A big part is the DM pinctrl driver, which allows us to get rid of quite
some custom pinmux code and make the whole port much more robust. Many
thanks to Samuel for that nice contribution! There are some more or less
cosmetic warnings about missing clocks right now, I will send the trivial
fixes for that later.
Another big chunk is the mkimage upgrade, which adds RISC-V and TOC0
(secure images) support. Both features are unused at the moment, but I
have an always-secure board that will use that once the DT lands in the
kernel.
On top of those big things we have some smaller fixes, improving the
I2C DM support, fixing some H6/H616 early clock setup and improving the
eMMC boot partition support.
The gitlab CI completed successfully, including the build test for all
161 sunxi boards. I also boot tested on a A64, A20, H3, H6, and F1C100
board. USB, SD card, eMMC, and Ethernet all work there (where applicable).
Currently, clock/reset setup for this device is handled by a
platform-specific function and is intermixed with non-DM pinctrl
setup. Use the devicetree to get clocks/resets, which disentagles
it from the pinctrl setup in preparation for moving to DM_PINCTRL.
This also has the added benefit of picking the right clock/reset
bits for H6 and new SoCs that have a rearranged PRCM MMIO space.
Signed-off-by: Samuel Holland <samuel@sholland.org>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Chips attached to the RSB bus require an initialization command before
they can be used. (Specifically, this command programs the chip's
runtime address.) The driver does this in its .probe_chip hook, under
the assumption that .probe_chip is called during child probe. This is
not the case; .probe_chip is only called by dm_i2c_probe, which is
intended for use by board-level code, not for chips with OF nodes.
Since this initialization command must be run before a child chip can be
used, do it before probing each child.
Acked-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Andre Przywara <andre.przywara@arm.com>
Chips attached to the P2WI bus require an initialization command before
they can be used. (Specifically, this switches the chip from I2C mode
to P2WI mode.) The driver does this in its .probe_chip hook, under the
assumption that .probe_chip is called during child probe. This is not
the case; .probe_chip is only called by dm_i2c_probe, which is intended
When the DM_I2C driver is loaded, the pin setup is done automatically
from the device tree by the pinctrl driver.
Clean up the code in the process: remove #ifdefs and recognize that the
pin configuration is the same for all sun8i/sun50i SoCs, not just those
which select CONFIG_MACH_SUN8I.
Prepare v2022.04-rc5
Per dm_i2c_ops.probe_chip documentation, i2c_probe_chip() shall fallback
to default probe method when .probe_chip() returns -ENOSYS.
Signed-off-by: Nikita Yushchenko <nikita.yoush@cogentembedded.com>
During sequential loading of data, hold the bus to prevent controller
from sending stop signal in case no data is available in fifo.
Signed-off-by: Sai Pavan Boddu <sai.pavan.boddu@xilinx.com>
Reviewed-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
Link: https://lore.kernel.org/r/2407b39d305999cb42438c5423aebc3b514acabb.1646122610.git.michal.simek@xilinx.com
Start write transfer after loading data to FIFO.
Link: https://lore.kernel.org/r/f0b3e443daa7758e00dfdcc245cf6b2120b0e907.1646122610.git.michal.simek@xilinx.com
Avoid a race condition where read transaction is started
keeping expected bytes as 0. Which sometimes would result in sending
STOP signal as no data is expected. Observed on QEMU platform.
Link: https://lore.kernel.org/r/487c8026791bfd60719403a2df2c54bb0ae99232.1646122610.git.michal.simek@xilinx.com
Per documentation, dm_i2c_ops.probe_chip() shall return -EREMOTEIO if
probe fails.
Currently, omap_i2c_probe_chip() returns 1 instead. Fix that.
This seems to be very similar to the already existing PCA9547, save for
the fact that it supports 0.8V and doesn't support 5V. In fact, it is so
similar to the PCA9547 that the NXP LS1028A-RDB board has been driving
this chip using a "nxp,pca9547" compatible string.
Create a new compatible for the PCA9847 (which is the same as in Linux)
and define the same operating parameters for it as for PCA9547.
Signed-off-by: Vladimir Oltean <vladimir.oltean@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Reviewed-by: Michael Walle <michael@walle.cc>
This adds a compatible string for the Allwinner Sun4i-A10 I2C
controller. Without this, boards based on the R8 and A13 (at a
minimum) fail to boot.
