path: root/drivers/i2c/sandbox_i2c.c
2015-04-16dm: core: Add dev_get_uclass_priv() to access uclass private dataSimon Glass
Add a convenience function to access the private data that a uclass stores for each of its devices. Convert over most existing uses for consistency and to provide an example for others. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: i2c: Move slave details to child platdataSimon Glass
At present we go through various contortions to store the I2C's chip address in its private data. This only exists when the chip is active so must be set up when it is probed. Until the device is probed we don't actually record what address it will appear on. However, now that we can support per-child platform data, we can use that instead. This allows us to set up the address when the child is bound, and avoid the messy contortions. Unfortunately this is a fairly large change and it seems to be difficult to break it down further. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-01-29dm: i2c: Provide an offset length parameter where neededSimon Glass
Rather than assuming that the chip offset length is 1, allow it to be provided. This allows chips that don't use the default offset length to be used (at present they are only supported by the command line 'i2c' command which sets the offset length explicitly). Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2014-12-11dm: i2c: Add a sandbox I2C driverSimon Glass
This driver includes some test features such as only supporting certain bus speeds. It passes its I2C traffic through to an emulator. Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
