i2c_probe() is changed to reinit the i2c bus upon read failure.
This is naturally the case upon i2c bus probing.
Also, some printf messages upon read failure are removed. As they
would interfere with the "i2c probe" command.
Additionally, i2c_set_bus_speed() now returns 0, so that the
"i2c speed" command can be used.
Cc: Amit Virdi <amit.virdi@st.com>
Cc: Vipin Kumar <vipin.kumar@st.com>
The same places that check for CONFIG_OMAP44XX need to check for
CONFIG_AM33XX as we share the same i2c block.
Acked-by: Heiko Schocher <hs@denx.de>
This reverts commit 0e57968a215d1b9d271f3fa5bebeddeaea0c8075.
The short version of the original commit is that some i2c devices cannot
be probed via read as they NAK the first cycle, so try and probe via a
write that we abort before it writes to the device. This however is not
allowed by the TRM for any of these parts. The section on I2C_CON
(table 17-35 I2C_CON for am/dm37x for example) says you must not change
the register while STT has been set. On these parts, the unpredictable
behavior that the chip exhibits is not problematic. On OMAP4 however it
results in the chip being in a bad state:
Panda # i2c probe
Valid chip addresses: 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 10 11 12
13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F 20 21 22 23 24 25 26 27 28 29 2A
2B 2C 2D 2E 2F 30 31 32 33 34 35 36 37 38 39 3A 3B 3C 3D 3E 3F 40 41 42
43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F 50 51 52 53 54 55 56 57 58 59 5A
5B 5C 5D 5E 5F 60 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72
73 74 75 76 77 78 79 7A 7B 7C 7D 7E 7F
Panda # i2c md 50 0
timed out in wait_for_pin: I2C_STAT=0
I2C read: I/O error
Error reading the chip.
We must revert the original behavior to bring probe back into line with
the TRM.
Cc: Nick Thompson <nick.thompson@ge.com>
Add tegra_i2c_get_dvc_bus_num() to obtain the I2C bus number of DVC bus.
This allows us to talk to the PMU.
Signed-off-by: Tom Warren <twarren@nvidia.com>
The designware i2c controller must be turned off before
setting the speed in IC_CON register, as stated in the
section 6.3.1 of the dw_apb_i2c_db.pdf.
Signed-off-by: Michel Sanches <michel.sanches@st.com>
Signed-off-by: Armando Visconti <armando.visconti@st.com>
Signed-off-by: Amit Virdi <amit.virdi@st.com>
Earlier, a driver exists in the u-boot source for designware i2c interface. That
driver was specific to spear platforms. This patch implements the i2c controller
as a generic driver which can be used by multiple platforms
The driver files are now renamed to designware_i2c.c and designware_i2c.h and
these are moved into drivers/i2c folder for reusability by other
platforms
Signed-off-by: Vipin Kumar <vipin.kumar@st.com>
Renesas SH7734 has two I2C interfaceis.
This supports these I2C.
V5: - include i2c.h.
- Add check of icsr bit polling logic.
- Implement i2c_probe.
V4: - Remove sh_i2c_dump_reg function.
- Use puts() when there's no format.
- Chnage check for I2C bus number.
- Remove space before the semi-colon.
V3: - Fix error for whitespace.
V2: - Changed bit control to use the clr|set|clrsetbits_* functions.
- Fix wrong comment style.
- Add new line before for loop in i2c_read.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Add basic i2c driver for Tegra2 with 8- and 16-bit address support.
The driver requires CONFIG_OF_CONTROL to obtain its configuration
from the device tree.
(Simon Glass: sjg@chromium.org modified for upstream)
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
This reverts commits 2faa76196af4b3e93bcb9e38ed9090cbd3b06db3 as
this has introduced some large problems on all other platforms and have
more changes in them than the commit message implies.
Cc: Patil, Rachna <rachna@ti.com>
This reverts commit 498cbdfe62a8330f6c89765bdd15e60328a26511 as we need
to revert the i2c changes that add the support for the platform.
