was introduced by this commit: 8dfcbaa dm: i2c: s3c24x0: adjust to dm-i2c api Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Przemyslaw Marczak <p.marczak@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-06-10dm: i2c: Add compatibility functions for dm_i2c_reg_read/write()Simon Glass
Add the legacy i2c_reg_read/write() functions to the compatibility layer so that they can be used when CONFIG_DM_I2C_COMPAT is defined. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-05-30Merge branch 'master' of git://git.denx.de/u-boot-uniphierTom Rini
2015-05-31ARM: UniPhier: update the vendor name of UniPhier in KconfigMasahiro Yamada
The business for UniPhier Soc family has been transferred from Panasonic Corporation to Socionext Inc. Update the SoC select menu in Kconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-05-31ARM: UniPhier: replace <asm/io.h> with <linux/io.h>Masahiro Yamada
In the Linux coding style, it is recommended to include <linux/io.h> rather than <asm/io.h>. Follow this trend. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-05-28cosmetic: change Author/MAINTAINER Name from Petermaier to SchmelzerHannes Schmelzer
Since i've been married, i also have a new surname. Mr. Petermaier moved to Mr. Schmelzer. In this patch i update all files in which my (old) name is present. Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2015-05-26Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-05-26i2c, mxc: rework i2c base address names for different SoCsHeiko Schocher
rework and unify i2c address names for different SoCs, which use the mxc_i2c driver. Signed-off-by: Heiko Schocher <hs@denx.de>
2015-05-26arm, imx6, i2c: add I2C4 for MX6DLHeiko Schocher
add I2C4 modul for MX6DL based boards. Signed-off-by: Heiko Schocher <hs@denx.de>
2015-05-18Merge git://git.denx.de/u-boot-samsungTom Rini
2015-05-14sandbox: i2c: search child emul dev and check its uclass idPrzemyslaw Marczak
The function get_emul() in sandbox i2c bus driver, always returns first child as i2c emul device. This may only work for i2c devices with a single child, which is an only i2c emul device. In case when i2c device has more than one child (e.g. PMIC), and one is i2c emul, then the function should search it by check uclass id for each child. This patch add this change to the get_emul(). Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Tested on sandbox: Tested-by: Simon Glass <sjg@chromium.org>
2015-05-14i2c: mxc: refactor i2c driver and support dmPeng Fan
1. Introduce a new structure `struct mxc_i2c_bus`, this structure will used for non-DM and DM. 2. Remove `struct mxc_i2c_regs` structure, but use register offset to access registers based on `base` entry of `struct mxc_i2c_bus`. 3. Remove most `#ifdef I2C_QUIRK_REG`. Using driver_data to contain platform flags. A new flag is introduced, I2C_QUIRK_FLAG. 4. Most functions use `struct mxc_i2c_bus` as one of the parameters. Make most functions common to DM and non-DM, try to avoid duplicated code. 5. Support DM, but pinctrl is not included. Pinmux setting is still set by setup_i2c, but we do not need bus_i2c_init for DM. 6. struct i2c_parms and struct sram_data are removed. 7. Remove bus_i2c_read bus_i2c_write prototype in header file. The frist paramter of bus_i2c_init is modified to i2c index. Add new prototype i2c_idle_bus and force_bus_idle. Since bus_i2c_init is not good for DM I2C and pinctrl is missed, we use a weak function for i2c_idle_bus. Board file take the responsibility to implement this function, like this: " int i2c_idle_bus(struct mxc_i2c_bus *i2c_bus) { if (i2c_bus->index == 0) force_bus_idle(i2c_pads_info0); else if (i2c_bus->index == 1) force_bus_idle(i2c_pads_info1); else xxxxxx } " 8. Introduce a weak function, enable_i2c_clk 9. Tested on an i.MX7 platform. Log info: => dm tree Class Probed Name ---------------------------------------- root [ + ] root_driver simple_bus [ ] |-- soc simple_bus [ ] | |-- aips-bus@30000000 simple_bus [ ] | | |-- anatop@30360000 simple_bus [ ] | | `-- snvs@30370000 simple_bus [ ] | |-- aips-bus@30400000 simple_bus [ ] | `-- aips-bus@30800000 i2c [ ] | |-- i2c@30a20000 i2c [ ] | `-- i2c@30a40000 simple_bus [ ] `-- regulators => i2c dev 0 Setting bus to 0 => i2c probe Valid chip addresses: 08 50 => i2c md 8 31 0031: 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-05-14dm: i2c: Add a function to find out the chip offset lengthSimon Glass
We can currently set this but there is no API function to get it. Add one. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Heiko Schocher<hs@denx.de>
2015-05-06i2c: s3c: Implant support for S3C2440Marek Vasut
This is a matter of simple additional ifdefery to cater for the different register layout of the S3C2440 chip. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Vladimir Zapolskiy <vz@mleia.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-05-05dm: i2c-gpio: Remove redundant dm_gpio_set_value() callAxel Lin
dm_gpio_set_dir_flags() will also set gpio output value when switching to gpio output. So it's not necessary to call dm_gpio_set_value() after dm_gpio_set_dir_flags() call. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-05-05dm: i2c: Add an explicit test mode to the sandbox I2C driverSimon Glass
At present this driver has a few test features. They are needed for running the driver model unit tests but are confusing and unnecessary if using sandbox at the command line. Add a flag to enable the test mode, and don't enable it by default. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-05-05dm: i2c: Add functions to read and write a registerSimon Glass
Add driver model versions of the legacy functions to read and write a single byte register. These are a useful shortcut in many cases. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-05-05dm: i2c: sandbox: Add debugging to the speed limitSimon Glass
