path: root/drivers/i2c/tegra_i2c.c
2013-08-13tegra: Avoid using I2C prior to relocationSimon Glass
Tegra recently moved to the new I2C framework, which sets up I2C prior to relocation, and prior to calling i2c_init_board(). This causes a crash on Tegra boards. Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23tegra: i2c: Enable new CONFIG_SYS_I2C frameworkSimon Glass
This enables CONFIG_SYS_I2C on Tegra, updating existing boards and the Tegra i2c driver to support this. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Heiko Schocher <hs@denx.de>
2013-07-23tegra: i2c: Add function to know about current busSimon Glass
Rather than using a variable in various places, add a single function, tegra_i2c_get_bus(), which returns a pointer to information about a bus. This will make it easier to move to the new i2c framework. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-14Tegra: I2C: Add T114 clock support to tegra_i2c driverTom Warren
T114 has a slightly different I2C clock, with a new (extra) divisor in standard/fast mode and HS mode. Tested on my Dalmore, and the I2C clock is 100KHz +/- 3Hz on my Saleae Logic analyzer. Added a new entry in compat_names for T114 I2C since it differs from the previous Tegra SoCs. A flag is set when T114 I2C HW is found so new features like the extra clock divisor can be used. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Laxman Dewangan <ldewangan@nvidia.com>
2012-10-15Tegra20: Move some include files to arch-tegra for sharing with Tegra30Tom Warren
The move is pretty straight-forward. ap20.h and tegra20.h were renamed to ap.h and tegra.h. Some files remain in arch-tegra20 but 'include' a file in 'arch-tegra' with #defines & structs that will be common between T20 and T30 HW. HW-specific #defines, etc. stay in the 'arch-tegra20' 'root' file. All boards build OK w/MAKEALL -s tegra20. Checkpatch.pl runs clean. Seaboard works OK. Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-10Tegra: Change Tegra20 to Tegra in common code, prep for T30Tom Warren
Convert TEGRA20_ defines to either TEGRA_ or NV_PA_ where appropriate. Convert tegra20_ source file and function names to tegra_, also. Upcoming Tegra30 port will use common code/defines/names where possible. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2012-09-01tegra20: rename tegra2 -> tegra20Allen Martin
This is make naming consistent with the kernel and devicetree and in preparation of pulling out the common tegra20 code. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-05-15tegra: i2c: Add function to find DVC busSimon Glass
Add tegra_i2c_get_dvc_bus_num() to obtain the I2C bus number of DVC bus. This allows us to talk to the PMU. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29tegra: i2c: Add I2C driverYen Lin
Add basic i2c driver for Tegra2 with 8- and 16-bit address support. The driver requires CONFIG_OF_CONTROL to obtain its configuration from the device tree. (Simon Glass: sjg@chromium.org modified for upstream) Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