1. Compliant with Philips I2C specification version 2.1
2. Supports upto 100Kbps in standard mode
Signed-off-by: Chandan Nath <chandan.nath@ti.com>
Signed-off-by: Patil, Rachna <rachna@ti.com>
Existing OMAP I2C driver does not support address
length greater than one. Hence this patch is to
add support for 2 byte address read/write.
Signed-off-by: Philip, Avinash <avinashphilip@ti.com>
Signed-off-by: Hebbar, Gururaja <gururaja.hebbar@ti.com>
At old overo boards TWL4030 RTC irq is connected to gpio112. Unfortunately
this pin is also used for revision detection. Therefore we need to send
shut-up to TWL4030 to avoid reading wrong revision. In SPL this must
be done before SDRAM is set up because the type of SDRAM is revision dependent.
By this patch it is ensured that all variables used by omap24xx_i2c.c are
located in SRAM.
Signed-off-by: Andreas Müller <schnitzeltony@gmx.de>
Fix:
davinci_i2c.c: In function 'flush_rx':
davinci_i2c.c:81:6: warning: variable 'dummy' set but not used
[-Wunused-but-set-variable]
This supports I2C of Renesas SH.
I tested on SH7724.
CC: Heiko Schocher <hs@denx.de>
* 'master' of git://git.denx.de/u-boot-arm:
arm, davinci: add DAVINCI_MMC_CLKID
arm, davinci_emac: fix driver bug if more then 3 PHYs are detected
arm, davinci: da850/dm365 lowlevel cleanup
omap5: Add omap5_evm board build support.
omap4/5: Add support for booting with CH.
omap5: emif: Add emif/ddr configurations required for omap5 evm
omap5: clocks: Add clocks support for omap5 platform.
omap5: Add minimal support for omap5430.
omap: Checkpatch fixes
omap4: make omap4 code common for future reuse
GCC4.6: Squash warnings in onenand_base.c
GCC4.6: Fix common/usb.c on xscale
OneNAND: Add simple OneNAND SPL
PXA: vpac270: Enable the new generic MMC driver
PXA: Cleanup serial_pxa
PXA: Drop csb226 and innokom boards (unmaintained)
m28evk: Fix comment about the number of RAM banks
mx31: Fix checkpatch warnings in generic.c
mx31: Use proper IO accessor for GPR register
mx31: Remove duplicate definition for GPR register
qong: Use generic function for configuring GPR register
M28EVK: Enable USB HOST support
iMX28: Add USB HOST driver
iMX28: Add USB and USB PHY register definitions
M28: Add memory detection into SPL
iMX28: Fix ARM vector handling
M28: Add doc/README.m28 documentation
M28: Add MMC SPL
iMX28: Add support for DENX M28EVK board
iMX28: Add u-boot.sb target to Makefile
iMX28: Add image header generator tool
iMX28: Add driver for internal RTC
iMX28: Add GPMI NAND driver
iMX28: Add APBH DMA driver
iMX28: Add SPI driver
iMX28: Add GPIO control
iMX28: Add I2C bus driver
iMX28: Add PINMUX control
FEC: Add support for iMX28 quirks
iMX28: Add SSP MMC driver
iMX28: Initial support for iMX28 CPU
MX25: zmx25: GCC4.6 fix build warnings
da850: add new config file for AM18xx
BeagleBoard: config: Switch to ttyO2
OMAP3: Change omap3_evm maintainer
devkit8000: Fix NAND SPL on boards with 256MB NAND
integrator: enable Vpp and disable flash protection
integrator: add system controller header
integrator: make flash writeable on boot
integrator: use io-accessors for board init
integrator: move text offset to config
integrator: pass configs for core modules
ARM: remove superfluous setting of arch_number in board specific code.
