path: root/drivers/i2c
2016-09-26i2c: mvtwsi.c: Add support for Marvell Armada 7K/8KStefan Roese
By adding the "marvell,mv78230-i2c" compatible property, we can enable this I2C driver to support these new ARM64 chips as well. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Omri Itach <omrii@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Hanna Hawa <hannah@marvell.com> Cc: Heiko Schocher <hs@denx.de>
2016-09-26i2c: mv_i2c.c: Validate read length in I2C commandjinghua
The I2C bus will get stuck when reading 0 byte. So we add validation of the read length in i2c_read(). This issue only occurs on read operation. Signed-off-by: jinghua <jinghua@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Wilson Ding <dingwei@marvell.com> Cc: Victor Gu <xigu@marvell.com> Cc: Hua Jing <jinghua@marvell.com> Cc: Terry Zhou <bjzhou@marvell.com> Cc: Hanna Hawa <hannah@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Heiko Schocher <hs@denx.de>
2016-09-26i2c: mv_i2c.c: Enable runtime speed selection (standard vs fast mode)Stefan Roese
This patch adds runtime speed configuration to the mv_i2c driver. Currently standard (max 100kHz) and fast mode (max 400kHz) are supported. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Wilson Ding <dingwei@marvell.com> Cc: Victor Gu <xigu@marvell.com> Cc: Hua Jing <jinghua@marvell.com> Cc: Terry Zhou <bjzhou@marvell.com> Cc: Hanna Hawa <hannah@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Heiko Schocher <hs@denx.de>
2016-09-26i2c: mv_i2c.c: Add DM supportStefan Roese
2016-09-26i2c: mv_i2c.c: Prepare driver for DM conversionStefan Roese
To prepare for the DM conversion, we add a layer of compatibility functions to be used by both the legacy and the DM functions. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Wilson Ding <dingwei@marvell.com> Cc: Victor Gu <xigu@marvell.com> Cc: Hua Jing <jinghua@marvell.com> Cc: Terry Zhou <bjzhou@marvell.com> Cc: Hanna Hawa <hannah@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Heiko Schocher <hs@denx.de>
2016-09-26i2c: mv_i2c.c: Remove CONFIG_HARD_I2CStefan Roese
CONFIG_HARD_I2C is not needed, lets remove it. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Wilson Ding <dingwei@marvell.com> Cc: Victor Gu <xigu@marvell.com> Cc: Hua Jing <jinghua@marvell.com> Cc: Terry Zhou <bjzhou@marvell.com> Cc: Hanna Hawa <hannah@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Heiko Schocher <hs@denx.de>
2016-09-26i2c: mv_i2c.c: cosmetic: Coding style cleanupsStefan Roese
Some mostly indentation coding style cleanups. Also, move this driver to use debug() for debug output. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Wilson Ding <dingwei@marvell.com> Cc: Victor Gu <xigu@marvell.com> Cc: Hua Jing <jinghua@marvell.com> Cc: Terry Zhou <bjzhou@marvell.com> Cc: Hanna Hawa <hannah@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Heiko Schocher <hs@denx.de>
2016-09-13i2c: at91_i2c: Fix the wrong include fileWenyou Yang
Since the 'clk_client.h' doesn't exist, it should be 'clk.h'. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-13rockchip: i2c: fix >32 byte writesJohn Keeping
The special handling of the chip address and register address must only happen before we send the data buffer, otherwise we will end up inserting both of these every 32 bytes. Signed-off-by: John Keeping <john@metanate.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-09-13rockchip: i2c: move register write out of inner loopJohn Keeping
There is no point in writing intermediate values to the txdata registers. Also add padding to the debug logging to make it easier to read when there are leading zeroes. Signed-off-by: John Keeping <john@metanate.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-09-13rockchip: i2c: use named constant when appropriateJohn Keeping
Make it clear that we are using the same value in two adjacent lines. Signed-off-by: John Keeping <john@metanate.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-08-26Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
2016-08-26i2c: mvtwsi: Fix order of address bytes (high to low)Stefan Roese
Patch f8a10ed1 [i2c: mvtwsi: Make address length variable] accidentally inverted the sequence of address bytes sent to the I2C device. This patch corrects this by sending the highest byte first and the lowest byte last again. Tested on theadorable Armada-XP board. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Mario Six <mario.six@gdsys.cc> Cc: Heiko Schocher <hs@denx.de>
2016-08-25ARM: tegra: remove stale nvidia, bpmp I2C DT propertyStephen Warren
The nvidia,bpmp property is left over from an old BPMP I2C binding, and shouldn't be present. Remove it from the SoC DT file, and update the I2C driver not to parse it; the value wasn't used for anything any more anyway. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-25ARM: tegra: fix Tegra186 I2C clock nameStephen Warren