Signed-off-by: Chris Morgan <macromorgan@hotmail.com>
Acked-by: Akash Gajjar <gajjar04akash@gmail.com>
Sphinx expects Return: and not @return to indicate a return value.
find . -name '*.c' -exec \
sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \;
find . -name '*.h' -exec \
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Add compatible and data platform struct for sam9x60 SoC.
Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
CONFIG_SYS_IMMR
We do this by consolidating the SYS_IMMR options we have and providing
defaults.
We also, in the few places where M68K was also sharing code with these
platforms, define it within the file to CONFIG_SYS_MBAR to match usage.
This should be cleaned up longer term.
Testing on Armada XP with an EEPROM using register address with size
of 2 has shown, that the register address bytes are sent to the I2C
EEPROM in the incorrect order. This patch swabs the address bytes so
that the correct address is transferred to the I2C device.
BTW: This worked without any issues before migrating Armada XP to
DM I2C.
Cc: Samuel Holland <samuel@sholland.org>
Cc: Baruch Siach <baruch@tkos.co.il>
Cc: Pali Rohár <pali@kernel.org>
Cc: Marek Behún <marek.behun@nic.cz>
Tested-by: Marek Behún <marek.behun@nic.cz>
Add I2C driver code for the Microchip PolarFire SoC.
This driver supports I2C data transfer and probe for I2C
slave addresses.
Signed-off-by: Padmarao Begari <padmarao.begari@microchip.com>
Reviewed-by: Leo Yu-Chi Liang <ycliang@andestech.com>
- Turris MOX and Omnia changes, mostly moving to Kconfig (Marek)
- a37xx: pci: Misc smaller fixes (Pali)
- cmd: tlv_eeprom: Fix building with DEBUG enabled (Sven)
- termios_linux.h: Fix tcsendbreak() implementation (Pali)
- mvebu: Add missing "if SPL" (Tom)
Move the config option CONFIG_I2C_MV to a Kconfig option
CONFIG_SYS_I2C_MV and move the default definition from config header
files into defconfigs.
Signed-off-by: Marek Behún <marek.behun@nic.cz>
The following warning is seen in ocores_i2c.c in a 32-bit build:
warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
Change to use dev_read_addr_ptr().
https://source.denx.de/u-boot/custodians/u-boot-stm
- Disable ATAGS for STM32 MCU and MPU boards
- Disable bi_boot_params for STM32 MCU and MPU boards
- Update stm32-usbphyc node management
- Convert CONFIG_STM32_FLASH to Kconfig for STM32 MCU boards
- Convert some USB config flags to Kconfig for various boards
- Convert CONFIG_BOOTCOMMAND flag to Kconfig for STM32 F429 board
- Remove specific CONFIG_STV0991 flags
- Remove unused CONFIG_USER_LOWLEVEL_INIT flag
- Add ofdata_to_platdata() callback for stm32_spi driver
- Update for stm32f7_i2c driver
- Remove gpio_hog_probe_all() from STM32 MP1 board
- Fix bind command
This bus controller is used to communicate with an X-Powers AXP PMIC.
Currently, various drivers access PMIC registers through a platform-
specific non-DM "pmic_bus" interface, which depends on the legacy I2C
framework. In order to convert those drivers to use DM_PMIC, this bus
needs a DM_I2C driver.
Refactor the rsb functions to take the base address as a parameter,
and implement both the existing interface (which is still needed in
SPL) and the DM_I2C interface on top of them.
The register for switching between I2C/P2WI/RSB mode is the same across
all PMIC variants, so move that to the common header.
There are only a couple of pairs of hardware/runtime addresses used
across all PMIC variants. So far the code expected only the "primary"
pair, but some PMICs like the AXP305 and AXP805 use the secondary pair,
so add support for that to the DM driver as well.
Refactor the p2wi functions to take the base address as a parameter,
all PMIC variants. Move that to the common header, so it can be used by
both interface implementations.
Compute i2cclk only one time in stm32_i2c_compute_timing()
and remove setup parameter (accessible in i2c_priv).
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
Signed-off-by: Patrice Chotard <patrice.chotard@foss.st.com>
Reviewed-by: Patrice Chotard <patrice.chotard@foss.st.com>
Add the support for the i2c-digital-filter binding, allowing to enable
the digital filter via the device-tree and indicate its value in the DT
The digital filter related computation are present in the driver
however the programming of the filter within the IP is missing.