SPL: Allow ARM926EJS to avoid compiling in the CPU support code
integrator: do not test first part of the memory
arm: a320: fix broken timer
ARM: define CONFIG_MACH_TYPE for all ronetix boards
dm646x: pass board revision info to kernel
dm646x: add new configuration for dm6467T
arm, davinci: Fix setting of the SDRAM configuration register
arm, davinci: Remove the duplication of LPSC functions
arm, davinci: Rename AM1808 lowlevel functions to DA850
da8xxevm: fix build error
ARM: re-add MACH_TYPE_XXXXXX for VCMA9 board and add CONFIG_MACH_TYPE
Cc: Detlev Zundel <dzu@denx.de>
Acked-by: Heiko Schocher<hs@denx.de>
fsl_i2c.c: In function 'i2c_init':
fsl_i2c.c:245:7: warning: assignment discards qualifiers from pointer target type
Arm: re-introduce the MACH_TYPE_XXXXXX for EB_CPUX9K2 board
arm: jadecpu: Readd MACH_TYPE_JADECPU
at91: defined mach-types for otc570 board in board config file
at91: defined mach-types for meesc board in board config file
mx31pdk: Enable D and I caches
ehci-mxc: remove incorrect comment
README: Fix supported i.MX SoC list for CONFIG_MXC_SPI
mx53: Turn off child clocks before reconfigure perclk_root
qong: enable support for compressed images
imx: imx31_phycore.h: fix checkpatch warnings
vision2: Remove unused get_board_rev function
mx53smd: Remove unused get_board_rev function
mx53ard: Remove unused get_board_rev function
mx53evk: Remove unused get_board_rev function
mx53evk: Add RTC support
mx53loco: Remove unused get_board_rev function
mx53evk: Remove unneeded '1' from mx53evk.h
OMAP3: mvblx: Initial support for mvBlueLYNX-X
ARM: dig297: Define MACH_TYPE_OMAP3_CPS and CONFIG_MACH_TYPE
omap3: mem: Move comments next to definitions
omap3: mem: Clean-up whitespaces
omap3: mem: Define and use common macros
Davinci: ea20: added PREBOOT to configuration
Davinci: ea20: added I2C support
Davinci: ea20: added video support
VIDEO: davinci: add framebuffer to da8xx
ARM: Davinci: added missing registers to hardware.h
Davinci: ea20: add gpios for LCD backlight control
Davinci: ea20: add gpio for keeping power on in board_late_init
Davinci: ea20: Add default U-Boot environment
Davinci: ea20: Add early init to get early output from console
Davinci: ea20: Add NAND support
Davinci: ea20: set GPIOs to hold MII-Phy in reset and set UART0-Switch for console
Davinci: ea20: set console on UART0
arm, davinci: add cam_enc_4xx support
arm926ejs, davinci: add missing spi defines for dm365
arm926ejs, davinci: add cpuinfo for dm365
arm, davinci: add lowlevel function for dm365 soc
arm, davinci: add header files for dm365
spl, nand: add 4bit HW ecc oob first nand_read_page function
arm, davinci: add support for new spl framework
spl: add option for adding post memory test to the SPL framework
net, davinci_emac: make clock divider in MDIO control register configurable
arm, usb, davinci: make USBPHY_CTL register configurable
usb, davinci: add enable_vbus() weak function
omap3evm: fix errors caused by multiple definitions
omap3evm: Add (quick) configuration for NAND only
omap3evm: Add (quick) configuration for MMC/SD only
omap3evm: move common config options to new file
omap3evm: Prepare to split configuration
omap3evm: Reorder related config options
omap/spl: actually enable the console
davinci_emac: compilation fix, phy is array now
omap3evm: Set environment variable 'ethaddr'
arm, arm926: fix missing symbols in NAND_SPL mode
arm, davinci: Add function lpsc_syncreset()
arm, davinci: replace CONFIG_PRELOADER with CONFIG_SPL_BUILD