The Tegra I2C binding dictates that the clock name for the Tegra I2C clock be "div-clk" not "i2c". Fix the Tegra186 DT and I2C driver to honor this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-16i2c: intel_i2c: SMBus driver PCI addition (e.g. BayTrail)Stefan Roese
This patch adds support for the SMBus block read/write functionality. Other protocols like the SMBus quick command need to get added if this is needed. This patch also removed the SMBus related defines from the Ivybridge pch.h header. As they are integrated in this driver and should be used from here. This change is added in this patch to avoid compile breakage to keep the source git bisectable. Tested on a congatec BayTrail board to configure the SMSC2513 USB hub. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Simon Glass <sjg@chromium.org> Cc: Heiko Schocher <hs@denx.de> Cc: George McCollister <george.mccollister@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-15Merge branch 'master' of git://git.denx.de/u-boot-atmelTom Rini
2016-08-15i2c: atmel: add i2c driverSongjun Wu
Add i2c driver. Signed-off-by: Songjun Wu <songjun.wu@atmel.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2016-08-15i2c: tegra: add standardized clk/reset API supportBryan Wu
clk/reset API was tested on T186 platform and previous chip like T210/T124 will still use the old APIs. Signed-off-by: Bryan Wu <pengw@nvidia.com> (swarren, simplified some ifdefs, removed indent level inside an ifdef) (swarren, added comment about the ifdefs) Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-15i2c: add Tegra186 BPMP driverStephen Warren
On Tegra186, some I2C controllers are directly controlled by the main CPU, whereas others are controlled by the BPMP, and can only be accessed by the main CPU via IPC requests to the BPMP. This driver covers the latter case. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-12Merge git://git.denx.de/u-boot-dmTom Rini
2016-08-12fdt: allow fdtdec_get_addr_size_*() to translate addressesStephen Warren
Some code may want to read reg values from DT, but from nodes that aren't associated with DM devices, so using dev_get_addr_index() isn't appropriate. In this case, fdtdec_get_addr_size_*() are the functions to use. However, "translation" (via the chain of ranges properties in parent nodes) may still be desirable. Add a function parameter to request that, and implement it. Update all call sites to default to the original behaviour. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Squashed in build fix from Stephen: Signed-off-by: Simon Glass <sjg@chromium.org>
2016-08-12i2c: Drop redundant platform data setting in driversSimon Glass
The i2c uclass has a default setting for per_child_platdata_auto_alloc_size so drivers do not need to set it. Remove this from drivers to avoid confusion. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-08i2c: i2c-uclass-compat: avoid any BSS usageVignesh R
As I2C can be used before DRAM initialization for reading EEPROM, avoid using static variables stored in BSS, since BSS is in DRAM, which may not have been initialised yet. Explicitly mark "static global" variables as belonging to the .data section. Signed-off-by: Vignesh R <vigneshr@ti.com> Acked-by: Heiko Schocher<hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-07-27dm: Use dm_scan_fdt_dev() directly where possibleSimon Glass
Quite a few places have a bind() method which just calls dm_scan_fdt_dev(). We may as well call dm_scan_fdt_dev() directly. Update the code to do this. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-27dm: Convert users from dm_scan_fdt_node() to dm_scan_fdt_dev()Simon Glass
This new function is more convenient for callers, and handles pre-relocation situations automatically. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-26Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2016-07-26i2c: fsl: Fix driver initializationmario.six@gdsys.cc
Due to a oversight in testing, the initialization of the recently introduced Freescale I2C DM driver works only for 36 bit mode of e.g. the MPC85XX SoCs (specifically, if the physical addresses are 64 bit wide and the DT addresses 32 bit wide). This patch corrects the initialization so that it will work in a more general setting. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: York Sun <york.sun@nxp.com>
2016-07-26i2c: mvtwsi: Add documentationmario.six@gdsys.cc
Add full documentation to all driver functions. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Stefan Roese <sr@denx.de>
2016-07-26i2c: mvtwsi: Make delay times frequency-dependentmario.six@gdsys.cc