Print a debug() message with the I2C speed is exceeded. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-04-23driver/i2c/mxc: Enable I2C bus 3 and 4York Sun
Some SoCs have more than two I2C busses. Instead of adding ifdef to the driver, macros are put into board header file where CONFIG_SYS_I2C_MXC is defined. Signed-off-by: York Sun <yorksun@freescale.com> CC: Heiko Schocher <hs@denx.de>
2015-04-18sandbox: Move CONFIG_SYS_I2C_SANDBOX to KconfigSimon Glass
Move this over to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher<hs@denx.de>
2015-04-18dm: core: Rename driver data function to dev_get_driver_data()Simon Glass
The existing get_get_of_data() function provides access to both the driver's compatible string and its driver data. However only the latter is actually useful. Update the interface to reflect this and fix up existing users. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: i2c: add i2c-gpio driverPrzemyslaw Marczak
This commit adds driver model support to software emulated i2c bus driver. This driver supports kernel-style device tree bindings. Fdt properties in use: - compatible - "i2c-gpio" - gpios - data and clock GPIO pin phandles - delay-us - micro seconds delay between GPIOs toggle operations, which is 1/4 of I2C speed clock period. Added: - Config: CONFIG_DM_I2C_GPIO - File: drivers/i2c/i2c-gpio.c - File: doc/device-tree-bindings/i2c/i2c-gpio.txt Driver base code is taken from: drivers/i2c/soft-i2c.c, changes: - use "i2c-gpio" naming - update comments style - move preprocesor macros into functions - add device tree support - add driver model i2c support - code cleanup, - add Kconfig entry Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Added braces in i2c_gpio_xfer() to fix style nit: Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18Kconfig: i2c: fix help message related to dm i2cPrzemyslaw Marczak
2015-04-18common: Make sure arch-specific map_sysmem() is definedJoe Hershberger
In the case where the arch defines a custom map_sysmem(), make sure that including just mapmem.h is sufficient to have these functions as they are when the arch does not override it. Also split the non-arch specific functions out of common.h Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-16dm: core: Add dev_get_uclass_priv() to access uclass private dataSimon Glass
Add a convenience function to access the private data that a uclass stores for each of its devices. Convert over most existing uses for consistency and to provide an example for others. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-15i2c: mvtwsi: Support for up to 4 different controllersPaul Kocialkowski
Orion5x, Kirkwood and Armada XP platforms come with a single TWSI (I2C) MVTWSI controller. However, other platforms using MVTWSI may come with more: this is the case on Allwinner (sunxi) platforms, where up to 4 controllers can be found on the same chip. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-04-10lpc32xx: i2c: add LPC32xx I2C interface supportAlbert ARIBAUD \(3ADEV\)
Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-03-18i2c: mvtwsi: Fix problem with baud rate calculationStefan Roese
The current implementation for baudrate calculation is incorrect. This part from the formula: "2 ^ (n + 1)" is not equivalent to (1 << n) but to (2 << n)! This patch fixes this and moves this calculation to a function instead of using a macro. This new function is taken from the Linux kernel. This was detected and tested on the Marvell Armada A38x DB-88F6820-GP eval board. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Ian Campbell <ijc@hellion.org.uk> Cc: Heiko Schocher <hs@denx.de> Acked-by: Hans de Goede <hdegoede@redhat.com>
2015-03-18mv_i2c: fix warnings on 64-bit buildsRob Herring
Change addresses to unsigned long to be compatible with 64-bit builds. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Heiko Schocher <hs@denx.de>
2015-03-15ARM: UniPhier: adjust device trees for business transferMasahiro Yamada
Panasonic's System LSI products, UniPhier SoC family, have been transferred to Socionext Inc. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-03-05dm: i2c: Add a missing memory allocaton checkSimon Glass
This strdup() is missing a check. Add it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-02-19dm: Move CONFIG_I2C_COMPAT to KconfigSimon Glass
Make this option available in Kconfig and clean up the board that uses it. Note there is also an entry in exynos5-common.h but this affects multiple boards and should be dropped as part of the Samsung I2C migration to driver model. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: Expand and complete Kconfig in drivers/Simon Glass
Expand the help messages for each driver. Add missing Kconfig for I2C, SPI flash and thermal. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-12dm: i2c: Make API accessible even without CONFIG_DMSimon Glass
Make the driver model I2C API available always, even if driver model is not enabled. This allows for a 'soft' switch-over, where drivers can use the new structures in code which is compiled but not yet used. This makes migration easier in some cases. Fix up the existing drivers which define their own 'struct i2c_msg'. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-02-12dm: i2c: Add a dm_ prefix to driver model bus speed functionsSimon Glass
As with i2c_read() and i2c_write(), add a dm_ prefix to the driver model versions of these functions to avoid conflicts. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-02-12i2c: s3c24x0: reduce transmission status timeoutPrzemyslaw Marczak