arm/km: portl2 environment address update to P1B
arm/km: adapt bootcounter evaluation
arm/km: enable jffs2 cmds
arm/km: trigger reconfiguration for the Xilinx FPGA
arm/km: add boardid and hwkey to kernel command line
ARM: Reintroduce MACH_TYPE_KM_KIRKWOOD for keymile ARM boards
netspace_v2: enable I2C EEPROM support
netspace_v2: fix SDRAM configuration
armada100: define CONFIG_SYS_CACHELINE_SIZE
pantheon: define CONFIG_SYS_CACHELINE_SIZE
kirkwood: define CONFIG_SYS_CACHELINE_SIZE
kirkwood: drop empty asm-offsets.s file
arm/km/mgcoge3un: enhance "waitforne" feature
arm/km: add variable waitforne to mgcoge3un
gplugD: Fix for error:MACH_TYPE_SHEEVAD undeclared
ARM: dreamplug: fix compilation
ARM: DockStar: fix compilation
ARM: netspace_v2: fix warnings
am335x: Drop board_sysinfo struct
am335x: Temporarily add MACH_TYPE define
misc:pmic:samsung Enable PMIC driver at C210 Universal target
dcache:s5p CONFIG_SYS_CACHELINE_SIZE added for s5p UNIVERSAL C210 target
dcache:s5p CONFIG_SYS_CACHELINE_SIZE added for s5p GONI target
smdkv310: use macro for mmc data read function address
smdkv310: use spl framework for mmc spl
SMDKV310: use get_ram_size() to validate dram size
SMDKV310: Initialize board id using CONFIG_MACH_TYPE
ORIGEN : use absolute paths and fix tool naming
ORIGEN : enable device tree support
MX25: tx25: Fix building due to missing MACH_TYPE
mx31: Add board support for HALE TT-01
mx31: add ESD control registers
mx31: define pins and init for UART2 and CSPI3
MX35: add support for flea3 board
MX51: vision2: add MACH_TYPE in config file
vision2: Remove unused header file
mx51evk: Remove unused get_board_rev function
mx51evk: Remove unneeded '1' from mx51evk.h
I2C: Fix mxc_i2c.c problem on imx31_phycore
mx35pdk: Add RTC support
mx51evk: Use GPIO API for configuring the IOMUX
mx51evk: Add RTC support
rtc: Make mc13783-rtc driver generic
qong: remove unneeded IOMUX settings
qong: Use mx31_set_gpr to setup USBH2 pins
mx31: Introduce mx31_set_gpr function
mx31pdk: Add MC13783 PMIC support
qong: remove unneeded "1" from qong.h
misc: pmic: fix regression in pmic_fsl.c (SPI)
mx5 configs: CONFIG_PRIME should really be CONFIG_ETHPRIME
MX35: Drop unnecessary prototypes from imx-regs.h
I2C: added I2C-2 and I2C-3 to MX35
MX35: factorize common assembly code
MX35: add reset cause as provided by other i.MX
MX35: add pins definition for UART3
MX35: added ESDC structure to imx-regs
Make the I2C2 and I2C1 use the same initialize codes.
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
The problem was caused by a global variable being used early in the boot
process.
The symptoms were on imx31_phycore board, reading the environment from I2C
EEPROM didn't work correctly and causes default environment to be loaded.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Tested-by: Anatolij Gustschin <agust@denx.de>
Tested-by: Stefano Babic <sbabic@denx.de>
When enable the multi-bus, the current_bus is not inited in the original
implementation, which make the i2c operation unpredicatable.
Signed-off-by: Lei Wen <leiwen@marvell.com>
When DEBUG_I2C is open, the following build issue would shows up.
mv_i2c.c: In function 'i2c_transfer':
mv_i2c.c:257: error: 'ISR' undeclared (first use in this function)
mv_i2c.c:257: error: (Each undeclared identifier is reported only once
mv_i2c.c:257: error: for each function it appears in.)
There are some locations in the code which anticipate printf() being called
before the console is ready by squelching printf() on gd->have_console.