Some devices using the MVTWSI driver have the option to run at speeds faster than Standard Mode (100kHZ). On the Armada 38x controllers, this is actually necessary, since due to erratum FE-8471889, a timing violation concerning repeated starts prevents the controller from working correctly in Standard Mode. One of the workarounds recommended in the erratum is to set the bus to Fast Mode (400kHZ) operation and ensure all connected devices are set to Fast Mode. In the current version of the driver, however, the delay times are hard-coded to 10ms, corresponding to Standard Mode operation. To take full advantage of the faster modes, we would need to either keep the currently configured I2C speed in a globally accessible variable, or pass it to the necessary functions as a parameter. For DM, the first option is not a problem, and we can simply keep the speed in the private data of the driver. For the legacy interface, however, we would need to introduce a static variable, which would cause problems with boots from NOR flashes; see commit d6b7757 "i2c: mvtwsi: Eliminate twsi_control_flags." As to not clutter the interface with yet another parameter, we therefore keep the default 10ms delays for the legacy functions. In DM mode, we make the delay time dependant on the frequency to allow taking full advantage of faster modes of operation (tested with up to 1MHZ frequency on Armada MV88F6820). Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Stefan Roese <sr@denx.de>
2016-07-26i2c: mvtwsi: Handle zero-length offsets properlymario.six@gdsys.cc
Zero-length offsets are not properly handled by the driver. When a read operation with a zero-length offset is started, a START condition is asserted, and since no offset bytes are transferred, a repeated START is issued immediately after, which confuses the controller. To fix this, we send the first START only if any address bytes need to be sent, and keep track of the expected start status accordingly. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Stefan Roese <sr@denx.de>
2016-07-26i2c: mvtwsi: Add compatibility to DMmario.six@gdsys.cc
This patch adds the necessary functions and Kconfig entry to make the MVTWSI I2C driver compatible with the driver model. A possible device tree entry might look like this: i2c@11100 { compatible = "marvell,mv64xxx-i2c"; reg = <0x11000 0x20>; clock-frequency = <100000>; u-boot,i2c-slave-addr = <0x0>; }; Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Stefan Roese <sr@denx.de>
2016-07-26i2c: mvtwsi: Make address length variablemario.six@gdsys.cc
The length of the address parameter of the __twsi_i2c_read and __twsi_i2c_write functions is fixed to four bytes. As a final step in the preparation of the DM conversion, we make the length of this parameter variable by turning it into an array of bytes, and convert the 32 bit value that's passed to the legacy functions into a four-byte-array on the fly. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Stefan Roese <sr@denx.de>
2016-07-26i2c: mvtwsi: Factor out adap parametermario.six@gdsys.cc
To be able to use the compatibility layer from the DM functions, we factor the adap parameter out of all functions, and pass the actual register base instead. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Stefan Roese <sr@denx.de>
2016-07-26i2c: mvtwsi: Add compatibility functionsmario.six@gdsys.cc
To prepare for the DM conversion, we add a layer of compatibility functions to be used by both the legacy and the DM functions. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Stefan Roese <sr@denx.de>
2016-07-26i2c: mvtwsi: Use 'uint' instead of 'unsigned int'mario.six@gdsys.cc
Since some additional parameters will be added in the course of this patch series (especially with the addition of DM support), we replace the longer "unsigned int" declarations with "uint" declarations to keep the parameter lists more readable. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Stefan Roese <sr@denx.de>
2016-07-26i2c: mvtwsi: Get rid of status parametermario.six@gdsys.cc
The twsi_stop function contains a parameter "status," which is used to pass in the current exit status of the function calling twsi_stop, and either return this status unchanged if it indicates an error, or return twsi_stop's exit status if it does not indicate an error. While not massively complicated, this adds another purpose to the twsi_stop function, which should have the sole purpose of asserting a STOP condition on the bus (and not manage the exit status of its caller). Therefore, we move the exit status management into the caller functions by introducing a "stop_status" variable and returning either the status before the twsi_stop call (kept in the "status" variable), or the status from the twsi_stop call, depending on which indicates an error. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Stefan Roese <sr@denx.de>
2016-07-26i2c: mvtwsi: Eliminate flags parametermario.six@gdsys.cc