If no device is connected to I2C bus, the i2c probe command can take a lot of time for probe each address. This commit reduces the busy timeout to 10ms for standard and high speed modes. This doesn't break the transmission an also allow for properly probe the devices. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Changes v3: - new commit, after split the next one Tested-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: i2c: Add two more I2C init functions to the compatibility layerSimon Glass
These functions are useful in case the board calls them. Also fix a missing parameter caused by applying the wrong patch (actually I failed to send v2 and applied v1 by mistake). Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: i2c: dts: Support an offset-len device tree propertySimon Glass
Since U-Boot can support different offset lengths (0-4 bytes), add a device tree property to specify this. This avoids hard-coding it in the driver. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: i2c: s3c24x0: adjust to dm-i2c apiPrzemyslaw Marczak
This commit adjusts the s3c24x0 driver to new i2c api based on driver-model. The driver supports standard and high-speed i2c as previous. Tested on Trats2, Odroid U3, Arndale, Odroid XU3 Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Tested-by: Simon Glass <sjg@chromium.org> Cc: Simon Glass <sjg@chromium.org> Cc: Heiko Schocher <hs@denx.de> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: i2c-uclass-compat: fix missed argumentPrzemyslaw Marczak
This patch fixes build error for CONFIG_DM_I2C_COMPAT. In i2c_get_chip_for_busnum() call, one of argument was missed, which was offset_len. Now it is set to 'alen' as previous. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: i2c: Move slave details to child platdataSimon Glass
At present we go through various contortions to store the I2C's chip address in its private data. This only exists when the chip is active so must be set up when it is probed. Until the device is probed we don't actually record what address it will appear on. However, now that we can support per-child platform data, we can use that instead. This allows us to set up the address when the child is bound, and avoid the messy contortions. Unfortunately this is a fairly large change and it seems to be difficult to break it down further. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-01-29dm: core: Add a flag to control sequence numberingSimon Glass
At present we try to use the 'reg' property and device tree aliases to give devices a sequence number. The 'reg' property is often actually a memory address, so the sequence numbers thus-obtained are not useful. It would be better if the devices were just sequentially numbered in that case. In fact neither I2C nor SPI use this feature, so drop it. Some devices need us to look up an alias to number them within the uclass. Add a flag to control this, so it is not done unless it is needed. Adjust the tests to test this new behaviour. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-01-29dm: i2c: Provide an offset length parameter where neededSimon Glass
Rather than assuming that the chip offset length is 1, allow it to be provided. This allows chips that don't use the default offset length to be used (at present they are only supported by the command line 'i2c' command which sets the offset length explicitly). Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-01-29dm: i2c: Add a compatbility layerSimon Glass
For boards which use multiple I2C devices, or for SOCs which support multiple boards, we might want to convert these to driver model at different times. At present this is difficult because we need to either use CONFIG_DM_I2C for a board or not. Add a compatibility layer which implements the old API, thus allowing a board to move to driver model for I2C without requiring that everything it uses is moved in the same commit. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: i2c: Rename driver model I2C functions to permit compatibilitySimon Glass
Add a dm_ prefix to driver model I2C functions so that we can keep the old ones around. This is a little unfortunate, but on reflection it is too difficult to change the API. We can undo this rename when most boards and drivers are converted to use driver model for I2C. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29i2c: UniPhier: add driver for UniPhier FIFO-builtin i2c controllerMasahiro Yamada
This commit adds on-chip I2C driver used on newer SoCs of Panasonic UniPhier platform. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-01-29i2c: UniPhier: add driver for UniPhier i2c controllerMasahiro Yamada
This commit adds on-chip I2C driver used on some old Panasonic UniPhier SoCs. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-01-29i2c: add CONFIG_DM_I2C to KconfigMasahiro Yamada
2015-01-08i2c:mxc fix array size of i2c_dataPeng Fan
We should not hardcode array size of i2c_data to 3. To CONFIG_FSL_LSCH3, there are 4 i2c interface, but not 3. So the size of i2c_data array should be calculated using "ARRAY_SIZE(i2c_bases)". To avoid compile error, move i2c_bases before sram_data structure which contains i2c_data array. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2014-12-11dm: i2c: tegra: Convert to driver modelSimon Glass
This converts all Tegra boards over to use driver model for I2C. The driver is adjusted to use driver model and the following obsolete CONFIGs are removed: - CONFIG_SYS_I2C_INIT_BOARD - CONFIG_I2C_MULTI_BUS - CONFIG_SYS_MAX_I2C_BUS - CONFIG_SYS_I2C_SPEED - CONFIG_SYS_I2C This has been tested on: - trimslice (no I2C) - beaver - Jetson-TK1 It has not been tested on Tegra 114 as I don't have that board. Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