Move this squelching into printf(), vprintf(), puts() and putc(). Also
make tstc() and getc() return 0 if console is not yet initialised
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
Rewrite the mxc_i2c driver.
* This version is much closer to Linux implementation.
* Fixes IPG_PERCLK being incorrectly used as clock source
* Fixes behaviour of the driver on iMX51
* Clean up coding style a bit ;-)
Cc: Jason Hui <jason.hui@linaro.org>
Acked-by: Jason Liu <jason.hui@linro.org>
Tested-by: Jason Liu <jason.hui@linro.org>
Cc: Paulraj Sandeep <s-paulraj@ti.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
This allows the EEPROM layer to send a single i2c write command
per page, and wait CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS between
i2c write commands.
Acked-by: Detlev Zundel <dzu@denx.de>
Signed-off-by: John Rigby <john.rigby@linaro.org>
Deblock i2c bus when switching to another i2c bus, if using
i2c_set_bus_num().
cc: Wolfgang Denk <wd@denx.de>
cc: Detlev Zundel <dzu@denx.de>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Holger Brunck <holger.brunck@keymile.com>
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Add the ability to support multiple i2c bus for mv_i2c
Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
Add i2c_clk_enable in the cpu specific code, since previous platform it,
while new platform don't need. In the pantheon and armada100 platform,
this function is defined as NULL one.
The original 10000 value would be 100ms, which is not
the comments said.
For better sharing with other platform other than pxa's,
it is more convenient to put the driver to the common place.
As exception among the i.MX processors, the i.MX31 has headers
without general names (mx31-regs.h, mx31.h instead of imx-regs.h and
clock.h). This requires several nasty #ifdef in the drivers to
include the correct header. The patch cleans up the driver and
renames the header files as for the other i.MX processors.
The omap24xx driver only seems to support devices that have a single subaddress
byte. With these types of devices, the first access in a bus transaction is
usually a write (writes the subaddress) followed by either a read or write to
access the devices registers.
Many such devices will respond to a read as the first access, but there are at
least some that will NACK such a read. (e.g. ADV7180.)
The probe function attempts to detect a devices ACK to a read access only and
fails to find devices that NACK a read.
This commit modifies the probe function to start a write instead. This detects
devices that respond to reads (since they must also respond to writes) as well
as those that only respond to writes. The bus is immediately set to idle after a
(N)ACK avoiding actually writing anything to the device.
Signed-off-by: Nick Thompson <nick.thompson@ge.com>
There is sporadic failures when more as one I2C slave
is on the bus and the processor tries to communicate
with more as one slave.
The problem was seen on a mx35pdk (two I2C slaves,
PMIC controller and CAN/RTC chip).
The current driver uses the IIF bit in the status register
to check if the bus is busy or not. According to the manual,
this is not correct, because the IIB bit should be checked.
Not only, to check if a transfer is finished must be checked
the ICF bit, and this is not tested at all.
This patch comes from analyse with a corresponding driver
provided by Freescale as part of the LTIB tool. Comparing
the two drivers, it appears that the current u-boot driver checks
the wrong bits, and depending on race condition, the transfer
can be successful or not.
The patch gets rid also of own debug function (DPRINTF),
replaced with the general debug().
Tested on Freescale mx35pdk.
This driver accesses to processor's register
via __REG macros, that are removed (or are planned
to be removed) and replaced by C structures.
This patches replaces all occurrencies of __REG macros.
This patch add I2C support for Freescale MX53 processor
Signed-off-by: Jason Liu <r64343@freescale.com>
Make at91 header includes in soft_i2c depend only on CONFIG_AT91FAMILY
rather than individual SoCs.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
Acked-by: Reinhard Meyer<u-boot@emk-elektronik.de>
It can be optimised out by the compiler otherwise resulting
in obscure errors like a board not booting.
This has been documented in README since 2006 when these were
first fixed up for GCC 4.x.
Fix some additional places.
Acked-By: Albert ARIBAUD <albert.aribaud@free.fr>
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