Due to breaking boots from NOR flashes, commit d6b7757 ("i2c: mvtwsi: Eliminate twsi_control_flags") removed the static global twsi_control_flags variable, which kept a set of default flags that were always or'd to the control register when writing. It was replaced with a flags parameter, which was passed around between the functions that needed it. Since the twsi_control_flags variable was used just for the purposes of a) setting the MVTWSI_CONTROL_TWSIEN on every control register write, and b) setting the MVTWSI_CONTROL_ACK from twsi_i2c_read if needed, anyway, the added overhead of another variable being passed around is no longer justified, and we are better off implementing this flag setting logic locally in the functions that actually write to the control register. Therefore, this patch sets MVTWSI_CONTROL_TWSIEN on every control register write, replaces the twsi_i2c_read's flags parameter with a ack_flag parameter, which tells the function whether to acknowledge the read or not, and removes every other instance of the flags variable. This has the added benefit that now every notion of "global default flags" is gone, and it's much easier to see which control flags are actually set at which point in time. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Stefan Roese <sr@denx.de>
2016-07-26i2c: mvtwsi: Improve and fix commentsmario.six@gdsys.cc
This patch fixes only comments/documentation: Streamline capitalization and improve grammar/punctuation. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Stefan Roese <sr@denx.de>
2016-07-26i2c: mvtwsi: Streamline code and add documentationmario.six@gdsys.cc
Convert groups of logically connected preprocessor defines into proper enums, one macro into an inline function, and add documentation to/extend existing documentation of these items. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Stefan Roese <sr@denx.de>
2016-07-26i2c: mvtwsi: Fix style violationsmario.six@gdsys.cc
This patch fixes seven style violations: Six superfluous spaces after casts, and one logical continuation violation. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Stefan Roese <sr@denx.de>
2016-07-26drivers: i2c: omap24xx_i2c: adopt omap_i2c driver to driver modelMugunthan V N
Convert omap i2c driver to adopt i2c driver model Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-07-26drivers: i2c: omap24xx_i2c: prepare driver for DM conversionMugunthan V N
Prepare the driver for DM conversion. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-07-26drivers: i2c: uclass: parse dt parameters only when CONFIG_OF_CONTROL is enableMugunthan V N
parse dt parameter of i2c devices only when CONFIG_OF_CONTROL is enabled. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-07-24ARM: uniphier: use (devm_)ioremap() instead of map_sysmem()Masahiro Yamada
This does not have much impact on behavior, but makes code look more more like Linux. The use of devm_ioremap() often helps to delete .remove callbacks entirely. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-19clk: convert API to match reset/mailbox styleStephen Warren
The following changes are made to the clock API: * The concept of "clocks" and "peripheral clocks" are unified; each clock provider now implements a single set of clocks. This provides a simpler conceptual interface to clients, and better aligns with device tree clock bindings. * Clocks are now identified with a single "struct clk", rather than requiring clients to store the clock provider device and clock identity values separately. For simple clock consumers, this isolates clients from internal details of the clock API. * clk.h is split so it only contains the client/consumer API, whereas clk-uclass.h contains the provider API. This aligns with the recently added reset and mailbox APIs. * clk_ops .of_xlate(), .request(), and .free() are added so providers can customize these operations if needed. This also aligns with the recently added reset and mailbox APIs. * clk_disable() is added. * All users of the current clock APIs are updated. * Sandbox clock tests are updated to exercise clock lookup via DT, and clock enable/disable. * rkclk_get_clk() is removed and replaced with standard APIs. Buildman shows no clock-related errors for any board for which buildman can download a toolchain. test/py passes for sandbox (which invokes the dm clk test amongst others). Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-06-10drivers: i2c: mxc: Add early initYuan Yao
Add early i2c init function with conservative divider when the exact clock rate is not available. Signed-off-by: Yuan Yao <yao.yuan@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-05-17i2c: mvtwsi: Eliminate twsi_control_flagsChris Packham
In a system where the initial u-boot location is genuinely NOR flash (as opposed to RAM or a cache-line setup by a pre-bootloader) writes to the data section are problematic. At best these writes have no effect, at worst they put the flash memory into a status mode which changes the executable code underneath us. Pass around a stack variable from the top of the twsi i2c driver to avoid writing to global data. Signed-off-by: Chris Packham <judge.packham@gmail.com>
2016-05-17i2c: Select SYS_I2C_DW_ENABLE_STATUS_UNSUPPORTED for SPEArStefan Roese
The DW I2C controller in the SPEAr SoCs doesn't support the enable status register check. This patch selects SYS_I2C_DW_ENABLE_STATUS_UNSUPPORTED for these boards. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de>
