path: root/drivers/i2c/tegra_i2c.c
2015-08-31dm: Use dev_get_addr() where possibleSimon Glass
This is a convenient way for a driver to get the hardware address of a device, when regmap or syscon are not being used. Change existing callers to use it as an example to others. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
2015-07-27i2c: tegra: Build warning fixes for 64-bitThierry Reding
Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-04-18dm: core: Rename driver data function to dev_get_driver_data()Simon Glass
The existing get_get_of_data() function provides access to both the driver's compatible string and its driver data. However only the latter is actually useful. Update the interface to reflect this and fix up existing users. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-01-29dm: i2c: Move slave details to child platdataSimon Glass
At present we go through various contortions to store the I2C's chip address in its private data. This only exists when the chip is active so must be set up when it is probed. Until the device is probed we don't actually record what address it will appear on. However, now that we can support per-child platform data, we can use that instead. This allows us to set up the address when the child is bound, and avoid the messy contortions. Unfortunately this is a fairly large change and it seems to be difficult to break it down further. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-11dm: i2c: tegra: Convert to driver modelSimon Glass
This converts all Tegra boards over to use driver model for I2C. The driver is adjusted to use driver model and the following obsolete CONFIGs are removed: - CONFIG_SYS_I2C_INIT_BOARD - CONFIG_I2C_MULTI_BUS - CONFIG_SYS_MAX_I2C_BUS - CONFIG_SYS_I2C_SPEED - CONFIG_SYS_I2C This has been tested on: - trimslice (no I2C) - beaver - Jetson-TK1 It has not been tested on Tegra 114 as I don't have that board. Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-25tegra: make local functions staticJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-07-03i2c: tegra: dump alen in debug statementsStephen Warren
Since tegra_i2c_{read,write}'s debug() call dumps the chip address, dump the address length (alen) too, so the address value can be correctly interpreted. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Yen Lin <yelin@nvidia.com>
2014-07-03i2c: tegra: write clean data to TX FIFOStephen Warren
The Tegra I2C controller's TX FIFO contains 32-bit words. If the final FIFO entry of a transaction contains fewer than 4 bytes, the driver currently fills the unused FIFO bytes with uninitialized data. This can be confusing when reading back the FIFO content for debugging purposes. Solve this by explicitly initializing the variable containing FIFO data before filling it (partially) with data. With this change, send_recv_packets()'s loop's if (is_write) code mirrors the else (i.e. read) branch. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Yen Lin <yelin@nvidia.com>
2014-07-03i2c: tegra: use repeated start for readsStephen Warren
I2C read transactions are typically implemented as follows: START(write) address REPEATED_START(read) data... STOP However, Tegra's I2C driver currently implements reads as follows: START(write) address STOP START(read) data... STOP This sequence confuses at least the AS3722 PMIC on the Jetson TK1 board, leading to corrupted read data in some cases. Fix the driver to chain the transactions together using repeated starts to solve this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Yen Lin <yelin@nvidia.com>
2013-12-18i2c: tegra: Add the fifth bus on SoC with more than 4 busesAlban Bedel
Create the i2c adapter object for the fifth bus on SoC with more than 4 buses. This allow using all the bus available on T30. Signed-off-by: Alban Bedel <alban.bedel@avionic-design.de> Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-08-13tegra: Avoid using I2C prior to relocationSimon Glass
Tegra recently moved to the new I2C framework, which sets up I2C prior to relocation, and prior to calling i2c_init_board(). This causes a crash on Tegra boards. Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23tegra: i2c: Enable new CONFIG_SYS_I2C frameworkSimon Glass
This enables CONFIG_SYS_I2C on Tegra, updating existing boards and the Tegra i2c driver to support this. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Heiko Schocher <hs@denx.de>
2013-07-23tegra: i2c: Add function to know about current busSimon Glass
Rather than using a variable in various places, add a single function, tegra_i2c_get_bus(), which returns a pointer to information about a bus. This will make it easier to move to the new i2c framework. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-14Tegra: I2C: Add T114 clock support to tegra_i2c driverTom Warren
T114 has a slightly different I2C clock, with a new (extra) divisor in standard/fast mode and HS mode. Tested on my Dalmore, and the I2C clock is 100KHz +/- 3Hz on my Saleae Logic analyzer. Added a new entry in compat_names for T114 I2C since it differs from the previous Tegra SoCs. A flag is set when T114 I2C HW is found so new features like the extra clock divisor can be used. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Laxman Dewangan <ldewangan@nvidia.com>
2012-10-15Tegra20: Move some include files to arch-tegra for sharing with Tegra30Tom Warren
The move is pretty straight-forward. ap20.h and tegra20.h were renamed to ap.h and tegra.h. Some files remain in arch-tegra20 but 'include' a file in 'arch-tegra' with #defines & structs that will be common between T20 and T30 HW. HW-specific #defines, etc. stay in the 'arch-tegra20' 'root' file. All boards build OK w/MAKEALL -s tegra20. Checkpatch.pl runs clean. Seaboard works OK. Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-10Tegra: Change Tegra20 to Tegra in common code, prep for T30Tom Warren
Convert TEGRA20_ defines to either TEGRA_ or NV_PA_ where appropriate. Convert tegra20_ source file and function names to tegra_, also. Upcoming Tegra30 port will use common code/defines/names where possible. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2012-09-01tegra20: rename tegra2 -> tegra20Allen Martin
This is make naming consistent with the kernel and devicetree and in preparation of pulling out the common tegra20 code. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-05-15tegra: i2c: Add function to find DVC busSimon Glass
Add tegra_i2c_get_dvc_bus_num() to obtain the I2C bus number of DVC bus. This allows us to talk to the PMU. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29tegra: i2c: Add I2C driverYen Lin
Add basic i2c driver for Tegra2 with 8- and 16-bit address support. The driver requires CONFIG_OF_CONTROL to obtain its configuration from the device tree. (Simon Glass: sjg@chromium.org modified for upstream) Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
