We use the U_BOOT_ prefix (i.e. U_BOOT_DRIVER) to declare a driver but
in every other case we just use DM_. Update the alias macros to use the
DM_ prefix.
We could perhaps rename U_BOOT_DRIVER() to DM_DRIVER(), but this macro
is widely used and there is at least some benefit to indicating it us a
U-Boot driver, particularly for code ported from Linux. So for now, let's
keep that name.
This name is far too long. Rename it to remove the 'data' bits. This makes
it consistent with the platdata->plat rename.
This construct is quite long-winded. In earlier days it made some sense
since auto-allocation was a strange concept. But with driver model now
used pretty universally, we can shorten this to 'auto'. This reduces
verbosity and makes it easier to read.
Coincidentally it also ensures that every declaration is on one line,
thus making dtoc's job easier.
Currently when using OF_PLATDATA the binding between devices and drivers
is done trying to match the compatible string in the node with a driver
name. However, usually a single driver supports multiple compatible strings
which causes that only devices which its compatible string matches a
driver name get bound.
To overcome this issue, this patch adds the U_BOOT_DRIVER_ALIAS macro,
which generates no code at all, but allows an easy way to declare driver
name aliases. Thanks to this, dtoc could be improve to look for the driver
name based on its alias when it populates the U_BOOT_DEVICE entry.
Signed-off-by: Walter Lozano <walter.lozano@collabora.com>
When using OF_PLATDATA, the bind process between devices and drivers
is performed trying to match compatible string with driver names.
However driver names are not strictly defined, and also there are different
names used when declaring a driver with U_BOOT_DRIVER, the name of the
symbol used in the linker list and the used in the struct driver_info.
In order to make things a bit more clear, rename the drivers names. This
will also help for further OF_PLATDATA improvements, such as checking
for valid driver names.
Add a fix for sandbox of-platdata to avoid using an invalid ANSI colour:
Move this uncommon header out of the common header.
Move this header out of the common header.
That's not correct and it breaks SMBUS-style reads and and writes for
some chips (e.g. SYR82X/SYR83X).
Stop bit should be sent only after the last message.
Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Rockchip use 'arch-rockchip' instead of arch-$(SOC) as common
header file path, so that we can get the correct path directly.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
rk3066 and rk3188 has two I2C controller implementations.
Current I2C driver wan't work with legacy implementation.
Switching between controllers is performed using a bit inside
GFR_SOC_CON1 register. The bit setting is performed by pinctrl
driver. The patch ask pinctrl to do settings.
Signed-off-by: Alexander Kochetkov <al.kochet@gmail.com>
Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
[fix warnings by including the rk3228 variant in the compatible-list]:
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
We have a large number of places where while we historically referenced
gd in the code we no longer do, as well as cases where the code added
that line "just in case" during development and never dropped it.
Add compatible to support rk3328 i2c
Signed-off-by: Elaine Zhang <zhangqing@rock-chips.com>
Acked-by: Heiko Schocher<hs@denx.de>
Update the Rockchip I2C driver to support livetree.
Acked-by: Heiko Schocher <hs@denx.de>
The hw can read up to 32 bytes at a time. If we need
more than one chunk, we have to enter the plain RX mode.
Signed-off-by: Wadim Egorov <w.egorov@phytec.de>
These support the flat device tree. We want to use the dev_read_..()
prefix for functions that support both flat tree and live tree. So rename
the existing functions to avoid confusion.
In the end we will have:
1. dev_read_addr...() - works on devices, supports flat/live tree
2. devfdt_get_addr...() - current functions, flat tree only
3. of_get_address() etc. - new functions, live tree only
All drivers will be written to use 1. That function will in turn call
either 2 or 3 depending on whether the flat or live tree is in use.
Note this involves changing some dead code - the imx_lpi2c.c file.
To enable mipi display, we need to enable pmic
rk808 first for lcd3v3 power,which use i2c0 to
communicate with soc. So enable i2c0.
Signed-off-by: Eric Gao <eric.gao@rock-chips.com>
The Cortex-A9 socs rk3066 and rk3188 share the IP but have their own
compatible values, so add them to make the i2c on these platforms accessible.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
The special handling of the chip address and register address must only
happen before we send the data buffer, otherwise we will end up
inserting both of these every 32 bytes.
Signed-off-by: John Keeping <john@metanate.com>
There is no point in writing intermediate values to the txdata
registers.
Also add padding to the debug logging to make it easier to read when
there are leading zeroes.
Make it clear that we are using the same value in two adjacent lines.
The following changes are made to the clock API:
* The concept of "clocks" and "peripheral clocks" are unified; each clock
provider now implements a single set of clocks. This provides a simpler
conceptual interface to clients, and better aligns with device tree
clock bindings.
* Clocks are now identified with a single "struct clk", rather than
requiring clients to store the clock provider device and clock identity
values separately. For simple clock consumers, this isolates clients
from internal details of the clock API.
* clk.h is split so it only contains the client/consumer API, whereas
clk-uclass.h contains the provider API. This aligns with the recently
added reset and mailbox APIs.
* clk_ops .of_xlate(), .request(), and .free() are added so providers
can customize these operations if needed. This also aligns with the
recently added reset and mailbox APIs.
* clk_disable() is added.
* All users of the current clock APIs are updated.
* Sandbox clock tests are updated to exercise clock lookup via DT, and
clock enable/disable.
* rkclk_get_clk() is removed and replaced with standard APIs.
Buildman shows no clock-related errors for any board for which buildman
can download a toolchain.
test/py passes for sandbox (which invokes the dm clk test amongst
others).
We can use the new clk_get_by_index() function to get the correct clock.
Add an I2C driver for the Rockchip RK3288, using driver model. It should work
for other Rockchip SoCs also.