The maximum value for the DNF is wrong and should be 15 instead of 16.
Replace driver internally coded enabling/disabling of the
analog-filter with the DT binding "i2c-analog-filter".
Today all the I2C instance point on the same global
variable stm32_i2c_setup according the compatible: i2c_priv->setup =
pointer to the same driver data.
This patch changes this driver data (stm32f7_setup and stm32mp15_setup)
to a const struct and move the timing struct 'setup' as element of i2c
privdata, initialized in stm32_ofdata_to_platdata() with the driver
configuration data.
This patch solves issues when several I2C instance have not the same
clock source or not the same configuration: each timing setup is saved
is the I2C privdata.
The controller may need to have clocks/resets enabled for it to work.
Add support for this. Since the clocks/resets are optional on some
platforms (per the device tree binding), do not prevent probing the
controller if they are missing.
The Linux i2c driver supports i2c-scl-rising-time-ns,
and i2c-scl-falling-time-ns, but U-Boot uses hard-coded values
for these values.
Update the calculation by fetching them from the device tree if
present and use the previous values as the default if they are
missing.
Now that we have a 'positive' Kconfig option, use this instead of the
negative one, which is harder to understand.
Use this new Kconfig to simplify the compilation conditions where
appropriate.
Prepare v2021.10-rc4
# gpg: Signature made Tue 14 Sep 2021 06:58:32 PM EDT
# gpg: using RSA key 1A3C7F70E08FAB1707809BBF147C39FF9634B72C
# gpg: Good signature from "Thomas Rini <trini@konsulko.com>" [ultimate]
# Conflicts:
# board/Arcturus/ucp1020/spl.c
# cmd/mvebu/Kconfig
# common/Kconfig.boot
# common/image-fit.c
# configs/UCP1020_defconfig
# configs/sifive_unmatched_defconfig
# drivers/pci/Kconfig
# include/configs/UCP1020.h
# include/configs/sifive-unmatched.h
# lib/Makefile
# scripts/config_whitelist.txt
This option has not effect now. Drop it, using PCI instead where needed.
The ocores_i2c.c driver is missing a sentinel at the end of
the compatible strings list. This causes the "dm compat" command
to spew garbage.
Signed-off-by: Thomas Skibo <thomas-git@skibo.net>
default n/no doesn't need to be specified. It is default option anyway.
[trini: Rework FSP_USE_UPD portion]
- As there are no boards that use different values for speed / slave on
different buses, use a single option.
- Switch to using the common SYS_I2C_SPEED / SYS_I2C_SLAVE options.
- Introduce _HAS_ options for additional buses as only the first one is
common to all users.
- Convert all remaining symbols to Kconfig.
- Migrate SYS_I2C_SH and related defines to Kconfig
- Remove currently unused SYS_I2C_SH related defines
- Cleanup related README section.
Cc: Marek Vasut <marek.vasut+renesas@gmail.com>
CONFIG_SYS_I2C_MXC
CONFIG_SYS_I2C_MXC_I2C1
CONFIG_SYS_I2C_MXC_I2C2
CONFIG_SYS_I2C_MXC_I2C3
CONFIG_SYS_I2C_MXC_I2C4
CONFIG_SYS_I2C_SPEED
CONFIG_SYS_I2C_SLAVE
This driver and it's only user are converted to DM_I2C, remove legacy
code.
The omap24xx I2C driver uses its own CONFIG namespace for common I2C
variables. Rather than convert more of them to Kconfig, rename these to
the common I2C ones and remove the entirely unused functionality. As
part of this, we make the am335x_shc platforms consistent with their
intended speed values.
There are no users of more than 1 i2c bus in the non-DM case currently.
Remove the additional defines for this.
Convert SYS_I2C_EARLY_INIT to Kconfig, and make it depend on
SPL_SYS_I2C_LEGACY. Remove the weak implementation as it's either
something that needs to exist for real, or shouldn't be called.
First, we convert CONFIG_SYS_I2C_LEGACY to Kconfig. Next, as you cannot
have SYS_I2C_LEGACY and DM_I2C at the same time, introduce
CONFIG_SPL_SYS_I2C_LEGACY so that we can enable the legacy option only
in SPL. Finally, for some PowerPC cases we also need
CONFIG_TPL_SYS_I2C_LEGACY support. Convert all of the existing users to
one or more symbols.
